PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. 3W 140 vs. DA 150
  2. 25% to 35% Jump
  3. Giant Sukhoi
  4. NX IMAC Props for DA-100 and ZDZ-80
  5. Needed: 30% Female Pilot
  6. First crash for Powerline Edge 540 (90 size)
  7. Anybody flying the Evolution 26cc?
  8. Composite ARF Giles.
  9. Aeroworks/World Models 33% Ultimate C.G.?
  10. Lanier Sukhoi
  11. G & L Hobbies 50% geeBee R2
  12. Carden Giles
  13. Where can I get a Pilot like that ?!
  14. TOC 30% YAK
  15. Composite-arf Extra 330 ?????????
  16. Dalton Aviation 42% 260
  17. Electric conversion
  18. Buying on the Internet !
  19. DP Edge 540T Virtual Cockpit
  20. Aerotech 40% Extra 260
  21. First 1/4 Scale, What Engine?
  22. ANY ONE KNOWS ABOUT KATANA'S FROM AEROWORKS ?
  23. HaiKong Models
  24. H9 46% Ultimate / DA150 owners
  25. Bob Godfrey
  26. bme aircraft 30% edge
  27. How to fix pinched smoke coil in muffler???
  28. world models Zero canopy
  29. What spinner do I use?
  30. HELP I need an ARF for my 3W106 ASAP
  31. 50 CC Engines
  32. Will aZinger 22x10 prop fit a DA-50?
  33. COMPOSITE ARF 3.0 Build
  34. Great plane's j3 cub 1/5 scale cockpit ?
  35. 1/4 Scale Cub Fans!! Need your help!!
  36. Prop Bolts
  37. Pull Pull Cable Crimps
  38. Re: Thrust line calculator?
  39. How light can you go. (Comp. ARF Yak 2.6)
  40. MVVS 45 Magnesium Case!!!
  41. Help setting up my Extra 28% servos
  42. 35% Yak Canopy and Cowl Delivery-Fantastic!
  43. da50 spinner backplate
  44. Light wheels
  45. gas setup references
  46. Carbon Fiber Wheel Pants?????
  47. SERVOS 9152,8611,8955TG
  48. Cap X
  49. Need engine ideas for a 1/3 scale Piper Cub
  50. Wing Tip Smoke System
  51. What would be arealistic finished weight for the 35 % Edge?
  52. Help with B-17 throws and cg
  53. Extreme Flight Yak C.G. Poll
  54. 35% Aerotech Extra 300?
  55. larger fuel tank for sig extra 300xs???
  56. Comp ARF 2.6M Extra Question
  57. The Father of Giant Scale has passed
  58. Building a Motor Mount for BME110
  59. DA-100 Prop question
  60. Flybaby Bipe Engine choice
  61. DA-50 1.25'' STANDOFFS PURCHASE?
  62. Cannister Mufflers vs. Tuned Pipes
  63. Foam Core vs. Built Up
  64. 84" Aerotech YAK 54
  65. Correct size eng on 1/4 scale Piper Cub?
  66. Aeroworks 31% Edge 540t
  67. Engine Thrust
  68. Tail Wheel Assembly
  69. Spinners
  70. Film covering large balsa-sheeted wing - Your techniques?
  71. rcsupergear - Where is my order?
  72. DR HOBBIES 2.6 EXTRA FLIGHT REPORT!!! UPDATE!!!!
  73. Ideas for cannister mounts
  74. How does the GP 25% Giles G-202 fly?
  75. Dynaflite PT 19
  76. dr1 pinked tape?
  77. Moki 1.80 back plate
  78. super cub wing joint
  79. Great Warranty Service
  80. Comp-Arf Super Extra
  81. Great planes new ultimate 160
  82. Gere Sport
  83. How does the H9 1/4 Cap fly?
  84. Quique and DA
  85. Need builder in Southern California
  86. Bob Shattelrow still in business ???
  87. Range check question?
  88. WHAT HINGE FOR MY EXTRA 27% ?
  89. Anyone have Plane line art to make vinyl graphics from?
  90. 1/3 scale j3 engine help needed
  91. Tucano Turboprop build thread **VIDEO**
  92. Old Byron 33% Pits cg
  93. Dave Patrick 330L Extra --- CG...???
  94. Help with plane/engine combo !!!!!
  95. CA models Extra 27% or 31% for mvvs 58?
  96. DA50 for TF giant scale Corsair?
  97. Aeronca C-3 plans 1/3 scale
  98. 28% Servo Recommendations
  99. Ziroli Stearman
  100. Engine for Super Cub
  101. Aero-Works Summer Sale!!!!!!!!!!!!
  102. Hueffmeier does it again
  103. 2005 ETOC
  104. how do you choose your servos?
  105. Aerotech 40% 540 Vidio
  106. Z50L
  107. Aeroworks ULTIMATE or Worldmodels?
  108. Maiden Flight Lanier 40%Edge
  109. DA-50 Smoke System Set-up
  110. Help with hinge glue question
  111. Guide to Flight Trimming Biplanes?
  112. Lite-Flyte products
  113. Extreme Composites Edge Build
  114. pwer box and matchbox?
  115. What Re-Ironing Method Do You Use?
  116. Any KNOWN Single Servo 35% Flutters?
  117. Buffing flat paint to a shine???
  118. Plane Recommendation for a G62
  119. Sullivan skywriter setup
  120. Question for 3W 44% ultimate owner/flyers
  121. Have Painted or tinted Your Yak Canopy?
  122. fw-190, moki 2.10
  123. Double Vision CG - for Dummies
  124. FUJI BT 64 EIS OPINIONS...
  125. Hangar 9 33% edge cans set up?
  126. Carb question: Fuselage as plenum chamber
  127. Throttle Setup DA-100
  128. DOES ANYONE KNOW?
  129. Comp ARF/DA 100 Questions
  130. 50cc Yak
  131. Tunnel Vision ETA
  132. Giant scale aerobatics near San Jose, California
  133. ZDZ 80 Airframe
  134. Thrust question
  135. 50cc Engines.
  136. Corsair 3D view
  137. 5,2 mt. RAVEN video
  138. Need Large Landing Gear - Where ???
  139. Midwest Extra 300
  140. 3D Ailerons or not on a 29% AW Edge?
  141. Byron Staggerwing
  142. Long carbon wing tubes?
  143. Thanks John!!!
  144. Desert DA 180???
  145. TF Giant Scale P-51 and ST 4500?
  146. Johndeere where are you? Are you out there?
  147. What's going on here?
  148. Which of these will provide the better power to weight?
  149. Wanted: 1/4 Scale Extra 230 or Larger
  150. Jmar 1/3 scale super cub?
  151. Moki 1.80 prop
  152. How to remove old vinyl off composites
  153. Comp ARF Hinge Question
  154. First Gasser Set-up
  155. MOVED: Shuttle
  156. Bud Nosen 1/4 Citabria
  157. wood prop spliting ??
  158. USQ Aero Engines on hollidays?
  159. Is USQ Aero Engines still on the bussiness?
  160. FORT WAYNE IN. GIANT SCALE FLY IN AUG 27-28
  161. Help put my 28% Wildhare Extra on a DIET!!
  162. master card modellers
  163. Monokote over monokote??
  164. Composite-ARF canopy mounting.......
  165. when can I hover TR like YOU!
  166. Pica P51 Mustang muffler
  167. Plane trimming question
  168. Hangar 9 Edge 540/DA 100 Video!
  169. Is there a such thing as being to TAILHEAVY!!
  170. Engine Selection for High Altitude Flying
  171. Calling all TOC Aviation owners
  172. 42% Edge
  173. "IRCC IMAA Winter Rally" Mulberry,Fl
  174. I need a little prop help
  175. who has QQ 72'' yak?
  176. 50cc Pitts S-12
  177. 3w 3D prop question
  178. Great Planes Pitts
  179. Anyone know this plane? (Large Extra)
  180. 35% TOC YAK 54
  181. Anybody looking at the GIANT big stick ?
  182. Hanger 9 TOC Ultimate elevator failure
  183. What is this airplane?
  184. GP 1/3 Cap 580 or H9 Edge...Help me pick!
  185. Polishing spinners
  186. H9 extra 260 27%
  187. KMP Edge 540
  188. hanfer 9 28% extra
  189. Katana VS 310 40%
  190. Radio Mixing on ryan sta..greatplanes kit.
  191. Printable Dash Panels
  192. Range Test Problems
  193. H9 330 Extra Problem
  194. H9 Extra/Da100 & Mejzlik 25x12 3 blade prop
  195. World Models 33% Ulitmate?????
  196. Comp-Arf Super Extra 3.1
  197. Multiple port charger
  198. Cap X parts
  199. NEED CG FOR W/M 330L 25%
  200. G-62 IN BALSA USA 1/3 SCALE J3 CUB?
  201. Looking for bomb proof servos ??????
  202. Extreme Aircraft CAP 232 colors?
  203. Aerotech 40% Yak
  204. Q about what to use.
  205. 30% Hostetler Decathlon
  206. us120 wing joint strength
  207. Big super cub
  208. Comp ARF 2.6 Extra vs Yak
  209. ohio extra 300S Help!
  210. 25% hanger9 cap232 question
  211. Lousy range in Christen Eagle
  212. Interstate Cadet
  213. Four Star 120 Build comming along nicely...
  214. 1 or 2 aileron servos?
  215. Costa Rica
  216. what is approx thrust in lbs for da100? thinking of buying one
  217. 3D Instruction Material Wanted
  218. Edge 540 30% what servos?
  219. Carbon wing tube sources?
  220. wiring diagram
  221. Scale Tailwheel for Byron/Iron Bay Corsair???
  222. Modeltech 1/3rd Scale Cub?
  223. gas engine for 25% cap
  224. Is Anyone out there Running the new 3W 157
  225. ACE digital servo
  226. Giant scale switches and charge jacks
  227. which of these 2 engines for a kangke cap 232-120?
  228. Hinging Composite ARFS
  229. 33% Lanier Laser set-up
  230. Simulator for IMAC/3D Practice
  231. Single Hitec 5955 in the tail for rudder for 35% plane
  232. Jtec Panzl/DA 100 exhaust exit pictures help
  233. 2 Metre 3W Extra Fun
  234. Gee Bee R3
  235. Midwest Extra engine box for DA50
  236. Lead time for 40% Yak?
  237. super stearman
  238. 35% Staudacher servos
  239. Lookin for a good instrument panel
  240. C/G for Mr Mulligan
  241. Top flite Giant F-4U Corsair
  242. QUESTON ON CLEANING SOLUTION FOR MY GIANT PLANE
  243. Help on engine down and side thrust Please
  244. Photos of Texas Hurricane Brison 2.4
  245. Spare Parts
  246. EF 87" Yak and Brison
  247. H9 Ultimate wing bags wanted
  248. 26% Cessna Skymaster
  249. da-50 soft mount ????
  250. 62" Ohio Ultimate CG Needed.
