PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Lanier Edge 540T or Hangar 9 Edge 540
  2. Extra 330s Hanger 9
  3. Bme Arfs
  4. WM 80" Extra 300s?
  5. H9 1/3 Sukhoi
  6. H9 Sukhoi/ 3W100B2 help
  7. Comments on Royal Super Cub
  8. What do you use to accurately measure and set the control deflections?
  9. Mejzlik props, where to buy?
  10. Finished - Jack Devine Models Gee Bee Z
  11. source for MM wing tubes needed
  12. Plans for a Piper Pawnee?
  13. Saito 1.80 problems
  14. DP Extra w/ DA50r
  15. Finished Fiberclassics Pics!!!
  16. What do you do about carb drool on a rear carb, in a 40% Composite-Arf
  17. Does Dave Brown Products have an email address?
  18. What's up with Futaba Customer Service?
  19. DP Edge 540
  20. 3W Giles G202 31% - Help!
  21. Suhkoi vs Cap vs Edge vs Extra vs......
  22. Yellow Aircraft Cap 10B Engine Choice?
  23. MR Aerodesign Cap10b
  24. 747
  25. 25% scale and GAS engine-- the best combination???
  26. Aw 540t
  27. Are two receivers necessary for a Fleet?
  28. DP Ultimate 120
  29. The best 25%-27% ARf Aerobat?
  30. Aw 31% Edge 540t
  31. I have a question
  32. G.P. 1/3 scale Pitts with DA 50
  33. G.P. 1/4 scale Giles 3 finished project
  34. Knife Edge trim
  35. Keeping up with the Jones'
  36. how to short land?
  37. Yellow Aircraft AT-6 engine?
  38. Help? 40% Fiberclassic Extra 330
  39. Servo Burn In - How Are You Doing It...
  40. Comp-ARF Extra 330 Spinner
  41. mounting a g45
  42. Is it possible to put smoke on my 1/4 scale hanger 9 CAP 232?
  43. Dynaflite 1/4 scale Flybaby
  44. 5" Scale wheels????
  45. 6 Bolt hub-hole orientation. DANGEROUS
  46. need help with engine cooling baffles
  47. Blue Dave Patrick Edge 540
  48. Aerotech RC-Chipmunk
  49. Stinson SR9 sale 100.5span Zenoah G38
  50. Can I connect a Y to another Y???
  51. L-19 "Birdog" Quest
  52. Wm Gs P-51
  53. Hanging Cannister Pipes Under a Fuse ??
  54. Bolly props for 150cc?
  55. H9 Sukhoi Cowl
  56. Balsa USA 1/3 Scale Sopwith Pup
  57. JR Digital Servos
  58. 3W Giles G202 31% level 2 - opinions ?
  59. Towing a Trailer
  60. 3 Blade Prop
  61. New Hanger 9 33% Extra 330s (mcconville Scheme)
  62. top hinging a 31% CA extra
  63. GP 330L Lateral Wing Movement Prob
  64. Canisters in a 40% Carden CAP232
  65. 28% videos
  66. Alternative foam wing finishings
  67. Aeroworks Edge 25 %
  68. Nelson hobbies hadware (need web site)
  69. Look what I finally finished! Its cool I promise!
  70. 80" Cap Balance
  71. 1/4 sig cub and ryobi 31cc need advise
  72. Byron originals Cap21
  73. aeroworks 33% edge arf and a zdz 80 enough?
  74. What happened to all the ARCs?????
  75. Springs between horn and tail wheel
  76. ESC power draw
  77. Hobby VAC FS
  78. Da-100
  79. Chief's vinyls for the H9 Sukhoi
  80. ST.3000 or ST 3250 and ST 2300
  81. Davis Acro Pro Info Please
  82. Hanger 9 cap and DA 100 Help!!!
  83. Work begins on 1/2 scale GeeBee R2
  84. Aeroworks 33% extra first flight today
  85. Colombo-Anderson 27% Extra?
  86. New Cermark 1/4 Scale Pitts
  87. Extra 330 Colour Scheme??!
  88. Battery questions
  89. 30% Sukhoi engine ???
  90. Tail wheel for Texas Hurricane
  91. ultra 1000
  92. Opinion on giant scale planes
  93. DP Extra 330L with ZDZ40RVL
  94. How long can the servo wires be....
  95. Composite-Arf 33% Gee Bee R2 - First Flight - Pics - Videos - L@@K
  96. carbon fiber push rods
  97. Comp-ARF 'Fantasy' Scheme
  98. Not happy with performance (,yet..)
  99. 3m Composite ARF or 3W 40%
  100. Bad News Loss of Jim Wright
  101. bent corsair
  102. Tail Gear for a 40% HELP
  103. Giant TF P-47 razor back and cockpit
  104. H9 Sukhoi w/ ZDZ80
  105. Hangar 9 Super Cub CG
  106. AW 42% Ultimate Balance!
  107. WHAT SIZE % BUD NOSENs 124in J3
  108. Extra 330 uncovered??
  109. my new plane
  110. anyone still sell moki ultra prop???
  111. need help to decide
  112. Another DP Edge thread Question.
  113. heres my Lazy ace 76"
  114. Stinger 120 / Moki 2.10
  115. H9 33 % 232 - time for some graphics...
  116. Anybody make a 100cc size aerobatic Biplane?
  117. GP Pitts ARF With OS 300 Super Gemini Twin
  118. hitec 700 and 645 servos - questions
  119. GP Pitts & Taurus 3.2......WOW!!
  120. Are FiberClassics repairable?
  121. SWB arms HARD to fit on!
  122. will hanger 9 come out with a 33% edge
  123. Extra 300 with a 3w-120
  124. JTEC Extra 330SX 35% ARF
  125. Is there a GiantScale shop in Richmond Va
  126. Cessna 150/152 Hostetler here goes nutin
  127. Mechanical retracts where do i find
  128. CA Extra 27%
  129. Big Bronco
  130. DP Extra 330L w / OS 160 FX . What prop would be best for this combo ?
  131. H9 80" Cap w/Moki 210 - What prop?
  132. dp edge and bme 50
  133. foam core or build up wings
  134. Dynaflite Chipmunk....What works & what doesn't. Need opinions.
  135. Please Explain The Reasoning Behind The AW 42% Ultimate
  136. Sullivan Smokewriter System
  137. Cessna 150/152
  138. MOVED: Construction Pics of a Carden 35% Edge 540
  139. Hanger 9 Scale Instrument Panels
  140. Hurley Extra
  141. Now that's a big cowl!
  142. What model of plane?
  143. Great Planes Giles 202 ARF - Goood, Bad, or Ugly ???
  144. Which antenna
  145. Yellow Aircraft Zero Muffler?
  146. Sig Sukhoi--Which engine to 3D?
  147. Tail Wheel control problems
  148. Citabria Pro Engine Size?
  149. Rudder for 28%
  150. ZDZ60 Prop nuts broke?
  151. What is THE BEST giant arf 3d plane on the market 25-30%
  152. Good ARF for G23?
  153. REDUCED FURTHER F6F Hellcat - Wing Mfg. Complete Kit Plus Robart Retracts
  154. REDUCED Dave Platt Spitfire Complete Kit & Retracts, Plus Construction Tech. Videos
  155. 1/4 Piper Tomahawk
  156. DP Edge 540
  157. flying wires
  158. Gotta have one of these!!!
  159. Giles manual update
  160. CA/Fiber classic Extra 330 2.6M Fuel/Smoke tank Ques.
  161. !/s scale Gee Bee info
  162. Composite ARF 330 or 3W 330??
  163. stadacuher?
  164. Arf-composite 2.6 Extra 330
  165. Giles G-202
  166. Stab incidence differs from wing incidence, why?
  167. aero works 36% extra 330 arf
  168. How to balance a big plane?
  169. Composite - Arf Carbon wing tube?
  170. Seagull Edge540 1/4 and GP Extra 300S
  171. CA-Arf 2.6M Extra 330L Comstruction article
  172. help me identifi this staudacher
  173. Byron Pitts w/G-62 motor mounting question
  174. Does someone fly the 35% and 40% Carden Edge?
  175. Sig 110
  176. Air Wild Giles
  177. Aliphatic or slow set epoxy?on pine
  178. Plan CESSNA 195 Giant
  179. nosen firewall set back
  180. 35% control horn setup
  181. 40% Carden Edge 540 Pics
  182. H9 46% Ultimate engine. 150 or 200?
  183. AG WAGON CESSNA 188
  184. just curious
  185. I need help on a Flybaby!
  186. Looking for photo of BOTTOM of Wagstaff white Tail plane.
  187. Movable CG
  188. giantscaleplanes 61" christian eagle
  189. Seats
  190. Lanier Giles 202 35% Kit
  191. midwest cap232 tail
  192. goin' to gas next kit... need help with basics.
  193. Pull Pull on rudder questions
  194. Bud Nosen
  195. A&A Industries
  196. Carbon Fiber Gear
  197. Balsa wood?
  198. Composite-ARF 2.6M Extra 330L scheme
  199. ironbaymodelcompany
  200. H-9 46% Ultimate servo choice
  201. Lanier Staudacher S-600
  202. Different Giant Aeromaster Cowl?
  203. KY Giant Scale
  204. Would you buy Hanger 9 Sukhoi again
  205. Hanger9 1/3 Scale Sukhoi help please!
  206. canopy hold down
  207. Where is your AW 29% Edge Balance Point?
  208. gaz engine for 24% CA Extra 300?
  209. Identity Crisis ;)
  210. Pine wood instead of spruce?
  211. G&L Hobbies 50% Pitts
  212. 46% Hanger 9 Instrument Panels
  213. zdz50 engine info
  214. Du Bro Transmitter Tray
  215. My 1st giant plane/ Giles 202-Need help
  216. Engine size? Balsa USA 1/3 J-3 Cub
  217. Edge 360?
  218. Dubro control horns?
  219. Plane assembly stand
  220. Tail wheel for a 33% plane
  221. 1/2 Scale Gee Bee R-2
  222. Aircraft Identification Challenge
  223. Show us those Breitling schemes
  224. 96 inch beaver indince question
  225. Hanger 9 Sukhoi sale
  226. Need help finding best place to get new landing gear for a DP extra 330
  227. cg problems on midwest 27% extra
  228. Need help with my pitts challenger
  229. Airplane for 3W-70iUS
  230. 35% rudder setup
  231. Is a Hitec HS-81 servo ok on 27% throttle?
  232. Hangar-9 Mustang 1.50 Cowl
  233. Built up pull/pull kit
  234. AW 31% extra JR/Hitec glitches
  235. Need suggestions for selection of prop size
  236. Extreme Flight
  237. New AT-6 kit check this out!
  238. Rally of the Giants Atwater, CA
  239. post hanger 9 edge pictures please!
  240. J-Tec/Radiowave planes
  241. Replacing or repairing a Rx after the crash?
  242. weak eyes
  243. Ohio R/C Extra 330L
  244. glue dried, hinges in wrong place
  245. Hangar9 1/3 Sukhoi?
  246. Radio setup for 33% - 9z
  247. 1/3rd scale cub plans
  248. bud nosen 310C plane parts
  249. H9 80" cap232 need info on dimensions
  250. CF Wheel pants?
