- Plane video on Higher plane production web site
- MOVED: Sig Extra 300xs servo torque
- Help to identify airframe please
- RC Air Show Crash Video
- Who makes the 70% Raven and +60% Ultimate?
- EXTRA 300 WITH ???? ENGINE POWER ?
- Aerotech Velox 28%
- Best servo gear life.....Titanium, MG, etc....
- 50cc Turbine Toucan
- Krill Velox Revolution II 47%
- Engine vibration destroying servo gears....
- 35% Power Setup Questions
- Composite ARF 300SX + DA-100, what hardware do i need?
- Balancing for 3D flying.Help me...
- Anyone have a 74" YAK fuselage they can part with?
- Engine Overheating problem??
- Bellancа Decatlon xxl 3d
- Azure 30% Extra 260 87
- Anyone have a YAK 54 Fuselage you can sell me?
- Matchbox VS Equalizer
- MR Aerodesign 1/4 Scale Mudry CAP 10b Review / Build
- 60 lbs Cable Strength for Pull Pull
- Powering Hitec HS-5745MG Giant Servos
- The World Models 34% Velox rev II
- Smoke Pump and Speed Controller
- Epo-Grip - Good stuff
- TT TOC 33% Extra 260
- best way to fix batteries to the fuselage
- Using a Water Bottle for a Fuel Tank
- SD-TOC EXTRA 260 30%
- Great combo
- "New" Aeroworks Extra 300 50cc 86" thread
- Prop Hole Too Large
- BME 116 & ES Pipes - Initial results.
- RC Pilot 50cc Build
- Prop question.
- Aerotech
- Throws on the H9 33% Edge
- 8611's without regulators?
- Final Trimming Setup by Flying? (How do I setup)
- Got a Comp-Arf 2.3m? Measurements needed!
- AW Extra 260 vs. 300 vs. EF Yak 110" vs. E-Comp Edge 540T
- Name me 3 Top Aerobatic 50cc ARFs
- The new H9 Sukhoi gets a BME!
- SIG 300 xs ARF
- MOVED: Need advice on 3D plane
- Nall ?
- Dave Patric Ultimate bipe with Saito 180....looking for help with prop selection
- Graphics
- Smoke?
- TBM Carbon Wing Tube Failure
- Hatch Attachment Without Bolts?
- Weston Groove
- 100CC PLANE ..HELP ME DECIDE..
- 33% Pilot-RC Yak and DLE111
- Anyone has experience with the HDS-9960 servo
- TT Giles 202 140...need help deciding on a engine....
- first giant scale plane maiden a success wheeee!
- New Plane for 100cc Engine
- 52% Edge getting close to flight
- 250° F - is that too hot?
- Any Idea How to do this Maneuver?
- Ultra RC Yak54 - Paying Forward
- A123 wiring
- Strange Habits.
- Knox Hobby Biiig Bipe
- 2.6m YAK
- ExtremeFlight Competition Rewards
- Howto - Dual to Single aileron conversion
- Byron christen eagle canopy
- Need help with my dual elevator setup
- Is the RealFlight G3 (not 3.5) worth purchasing?
- Adding SMOKE to MTW canisters
- Question about match boxes and HV servos!!
- Help me select...Aeroworks Ultimate 50cc, Yak 54 50cc, or Extra 300 50cc
- 27% H9 Extra 260-Covering?
- g23
- Power Box Or Smart fly?
- jumbo jamboree at mcrcs
- Can someone tell me what airplane I have and an approximate value?
- Does anyone have set of plans for EMHW Challenger 50%?
- Will a SFG(side force generator) work on a large gas plane ?
- 27% H9 260 tail shake !!!
- Evolution 58GX2 prop questions
- Carbon Fiber Pushrod Ends
- 3 blade prop on a 50cc
- Replacemant wheels
- MOVED: ys fz 140
- YS 160 Needs Plane
- Cermark SS-77 28% Edge 540 & SPE 43 Build thread
- sd python maiden
- Picked up used H9 Taylorcraft w/G26 have questions
- Post crash "what if?.."
- Dual elevator servos...need set up help
- PAU sale!! Killer prices!!
- Need Help Godfrey 30% Ultimate
- Moving to a 100cc extra
- If you want it right Buy EXTREME FLIGHT
- Where Did The Team Pilots Forum Go?
- Redbull scheme
- is a super cub more agile than the original J3 ?
- The new BME 150LT in a 35% plane? You betcha!
- Checking Voltage on Fromeco Regulator
- Throttle servo recommendations for 50cc
- Dalton Aviation Kits
- Hanger 9 Sukhio 26mm wing panels??
- INFO PLEASE ON 1/3 SCALE CLIPPED SUPER CUB-HAS ANYONE DONE THIS ?? is there such a beast ???
- JR 9303 Setup Help
- Covering for aerobatic kit/scratch build.
- Finally got pics of my Katana
- 35% H9 extra 260....weak wings / failures...
- Whats this extra?
- Servo Question
- Reza Gholamipour 3D Video
- Great planes 1/3 scale Cap 580 Embry-Riddle
- Help identify large glow TOC motor
- My first "Giant" plane
- Recommend a 25% YAK or Sukhoi
- Cermark SS-77, Scale Series 77", 28% Edge540
- Pull - Pull or Direct Connect??
- HD servos
- MOVED: DA-85 VS 3W-85
- Which Yak or Suhkoi for my engine.
- Is this battery location ok????
- Plane for an OS FF 240 Pegasus
- Pilot RC 50cc planes
- Hangar 9 ultimate
- Greves pipes and Aeroworks 40% Yak heating question
- TOC Question?
- Zlin 50 LS 1/4 Composite
- GreatPlanes Cap 21
- TZB Need Your Help! RC Clubs wanted!
- What's the Hot new 50 size bird?
- Blazing Wing's 95" Pitts (DH Models)
- Smart Fly Batt Share question???
- TT yak 54
- WARNING: DO NOT ORDER FROM AEROWORKS....
- Servo load feedback?
- Yak vs Extra
- Goldberg Ultimate CG
- Aviation Models Extra 260
- Looking for a cradle/ transport stand idea
- EF 88" Extra 300 or WH 88" edge 540
- remote control switch
- Aeroworks 100cc Extra 300
- What size Metz prop on a 40% Aeroworks Yak w/ DA150?
- Wild Hare 35% Edge
- What happened to the DOD website?
- Edge 540 Anyone seen this one?
- Hostetler Skybolt/Saito 300 twin combo
- Giant Scale Planes Giles 202 109"
- ak models 100cc extra
- Cowl for GP Giant Aeromaster
- Engine Box Reinforcement
- Compare QQ 73" Yak and Aero-works 73" Yak
- PAU 43% Edge 540 PICTURES
- HITEC 7955TG
- programming 4 aileron servos on 9303
- Best power system for EF 88 Extra (or Yak)
- New Crash Protection Program offered by Ace Hobby Distributors, Inc in North America.
- Running Smoke
- Xtreme 3000
- Mini Smoke System
- ASSAN 2.4g RCVR
- Don Smith Giant Scale Spitfire Video By PlaneVideoArt
- 35% Edge 540 to 35% Slick 540
- Great Planes Yak 25% Horiz. Stab alignment problem
- lanier extra 330 single rudder servo
- props for 3W-342
- 89" P-51 servo installation
- A123 batts and NO switches for my new set-up
- Dietrich Slick 540 on Steroids
- 100cc extra 260 WildHare QB or Aeroworks QB
- Lateral Balance...
- Fuel Dot ?
- TBM 50cc 30% Magic Hand Yak 54 Build Thread
- 50cc Setup?
- Central California 3d Fest
- Smoke Setup
- Cyclone Toy & Hobby Edge 540 100CC
- Buy 1, Get 1 Free FASST Promo
- HANGER 9 540 EDGE
- mixing question
- Can/Prop Combo for Extreme Flight 88" Extra 300?
- Why Not Futaba?
- Gathering of the Gaints Would like to invite you
- GP extra 300S 160
- Can Anyone Help With My Prop Balance?
- Raven 50cc....Anyone built and flown it?
- Pacific Planes Extra 260; Anyone flown one?
- Lightest yet sturdy wheels for 50CC bird
- Colorado HuckWest
- are zenoah engines good to prop hang ?
- How do you MAKE sure it is Zero?
- Replacement Gear
- Wild Hare old parts clearance
- 3 Bladed Prop on DL50???
- checking incidence angles
- Goose's TWM 27% Ultimate assembly
- DA 50 Muffler
- Help - Plane ID
- Aeroworks 85cc Yak 54
- Official Build Thread: Magic Hand yak 55
- H9 CAP Crash; 6014 blame? Replacenet ideas?
- New 3D plane
- First giant scale, first gasser.
- Looking for Pics of DA85 on a H9 33% Edge
- Pacific aeromodel 25% Katana???
- Good profile for a Brison 2.4?
- MOVED: Extreme Flight 74" Yak 54
- MOVED: new at 3D Fliying
- Nitro Planes 35% Su 26, $399
- Looking for RCU member
- Did anyone kit a Texas Hurricane? Need plane ID help
- CYCLONE 88" EXTRA 330l WITH RCGF 62CC ENGINE QUICK BUILD
- BVM Props Liquidation Sale
- Giant Super Decathlon vid
- Extra 330 cmpro and DL 50(pls delete the other thread in giant scale)
- Has anyone tried this one?
- 50cc TT TOC Pitts M12 CG???
- MOVED: Edge 540T 3D EP
- Biggest plane and smallest car
- the best 50cc mount?
- Best 50cc plane for 3D?
- Peak models question
- Giant Telemaster setup questions
- Something different for 50cc?
- Corpus Christi Giant Scale Clubs/Fields?
- MOVED: Area 51 or DL-50?
- White Rose Tail Wheel
- First 40% Power Setup??? Power Expander?
- Smart Fly PE Results
- Black Horse 1.8 CAP 232
- Dietrich 42% Extra 260??
- AR 7000 Servo Load?
- Need help with Midwest Extra 300s
- Servo selection help?
- Snappy Extra
- Instructions for GP Christen Eagle
- Extreme Flight Extra 88 MTW TD75 Canister Install
- 100" Katana (Funtana) design
- 60% Yak54 Hell Yeah
- Manual needed- Peak Edge 540 SPE26
- 50cc Aeroworks Extra 260 Canister question
- Brent Good Custom Airframes 106" Yak 54
- Need help on id aircaft
- 40% sd extra
- QQ 101 Yak for $650.00!!
