PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Smoke on my 26CC Weed WackerConversion
  2. DA/DL50, DA 85, DA 100 Stats
  3. Quality & Cheap ACFT Build (ARF)Giles 202
  4. Toledo
  5. Help with servo choices.
  6. Odd 35% behavior in 3D mode
  7. Wingtube installation problem
  8. Review:Aeroworks 50cc Pitts Python!
  9. NEED HELP!
  10. 3d flying video and set ups???
  11. DA 100 specs
  12. 3d flying video and set ups???
  13. Setting up 1/3 scale with Hitec Servo programmer problems
  14. My new adquisition.
  15. wheel pants ?
  16. Can anyone source this tailwheel part???
  17. Large Plane CG finder
  18. Fromeco Sahara
  19. reinforcing motorbox/firewall
  20. Two Switches One Battery = I am a believer
  21. Surface mounting Comp-Arf elevator servos
  22. antenna routing
  23. re-birth of an old Lanier 90" Edge...
  24. unexplained interference
  25. New Thunder Tiger SD Yak
  26. Giant scale elictric and A123's
  27. Super Customer Service
  28. Lanier Yak 54 87" engine choice?
  29. 50cc Yak
  30. Finally getting bigger - have questions!
  31. please tell me what the c of g should b for my 28%xtra 300l
  32. Holiday today?
  33. Dual A123 packs for giant scale
  34. Lanier Extra 330 94" ARF
  35. Byron Pitts parts photo
  36. first 35% setup questions
  37. Where to get HD servo extension?
  38. Same battery to Ignition and RX
  39. DA 100 or 85 on the new 35% plane
  40. Any Large RC Fields near Asheville, NC ??
  41. Hangar 9 + Carden = History
  42. Where to get graphics for the dask panel on a yak?
  43. Which servos do I need?
  44. Desert Aircraft in Fort Lauderdale
  45. SkyShark
  46. Dual receiver battery packs and switches
  47. Dual receiver battery packs and switches
  48. HD Servos
  49. How do YOU seal hinges?
  50. has anyone ever seen a 100cc non-rc engine converted?
  51. Triple Creek 3D Fly-In: TC3D, Tampa, June 21 & 22
  52. giant stinger arf
  53. Canopy Repair Glue or Tape
  54. Balsa USA Fokker D VIII
  55. A123 Self Discharge?
  56. I need to know how to setup a gas tank
  57. cannisters
  58. tuned pipes vs cans
  59. 2.4 problems or A123s or?
  60. Cape Coral Airshow Pictures... Warning 56K
  61. AW Yak54 QB 75cc - Single servo on Aileron ??
  62. AirWild 40% Sukhoi SU29 ... all you need to know
  63. H9 33% Sukhoi 26mm
  64. Smoke Injector Fittings
  65. Wing Fillets
  66. Dietrich 50cc Extra 260 (New Build)
  67. Source to buy 2mm nylon bushings to eliminate elevator hinge slop in a Comp ARF 2.6m Extra?
  68. How to make Fiberglass Cowl Baffles
  69. need help with my yak SD
  70. RCU Build/Review: AW 50CC Pitts Python
  71. Katana 200 arf
  72. H9/Carden 89" Yak 54
  73. Klett hinges?
  74. Installing a Smoke System
  75. How to keep cowling screws in, on GAS plane??
  76. First Aerobatic Big Bird Question
  77. 33 or 35% Yak 54 for a BME 102
  78. MY NEW PLANE
  79. Cactus Aviation
  80. vess prop for bme 110
  81. Dual Carbon Horns
  82. servos
  83. My current large planes.
  84. aeroworks 42% 260 vs carden 300
  85. Thoughts on GP 28% Extra 330s
  86. servo power
  87. Extreme Flight RC at 2008 Toledo trade show
  88. Precision Hobby Products Extra 260?????
  89. 35% Fun!!!!!!!!!!
  90. Carden 35% Cap 232 Cowl
  91. Prop to cowl spacing
  92. E-flight Divo 3D and EVOLITE 800mah Question
  93. Carden ARF Yak (Hangar 9)
  94. 2-56/4-40 Nylock Nuts Provided with Rocket City/Nelson Components....
  95. Troy Built Models (doin' me wrong)
  96. Will this servos do the job
  97. Aluminum charge jack
  98. GP 38% Extra 330s Geat Planes Build
  99. grieves pipes
  100. edit
  101. How to frame a canopy
  102. How to frame a canopy
  103. Chattanooga 3D Jam
  104. Carb Diaphram Plate Venting
  105. I am about to buy a lanier 87" yak, is it worth it?
  106. Help Me Find A Engine Please
  107. 40% carden 300
  108. best 40% arf for 3d
  109. Which Servo's to use
  110. Winter Rally of Giants
  111. hanger 9 50cc Yak 54
  112. Pacificplanes 35%extra 260 anyone have???
  113. interference on 2.4?
  114. 75CC Brent G. Airframes Yak54 Build
  115. Ft Rucker, Alabama hobby shop?
  116. Air Wild Servo Extensions
  117. a123 batteries
  118. Double Vision Instructions?
  119. H-9 Cap 232 1/3 Scale...Liited Edition.
  120. Is it possible to do a torque-roll on a 50cc decathlon
  121. Electric conversion's
  122. Da Fuel Dot
  123. Lanier 94" Yak help
  124. Hanger 9 and Carden Aircraft Join forces
  125. Biplane trimming help
  126. Plane for DA-85
  127. Help with TOC-X Yak 33% Aileron Control Horns, Please?
  128. Which Yak would you get?
  129. TOC 37% yak-54
  130. A123 Radio Ignition Setup
  131. Anyone have tail feathers for an EF 68" Yak??
  132. QQ 102 yak build!
  133. WHO has a SPIRAL-painted Spinner on an Extra or other Plane???
  134. Largest Fuel Tanks
  135. carbon fiber spinner
  136. Help Identifying 100" Extra -- Old Fiberglass Airframe
  137. Que Que Yak 86 CG
  138. need help cg Que Que yak 86
  139. Dawghouse RC yak 55
  140. EF Yak
  141. My home built trailer
  142. Great Planes 38% extra 330
  143. Who Makes This Giles 202 120 72''
  144. spinner balancing
  145. Reversing Y harness and 2x 5955
  146. Prince P-Tip Props
  147. x
  148. will my plane fit in any of the following?
  149. Tailbraces/support
  150. Ignition and Receiver Batt/Reg Setup
  151. Better flying plane?
  152. wingtips
  153. Help me pick a plane!!!
  154. Mike Hurley EXTRA 300 build!!!
  155. How do you guys transport....
  156. Help!! need a source for a round aluminum servo horn
  157. Whats the purpose of the canister?
  158. Velcro straps
  159. Where can I get some cheap 5945, 5985, 5955?
  160. Comp Arf need help with servo arms
  161. Curtis P-1 Hawk plans
  162. Curtis P-1 Hawk plans
  163. Lanier 300
  164. Need Suggestions for a YAK or Extra for a Saito 180
  165. Question on Midwest Extra 300
  166. x9303 high/low idle
  167. 2.4 ghz and single a123 battery
  168. Obsessed with giant planes???
  169. HS5945 good for 30%'er?
  170. Hitec HS 635 on 50cc WorldModel Ultimate
  171. Flamed 40% ZN line, everyone say goodbye
  172. CMP extra 330L-servos
  173. New Lanier stinger
  174. 33% 3d plane
  175. New switch for A123 batteries from Fromeco
  176. Edge or Giles??
  177. Outdoor storage in hot/humid miami
  178. Nylon bolts on one piece wing and hard 3D?
  179. 12FG TX using 2 cell 7.4/2600mah lith ion?
  180. Edge 540 from Modell-Expert
  181. BME 37% Ultimate????
  182. What adhesive do you use on firewalls??
  183. JR 8717 in Giant Scale Aerobat?
  184. Extreme Flight Yak 88 or Extra 88.5?
  185. Who has the 12fg and how do they like it?
  186. Hahgar 9 46% TOC Ultimate 10-300
  187. Dual Elevator Servos
  188. Quique's Aircraft Company will be at WRAM Show
  189. WHERE TO FLY 3D IN AZ
  190. Hitec HFP-10/20 internal battery size?
  191. 1/4 scale Diablo
  192. New Dietrich colors.
  193. Smoke system/Battery Question...posted it here to hopefully get an answer..
  194. Lanier
  195. VIDEO: Emcotec DPSI RV TWIN
  196. Composite-ARF Extra 330L 2.6M WING SPAR
  197. Purchased new 50cc 260
  198. Question for all 2.6m 260 Owners....
  199. AUSTARS MODELS 42% EDGE 540
  200. C-ARF 2.6m Extra 300SX Components
  201. Lainer 40% EDGE 540T PLANS NEEDED
  202. Original Hanger 9 Extra 330S - DA-85??
  203. Carbon Fabric Spinner
  204. Dual RX - who's using them?
  205. Saito FG 36 Gas in a ?????Edge 540
  206. Futaba12fg Servo Speed
  207. Large scale models - building them properly
  208. Plane Hoist Needed...
  209. Which 35%
  210. Attention Extreme Flight RC pilots-we need your pictures!
  211. DX-7 Failsafe & Optical kil switches
  212. My Experience With Somenzini Aircraft Co
  213. How to be a Good Spotter at and event.
  214. 8" Wheels???
  215. balancing large wood props
  216. PPM & Gassers
  217. H9 35% Extra 260
  218. Anyone building a H9 Sukhoi yet???
  219. 40% SU26 MX
  220. Best 2.6m Composite-ARF?
  221. Best Plane to buy
  222. Carden prices?
  223. Power HD servos
  224. Fuselage / electrical grommet
  225. DA 100 Throttle Arm
  226. A123 Info Page is up
  227. Larger Python
  228. help looking for info on peakmodel planes anyone have one
  229. Firrts 50cc for Peru
  230. peakmodel edge 540
  231. Setup Process
  232. Am I off-base here?
  233. Brisson 4.2 Questions
  234. G/P 38% Extra
  235. Comp Arf 2.6m Extra 260 Build Threads...
  236. FX3D! Who's comin' and wacha bringin'!
  237. "New Kid On The Block"
  238. Harris Smoke Pumps - Ready to Ship
  239. Batteries for Aeroworks 35% Extra 260
  240. Is this a good plane?
  241. PA prop??
  242. Twin battery gear drive starter
  243. center of gravity EDGE 540
  244. SD Aviation Models
  245. Is there a lightweight gas tank?
  246. Can anyone help with R/C Blimp Tailwheel Source???
  247. tell me i am wrong here
  248. AR9100
  249. Wing Incidence
  250. Aeroworks 50cc Extra 260
