PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Who has Changed the Trim Scheme on the H-9 Giant Cessna 182?
  2. Giant Sukhoi builders kit
  3. JR DS9411 Servo Gears
  4. Range check question
  5. 1/4 scale extra 300 parts needed???
  6. Buying a DA150 .... where?
  7. Wing Loading
  8. H-9 Su 31 Decals?
  9. let us see your giant airplane
  10. Getting Sponsored
  11. JOSH
  12. 1/4 scale WWI decals
  13. CapX deliveries?
  14. double vision
  15. Remote Control Paratroopers??
  16. zdz60 /edge in response to Matt.
  17. PCM/FM Reciever Help.
  18. A Fat 28% 300 Special Hornet Edition Smile
  19. 4702 views in one day
  20. custom exhaust & mufflers
  21. Sig 4 Star 120 Control Throws
  22. carbon fiber landing gear
  23. MOVED: Carden Edge 540
  24. Vision 3D vs. 27% Extra 300S
  25. Checker patterns on wings...lets see pics
  26. hook up on servo arm
  27. sealer for balsa
  28. Plans of CAP 232 27%, Edge 540 T 25%
  29. Columbo Anderson
  30. Minicraft Edge 540
  31. How Good Are The Aeroworks AFTF Planes
  32. DOD Website?
  33. My H-9 Sukhoi
  34. Cub 1/4 help pse
  35. Composite ARF - 3.0 Extra - just pulled the trigger
  36. AeroTech 35% Edge 540
  37. Double Vision ships
  38. Kavans in Stock????
  39. Futaba digital servos
  40. Hitec Digital servos
  41. F4U book
  42. GAS Conversion Engines? From weedwacker> ect..
  43. Pull-Pull Setup Problem on Extra Special
  44. Airmodels 26x12x3 &3W106
  45. 3 hole motor mount 80" cap 232
  46. Seagul Edge 540 80inch span
  47. CA 34% Extra...... info needed
  48. CA Hinges
  49. Some final Adjustments on the 28% Edge w/DA50
  50. Comp-Arf 2.6 - Couple of Quick Questions
  51. Airplane Scheams
  52. Behrlan 1/4 Fokker D7
  53. RickP's Replacment - Cast your vote
  54. 40% CARDEN CAP
  55. 28-30% Xtra ARF/ARC/Kit..Whadya Think?
  56. J3 Cub 1/4 Scale Dashboard
  57. 2.6 Comp-ARF - Unthinkable???Unspeakable....
  58. Is there life after smoke fluid?
  59. CG for Sig Sukhoi ARF
  60. Giant Stinger - How to repair?
  61. Ideal Giant Scale Plane, whats yours?
  62. WOW!!! H9 Cap232 80"
  63. ziroli dc3
  64. FPE and 28% Extra
  65. DV's have arrived
  66. BME Aircraft
  67. Incidence Meter for 40% Planes
  68. Best 25-35cc Gas Engine for Dynaflite Decathlon
  69. 300XL
  70. looking for Todd Cox, Bremen IN
  71. how big of a smoke tank
  72. MOVED: Carden Parts
  73. NEW DV AND A MINTOR 1.70
  74. Wanted: 2.6 Comp Arf Extra canopy
  75. Fiberclassic Aircraft
  76. Engine choice
  77. Kangke Texas Hurricane/Saito 180 Help!
  78. ETOC Double vision foam plane
  79. Looking for larg Cub
  80. 1/3 spacewalker came in the mail
  81. Comp-ARF YAK 2.6 Shipped!!!
  82. Tygon gastank clunk setups
  83. Best plane for DA-50
  84. PBY Gunner Blisters
  85. NEW REVIEW: Hangar 9 P-51 Mustang 150
  86. Extreme Aircraft servo trays...anyone use 'em?
  87. Extra330L 3.1 composite arf info
  88. Want a twin- Which one ?
  89. WH Giles 35% landing gear
  90. Snap Rolls
  91. Need giant servos for kite
  92. CA 27% Extra 300L, what hinges ?
  93. Composite ARF Extra 330 2.6M anyone have any input??..have one??
  94. stuck with a brison 2.4
  95. Quadra 50 in GP Pitts
  96. GP 1/3 Pitts engine right thrust
  97. Stand offs with ZDZ 60
  98. 8411's Are they enough?
  99. What was used??? Y plugs/matchbox/programmer
  100. Lanier 40% for under $600?
  101. Landing advice needed..36% Extra
  102. Servo horns for WH 285 planes
  103. MVVS 2.15 tuning help please
  104. PowerfLite's with PowerBox or not???
  105. 36% Extra Carbon landing gear source
  106. Aeroworks Katana
  107. Inverted O.S. BGX - 1?
  108. Are there 2 versions of the H9 Sukhoi SU-31
  109. Success!!! Tuning the O.S. 1.60FX and keeping it running- (Thanks everyone)
  110. Wing tube collar/hose clamp
  111. 25% Lanier Extra 300s
  112. big piper
  113. slimline excel gas fueler
  114. 28% Extra 300LX finished
  115. Mode 1 or Mode 2 ?
  116. Extra Special and CG
  117. First 40% Flight!
  118. Which engine??
  119. CAmodel Extra 300 24%, what engine for 3D?
  120. 70% Raven wingspan 17 ft.
  121. Katana full Composite 33%
  122. ZDZ 210 vs DA150
  123. Prop Selection Question
  124. Dave Patrick Extra 300L and Gas Engine
  125. Brakes for Piper PA
  126. Sopwith Pup covering
  127. R/C Wingbags
  128. 28% Extra and MOKI 2.1
  129. power box vs i4c vs power bus pro
  130. Giant scale engines
  131. Most Accurate Gee Bee R2 Design??
  132. New 41% Pitts Model 12 finished
  133. H-9 330S Removable Rudder ?
  134. Balancing 1/3 Scale Hangar 9 330S ARF
  135. fuel tank question...
  136. Will Fuji BT-64 work well on GP pitts
  137. What prop do I need??
  138. HELP!!! gp wagstaff question
  139. .........2.6 Chapter II
  140. The Bombdiggity
  141. Moderator, please delete this thread.
  142. Electronics configurations for large scale
  143. Is there a really scale big Sukhoi su31?
  144. color code fore a super chip?
  145. Canopy Tinting help please
  146. 1/3 Scale Fleet Biplane
  147. Chief Aircraft Service !
  148. whats a good plane for a brison 5.8?
  149. optical kill switch
  150. My Edge is here!
  151. ppg omni and monkote metalics
  152. Saito 300 Twin Owners- A Question
  153. Invitation to the JR-SCAT Series contest in North Las Vegas
  154. what ARF for my Saito FA-300T twin?
  155. Insanity at its finest
  156. DIABLOTIN XL STRUCTURAL FAILURE
  157. Aeroworks edge vs. Carden extra
  158. Tree Hopper Plans
  159. GP Pitts/QUADRA 42
  160. Byron GeeBee
  161. Whose Incidence Meter to Get?
  162. OUT OF THE COUNTRY
  163. Come on, no one is kind enough to answer my post??
  164. ballance prob
  165. Pull Pull elevator
  166. Out of Alignment Elevator - Need Advice
  167. Great Planes Christen Eagle II
  168. What's a good 28% ARF?
  169. Extra Special Wing Tube Too Tight
  170. Canopy helmets
  171. Hostetler's 30% Super Decathlon
  172. Composite ARF - 2.3 Extra - Finished Pics
  173. Servos required for the AW 29 % edge and the CA 27% extra 300?
  174. Voltage Regulator or NO voltage regulator
  175. 28% Extra weight
  176. 35% Giles -- Question...
  177. Enlarge Guillows Plans for 60" Wingspan? Maybe silly idea but Can you?
  178. Top Flite P51 Gear Doors
  179. Flair's spirfire gas or glow?
  180. h9 suk with da100 power
  181. Another question from ME!
  182. Anyone Else in UK got an Extra from Wildhare?
  183. Robart website still down...zzzzzzzzzzzz
  184. CACTUS AVIATION XTRA 330
  185. 28% - Sealing the hinges
  186. H9 1/4 Scale Talorcraft cowl width?
  187. Funaero S.E.5A
  188. Lanier 33% extra mods?
  189. Anyone have any Composite YAK VIDEOS,,that work..
  190. 1/4 scale Sig CW Cub
  191. Wing Bags for Wild hare Edge
  192. CA 31% Extra Surface Throws ???
  193. Super Flying King & Paramax Jumper Video
  194. Extra Special Cowl Paint
  195. I have G-23 what good ARF will it fit?
  196. Old Masking tape removal
  197. What Extensions and Connectors to use in 40%'er?
  198. 6 volt or 4.8 volt system??
  199. Building the 88" Ziroli Stearman
  200. Edge 540T Elevator Servo in Stabilzer?
  201. Need HELP on Lanier 30% Edge ARF
  202. Looking for a Slimline Smoke muffler
  203. Color of DP Edge 540
  204. Laser 200
  205. Removed cheesy video- to many downloaders
  206. lanier edge 30%
  207. SU-31 First Flight :-)
  208. Upgrades
  209. CAP XCELLENT
  210. I need the dimensions of the Edge landing gear
  211. 33% Aeroworks Extra?
  212. MID. Super Stinker GAS ENGINE HELP
  213. CG Sanity Check on Extra Special Please
  214. Comp-ARF 3.3m Yak Video
  215. Transport
  216. Wendell Hostetler Cessna 182 Info wanted
  217. 1/3 spacewalker,, ordered!!
  218. ARMY & NAVY Stearman Drawings
  219. Pull Pull exit point question
  220. Top Flite ARF Mustang
  221. 3W Silencer
  222. Ignition systems??
  223. Cap X and Saito 180?
  224. ZDZ 60 on 28% Extra Special
  225. There's got to be a better way..???????
  226. CA 27% extra 300L Weight with DA50???
  227. Pull Pull Setup Help Please
  228. *VIDEO!!*UPDATE* H9 Ultimate first flight... Side by side with aeroworks 42% ulti!
  229. mpi servos
  230. Sig 1/3 Space walker,, anyone build?
  231. JR8611 Bad Servo for 28% Edge?
  232. CF wingtube?
  233. Giant Scale Smoke Systems
  234. Scoop. Servo breakthrough from hitec. 320 oz/in standard size!
  235. Need some help with a ZDZ 80
  236. DeHavilland Tiger moth wheel emblems
  237. different size prop with a dash-10
  238. On Line Manuals for the Double Vision?
  239. great planes patty wagstaff question
  240. great planes patty wagstaff question
  241. Edge arrived today, I goofed 2X
  242. 34% Extra?
  243. crash repair help
  244. H-9 330S Wing Tube
  245. !!!!!!!!!!!Graphics for planes!!!!!!!!
  246. TME SMoke Pumps
  247. Best ARF Extra 300L 24% to Buy
  248. Wild Hare Edge F/S in Indy, Friday 4/23 6pm
  249. MIDWEST CAP 80" BUILDING HELP
  250. Routing Ideas??????
