- Yak won't stall?
- Assembling and Flying the AeroWorks 75cc Extra 260
- Too many servo's to pick from 540 edge
- Tail Wheel Straps?
- Any QQ 102 Yaks with 106's up front"
- Top Model CZ
- My first giant
- Pacific Planes Customer Service A#1
- Correct Prop for Extra 330
- Make the Jump from 50cc to 35% on a quality budget..PP Extra 260 and Torch single cyl. gasser
- Help with Hitec 5645 MG Digital
- WingTube Question!~
- SD model Extra 260 50cc - one or two receivers?
- Y-harness elevator setup (with Futaba PCM 148)
- Futaba's 9C capabilities ?
- best muffler for the DA50??
- JR/Spektrum Servo Arms
- Please Help. Color scheme for my own desing Yak-55
- Question extra 330l or yak 54
- Dual Elevator Setup
- Powerbox and 123's
- Midwest Giles 202
- Yellow Aircraft / Fun Key
- 100CC SIZE PITTS OR ULTIMATE KIT?
- extreme flight vs wild hare
- New to Giant Scale
- Composite-arf-surface mounting elevator servos
- Dietrich 50cc Extra
- Which biplane for 50cc or 80cc?
- 50% Aircraft, (other than Bill Hempels)
- Best Way To Add Right Thrust?
- Battery chargers
- 8711 & regulator
- Your advice needed
- Es composites info?
- Great Planes " tweeners " ?
- How best to get to England?
- 1/3 Sig Spacewalker
- Help picking a battery setup for my 1st 50cc
- Ultra RC
- "Florida Freestyle Aerobatics Club" Floridians Speak-up!
- Miles Reed 90" Extra & Solution 77"
- 50cc Extra or Yak plane?
- DA-50 on a Katana airplane
- Edge 540t - Wildhare or Precision Aerobatics?
- What a Waste
- GP Stearman ARF bipes
- Prototype H9 Sukhoi 26
- Tucson Aerbatic Shootout 2007
- Prop for Christen eagles/
- Aeroworks 33% Yak and TOC EXtreme
- looking for info on g & l hobbies planes?
- SD MODELS -IS IT TRUE?
- Best prop for DA 100 on canister's
- ZDZ 80RV-J & H-9 Extra 330s Combo.
- H9 EDGE 540 33% Here it goes....
- brillelli 60 with a 1060 canister
- Balance woes - Edge 540
- es composite pipe on a brillelli 60
- Please read...!!!! 33 - 35% Builders kit info
- Lighter flies better?
- learning the crow manuevar
- Trouble deciding
- 88" ef yak what motor?
- DA 85...where to buy?
- How much time do you spend to maintain your giant-scale
- DA 85 Kits?
- QQ 86" yak or sd model yak
- Weight issue
- Looking for a 4" fiberglass spinner
- inverted flying and Torque Rolls
- Any 75cc Bipe ARF's?
- XtremeLink input voltage
- Wild Hare 29% Ultimate manual
- Hot New 50cc Yak at TBM
- H9 cap 232 33% with a GT-80???
- 50cc Yak 55?
- Great Planes 38% Extra ARF
- Servo City sale!
- Extreme Flight RC announces Team Extreme pilot selections
- 37.5 or 40% Yak
- GP Patty 300S or H9 27% Extra 260?
- Lookin for a 50cc edge!
- Please call
- Team Extreme UK @ Oxford, UK, VIDEO!
- SeaGull SuperStar linkages?
- Rocket city hardware?
- Dietrich 85cc Extra...When?
- Repair Parts
- 20lb plane with 65cc engine
- Hotlanta Hucktoberfest 3D Huckathon - You Going ?
- Extreme Flight 74" YAK 54 and Torch Engine 40cc
- Parts
- Spectrum Conversion
- Recommendation for 25% Extra 300/330?
- Throttle Servo standard or digital
- Airworld Su-26mx
- 42% Extra 300 Fuselage length
- Fuchs vs Beila props?
- 29x12 3-blader question
- SD Models 33% Extra 260
- Best source for methacrylate adhesive?
- Ultra RC 87" Yak
- Comp-ARF 3.3 Yak Question
- Looking for a Ultimate
- Yak54 cooling for a single cylinder
- Giant U Can Do - gas engine ??
- Redundant battery setup
- 26cc or 35cc???
- Colored smoke?
- TME Simple Smoke pump LEAKING!...
- Moving to NY from the UK
- DS8711
- 35% 260, which one?
- PA Edge 540T 50cc Elevator failure !!
- GSP-Giles 202 CG question
- HELP!
- Evolution 58 and a Extreme flight Yak 88
- CA Models 34% Pitts stinker
- Huck Day at Orlando R/C Association Flying Field
- li ion charger.....
- Servo jitters
- Edge 540 45% CAModel
- Sig 1/3 Scale Spacewalker
- Servo and Prop choices
- Aerotech Yak 55sp Prototype for sale
- 1/4 scale Patty Wagstaff smoke...
- Patty's new scheme
- 3W 75 iUS
- 35% Extra - Production status?
- Kimball-Somenzini Python Build Thread
- chip hyde 34% extra
- 1/4 x 20 nylon wing bolts
- Spruce Goose plans anyone?
- Pilot needed for 2x2 Comp arf extra
- RF Modellbau / FMG
- Cap 232 35% kits.
- Any good ARF that works with a DA-50?
- DA100 RPM'S
- Glitching troubles
- Living and Flying is the Seattle Area?
- BME/PAU edge540 III Parts
- Comp ARF Extra 2x2 clear canopy
- DA100 Question
- 41% Pitts S12 from BIGAIRPLANES
- R149DP RX & THROTTLE LOCK OUT
- DA-85 Engine Reports Please
- 46% Hangar 9 Ultimate
- SD Models/Aviation Models/TOC Xtreme 30%Extra 260
- Need a cool Pilot for a Hangar-9 27% Extra 260
- holding your plane when starting?
- Smoke and Monokote
- MOVED: Any Realistic G3 3D Planes?
- My Extra 330 crash
- 4-40 tap question
- cant descide between QQ yak or Aeroworks Extra
- what glue for vertical fin on carden 35% edge?
- How do you fill your tank ?
- anybody doing the QQ python 100?
- How Do I Report an Unethical Member?
- Will 5.9 stabil volt shorten the lifetime on the servos or reciver?
- How many would like to see Pocket Hinging in 50cc birds
- Using two receivers
- Servo matching
- GP Yak 54 Fuel Tank Ideas
- Extreme Flight Extra 300, 50cc, 88.5inch Wingspan, Build !!!!!!!
- First time gasser, need advise
- Brent Good Custom Airframes 50cc Yak 54
- Extreme Flight RC seeks to add 2 pilots to “Team Extreme” roster
- GP Wagstaff ARF smoke system
- ARC vs ARF...MANUFACTURERS TAKE NOTE
- z
- Large Ultimates, Hangar 9 TOC
- YAK 54 81" NITRO MODELS ,AND VENOM 45??
- Ultra RC support
- best place to buy xoar props online
- Troy Built Models
- wells cargo trailor question - painting
- Xtreme Composite Edge 540 build thread
- Decided on the Hangar-9 27% Extra.... Help with electircal system..
- 3W 80 twin
- Brakes on 1/4 scale Extra or similar
- Miami Valley 38% Laser 200
- Giant AeroMaster ARF
- Thinking about getting my first 50cc'er
- Manual for BME Edge 540 Mk 1
- My first Giant plane choice...
- Rascal 110 - 6 degrees of freedom/aerodynamics?
- Saito 300, Does it fit the World Models 80" Extra 300S ??
- 34% Colombo Anderson Extra 300L Build!!
- SD models 30% Extra 260 HP
- Anyone tried SFG's on a 40%
- Plans for a IMAC plane
- Powerbox Smoke Pump System (Aircraft International)
- H-9 Extra 260
- First Giant 50cc looking for guidance
- GCM Models 44% Extra 330s
- Composite-ARF 2.3 and 3W 75i
- Which Size?
- For those of you who have 40% SD-model / Aviation model / TOC Extreme Yak...
- model-airfields LA - Reno
- Autopilot--anyone has used it?
- Amazing deal in Europe
- Airwild Unihubs
- Good News?
- Throttle Stick Position for Hovering
- 40% staudacher (lanier?)
- 2.6m battery questions
- Is 1500 mah (lipo with reg) on ignition to a DA 50 enough?
- 30% Pilot Figure
- CHRISTEN EAGLE ENGINE AND FIREWALL EXPLODED
- Rotary Drivers???
- ILLUSION BI PLANE
- Composite-arf Extra 260 3M
- Extra 300 3 view
- Looking for some websites
- Spinner balancing
- Ohio RC Ultimate Parts
- Discharge Amp - 2400mAh NiCd 6.0v or 5200mAh Li-ion?
- Exclusiv Modellbau 50% Pitts S1
- Throttle servo location
- hitec or jr servos
- CA Models 31% Extra c.g.
- Salute and Goodbye to Jim Leroy / Bulldog
- Extreme Flight 88" Yak Header/Can DA50
- Enough Juice?
- Balancing Mejzlik Props?
- Red Bull decals
- Aerotech 50cc Pitts M12 Maiden Flight!
- Anyone heard of this plane
- Smoke on canister mufflers
- Set Up Help
- Comp-Arf 2.3 Extra
- New Somenized Yak-54, GenIII
- pacific planes 35% Extra 260
- can high power servos effect range check?
- throttle curve on a da100
- BIG BIRDS at TORKS
- Cant stop Airwild 260 from wanting to torque, help
- Peter Goldsmith Articel & Dynamic Balance
- QQ Pitts M12 Building & Flying
- richmodel yak
- QQ 102 Gen III
- Are you 100%, positively sold on XPS for giant scale 3D?
- Verdict on new Servo
- MOVED: SmartFly quality question
- Hangar 9 Edge 540 - need help with headers/cans for DA100
- 46% Ultimate / DA150 / Pipes ???
- ? HS 5955 Gear Train ?
- sukhoi kit
