PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. GP 38% Extra
  2. receiver amperage
  3. yak 30cc SD
  4. Hitec 645MG
  5. PAU 36% Edge 540 Assembly
  6. dual power source
  7. What Prop for a QQ Yak 54 and OS 160FX
  8. Need help for a friend please
  9. Calling all members in Minnesota
  10. Which ball ends wear the best?
  11. Need Help with Giant Scale Accessories Guys.
  12. Midwest Extra 1.8 Setup
  13. composite arf- dual power source
  14. Composite Arf 2.1m Yak/2.12m Extra Owners...
  15. PAINT TO MATCH MONOKOTE METALLIC RED
  16. Video Sukhoi with GT80. Video
  17. Aeroworks 35% 330 QB
  18. CPM Extra 330L engine choices
  19. EF 87" Yak or Ultra RC 87" yak. Who makes them now?
  20. Comp Arf 2.1m/2.3m/2.6m questions...
  21. Some basic gasser questions
  22. how is wing area measured
  23. Windy Fliers
  24. World Models Katana S 50cc ARF
  25. Spoilerons for landing
  26. JR8611A or Futaba 9156
  27. NEW Composite YAK 55 2.12m DA 50
  28. AeroWorks QB 260 50cc with G62
  29. AeroWorks Builders Kits
  30. Sullivan Customer support!
  31. Which 30% should I get?
  32. choke set up on DA 85
  33. new hangar 9 sukoi
  34. Aluminum wing tube
  35. Are Mejzlik Props only for gas engines?
  36. 8711 vs 9156
  37. DA-85/ Extra
  38. 27% planes who makes them????
  39. engine thrust
  40. Hanger 9 35 % Graphics
  41. 2008 SKYMAC Vette City Big Bird
  42. Gas Tank 50cc gas 540
  43. Gas Tank
  44. Restraint system for 27% and larger???????
  45. Aero-tech 47% 101"Ultimate 20-300
  46. Rascal 110 & Saito 180
  47. CG for 40% 3W Extra 330 S
  48. PAC Logo Request
  49. what happened to the 3D flight school thread ?
  50. Happy Holidays
  51. Wingbags? what do you need?
  52. HELP me decide: PAU Extra 330L or SDM Yak 54
  53. AUSTARS 42% YAK (now with vids)
  54. New Power Box Batteries???
  55. Duralite Gemini reg on 35% plane?
  56. CA Models/Aeroworks 28% Edge 540 T Kit
  57. Yak 54 87" with skiis -success-pic's
  58. Pushrod Setups
  59. Fiberglass Fuselage
  60. Benefits of a Cap(icitor)
  61. New Harris Smoke Pump
  62. 33% Sukhoi SU-31 Please HELP!
  63. Mejzlik
  64. Dalton Aviation Extra 260
  65. Why? External servo mounting.
  66. Extremeflight 88.5" Extra - Build and Fly
  67. How to get the best out of hitec Servo's
  68. extreme flight yak
  69. RED Bull Scheme help..
  70. Lanier Yak 94"
  71. Best 35% ARF
  72. any insure there plane?
  73. Problem with Hangar 9 33% Edge & horiz stab tubes
  74. CAMODEL 35% EDGE DESIGNED BY CPLR
  75. Best deal on 8711's?
  76. edge540 vs: extra260 50cc size
  77. Great Planes Yak-54 graphics scheme
  78. pull pull system help!
  79. MPI Miracle switches crap?
  80. Smart fly
  81. EXTREME TOC/SD MODELS 260
  82. 50cc Yak Kit Suggestions?
  83. Giant Scale Extra-260 for $199
  84. Hitec/JR Servos more popular than Futaba?
  85. any body know who make or name this plane
  86. composite arf 3.1m super xtra
  87. Jack screw retracts ????
  88. Futaba 7C 2.4 FAAST For 30% Planes
  89. Seagull Models' 33% Extra 260 for $399
  90. Rare Pilot Christen Eagle 1/3.7
  91. I heard you guys are the one's to ask about radio set-up
  92. GP Yak 54 balance problem and advice
  93. Remove & replace Robart pin hinges
  94. Direct drive servos/surfaces?
  95. Which 100cc for Christmas???
  96. Dietrich 50cc extra 260
  97. Bisson Pitts Muffler - is this where you guys would drill??
  98. Wagstaff Extra engine choice.
  99. Comp Arf 2.6 Yak
  100. spinner for carf 2.6 yak
  101. best place to get a mezjik 3 blade 25x12 (AKA Lowest priced)
  102. Can Carbon props be repaired?
  103. Best Servos
  104. BEST IMACer?
  105. Balancing 35-40%ers
  106. Throttle Response
  107. Smoke injector location question - Bisson Pitts Muffler
  108. Extreme Flight 110" 100cc Yak 54 Build!
  109. PAU New 36% Edge 540
  110. Hostetler 33% Extra 300XS construction article
  111. G Shark help
  112. Direct Drive Servos
  113. 30% yak 54 sd-models arf
  114. wild hare 80" yak
  115. Need help contacting MAUDIB
  116. Difference between Yak and Extra?
  117. Standoffs for DA100 on GP Cap580
  118. YAK 87" extreme flight landing gear replacment
  119. Hanger vs. Aeroworks - 35% extra 260
  120. Needed Sig 1/4 Scale Wing plans (Long wing
  121. 40% SD Models Yak
  122. DA100
  123. Lanier 94" Yak ???
  124. Which size 80cc single or 100cc twin
  125. saito 1.80 vs magnum 1.80
  126. Cheap titanium servos
  127. Performance Aircraft Unlimited 30% Extra 330l SALE!!!
  128. A PUZZLING SITUATION FOR SURE
  129. dr 107 one design
  130. trade show????
  131. Real world data on power demands
  132. RC Blimp still out there
  133. MOVED: Most beautifull airliners landing
  134. VIDEO: DA-85 break in
  135. KATANA S
  136. 72 inch wingspan 3-D
  137. Mods for Extreme Flight Yak 88"
  138. 6.6V 4600 A123
  139. Best prop for a YS 120 in a 120 size ultimate?
  140. Prop RPM Limit ?
  141. Vess Prop Split, safe to use?
  142. DA-85 needle settings
  143. What would you do, read on plz....
  144. Help me pick the radio/battery setup for my 50cc
  145. Crossed pull-pull cable
  146. 35% Canopys
  147. H9 46% Ultimate in Action
  148. dead thread
  149. Dawghouse RC??
  150. QQ Yak and DA-85
  151. airfoil for Edge 540
  152. 33% Hostetler Extra 300XS foam wing
  153. Broken phenolic horn on Comp ARF 2X2
  154. Stripped prop hub
  155. Team Extreme at "Roar & Soar"
  156. NEW 43% & 36% EDGE's coming
  157. EF YAK 54
  158. Servo setup question on 35% Yak
  159. Lets see your hanger
  160. What I want
  161. New To Giant Scale , LilL' help needed
  162. Are you around?
  163. 35% planes: 300L, Edge 540, Katana S?
  164. DOD 3-D, Giant scale vs. glow comparison
  165. DA 100 on can's and Vess 27B
  166. DA 100 sag's on takeoff rollout.
  167. Giles 202
  168. Need Ideas For Quieting Wing Vibration
  169. Great Planes Pitts
  170. 2008 New Airplanes
  171. Midwest Cap 232 80" - Servos & Engine suggestions for IMAC/3D
  172. Aeroworks 35% Extra 260 with top components or 42% with average components?
  173. christen eagle
  174. Wow, which plane and engine?
  175. 35% H9 Extra 260 Maiden - I stand Corrected
  176. looking for a place to get the best priced servo horns
  177. Miles Reed 90" Solution XX
  178. Red Bull Air Race
  179. trojan t-28
  180. Voltage Regulators
  181. Spectra/Dynema For Pull-Pull?
  182. H9 27% Extra 260
  183. The ALL NEW Dietrich 75cc Extra 260
  184. Florida eXtreme 3D Fly-in! FX3D- Are you in?
  185. BUILDING UPDATE H-9 Exra 260 35%
  186. 2 rudder servos on 35% planes?????
  187. pilot
  188. Chief Aircraft 330L
  189. looking for a spinner for 3 blade melzik 25X12 prop
  190. H9 Ultimate incidence question
  191. Krill Katana wing bags
  192. Smart-Fly Engine cutoff Question
  193. 1/3 Pitts cowl question
  194. CMP 120 Super Chipmunk
  195. MOKI 2.10 Bearing failure
  196. Best 50cc for 3D?
  197. Help!!!Search a Manual for the Sd Models Pitts M12
  198. Smoke Fuel Tank
  199. Large A/C Radio Setup
  200. Prop Weights
  201. Saito FA220
  202. Some 3-D and Scale flying at our field
  203. Aero Craft 30% Staudacher Parts
  204. Great Planes 25% Yak 54 Build Comments
  205. Great Support!!!!!!!!
  206. CAP-X
  207. Experienced Pilot needed in Southern Alabama
  208. How big is your field?
  209. H9 35% Extra - engine right thrust
  210. 50cc Edge 540 Scratch Build
  211. H9 35% Extra 260 Loose Stab ??
  212. Firewall - Epoxy or Gorilla Glue?
  213. SAITO 300 TWIN
  214. DA 150 Prop Bolts
  215. small gas plane? (kit)
  216. Houston HuckFest ALL 3D Nov 9-11 You In?
  217. inside a canister
  218. matchbox setup help
  219. Hanger 9 27% Extra 260
  220. SPE 26cc GAS motor & airframe- Info needed
  221. Great Planes 25% Yak CG Help
  222. CG YAK 77"
  223. Decals for ultimate bipe
  224. extra 330L 1,78m setup!!
  225. dual aileron connections
  226. 27%+50CC too much power?
  227. Composite-Arf 2.6m Yak or SD(AM)37.5 Yak?
  228. 35% Yak... DA 100 on full length pipes???
  229. Hucktoberfest
  230. ES Composites tuned pipes. Who's got 'em?
  231. electronics for 100cc advice needed
  232. 3 blade vs 2, Pors and Cons
  233. Nitroplanes Extra 330L-50cc
  234. best place to buy all the electronics?
  235. Hauling your plane
  236. Where to find a custom header?
  237. Ultra Giant Scale
  238. 33% Krill katana
  239. Extreme Aerobatic Club Cancels show doesn't tell anyone!! Hot Springs AR
  240. DA 100 Can muffler advice.
  241. Comp-ARF 3m Yak and SD(AM) 37.5% Yak Price!
  242. New ZDZ 210 for My 40%SD Yak
  243. Powerbox Royal twin Rx unit
  244. Battery Blew Up...Yak on fire
  245. Shipping Items for sale in RCU Marketplace
  246. Removable rudder
  247. Current draw 25%
  248. Delete
  249. Gyro? No gyro? 3D with a 33% Egde
  250. H-9 1/3 Sukhoi SU-31 Engine ??
