PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. MX2 test flight
  2. Life set up question
  3. 25% Edge 540 Retrofit
  4. Goldwing SBACH 30cc
  5. Parts for QQ 85
  6. SPINNER FOR 1/4 SCALE CUB
  7. DA 100 or 120?
  8. Looking for a Hanger 9 Sundowner 80" want to buy!
  9. Smoke on a 30cc Plane?
  10. SOUND LEVELS ON 42% PLANES
  11. Servos for a 35% yak?
  12. Nitroplanes 100cc yak 54?
  13. Extreme Flight Extra 300DA 50
  14. Back after 5 yrs away
  15. Wing Tubes
  16. Wing Tubes
  17. EG MX2 100cc Build
  18. MSX-R 30cc
  19. Byron Sukhoi 27% flutter
  20. Jtec 40% 330L Transport?????
  21. Yak 54 30% - What Futaba SERVOS ???
  22. Data manager for Royal Evo version 1.4
  23. lomcevak
  24. seagull harrier 3D to take 15cc/20cc petrol engine? help!
  25. Canopy for a Vision 3D
  26. Engine size for 1/4 scale Aeronca Champ
  27. Matching servos using the Tx
  28. Anyone lost or got stolen JR9303 PCM in the Bay Area
  29. Peak Model planes??
  30. VESS prop tiny damage - how serious is it?
  31. Lanier Cap 232 1.5
  32. Goldwing SBACH 30cc Tail issue
  33. Float Plane
  34. Giant scale with 2 recievers
  35. is vess 23A prop with Slimline pitts muffler good for 3d
  36. Need help to ID nitro motor
  37. What is best for 3d: 22x8, 23x8 or 22x10 on 50cc sd yak?
  38. bought a giant scale mx-s
  39. how to get over the pucker factor? Got it!!
  40. Lost Stabilizer half in flight-wake up call
  41. Pitts BULLDOG
  42. World Models Spinner
  43. RC Aerodyne Extra 330
  44. Hitec 7954SH on 7.4v unregulated lithium-ions?
  45. EMS Heavy Duty Switches
  46. Drill Guide Template Needed
  47. Carf yak 3m build custom scheme
  48. Modellbau Giant Gee Bee??
  49. Perry GA event, Looking for a few items!
  50. Giant Model Products Introduces a 50cc GeeBee R3 ARF
  51. looking for giant arf ,cub/telemaster etc.
  52. Goldwings MX2 30cc 3d arf anyone have one the built?
  53. What type, size control horns?
  54. 50cc Sukhoi
  55. Why the long servo arms
  56. 3/4 pound foam bulk order..who wants in?
  57. 30% Sbach - Are these servos sufficient?
  58. 29% World Models Cap 232 - GAS
  59. To smoke or not to smoke?
  60. weight of DA-50 and DL-50 ?
  61. RC Aero Still in buisness?
  62. DLE 30 plug cap
  63. ACE 1015 Servo
  64. lifetime of a lipo battery on a 3d 50cc
  65. OMP/EG Aircraft Raven 150cc
  66. 33% Landing Gear
  67. Golden Age ARF
  68. Need Ultimate Help
  69. Goldwing 30cc Sbach
  70. 85-DA and 35% Plane
  71. what is too windy for giant 3d?
  72. 30cc sbach control horns
  73. First Gas Plane Help
  74. extreame flight edge540t 88"
  75. NEW PowerBox Systems Kill Switch
  76. First gas model
  77. Metal servo arms
  78. DA-50 idle question
  79. Master Airscrew 22x10 Wood Prop
  80. How are your A123 packs doing?
  81. Regulator for a 50cc yak
  82. Problem with Graph Tech gear
  83. GP Patty Extra & Zenoah G-38
  84. WHAT HAPPENED TO THE ADS FOR RCU??
  85. pull-pull rudder cable question
  86. Aerotech 42% Slick 540 Build
  87. 2011 AeroWorks 100cc Edge 540 QB
  88. 50cc Decathlon
  89. Servo's EVERYWHERE... but which one?
  90. What is the engine power/weight ratio for sd model 50cc YAK
  91. DPM Edge 540- Will OS 160 fly it?
  92. Extra 300 50cc scratchbuilt
  93. Rrr, why can't I delete this post!!!
  94. gasser gor a 90 size dp ulti?
  95. PEAK R-C ........No Customer Support!!!
  96. 30cc Slipstream Yak 54?
  97. colors for katana s
  98. Jumping back in
  99. cap 21...CG?
  100. Need suggestions on 30cc plane
  101. Need Help: SD Model 50cc yak/Phoenix simulator YAK 54 question
  102. Need some 170cc setup advice
  103. Giant Scale Mechanical Retracts
  104. TopFlite P-51 w/ DA-50
  105. power distribution
  106. Best Carbon prop for 100cc Yak 2 blade
  107. AirWild 540 Edge
  108. Pilot R/C Extra 260 Quality and Service????
  109. New Sbach 342 - 90 inch
  110. Dynaflite Decathlon Engine question
  111. Asp/sc 120fs in adrenaline 120 plane will it be powerful enough???
  112. Parts for QQ 86" Yak
  113. E-Flite Extra 32 Assembly
  114. GP Yak-55M
  115. Kangke Pitts Python 50cc?
  116. HANGAR 9 BEAST
  117. Kudos to Pilot RC
  118. Sullivan Aluminum QD Ball links strong enough?
  119. G&L Sukhoi 26 50%
  120. check this out 40% custom extra
  121. Power Box
  122. 36% Ultimate balance issue
  123. SlipStream R/C Yak 54?
  124. 73" or 87" Sbach??
  125. 50cc PAU Pitts vs Aeroworks Ultimate?
  126. Horizon went big
  127. EG Aircraft
  128. Q on Pilot RC ARFs
  129. Comp-Arf 2.6m Edge 3D Monster- Anyone Flown one?
  130. Miles Reed Extra 260
  131. Question about cans
  132. tuned pipes for DA 170
  133. 42% Extra 260
  134. NEW Large Scale Retract Systems, PnP
  135. Hovering Help!!
  136. Battery question?
  137. Great Planes Yak-55M Sport/3D ARF 50-55cc,88"
  138. Solution XX
  139. best power setup??
  140. DA 100 throttle curve help
  141. Pilot rc 30cc Sbach.
  142. Need Comp-Arf cosmetic repair technique help
  143. superxtra with a DA-170
  144. An idea to power SEIKO servo
  145. Giant Aeromaster CG
  146. Sbach 342 drawing ...
  147. dle55 smoke?
  148. AK Models Extra260-100CC
  149. Extreme Flight Extra 300 or Aeroworks Extra 300
  150. Is Chief the only distributer for Pilot in the US
  151. Friday Night & Beer!
  152. ACE/HOBBICO
  153. radio question on failsafes futaba
  154. MEJZLIK AND PT MODELS CF 3 BLADE PROPS ???
  155. Extreme Flight 87" Yak cowl and U/C fix wanted
  156. Solution X - Dave Dessecker
  157. Number of servoc per elevator half on 40% planes
  158. Hitec HS-5665MH servos
  159. 50CC MX2 C.G. FOR 3D
  160. Who makes a nice 100cc size Ultimate bipe?
  161. 30% Peak 50cc Yak54-A V3
  162. Rudder flutter!!
  163. DLE30 and 1.20 Hanger 9 Cap 232
  164. BEST IN THE WEST JET RALLY
  165. REDWING RC MX2
  166. Peak Models
  167. NEW WEBSITE
  168. NEW WEBSITE
  169. Tempest MkV on the way!
  170. Donatas PauÅžuolis Freestyle Video
  171. KMC Tech YAK 54 Giant Scale 100CC ARF 102'Wingspan
  172. Pitts Viper
  173. Hangar 9 33% Edge 540 ARF and DA 100
  174. 33% Extra Control Horn Size
  175. Staudacher 90
  176. SBACH342
  177. Lanier Laser 200 33% kit completion
  178. DA 50.....best prop (needs more vertical)????
  179. lottery list
  180. Pink Panther Giant Scale 3D Foamy
  181. Rudder Servo Tray & Other Giant Scale Set-up Questions
  182. WTB Pilot-RC Yak 54 50cc
  183. Have this ever happen to you??
  184. QQ 102" YAK Gen II Recover/Build
  185. CA hinges Hmmmmm?
  186. 33% TT YAK
  187. Goose's 50cc Aeroworks Ultimate Assembly...
  188. H9 33% 232 help!
  189. dx7 programming travel throws question
  190. Help with Extra 300
  191. Best 30cc class engine for 3d?
  192. Structural Wing Failure; your opinion
  193. Li-Ion Battery Q
  194. building cub and modding one
  195. 35% Edge 540 or Yak
  196. Help A123 connector
  197. Dubro Kwik Links
  198. 50cc motor help
  199. Giant Scale 3D Plans
  200. Wing tube size
  201. LiFePo4 on my 30% Questiosn
  202. Extreme flight 78" or Gp 1.60?
  203. Throttle Servo
  204. LOOKING FOR WING BAGS FOR QQ'S PYTHON
  205. HELP with Dietrich Extra 260 50cc - Missing Parts
  206. Plane Cover
  207. Patty Wagstaff pilot 33%
  208. DA 150 Smoke help
  209. Pilot RC Sbach 342 (36%) or AeroWorrks Edge (35%)
  210. This ones for the Universe!
  211. Header Drop for Comp-Arf
  212. DPM Edge 540 manual
  213. Pilot 30cc SBACH with DLE 30 question
  214. plans for construction
  215. YS 160dz ~ advice
  216. Sbach 50cc Goldwing
  217. Composite Arf vs. Krill models
  218. Getting Started in Gas
  219. AEROWORKS TAIL HEAVY
  220. NEED INFO ON 86" CORBY STARLETT
  221. IDENTIFY THIS AIRPLANE....
  222. H9 46% Ultimate
  223. Prop Size US41
  224. PeakModel Sbach 300 30cc Build thread
  225. Thunder Tiger TOC 30% Pitts M12 build thread?
  226. Kangke Models**Buyers Beware**
  227. 30% OMO YAK 55 servos
  228. Jack Bally's B-17 ?
  229. New MXS-R
  230. Broken Rudder on H9 260 27%
  231. Yellow Aircraft Cap 10b Resurrection
  232. EG Frazer Raven 50cc
  233. Sebart Funtana 140
  234. Great Planes 1/3rd Cap Eagle 580 - CG ???
  235. Sullivan Skywriter Programing for JR
  236. Pilot Yak-rolling machine!!!
  237. Favorite plane
  238. Frank Knoll 38%Christen Eagle
  239. DELRO USA - Vogelsang Aeroscale presents the Delro line of ARFs and kits
  240. PAU vs Pilot RC
  241. Recommend good bipe for a 4.2
  242. PeakModel 30% Yak54 Version 3. Help me on my first build please.
  243. Robart Hinge Help
  244. Pilot 30% Extra 260
  245. Lanier/Godfrey Laser 33% Canopy
  246. Pull pull question
  247. pilot rc 40% sbach
  248. Pilot RC 30% YAk Graphics ?
  249. HV Servos for GS?
  250. Extra 300 balancing issue and power
