- 2.3m Extra perfect test flights.
- KISS(keep it simple stupid)!!!!!!!!!
- Miracle Switch constant drain caught me out - CRASH
- 8611 Metal servo wheel ?????
- Composite-Arf Trucking/Delivery??
- Cermark Pitts S2B Sources
- Aeronca Champ CG? WHERE?
- power box question
- 3W Votec 322...
- CA Yak 3.3 owners
- Models of the movie Aviator
- Faster TR's with 22 x 8 vs. 22 x 10
- Getting rid of wrinkles or small bubbles?
- Terry Nitch where are you?
- Double truss control horns
- PK Max props?
- Fore-Play vs. the Raptor3d
- Smart fly optical ignition cutoff setup
- JR 8103 and elevator setup question
- Giant Scale Building Data
- The CHIP HYDE VISION POST
- Builder Needed...
- H9 sukhoi/DA100/kill switch
- Anybody flying an ISC 1 800 Collect?
- My Tensor
- Deleted.. I found problem
- Need advise
- HELP!!!
- DV Rudder linkage & elevators hitting?
- 35% Carden Extra Build Pics
- CA Models Pitts Stinker
- Prop Trader
- 3.1 C-A 330 issues
- GS Wing Sheeting ?
- Aeroworks 36% katana stab tube diameter and length
- GP 1/3 Scale Matt Chapman Cap 580...
- 33% hanger 9 edge rdy...what kind of throws??
- What is the Difference between 3W-75 TOC and Stock???
- where can I find TOC videos
- minicraft taylorcraft available ?
- Josh Glavin ETOC video
- Coleman fuel in lieu of gasoline?
- Would TNT aluminum landing gear be better then stock on 1/3 scale?
- personal opinon??????
- Fromeco or Smart-Fly Adj.Reg/Switch?
- Who Sells Mejzlik Props Besides DA
- Midwest Extra
- Is the rubber band method to hold wing halves on a 1/3 size Cap OK?
- Best Smoke Pump>>>For Gasser's
- New 27% Extra 260
- BME Ultimate 37% - questions
- Need advise on G62, Please advise
- ZDZ 80 single too hot?
- SIG Spacewalker aerobatics
- Servo wire holders
- 87" Yak new video
- 2.6 EXTRA DIED THE SAME DAY THE POPE DID
- Number of servos run thru Receiver?
- Concealed flap linkage
- Where to get scale pilots?
- Carden 35% Balance
- What Radio?
- Let's see some Toledo pics !!
- bateries for my yellow p-47
- Jumping Jack Set Up for 3D
- CURTIS JENNY at Toledo 2005
- IMAC/3D type simulator: G2 or G3 ??? HELP CHOOSE
- Wing area of 27% CA Extra 300L
- Hangar 9 Extra 260 27% Scale ARF
- is the there an Old H9 Cap232 and new???
- Do you know when the price of DA-50 increased?
- Right thrust
- 1/4 Scale Nosen Citabria CG?
- Lipoly 2 Cell on Ignition???
- High speed digitals a must for 3-D?
- 31% AW Edge 540T--Few last questions?
- Anyone know where an Aeroworks 37% 300L kit might be?
- RCWingbags.com 2.6 YAK Bags arrived today!!
- Comp-ARF & DA100
- Dual Batteries Saved my Plane
- 1\3 scale spacewalker plans
- Motor box thickness?
- Updated DA 50 and servo mounting?
- Carbon Fiber
- GETTING BIGGER!!
- Balsa USA Cub as Super Cub
- Need help on a cowling size
- Foreplay & the Kevlar thread
- Anyone speak german? Engines in a Comp-ARF 2.3 & 2.6
- Programming a 9C and the Skywriter smoke pump .. help
- SIG YAK 18, 75"
- ZDZ 80 for H9 Edge or WH Extra 260?
- CA Glue on my canopy
- 87" extreme flight yak 54
- Byron Glasair RG
- I finally maidened my 1/3 GP Extra 330L!!!!
- Wing Fence on new scheme DV
- New 27% Extra 260 from H9!!!
- Help with GSP extra 300 engine choice
- GP Christen Eagle Aileron servo hook up
- lanier 30% edge canopy
- Looking for a set of Wingtote Ultimate Wingbags
- What engine for my new CA Yak 3.3??
- How much is this H9 ARF worth>>>
- 29% Aeroworks Edge (Kirby Chambliss)
- Thnak you for the help - First 28% plane
- scale size for 1/3 p-47?
- Giant Stinger rebuild update
- LANDING PROBLEMS
- My new DR Hobbies 2.6 composite extra
- Engine for 1/4 scale Tiger Moth
- Dual LiPo/Adjustable Regulators + Single Rx
- cg on my laser ?
- Lithiums- help!
- Will fuel leak out of ZDZ's 80 carb (Walbro) into the plane?
- Hanger 9 Edge 540, ZDZ-80, KS canister Build
- Why no big sukhoi's???
- 3W 106 Muffler install help....
- First Gasser
- Gas engines and Oil mixes
- 1/3 Pitts/HELP!!!!!!!!!
- Comp - Arf Throws ???????? 2.6 Extra
- Defuel gas powered planes
- Large bent wire Nose Gear
- AW 27% Ultimate smoke location
- Please help need some information on a manufacturer
- Anyone know Ron Duke, "olhippie"?
- Edge 26% - slight misalignment
- Comp-ARF Yak or AeroWorks Katana?
- Anyone using 6V regulators on 6V NIMH?
- DR Hobbies 40% Extra
- Bud Nosen Aeronca Champ plans needed
- Lightened Elevators
- Removing Oil from Composites?
- CHIP HYDE COMPETITION SERIES 300S
- C-ARF Pitts S-12 Oracle Scheme!
- Manual online now
- G3 vs Aerofly pro
- 42% Ultimate-H9 or Aeroworks?
- 3w 106 help.....
- Where to get a Mejzlik 28.5" x 12" 3-blade
- quite pipe on the MVVS 58?
- IS YOUR PILOT REALLY PROTECTED? PROTECT YOUR PILOT - USE THE NEW CANOPY CONDOM
- Spinner size for Comp-Arf Yak 2.6m
- H9 Super Cub + Quadra Q35?
- loving my h9 ultimate
- Rudder setup?
- Pro Zinger Props
- Canisters in a 33% Ultimate (World or Aeroworks)
- Dual receivers
- 1/4 SCALE CAP 232 FORUM
- Question on battery backup
- ALUMINUM (METAL) Large Scale Fuel Tees
- setting up dual 8611's????
- An other smoke pump question !
- ignition battery mounting
- Waco YMF
- I need a 3W-75 for my Comp Arf 2.3
- Edge 540T, Bent Wing Tube, replace?
- My CA34% extra 300 pics
- Next shipment of 87" EF Yaks?
- Fuel dot options
- Planes Plus 2.6M X-treme Composite Edge 540T?
- Aerostuff Carbon Fiber Rods
- Futaba and Hitec for Gs
- Covers
- Planes Plus Pro Series 27% Extra???
- Need Manual - Hangar 9 CAP-232 120 1/4 Scale
- Engine for Composite ARF 2.3m Extra
- Loaded Question about Carden or Composite ARF
- Any real reason for not using FM RX on GS models?
- What do you guys use for antenna exit tubes?
- gws servos
- which foam??
- Switch/Voltage Regulator
- Fromeco battery installation pic anyone?
- Robert Nelitz plans
- Edge 540t or Velox ?!?!?
- Pilot 96 inch w/s Decathalon-what engine?
- where is a modell building store in miami fl
- Regular 30 minute epoxy or Hysol
- Vids of SW Florida flying
- Balsa USA Sop pup
- Smoke system ???
- New to 1/4 scale, need suggestions
- Aeroworks 42% Ultimate ARF unusual question
- Full scale rc
- swb rudder horn
- Need a pilot figure for a 28% plane, can't find a nice one.
- Lateral Edge balancing?
- R.B.M. Extra 260 35%
- 3D stills
- Carbon Fiber and wood laminate plates.
- Servo Glitching...What is the problem???
- 87" EF Yak video thread!!!
- 2.6 yak hardware question
- Lanier Giles 202 37%
- DV firewall template
- Dave Patrick edge 28%
- Extreme Flight 87" Yak 54 - Cockpit Build
- Fuel filter question
- Carden Cap 232 posiable stab prob????
- Who makes wingbags for WM 33% Ultimate?
- Wanted: composite Sukhoi for DA-100
- ASSEMBLY TIPS FOR MONOCOUPE
- H9 73" CAP 232 at 5200 ft. engine question
- Composite-Arf SuperExtra 3.1 CG
- Need help finding pilot for MISS AMERICA P-51
- smoke system needed...
- Fuel system setup?
- fuel tank size for the CA34% extra300
- Aeroworks/WM 27% Ultimate Engine
- US 41cc in 1/4 scale Extra 300
- 5945 w/programer or 5945 with Equalizer
- Streamers on Biplane - two or four
- PROPELLER BLADE SEPERATION !!
- DPM 26% Edge-need tank on cg mounting ideas
- Thanks for the help
- Rudder Servo Rails - Got Wood?
- Balsa USA Ercoupe
- Fly-in scheduled for April 9
- OH NO, What is going on? Please Help!
- Control linkage hinge point
- Citabria Pro Finished
- CA hinges Vs HD Plastic
- JR/Horizon Great Service
- GP Cap 580 1/3 scale
- ULTIMATESPORT RC?
- 36%Edge help needed.
- H9 Super Cub---Magnum 120
- 5645s enough for a 40%
- Simple question for George, 6mm depron + Tensor
- Compa-Arf 2.6 Yak 55 vs. Extra
- comp arf 3.0 cans
- Who makes the best smoke pump?
- Required Servo Torque
- AeroPro Laser 200
- Trimming Help
- GP Christen Eagle Cabanes?
- 35% Carden Weight
- DA100 QUESTIONS
- D.V. wing tube
- Kangke Cap 232 Question
- Engine for Super Decathlon 96" Giantscaleplanes
- Big CAP in the future?
- What 25-28% plane to get next?
- 3w 140 4 cylinder??
- 3W 140 Problems
- columbo anderson 27% extra
