- Edge 540 weight
- Fiberglass fuse questions
- just went to order my wingbags from...
- DOUGLAS DC-6B /CONVAIR 440
- 5" ultimate spinner
- 1/5 Pica T-28 Question
- Check This Huge Bipe Out
- What battery to use?
- suggestions for a kit. see requirements.
- Zinger Props?
- Aero-Works Kits?
- servo selection
- engine problems please help
- Cockpit Detail for Beaver
- 3w extra almost done
- which glue for canopy to hatch on Edge?
- aileron counterbalance
- Servos for Midwest Extra 80" ??
- Airasys Models Turbo Raven
- Weeks Special or Solution?
- Another On Board Starter question
- DA-50 & Giant Ugly Stick
- Mathcbox? Is it really needed?
- On Board Starter Question
- Custom made landing gear
- Jr Y harness with amp.
- G Shark MK 2 CG
- 1/4 Cap
- Any info. on the Rearwin Speedster from Dymond RC?
- xf-11
- Hitec 5945 Output shaft.
- Giant Scale AT-6
- Anybody have experience of DA150 on Mufflers
- Monocoupe 90 ARF by Super Kraft?
- Dp Edge 540
- Will a 35% fit in a Ford Expedition?
- Edge 540
- Giant Scale Servo Output Shaft Support Kits?
- Looking for Stearman picture book
- 29% AW edge 540 empenage
- Northrop Gamma (maiden Fligth)
- Precedent Stampe
- Dual Servos on Split Elevator, Spacewalker
- 38% CA Extra Contruction
- Balancing a Giant Stinger
- ZN Line Extra 300 LX arrived
- GP Pitts
- TME Smoke Pump
- Pull Pull help on my 29% Edge !!!%$@#$%%
- H9 Edge 540 engine question?
- What does your H9 1/3 extra weigh?
- Floats for 1/4 scale Aeronca Champ
- Are IMP adj. control horns suitable for large planes?
- CF Gear, Can It Be Rejuvinated
- Shulman (2000) scheme
- First Flight For Hurley Extra!!
- Ace Extra 230 33% decals needed
- WM Extra 300 engine conversion
- need morrisey parts
- Starting my first Giant Scale
- Nieuport 28 Rib Stitching
- GP 1/5 CUB which gasser??
- Supermarine S6B
- Control Horns For GP Giant Extra 330
- Servo Extensions?
- Beechcraft Bonanza Lighting Kit
- Godfrey 35% Extra 300
- Nieuport 28 5 color camo scheme
- Right thrust on 35% Carden Extra 300s???
- Great Planes Giles
- 182on board glow systems
- Storing in trailers?/your opinion is valued
- 3W 150 RPM?? Mufflers????
- Is BME 50 too much for Sig Sukhoi???
- Elivator gliching on U-Can-do with gas moter?
- Composit-arf.com "fall out"
- Ziroli Stearman or Hostetler Liberty sport?
- Gp Pw Extra 300
- Ace 4-120 biplane
- tail wheels
- ZDZ 80 enough engine for Carden 35% Extra 330?
- Carbon Fiber Dome Mounting?
- Second Source for the Glass/Plastic Parts for the Mike Hurley Extra 300
- Me/Bf 109
- Fusco Models
- Best engine for 1/3 J-3 Cub?
- manual for H9 33% Cap
- Rutan Proteus Project
- Duralite Plus Batt. One four cell pack or two 2 cell?
- another quick antenna routing question
- mechanical retracts????
- What control horn works for you?
- Nwht Sale????
- Stinson update Pt 2
- BSUA Dr-1 elevators
- Can I run 2 servo wires in same tube to tail?
- 33% pilot bust
- balance on ohio rc 75" ultimate ????
- Pegasus - 320
- DP Edge 540t and Da-50?
- control horns
- Looking For C/F Wing Tubes
- Planes Plus...I am sorry
- Engine for Balsa USA Stearman PT-17
- Busa Dr-1
- 1st 1/4 scale (edge, extra, cap232)
- Which Extra Kit??
- Want to Try Obeche Sheeting 300 extra
- 1/3 Acrosport I kit or plans?
- Looking for this plane
- Sig extra 300XS and quieting the mvvs 1.6
- The Eagle Flies!!
- Engine for Byron Christen Eagle
- need EXTRA help....
- Meister FW-190 Landing Gear Product Improvement
- Taube
- Need Help w/3.7 D&B into a Carden Extra
- 3W extra 330s small model
- Carden 330 is covered
- composite landing gear
- What gas engine for H9 Edge 540???
- pic DR1 479/17 Leutnant Raben
- Rascal 110 Questions
- My FC 2.6 earned Its wings today
- Glasair III
- ZDZ 80 in H9 Cap 232
- Stinger fuse weight? &Plywood thickness
- Kirby Chambliss Edge 540 - Carden 40% - FINALLY DONE!!!
- Any coments on Laser Lizard kit cutters?
- WTBuy-1/4 Dubro Cub Wheels W/air valves
- bme 110
- ryan sta
- couple of questions for GP 1/4 scale G202 pilots
- Hangar 9 Edge final weight?
- Engine selection GB Y
- J-3 1/3 Scale Engine size?
- Completed 40% Carden Extra
- 40% Radiowave Extra 300LX
- Flybaby&US25
- Saito 1.00
- Sources of big 3 blade props?
- Best Extra for 85cc engine
- Anyone using Spectra pull-pulls?
- Moki 2.10 drive hub removal ?
- Dynaflite Giant Chipmunk Questions
- BEST TIRE FOR A 40%er ON PAVMENT
- MLP Airwild servo arms?
- Tail skid for Fokker DR1
- busa flybaby bipe
- Is the SIg Sukhoi fixed???
- Planes Plus
- Cowl Paint
- Bud Nosen Champ
- like to know
- Lazy ace info
- Creek Hobbies Sukhoi balance problem
- North West Hobby's Gee Bee R2 Help??!!
- Giant Mystery Trainer...Help!
- Modifying an Edge 540 to 540T??
- Kill Switch Help
- Extra 300 XS with a two-cylinder ZDZ
- Transition into giant scale
- Sheeting foam wing cores
- Cactus Aviation X-tra Fun 330. Who flies one??
- Giant Goldberg Tiger
- do you have bolly prop experience
- 1/4 giant scale trainer
- WH GilesG202/ZDZ80RV/in fuse cannister?
- Just got My GP Pitts
- Elevator Counterbalance LE shape on GP 330L
- h-9 taylorcraft power
- G&L ultimate bipe
- Hardware store aluminum Cabanes, strong enough for Ultimate?
- gp 1/3 pitts or the h9 1/3 sukhoi
- Robart Hinge ??
- Lanier Sukoi
- Engine quit during low hover
- Where to go in Houston??????
- whose quality?
- Ohio Rc Ultimate Bipe Templates
- servo extension body and pins and more info to make you own up. Follow up post
- Composite ARF models??
- H9 1/3 CAP - new batch from Chief
- Help Making Conversion from MW Extra S to XS
- dihedral in simmetrical wing? How the heck???
- W. Hostetler Lancair ES...
- 40% carden cap
- Carbon Fiber Props
- Hurley Extra real close/cont.
- Zenoah G26 - RF interferrence
- Pull-Pull Rudder
- Foam Wing Cores
- Lanier Cap 232 thumbs up!
- giant sweet and low stick
- Need Help With H-9 Sukhoi Set up
- TROUBLE STARTING AN ST-3000
- Carden and Covering
- Gas Engine for 1/5 Albatros C3
- Installing pull pull on the Edge 540
- Hurley 300LX
- Giant Mystery Trainer...HELP!!!
- Hurley 300LX
- H9 Giant Cessna 182 ARF 94"
- CA 31% Extra 300L ground clearance (or lack thereof)
- Aerotech 42% Velox Rev II
- OS 7H Carb information
- What's the current price and availability on the 27% CA Extra?
- Servos requirements question
- gasoline fuel pumps
- Can someone measure their H9 80" Cap Canopy?
- Whats up with Flyingthingz
- Bruce Lund Plans?
- Petemodel C.F Spinners?
- How often should servo gears be replaced?
- Gas or Glow for 81" Ultra Hots?
- HITEC RF ??'s
- Crashed my 24% CA extra 300L :(
- GSP Edge 540
- H9 Super Cub w/ G-38 pics
- Engine box questions...please help!
- pictures
- which manufacturer HELP!
- Giles202
- H9 Cap 232 or Sukhio
- Anyone Flying a Colombo Anderson Extra?
- Wendell Hostetler Jungmeister
- Custom engine stand for giant engines
- Wow!
- Ohio R/C Extra 300S (Very Proud Of)
- American Eagle webb page
- C G for Bud Nosen Citabria
- Great Planes 1/3 Scale Pitts
- Lanier Edge 540 & Zenoah G23 Hanson
- flat pinned hinges
- h9 taylorcraft HELP!
- Cobra Bipe pics
- Large wheels
- first gasser recomendations
- Lanier Cap 232 control throws
- Smoke Problems
- ZDZ60 single sensor installation??
- Yellow P-38 Kit Price?
- World Models Extra 300S Feedback...
- 1/4 Scale Set up site?
- Pics of the new Carden 35% are out!
- Reducing Weight
- Extra 330L Aileron hookup question (Help).
- Hanger 9 1\3 Cap 232 (Updated)
- How far back for CG on Wild Hare 35% Giles?
- Anyone have smoke on their 33% H9 cap or sukhoi?
