PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. VOTEC 2KRC.com LINDINGER.com PASONTEC.com wing FAILURE/update:OWNER BLACK MALIED INTO SILENCE
  2. Double truss control horns
  3. Nylon wing bolts??
  4. Giant Scale Building kits
  5. Yak54 Vs. Extra330. Which to get? Help my Build Please.
  6. preping for smoke
  7. Lanier RC 92" Giles 202
  8. Red Bull Near miss
  9. Which 50cc Yak 54 should I get?
  10. How to crate and ship 40% Carden?
  11. My 40% Carden CAP 232
  12. Matching HV servos
  13. what throttle servo for 100cc plane?
  14. Peak Model Edge 540 30CC????
  15. 2010 skymac vette city big birds
  16. The Amazing MX2-50cc - Red Aero RC - Build
  17. China(Cyclone) Single Seat Sbach300
  18. Hangar 9 SU26 85cc
  19. landing gear ?
  20. Digital Servo's (noise)
  21. Futaba 12FGA help - best way to set up 2 elevs
  22. 6 & 6.5" Turnbuckles
  23. mpi miracle switch problems?
  24. Building the new Nigel Lamb 50cc Breitling MXS-R
  25. Smoke Oil formulas
  26. Pilot RC 27% Extra 260 Servos
  27. Extra 260 ??? Aeroworks / EF / Pilot-RC
  28. H9 Extra 260 35% Servos etc?
  29. Gasservo Problems
  30. Match Box Question
  31. Need Fuel Tank Advice, please help!!!!
  32. how would you ship a giant plane like a 46% 110" long
  33. MT-57 help - please!
  34. Wow
  35. 27% question
  36. Zenoah 80 for a 33% Extra 260
  37. Seiko servo 105?050?
  38. Thinking about a 50cc F6F Hellcat
  39. 30cc Slipstream Sbach342
  40. hs 5645 on ailerons
  41. Glue in question..
  42. GP Ultimate or GP Pitts M12?
  43. 200 cc size ultimate - plans or kit?
  44. thrust anglepic
  45. QQ 85" right wing panel wanted
  46. 3W-85XiCS Dies after Snaps
  47. Really Long (9') Servo Extension
  48. Replacement Landing Gear?
  49. Power Box Royal
  50. Which BEC for a 2S lipo powered 50cc?
  51. pilot rc 73'yak
  52. Lanier Yak 54 87" COG??
  53. slipstream MX2 30cc
  54. How to repair a foam wing?
  55. ZDZ80RVJ vs DA85
  56. What size Battery for my 87" Lanier Yak 54
  57. How Do You Transport Your Large Aircraft?
  58. Battery Choice
  59. Jeff Foxworthy in his Laser 200
  60. pilot 30% extra 260
  61. best prop for a da150 with a 3m extra
  62. Velocity Stack for DL 100
  63. Electric Me 262 - 225cm span !
  64. 36% Edge 540 Indentification??
  65. Oldie but a goodie, WildHare Extra!
  66. Byron Pitts assembly manual
  67. TME Smoke system - Need to reduce output
  68. SIG BRAND XX HINGES
  69. NEW!! GW 50cc YAK-55sp quick build!!
  70. Control Surface Throws
  71. do you by chance know the manufacturer
  72. Great planes yak 54 25%
  73. Extreme 88" Extra Stab Problems
  74. 35% pull pull
  75. Desert Aircraft DA 60
  76. Giant Stinger...What Engine to Use??
  77. Where to find 4 inch rubber starter insert
  78. Aeroworks 100cc Edge Build Thread
  79. Ultra Stick Lite
  80. Wild Hare Edge wings get stuck on tube
  81. Recovering a 33% Extra 260
  82. Which RX battery
  83. Peak Model 50 CC Edge 540 T build
  84. W/H baby edge build!
  85. Can I go from micro 3d to giant scale 3d directly?
  86. Chip Hyde's Double Vision Wing Fences
  87. B-29 plans??
  88. Wing tube too tight - need suggestions please
  89. 3w 40% Extra 330 CG for 3d setup?
  90. What is the best profile/foam plane to practice with?
  91. Rudder for 50cc KMP Yak
  92. Need a carbon fiber stab tube for CompARF Super X
  93. Why cant you use an AR7000?
  94. Definine giant scale??
  95. Superior RC 33% yak 54 build thread
  96. Comp Arf 2.3 maiden flight
  97. IS THE NEW H9 BEAST HERE???
  98. Large plane C.G
  99. 50cc Wild Hare Giles
  100. In Shock.... Craigslist purchase story inside
  101. Fuel flow problem.
  102. My 50cc Aerobatic setup
  103. Which PowerExpander To Use
  104. top dawg edge is here
  105. 40% aeroworks EDGE-540 parts needed
  106. Good airplane for my ZDZ60?
  107. Suggestions for Edge/46GT Brillelli
  108. Need opinions on NiMh battery pack brands...
  109. Wilhare baby edge info needed/ help on gas in general
  110. Ace 1/3 scale Weeks Special help needed
  111. Ellipse props for RC?
  112. 3w 150ibF ignition module question
  113. Does anybody know what this is??????
  114. Pilot 1/3.5 Scale Pilot Bucker Jungman
  115. H9 CAP 232 33% - question
  116. Help: OMP 100 CC extra. Which header drop??
  117. 42% Products Lithium Ion Charger
  118. Extreme Flight 78" Extra
  119. nimh 5 cells 2000 6v + 5645+r617fs
  120. Hinges for removable rudder for 40% plane
  121. Any Station Wagon owners out there
  122. sdshobby?? ever heard of
  123. New Hitec Servo's - 600 + Oz of Torque
  124. WildHare 50cc MX2 Build
  125. RC League 33% Edge 540
  126. Wild Hare baby Edge.
  127. The most higher adrenaline video ever seen in my life !
  128. When should you stop using battery packs with a standard connector?
  129. PLEASE HELP (Lithium Ion Batteries)
  130. Pilot R/C 30% YAk 54 R.T.F,Weight!!!
  131. Help with large scale setup.
  132. anyone else thinks inverted harrier is the hardest maneuver?
  133. G&L hobies
  134. Flight - Model 35cc SU29
  135. Volt Magic
  136. Final a123 Setup for 30%
  137. inverted harriers
  138. Which power expander?
  139. Flying site near Sarasota Fl.
  140. Smoke Setup Question?
  141. top dawg 50cc edge
  142. help finding a 3d plane
  143. Aircraft International
  144. 7955 with a Y-Harness?
  145. ultimate biplane help
  146. Best 150cc IMAC?
  147. Question About Fromeco Balance
  148. Pilot RC Yak 54 33%
  149. Sky Aviation Super Star
  150. BYRON A-1 HUSKY
  151. CA Model Argentina
  152. Looking for Good Throttle Servo
  153. QQ Python CG issue (was
  154. weight difference
  155. Aeroworks Edge 540 QB Wins 1st place Mexico Freestyle Competition!
  156. need some servo help w/ GP cap 580
  157. Looking for a rudder for QQ 73" yak 54
  158. Red Aero MXS-R sigting
  159. GP Extra 1/4 (78") Owners, need help!!!
  160. RCU search engine: Good or Sucks
  161. pilot bust
  162. Any good plans for 50cc aerobatic planes out there?
  163. Shipping Large models
  164. ChickenStick Aviation - 50% Pitts M12 - ARF
  165. Lanier cap 232 80inch wing 79 1/2 fuse.
  166. Aeroworks Pitts Python Motor???????
  167. Anyone recognize the early aerobatic plane??
  168. A123's on ignitions
  169. QQ Beast Engine????
  170. 50cc Gas fuel tank size.
  171. Dietrich 300LP 39% or Carden CAP 232 40%
  172. Why would there be three on/off switches?
  173. What charger for 7.4v 2600mah 2-cell battery?
  174. Christen Eagle_ Color Scheme AND Pattern
  175. Optimizing Smoke System
  176. Aeroworks now carried by Tower Hobbies !?
  177. GIANT UGLY STICK
  178. best receiver batteries
  179. which battery for a 150cc extra
  180. Can I learn 3D at age 50
  181. Krill Katana 28% or CARF Yak55SP 2.1
  182. Krill Katana 28% or CARF Yak55SP 2.1
  183. 26% Pitts Python graphics needed
  184. Can anyone id the mfg of this YAK?
  185. looking for a cowling for 102" QQ Yak
  186. Custom Graphics for a 50cc
  187. How are you guys weighing your birds?
  188. Li-Po chargers Cellpro vs Ion cube
  189. Who was looking for Laser plans?
  190. DL55, DA50 Which is better?
  191. Wild Hare, EF Yak 88, Pilot All 50cc
  192. DLE 30 won't start. need help
  193. Anyone have a tower coupon forover $600 for me?
  194. Extreme Flight__88"__Edge 540T__Build
  195. Wings India 2010.... RC meet in India
  196. Where To Buy Large Fuel Dot???
  197. Need bottom wing for G.P. Christen Eagle!!
  198. Aeroworks at AMA Expo in California
  199. Pls Vote on my best CA poll
  200. 50cc A123 ignition/flight pack advice.
  201. Can Anyone Help Me Here ( Ultimate Biplane)
  202. Electronics for an 78
  203. Aero-works Kit plans for 29% EDGE
  204. CA Model Planes ON SALE
  205. MOVED: need help w/ dle 30
  206. "Aerobatics Made Easy" DVD with John Glezellis
  207. Can 2lbs make a difference
  208. Pilot RC SBach 87" or SDhobby SBach 87"
  209. Batteries
  210. Can't decide... 50cc OMP Yak 55 or Pilot Yak 54!!
  211. Testing Servo Strength
  212. Skywriter smoke pump question
  213. Hinge point installation
  214. Help with Pull-Pull setup
  215. looking at new 50cc planes need help
  216. Looking for 25%-30% kits.
  217. Pilot RC 30% Yak tailwheel-need good fix
  218. aerobatic maneuvers how-to
  219. Giant Scale CG?
  220. whats the best setup
  221. Are there any 30cc kits out there?
  222. Team OMP Extra 300 50cc Build
  223. Flight tech 8a voltage regulator (needs help)
  224. Has Anyone Ordered fromthis Company?
  225. OMP/EG Aircraft 30% Yak SP-55M build
  226. What is a good plane for 35cc Engine?
  227. GH Air Products
  228. Maiden Flight CARF Yak 55 2.1m
  229. Smoke System in 30cc Bird
  230. Testors Tansparent Black Window Tint?
  231. lipo or nicd
  232. Pilot RC 33% Yak
  233. How to drill servo holes?
  234. Powerbee Motor 100CC
  235. Slipstream 30cc MXS
  236. Exhaust vs. Cowl (noob question which goes on first)?
  237. Pilot RC Stienbach (Sbach) 342 29% 50cc
  238. Wanted, Great Planes 38% extra...
  239. torque rolling a yak on fms versus real life
  240. Small, Light Smoke Pump
  241. Video - PBRCA South East Big Bird '09
  242. New build
  243. Wild Hare Edge assembly with DLE30
  244. New H9 Ultimate is here!
  245. maiden flight trim rates???
  246. No Ignition Battery! - What? / Part II GasEngineKill
  247. Extreme Flight 110" Electric Yak
  248. which of these would be the best choice for entry level IMAC.
  249. A123 Power Setup
  250. Bob Dively 80 inch Pitts S2A?????
