PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Biplane trimming question
  2. Hitec's new 5995TG in DPM 40% Edge
  3. Nimh batteries downside???
  4. CompARF painter in DFW needed
  5. Hanger 9 Super Cub: Scotchguard the fabric covering??
  6. Light wheels for 27%
  7. Maidened the 3.3M Yak!
  8. fuel tubing for a da150
  9. Byron Husky OS 160 Gemini twin??
  10. looking for a 35% Extra (ARF) and need some help to find the right one !
  11. Custom pilot figures... where do I get?
  12. 3 Meter Comp ARF Extra Owners, what wingbag you using?
  13. Quadra-Aerrow 200 RSS
  14. hovering setup
  15. 3W Aircraft
  16. Acceptable Wing Gap Size and Wing Alignment
  17. ZDZ80 Single Looking for a home
  18. Engine for 108" Nosen Citabria ??
  19. Li-ion vs li-poly
  20. I need a JR throttle servo (standard size)
  21. Tuned cans for DA-150
  22. Lightening an Overbuilt 1/3 GP 330L
  23. Servo wire keepers
  24. Tapered Ailerons
  25. Planes Plus 34% Extra
  26. On-line kit instruction manuals
  27. DA-50-R Sources?
  28. Comp-arf phenolic horns
  29. Wing tube lube?
  30. UPS man got me
  31. Lanier Laser 200 1/4
  32. SWB website
  33. Hostetler C-421 flying Characteristics
  34. Best 50cc size kit
  35. Winter Projects-Lets see 'em--
  36. NiMh bat life? or li-ions in 27% 'er
  37. 8611's on 6 volts
  38. Texas Hurricane with Q42?
  39. Double Vision with ASP ?
  40. Biplane wing fences
  41. Customised Propeller
  42. 1/3 GP Pitts ARF wing failure
  43. How many STUPID mistakes can you count??
  44. YS 140 Exhaust
  45. Comp-arf shipping
  46. 40% Fly-Fan
  47. pdf file of PA-18 dynaflite
  48. 32.5% godfrey extra info
  49. vintage wheels
  50. Loose wing or stab tube
  51. Fast Fueler/ Check it out!
  52. Skytech Aviation Superstar 33%
  53. Columbo Anderson 34% Pitts Stinker, anyone built/flown?
  54. Two Questions
  55. 1/4 scale plans
  56. New Kit
  57. Palmer C-119G Info
  58. Aerotech Yaks are they out???
  59. Flybaby Bipe Info
  60. GEM2000 Blinking Light is Aggravating!
  61. Need Help with Rudder Pull-Pull Problem?
  62. JR 8411 0r 8611?
  63. shipping crate
  64. Best Plans or Builders Kit for a 35% Extra
  65. Graphite Carbon Fiber spinners
  66. DA 150 STALL- PLEASE HELP
  67. Servo Buzzing normal??????????
  68. PROP FOR 2.1 MOKI HELP
  69. Model Airplane News Looking for
  70. Any Ideas on Canopy Repair?
  71. HELP AUGUSTA, GEORGIA
  72. How do airplane companies ship 40% arf's??
  73. AIRWILD HOBBIES EDGE 540
  74. Looking for a HAN9 Taylorcraft
  75. Tensor and Ultimate servo
  76. Hitec HS 5995 or HS 5998
  77. Needa Pilot
  78. need plans for 72" German Strorch, high wing monoplane, ~ 1937-1940
  79. looking for plans 72" of German Strorch, High wing Monoplane, long landing gear, 1937-40 era
  80. Hitec servos w/ Karbonite gears
  81. Single Rudder Servo on 33%er
  82. DA 100 (mixture to rich)
  83. Servo reversing on elevator servo
  84. Need Pic of 1/3 GP Extra Cowl Bottom
  85. Futaba S9152 and S9153 servos
  86. Comp-arf 2.3m aileron differential
  87. CA 24%, 27% and 34% airplane gear mount Q
  88. Repairing Giant Cowl Gelcoat?
  89. Giant Scale Pilots...
  90. lithium batteries
  91. Wing Tube size for CA Extra 31% ?
  92. spare parts for chip hyde planes
  93. What paint to use?
  94. What radio for Sig 1/4 scale
  95. 3W vs. DA
  96. Close Call Today
  97. DA-50 Best wood for break-in
  98. Harrier horizontal ocillation
  99. Sullivan Skywriter?
  100. THANKS ALL - PLEASE ADD TO YOUR FAVORITES
  101. Da 100 perf
  102. Yellow Aircraft Giles G-300 120 Size
  103. Imac Introduction
  104. Electronic Setup in the Tail Area Question
  105. Carden 40% Edge coupling problem
  106. Plane Speeds
  107. Columbo Anderson 34% Extra
  108. Need help with rudder setup please
  109. Prop Bolt Pattern ZDZ vs DA?
  110. Columbo Anderson 34% Extra?
  111. New Prop Manufacturer
  112. "Giant" ARF for Q42?
  113. I'm just in a dead town
  114. Extra SFG's on Tensors
  115. Stolen Ultimate Composites SU-29
  116. H9 Ultimate is finally here
  117. Prince P-Tip Props?
  118. new planes
  119. Quadra 50 needs a plane??
  120. Comp-Arf 2.6m Yak With 3W106
  121. Servo's for Dynaflite Decathlon
  122. In Search of Cessna 170 1/4 or 1/3 scale plans
  123. hauling large planes to the field
  124. Zeno's War Bird Videos
  125. ST 2300 engine problems
  126. H9 SUPER CUB COWL 4 G26 QUESTION?
  127. I'm Back
  128. Comlombo Anderson
  129. Mobile Phone Control
  130. E-Flight,Brushless 370 outrunner ??
  131. Starting the dang Quadra 52
  132. Miles Reed Weeks Solution X
  133. GP Cap 580
  134. Dynaflite Decathlon & OS160 FX
  135. Newbie question on aileron servo
  136. Small, Cheap 25cc kit?
  137. Successful Comp Arf Yak flight
  138. G&L hobbies 28% 330
  139. Extra Special BME 50
  140. ZDZ 80 setup on 2.3 comp-arf
  141. Good Combo For Ryobi 31cc
  142. Satisfied Customer!
  143. DA 50 problem?
  144. DA-50 problem?
  145. Comp-ARF 2.6m Yak-55SP
  146. Whittier and flyin the SX
  147. Prop for Moki 1.8 in Giant Sudokohi
  148. CA 2.6 YAK - Maiden Weekend
  149. what Batteries to use ?
  150. Anyone flying the AW 50cc Katana?
  151. ZDZ-80 Baffling in H9 Edge/Extra
  152. I need a gasket
  153. DR Hobbies 2.6 Extra 330L
  154. best gas fueler
  155. h9 cap 232
  156. Where to get aerotrend fuel line?
  157. DA100 and TME smoke pump not smokin...
  158. Exclusiv-Modelbau Ultimate 1.85m
  159. CF gear for Edge 540T
  160. Ultimate building question..
  161. Battery setup
  162. Question for you CA 300L builders.
  163. Battery Charger
  164. Sig Ryan STA landing gear
  165. knight twister imperial
  166. Speed VS Torque
  167. Anyone using the new 420 oz hitec servo yet?
  168. Rascal 110 Opinions
  169. DA-100 or 3W-106
  170. HAS ANYONE REALLY HAD LI-IONS EXPLODE WHILE BEING CHARGED IN THEIR AIRPLANES?
  171. Seiko PS-050 servo Yak 3.3 composite arf
  172. Von Extra 260
  173. Fuel systems, how did you set yours up?
  174. Customized H9 Cap 232!
  175. LITHIUM-ION REMOVEAL FOR CHARGING
  176. Stinger 120
  177. Edge 540 CG with CF gear?
  178. CG on Extra Special
  179. Buying used large scale planes?
  180. Kill switch options
  181. New to Gas, have questions about exhausts
  182. CH Double Vison hatch and canopy. Needed
  183. Benefits of flat airfoil for indoor 3D????
  184. La ferte - 1/2 scale Tigermoth
  185. 50CC Plane Wildhare, Aerotech, or Great Planes
  186. DA-100
  187. US41 ?
  188. DA-50 vs. BME 50
  189. L@@king for a GIANT SCALE Christen Eagle
  190. GP Super Stearman question
  191. Typical fuel consumption for small gasser
  192. Engine swap
  193. Aerotech 35% Kits
  194. Looking for a 1/3 TravelAir Mystery Ship
  195. Laser 200 Question
  196. aileron servos in a 34% colombo extra
  197. WHY DOES it require to have engine offset?
  198. PP or WH 28% performance
  199. 3D Foamy Raven Video
  200. first giant builder with some questions
  201. Dynaflite Super Decathlon Kit
  202. chip hyde forum a joke
  203. 33% Aircraft
  204. Comp-Arf 2.6 Spar core
  205. 1/4 cub wheels
  206. Matching Servos - Help me out?
  207. 38% Laser 200
  208. Li po charger
  209. Something Different, BIG BINGO BIPE
  210. My HANGAR9 Edge 540 Gripe
  211. Hinge Gap
  212. 9C vs 7C Futaba
  213. Aerotech Velox 84" - need comments
  214. Batteries/Isolator: what Would You Do, and why?
  215. Help me build a 80 Inch Extra !!
  216. 3W 3D Prop??
  217. New 3.1m SuperXtra Scheme!!
  218. Edge 540 T will it fit
  219. Question on hinge spacing for 31% Edge?
  220. Funtana 40 severos ?
  221. Midwest extra 300 XS with wing tube
  222. Vert punch F3A VS 2.3 comp air
  223. Aerotech 81" Velox and canister
  224. 40% Edge VID!! #3
  225. shipping planes in a box
  226. sparkplug-gap Moki 45cc ??
  227. 3W56ib2 and ZDZ50NG
  228. Belt Drive Prop Reduction
  229. New Radiowave 40% Extra Video
  230. hovering
  231. Ultimate Bi-plane
  232. Down-line Fuel Draw
  233. Shippement !
  234. ultimate won't knife edge, horrible invert????
  235. Best prop ZDZ80 3D
  236. HELP!!! Can't Find Lawnboy!!!! Alternatives???
  237. Need Some 35% Help?
  238. tensor for gorge
  239. futaba 9206 on comp arf 2.3??
  240. 106" Aeronica
  241. What would you do??!!
  242. H9 Ultimate Finally Finished
  243. Smoke and lots of it!!!
  244. Fuel efficient gas engine for UAV
  245. my new 3w 37 % QS yak
  246. Sig 1/3 Scale Spacewalker ?
  247. Engine Offset for 3.3 YAK and DA 150
  248. CARBON FIBRE AND HEAT
  249. Current Draw For 8611
  250. Engine for Composite-ARF 2.3
