PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Big Plane Newbie. Help please
  2. 4-40 solder linkage, what type/(% of silver) of solder to use?
  3. Carbon Fiber tuned pipe?
  4. What happened to Maudib?
  5. Prop for 3W 106
  6. NEW!! EXTREME FLIGHT 123" EXTRA BUILD !!
  7. Hot Cowl Air into the Fuse.
  8. servo selection
  9. where is cheepest place to get Hitec servos
  10. best brand of 22-23" props?
  11. Fuel tank/clunk set up question
  12. Recommend a good plane for a DA50
  13. Super Stinker kit?
  14. SD/toc 40% extra 260 or airwild 40% suk
  15. Pardon me while I rant
  16. I really like my Moki.... where can I get another?
  17. Extra 2x2 electric install pics.
  18. Two Fuel Tanks on a gasser - How
  19. Extreme Flight website experiencing technical difficulties
  20. Spektrum Li-Po Receiver/Ignition Packs
  21. Large scale Pitts plans?
  22. When the radio does it and not you. What do you think?
  23. Comp arf 2x2M cockpit ideas please.....
  24. Wellll???
  25. Cermark 50 cc Sukhoi
  26. Witch GS Bipe for Sport/Aerobatics
  27. Built Notes Hanger 9 Carden Yak
  28. Double post-Please delete
  29. Smoke System Help Needed!!!
  30. H9 33% Cap manual??
  31. Cant Fly 3D in Miami
  32. PowerBox smoke pump!
  33. Aluminum Smoke & Gas Dots
  34. Am I the only one still using NiCads on ignitions???
  35. A123 cells at Napa Auto Parts...
  36. piled up my 1/4 scale now what
  37. Playing in the back yard !!
  38. Smoke fluid shelf life???
  39. H9 Extra 260 wing tube problems
  40. Throttle servo
  41. Cactus aviation / 3W Super Chipmunk info ??
  42. Is anyone still flying the Gene Soucy 1.60 Extra 300S?
  43. Servo reversing problem
  44. Sig Cap231EX motor question...
  45. which crystal with FMA receiver (FS8 co-pilot)?
  46. SD Engines
  47. Help on cg location and throws for a nitroplanes Extra 330L
  48. Suggestions for a Moki1.8
  49. BME or PAU 27% Pitts Challenger ???
  50. Airfoil for 40% large scale
  51. Balancing CMP 50 cc Edge 540 T
  52. Aeroworks 40% Yak 54 150cc QB
  53. Smoke Pump Question
  54. EXTRA 330S WITH GAS ENGINE!!!
  55. DuBro 1/4 Scale Pin Hinges
  56. Control Linkages
  57. Matt Chapman 33% Cap 580
  58. Looking for advice on 3D/IMAC plane
  59. RC flight school to learn IMAC - Feedback needed
  60. Magic Hand planes?
  61. 68-70 inch 3D edge
  62. 40% Carden Edge - weight reduction
  63. BATTERY BURNING!!!!
  64. ANNOUNCING
  65. EF 50CC Extra in an Acura???
  66. Easy Flying ARF for G-38?
  67. Futaba Heat issue with reciever
  68. help for rookie first 1/3 scale build
  69. Edge, 50cc
  70. Online store that takes PayPal?
  71. 33% Edge tail waggle in level flight.
  72. Metal gears or plastic gears servos
  73. props, where's the best place to purchase?
  74. Nitro Models 50cc Ultimate
  75. My new H-9 35% 260 Extra SUCKS
  76. TOC Extreme
  77. Smoke Question
  78. Build Thread: New QQ-Yak 54 101", DA-85
  79. Muffler, canister, and tuned pipe, which is the best?
  80. Battery Size
  81. Dad's or Aero Express Trailer
  82. DA170 Plane - Dietrich and Radiowave
  83. HELP My new 34% Extra 300 SUCKS
  84. ef 88' yak or ef 88' extra wich flys better
  85. Yak 54 86" e 89"
  86. Ohio Models replacement cowl and canopy?
  87. Having a problem proforming the elevator maneuver
  88. What size Carbon fiber tube??
  89. Problem balancing my GP PW Extra 25%
  90. Sports Aviation Corby Starlet ARF
  91. Extensions
  92. CMP Extra300S
  93. Troy Built Models‏
  94. Li-Ion shortage...now what?
  95. FORUM CLOSED
  96. canopy covers????
  97. what's the best deal for first gaint 3d r
  98. Scratch built Sukhoi engine.
  99. Anyone Built Harold Osbornes 74" WS Westland Whirlwind...
  100. H9 Cub 40 size??
  101. Power System Question
  102. Double receivers with 2,4 GHz?
  103. What's a good 'smaller' gasser?
  104. DELRO XXL RAVEN 3.1meters wingspan
  105. 2008 skymac vette city big bird giant scale meet
  106. Please help with this guys
  107. metric wing tube source?
  108. Looking for a 40%
  109. What switches for A123 batteries
  110. Flying Wires
  111. Need I.D. help
  112. Smoke tap in MTW header
  113. Fuel Odor
  114. Receiver battery next to DA Ignition?
  115. I4c and 2.4
  116. 35cc Aeroworks Extra 300 - Electric Conversion
  117. Need a measurement on DA-85
  118. Ikon N'wst Monocoupe D-145
  119. Ready to maiden
  120. Securing Planes in Trailers
  121. HELP!
  122. What Plane do I Fly?
  123. Crazy 3D in Puerto Rico
  124. Extreme Flight Extra 300 and 3W-55I??
  125. Cutting out bays on a foam core wing to lose weight?
  126. Pull-Pull systems
  127. Cheap! But will it fit?
  128. Byron Cap 231 flight performance needed
  129. Another 3M 330 Video
  130. JR 8711 servos
  131. How do you fly
  132. new cmp 540 edge T 50 cc fly problems need answers
  133. 3M 330 Vid
  134. Robart R780 Radial. Who is using this engine
  135. Aeroworks 33% Ultimate
  136. Pitts Maiden - Threadlock?
  137. Hopper Tank??
  138. os 160 starting issues
  139. Which 50cc Yak????
  140. What to do with plane?
  141. Turbine Toucan
  142. Nice pic
  143. Joe Nall Thurs 15th Photo flood
  144. PITTS 12 cactus aviation
  145. GlobalHawk Wings and fuselage connecting problem
  146. expo question
  147. Giant scale Hardware
  148. cml extra 260
  149. Magic Hand Yak
  150. Throttle servo
  151. Spinner for a pusher propeller.
  152. 88" ef extra
  153. Aeroworks support
  154. Glens 30% Cap 232 cowl.
  155. Lookint for Aerobatic Performers
  156. Wing incidence adjuster-where to buy?
  157. "throttle hold" on 50cc
  158. Flying Styles of the Different EXTRAS
  159. Help with hangar 9 extra 35%
  160. A123 and smoke pump
  161. Receiver/Ignition power system for 75cc Extra 260 help...
  162. yak 54 for a g-26 needed
  163. Best 50 to 55cc engine
  164. Pull- Pull play
  165. carbon fiber pushrods
  166. Mejzlik 23x8
  167. Horizontal stabs
  168. Stalling the H9 Extra 260
  169. BME Edge 540 version 1 (video - fresh video soon))
  170. Parts needed for 50cc Yak
  171. Dietrich 50cc extra 260
  172. Why do I get a porpus during an elevator?
  173. Looking for a specific video
  174. what do you use?
  175. Ganging 5955TG's on the rudder
  176. Zenoah G-38 Engine Kill Switch
  177. MacDills Air Fest (Pictures)
  178. A few a123 Q's
  179. I Need Servo Advice
  180. PAU 30% Edge 540
  181. A123 Chargers
  182. Please delete
  183. Messed up my engine mount. Now what?
  184. Katana S 140 form Nitroplanes
  185. w to gas planes
  186. New to gas/giant scale
  187. what plane for my os 160 fx and why
  188. Zillah, Washington Spring big bird pictures (ALOT)
  189. Major issue wiith Spektrum 9100 and JR Y-harness
  190. 6 Volt NIMH
  191. Wright RC/Virtual cockpits no response?
  192. Showroom finish
  193. PAU Extra 330 Ultracote colors
  194. Great Planes 1/3 Pitts
  195. Looking to contact Sean McMurtry
  196. DA 50/BME Yak
  197. your thoughts on full power run-ups
  198. Need Wing
  199. R/C Extra's 1/3 scale Extra 230 Kit
  200. Funtana 90 with a spe 26cc Gas motor
  201. H9/Carden Yak 54
  202. How do I break in a brand new 3W106?
  203. JR 8711 Jitter's
  204. rx battery for my servo setup?
  205. Flyboy Models Edge 540 75" Build
  206. Aeroworks 75cc YAK54 Quickbuild Thread
  207. SF power expander tip. Safety first.
  208. smart fly power expander?????
  209. Tell me about this 50cc Katana please
  210. How many times a week do you fly?
  211. Still no regulators, going strong
  212. Burble During Inverted Flight
  213. First Giant scale problems
  214. Aero Works Python actual weight????
  215. What RPM should I be looking for with my 160FX?
  216. A123 Help
  217. Cutting CF wing tubes
  218. Lanier Yak 54 ARF 94" 3 part...
  219. Tail Hook?
  220. 3D wing for 84" Extra
  221. 35 % and 40% Aerobatic Airplane Weights
  222. Futaba with Hitec servos in giant scale planes
  223. 120 2stroke smoke?
  224. What spinner? H9 33%
  225. Is it too early to start waiting for a 111" EF Extra?
  226. 400 ft. runway
  227. VQ Cap10b
  228. Replacing Robart hinges
  229. CG Projection from tip to fuse
  230. Antenna in Turtle Deck?
  231. Does anyone use 3 bladed props for their 3D/Aerobatic planes?
  232. Thrill with a Giles 202
  233. OMP Hybrid Edge 540 Build
  234. 27% Extra or 89" Carden Yak 54
  235. Great Planes 27% Extra 330S
  236. 'How should I expect this thing to fly???
  237. Aeropro Laser 200 manual
  238. How do u fasten your planes in the trailer?
  239. YAK 54 QUESTION
  240. Dual receiver packs and ignition
  241. Hitec 5985 lock up
  242. Rx and ignition battery packs
  243. YouthMasters in Florida
  244. 150cc AW Yak 54 and 2.4 DX7 Radio
  245. ZDZ-80 Muffler Bolts
  246. Landing to hot, I'm at a loss on what to do...
  247. Servo Chatter JR8711
  248. Flying sites in north New Jersey
  249. 3W Extra 300 - Toledo winner !
  250. Lanier Giant Stinger ARF
