- CARDEN 35% EXTRA OR EDGE
- Anybody with a Technopower Engine
- RV-3 anyone?
- CG position for an AeroWorks 31% Edge...???
- Best way to add trim ???
- FMA Receiver
- Comp ARF Extra 2 X 2
- Giant Scalers near Ft Pierce, Fl?
- 3-view drawing of a Edge 540T
- SWB arms... Gear Puller?
- Pilot head
- 30% Super Cub - Engine options?
- Engine for Carden Extra 300s 35%
- Pacific Aeromodels 27% Edge 540T ARF
- Throttle curve?
- Radio Setup questions
- CA Extra 300L 27% build sites or threads?
- Aeroworks 36% Katana
- Fromeco Batteries--New and Improved Poll
- Plans for Giant scale corsair?
- Comp-Arf 3m Stab tube
- Ultimate needs an engine?
- Mounting DA100
- World Models 28% Extra 330L
- TOC Aviation YAK 30%
- need a aluminum engine standoff fo DA100...
- SIAI Marchetti SF-260
- THROTTLE SERVO ON ENGINE BOX
- Comp ARF 3.1 SX question.
- Help with fiber glass?
- New Berg / Sombra RXs in the Heavy Iron
- Giant Scale High Wing Gas Trainer?
- Comp Arf 2.3 & 3.0 Carbon fiber wing tube?
- deBolt 1/3 scale RV-4
- Ultimate Done
- Hanger 9 Cap 232 questions
- X-Wing Bi-Plane Help
- 3W 75---anybody have one--?
- 50mm Carbon Fiber Wing Tube...where you get one?
- who here can build me an airplane?
- Pilot busts from litepilots.com!
- New Plane
- Single HITEC 5955 per surface
- 1/3 Waco
- Composite Arf 40% Extra Delaminated Firewall
- What a difference letters make
- Radio/ Power problem...
- What engine for a CA Yak 3.3?
- Delta CG
- Straight pair of wings ?
- How did you become the person you are today
- mike mcconville
- double vision video
- best setup servos for a 40%
- A pox on Zinger
- Ultra Stick Lite CG??
- Plane Fever
- Good Job Kickin our Buts and the Red Barons Fly In Josh
- Axle with Longer Treaded Shaft
- tensor landing gear advice
- Bal G+L Ultimate 10-300
- JR Challenge 2005 coverage?
- 46% Ultimate
- Help! dual rx.
- GP 330L engine installation
- Tensor Rec. CG?
- Hot new stuff from Comp-ARF
- Byron Originals Pitts Special
- How to properly make a dual receiver system?
- 1/4 scale Extra 260 ready for maiden
- PLANES PLUS EXTRA 330L
- Help with Biela 25X12 on DA100
- Super Servo in SuperExtra...
- WM 27% Ultimate
- Carden 35% Extra 330 CG problem
- quadra hub help!
- IMAA 're-up'?
- Christen eagle
- MOVED: Carden Builders, Help !!!
- Carden Extra, Fuel dot mounting
- Ziroli stuka engine options
- Why use a Matchbox/Equaliser???
- Now THIS is Customer Service!
- What exponentials do you usually use on big Extras?
- What is the procedure for balancing a 3 balde prop?
- what kind is it, what size engine to use?
- 33% Ultimate - Aeroworks or BME or Other?
- Ideal home for a NIB ZDZ 40
- Carden 35% extra Prop
- Dave patrick 40% edge 540T setup. little help please
- Bolly props and zdz 80 single
- tensor fly in neighborhood
- Airtronics / futaba
- Video: Hanger 9 Extra 330 with a GT80
- WRAM Show
- Cap X radio setups
- Chief Aircraft Extra 300S 140 ARF
- Best HD battery switch for a Giant plane?
- Is the Lanier Taylorcraft a good airplane?
- fPlastic screws and nuts!
- Somenzini 37.4% Yak
- PLEASE HELP : Hanger 9 extra 330L
- One Wrap Stretch Velcro?
- can I have a fully 3D capable 40% plane for 6000$?
- H9 46% Ultimate Bulldog
- Your Thoughts on Sealing Hinge Gaps
- Tail wheels
- Fly Baby Build
- Foreplay
- Giant A/C Cradle
- H9 33% Cap 232 engine size ?
- Engine Standoffs
- Comp-Arf 3 meter build threads
- 25mm Wing Tube Needed
- hitec 5955 y harness?
- comp arf 3.0 owners balancing
- Need help from you gas gurus!
- INSTALLATION OF THE ZDZ 80RV single IGNITION UNIT
- CLOSED
- using a jr matchbox??
- RCS 215 Radial
- YS 120
- torque rolling and special trim
- construction ultimate 46%
- My first gas plane for IMAC
- H9 Ultimate-ALL FINISHED
- DRILLING FOR CONTROL HORNS
- 42% ultimate
- Redundancy on a 35%???
- carden 35% balance point??
- Flying without a cowl?
- J’Tec 40% Extra 330L – Awesome!
- 1/3 scale waco closed cabin bi-plane plans
- suggestions on covering 1/3 sopwith pup
- Aeroworks 25% Edge Question
- going to buy a trailer
- World Models 27% Ultimate
- Chip Hyde Double Vision Official New Scheme Preview
- Knife Edge spin
- Low & Hi Needles on ZDZ80RV
- Carden or Kit Builders!
- What Should my incidences be on the Double Vision?
- Double Vision Engine Set up
- Ultracote / Oracover
- CG location for Nosen 1/4 Citabria
- Exclusiv-Modellbau Ultimate
- CA Models 24% Extra 300L
- Manual for Midwest Extra
- Ultracote cub yellow paint
- Single Aileron servo position on a 34% extra
- El Bandido
- Radio setup question for my first 1/4 scale.
- Need a measurement from the AW 27% Ultimate
- 35% dual receiver setup
- How is Planesplus Pro Extra 27%?
- Programmable Mix Article
- Funtana90 thrust angle problem????
- 35% Cost?!
- 2nd Question regarding Carden
- Composite-Arf Wing & Stab Control Horn ???
- Pull-pull Controls
- MOVED: Carden Cuda Suggestions
- DPM Edge 540T 26% - two questions
- Giant ARF`S
- My Fleet
- Super Decathlon 96" ARC Giantscaleplanes
- Least expesive ARF?
- Gas Smoke Muffler Question
- Aerofly Pro Deluxe - what large plane
- Question on Pull-Pull Cable Slack
- airwild 38% Giles questions
- I made the plunge
- need some help Edge 540 33% Hanger 9?
- Parts for CA Model Etra 300L
- Fore-Play help
- NX-Pro vs. regular NX
- George-Good Luck at Memphis and ETOC
- My Frist Giant Scale.
- How many amps can a receiver handle?
- anyone know who makes this arf ?
- New to 1/4 Scale! Help!
- Aeroworks 33% Ultimate servo extensions?
- What size prop?
- How much right thrust and down thrust?
- Tensor Video
- 2.6 Comp Arf Engine Baffle
- Construction question
- category III aircraft
- Hey Chip, any upgrades on.....
- Chip Hyde Foreplay
- Wing loading on a big bird?
- Aerotech Customer Service....
- Giant Stinger
- KPM dh Beaver
- Wing Incedence
- Comp-ARF 2.6 Yak
- bme 30% edge 540 with bme 50
- C-ARF SuperXtra 3.1m
- GSP Sukhoi 31 96"
- carden 35%, da 100 and a choke servo
- Tribute and Astro 010 geared
- Full throtle knife edge snap on giant scale. Should I worry?
- H9 Taylorcraft & OS 1.60 FX/Moki 1.35
- D.W. Aircraft ???????
- POLL: Should we break "Giant Aircraft" into Giant Aerobatics & Giant Planes?
- P-Mix question
- Hangar 9 46% Ultimate questions
- TO SOLDER...OR NOT TO SOLDER
- hitec 5945's
- Battery access for voltage checking?
- Aeroworks 27% Ultimate Whats up with these elevator halves?
- More questions
- Pull-Pull hardware for rudder
- Sky writer smoker set-up
- is this to heavy for a Spacewalker II
- Figuring out starting point for throws.
- SkyWriter Smoke System & Futaba
- comp-arf 2.3 extra or WH 28% edge
- Experiences with Y/A Spitfire Mark XIV
- Wildhare 35% or Composite 2.6?
- ARIA Mount for OS140RX
- Engine thrust angle / adverse yaw
- ProCraft (OHIO RC) Ultimate 77" Setup
- Balancing props
- WHAT EVER HAPPENED TO KITS?????
- Dalton Aviation 42 % extra
- Anyone going to the XFC this year??
- my new midwest extra 300
- New RC Universe Member Video Post! Submit links to your videos to post instantly
- Aeroworks 27% Ultimate "first crash"
- Ace 4-120
- Cary Lingo
- Smoke - Muffler Question
- Bridi Big Bee
- C-ARF Extra 2.6/ZDZ80 Video???
- Building my own HUGE plane
- Aerotech 35% Yak?
- Electronics for a 35% plane?!?!?
- CAP X manual
- Composite ARF Pitts Biplane / Anyone?
- Chip Hyde CAP X
- what's the 411 on the Carden YAK
- JJ
- Charlie Hilliard Pitts graphics
- Pilot for 35% extra
- wild hare giles g-202 setup for 3D with a zdz 80 single
- Pull-Pull cable length?
- Ultra-RC Problem
- Should I place my throttle servo on the engine box?
