- CF gear for a CA Extra 38%?
- GS Flyers - Check your batts!!!
- "New" Pull-Pull Rudder Setup
- Help?Dave Patrick Edge/ST-3250
- Radios
- My newest plane!!
- Did I have enough servo?
- dp 300 gets da50, need help w/ set up
- Crazy Pilots
- MVVS 35?
- single or dual rudder setup on 28% edge
- need cambria 1/4 scale piper tri pacer sheet 1[fuse]
- dual servo aileron and dual servo stab help
- Hinges on 29%
- Throttle servo speed
- Moki 1.80 or Zenoah G38??
- wing retainers.
- Aerotech-rcmodels 35% velox Revolution II
- Heli-world
- Air Wild 540
- Need help on servo throws.
- Peter Goldsmith's Email address
- Straight or twisted Servo extensions
- Proud new parent!!!!
- 2 transmitters?
- Were to put the rx switch and kill switch?
- Balsa USA Stingray and Thunderbug 120?
- Carden three view needed
- Spitfire 1/4
- Comp-Arf and radio interference problems??
- Giant Scale in Houston area?
- Smoke system problem
- 35% pirate cap, help needed!!!
- laniar cap 232
- GIANT SCALE B-17 ARF NO WAY??
- Gas throttle Curve Help?
- 1/3 H9 Edge540 Video
- Looking for a place to buy large planes and equiment
- Weeks Solution Engine Choice
- AeroTech 35% Edge 540
- Byron Wedell-Williams decals
- Sukoi
- 2.6 Comp arf right thrust ?
- Dave Patrick Service- Excellant, dude
- Pictures behide the gas tank section
- BME 110X settings question
- DIY Instrument Panel for Extra 330
- OMP 80" Edge 540 Profile Kit +SP 3250
- Servos & Amp draw
- Chip Hyde in Brazil ??
- Midwest Extra CG
- gas engine in h9 540 help
- Rally of Giants
- Servos For A Mustang
- The PUP FLIES!!!! (movie)
- WH 28% Edge control throws
- Wing bags
- 3.1m Super-Xtra is in the House!
- Help! Need rib templates for Ohio R/C 72" Extra 300L
- Hangar 9 330s vs. ???
- Extensions for Edge 540
- A Question About Giant Scale Purchases
- PowerFlite Batteries Warning
- I have a new 38% CA Extra kit, anyone ever build one?
- 1/4 scale h9 540 edge gas engine advise
- Lets talk about servos
- I'm going crazy, cant figure out why its short
- Height of WH 28% Edge
- sure-link arms
- Throttle servos....
- Electric Start - Fuji 64cc - Pitts
- Engine Mounting Bolts
- Biggest ARF on the market??
- flying in St Louis on 6/26
- EASE OF BUILDING A COMP-ARF???
- Wing tubes tight?
- Poor vertical power with DA-50 on WH Extra Special 28%(Updated)
- 36% 3W Extra
- Eng. and servos for Cub
- Firewall reinforcement plates on Hanger 9 Cap 232. Is it nessessary?
- Air Tractor AT502b 1/3 scale
- 2.3m extra vid!
- Need Plans for Howard Mike 1/4 0r 1/3 scale
- Is the DV IMAC Legal??
- Is this legal for IMAC
- Midwest Extra 300s: Joining the wing
- Rob' Extreme Trailer Set Up
- H9 Edge 540
- 30% C.G. Ultimate
- XFC!
- BME Pitts Challenger
- Sheeted Foam Wing vs Built-up Wing????
- SMOKE
- Props that perform as well as MENZs
- MPI switch help....PLEASE!!!
- Comp-ARF 2.6m
- composite arf 2.3 extra with DA50.....WOW!!
- Precision Aerobatics 84" Edge 540T????
- KANGKE
- kit builders
- Vehicle choices for hauling a 40%
- Lanier Giles 202, any good?
- extra 260
- Ant location
- new 35% carden - engine choices??
- Colombo Anderson 38% extra
- MOVING ON UP - WHAT'S THE BEST 35% COMPOSITE AIRPLANE??
- Starting H9 extra 33% #2 new tips?
- Composite-Arf Super-Xtra Vid
- X-special is treating me great
- Using one servo on a two servo wing.
- 28% 300LX wing measurements
- J-TEC Radiowave
- Giant Scale!
- My New Trailer
- 3D prop for the 35% WH Extra
- Tuning 4 cylinders
- XFC Amateur video
- I'm a little confused with my mixing!!
- ARC Pitts Challenger
- Who has used 0-80 screws to mount their Composite Arf canopy?
- What pack for zdz 80
- DA50 PROP HOLE SIZE
- WH Extra Special and throttle servo placement...
- ZENOAH GT80 ACTING UP!! PLEASE HELP !!
- Hostetler Super Decathlon 35 %
- Power for GP giles
- which would you do
- Prop size question.
- accessories for big planes
- First Gasser Attempt
- DA-50 on can in WH Edge??
- Kit Bashing Bipe ??
- Want to see a 2.6 Yak fly? VID
- Balsa Cub Kit
- Ultimate Question
- MOVED: Carden 30% Extra - Any CF L Gear?
- My Edge is Gone...
- Web site updates
- The New V-Mar Giant Piper Cub 13 ft Wing Span
- 50% G&L CAP
- YW engines?
- new giant scale plane
- Zivko
- Troy Built Models Li-Ion Batteries???
- Peter Goldsmith .........
- Edge 540T Setup
- Redundant rx batteries. What capacity?
- Aeroworks 33% Edge 540T ARF
- important question
- G-SHARK {HELP!!!!!!!!!!}
- H9 / zdz mount from chief
- 1/3 scale stearman
- Help pick a plane for my DA-100
- All Vinyl Comp-ARF 3M Extra
- Muffler for Zenoah GT-80 and H9 30% Su-31
- AIRPLANE STAND
- GP Pitts/Quadra 42. Soft mount needed??
- A new awesome 3M Mintor 150cc
- GAINT SCALE B-52
- Did the 70% Staudacher ever get flown?
- Where can I get the BEST accessories ?
- what size standoffs for hp cap zdz 80
- SAITO 180
- 5" Kavan tires...not too durable...``
- tail wheel steering mount
- Cutting a Hyde mount?
- ???? on 300 sp w\da50
- large, light, strong, and easy as a trainer to fly
- zdz 80 sukhoi
- CARBON FIBER PUSHRODS
- Colored Smoke?
- XFC or BUST.....
- None
- Rocket City Hdwre for GP PW 300
- Yet another Composite-Arf 2.6 330L is...
- Awesome Freestyle
- Lanier 40% Edge build thread
- WARNING: Servo arm mounting screws
- Wing bolts
- GP Christen Eagle
- G62 -->need hints to lower dB's
- DA-100 or BME 110 EXTREME
- Super Cub?
- Brison 4.2
- Edge climbs inverted?
- Futaba S3050
- Aeroworks 42% Ultimate balance, PLS HELP!!!
- body count keeps rising
- Powerflite's and amplified Y harness
- 35% Staudasher with da100
- A Pair of Hares
- 4.8 vs. 6 volt/JR 8411'S
- Smoke Nipple Woes
- More 300 flights
- Engine Kill
- Crashed 2.6m Extra DOES fit in a BMW Mini...
- GS Digi Throttle Servo?
- Need help H9 1/3 cap, zdz 80
- GSP 80" katana cg?
- 3D airframe for 50cc
- Spinner size for 1/4 scale Tiger Moth
- CompArf Canopy
- Programming Manual for the 9Z?
- 1/3 scale spacewalker
- JR Challenge On TV?
- Ca 27% extra
- Can you identify this plane?
- Same Plane .... Different Engine ...Too Many Problems
- GP Pitts Engine mount
- 35% Extra Review
- Fuji Engine or DA?
- Anyone using 5625's on H9 Sukhoi???
- Ziroli Stearman Engine / MVVS26?
- Cheaper Spinner for H9 1/3 Scale Applications
- Aeroworks 27% ultimate biplane
- Who's Got The Props?
- DA 50
- First giant maiden!
- Lost nerve...need help!!!
- Edge w/YW48
- HITEC HS 5945
- If anyone wants Hitec 5735 servos..
- Engine standoffs, yea or nay?
- 40% FiberClassics VS Farm Equipment
- Advice on cowl opening for Aerotech 42% Edge
- Pete Model Spinner Slipping!!!HELP
- Hostetler Cessna 310R
- Wow, is this a sickness or what??? SWEET PIC
- Dual servos in the wings whats the best??
- Welding vs Brazing....
- GP giles 1/4
- NIB 35% extra available
- DA-50R engine
- One piece wing or 2 pieces wings
- Info on Monster Telemaster
- To Tom: Edge 540T Shipping
- marvel mystery oil in engines
- Pitts S-12
- Carbon fiber accessories
- Ohio R/C CAP 232
- Good set-up or bad set-up
- YS or Saito 180
- saito 180 or YS 140????
- Cap 232X
- Delro USA Importer?
- egg nest for spacewalker
- Pilot Busts from Aircraft International ?
- Double Vision
