PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76
  1. Balsa USA
  2. Fuel Port and Switches Safety Question
  3. Hurley Extra with ZDZ 80????
  4. airworld models katana t-30
  5. If you Could, Which would YOU like ??
  6. spitfire
  7. 3w 75 & 33% 540t
  8. Zenoah Engines?
  9. new kits on the block
  10. Shaping control surfaces
  11. Aero-works sukhoi ?
  12. Fc 2.6 which engine BME or DA
  13. Giant Sweet N' Low Engine & Setup Questions. Please help
  14. lanier laser 200 landing gear
  15. 27%H9 Cap W/DA 50 VS. Lanier 30%Edge W/ZDZ 80
  16. Kevlar pull-pull rudder question
  17. Dynaflite Super Decathalon vs RCS 140
  18. Hanger 9 95" Cessna 182!
  19. Nieuport 17 pull-pull & flying wires?
  20. anyone familiar with the ohio models 330l 33%
  21. Getting Your GS Plane to the Field???
  22. help finding a 29% - 30% edge kit
  23. Sukhoi 31 from Airworld anyone got this ?
  24. 33%-35% 3D Machine? What Radio System?
  25. 80" cub big enough for here?
  26. bubbles with film over balsa sheet
  27. Trouble with a 3W100B2
  28. Cowl baffles
  29. Model Design (Australia) reputation, quality?
  30. Saito 180 v OS 160 For H9 Edge 540
  31. Need Suggestion
  32. Gsp 96inch cap? Any thoughts?
  33. Carden 35% Edge: Dimension Needed
  34. 1st Big Plane
  35. Center of gravity on Balsa USA Der Jager
  36. Prop For Da 150
  37. Servo lead extensions.......
  38. What engine for a 1/4 Pitts?
  39. AW Extra 330 33% CG
  40. Iron Bay (Byron) T-28
  41. Creek Hobbies Staudacher 1.20 with a G38
  42. Hi, Newbie to giant scale, Please Help!!!
  43. Secanite(sp?) iron on covering
  44. Center of Gravity on ohio rc extra 300L
  45. CA 31% Extra 300L
  46. 8" fokker DIII wheels
  47. Sig Sukhoi Available??Did they fix the wing?
  48. Wanted - 40% scale J-3 Cub Wheels
  49. Engine/Servos for a Sig CAP 231EX
  50. Yak55 (painting the fuselage)
  51. Is Hangar 9 edge too small for gas engine??
  52. Will this motor fit a Lanier 30% Edge?
  53. Great Plains 1/3 Extra ?
  54. Aeroworks 31% Edge 540
  55. vailly tempest
  56. The best ARF for Saito 182 twin
  57. Is Butyrate dope compatible with S**** Poly-Tone
  58. Tail struts/rigging--RF interference???
  59. Flaperons on 1/3 scale sukhoi...
  60. Wing Failures
  61. Radiocraft 33% Extra 330LX Engine
  62. Hangar 9 quality
  63. How to buy USA ARF in Italy?
  64. h9 1/3 sukhoi , 3w 80b2 or zdz 80 ?
  65. Creek Hobbies 1.20 size SUKHOI 31M
  66. where can I get plans and cores 4 extra or cap 27% 80'
  67. Is there any info on the aeroworks 33%extra arf?
  68. Why are bellcranks different??
  69. Is it true???
  70. Gas engine for H9 Cap232 80" Wingspan
  71. Little Toot flying qualities
  72. G P 1/3 pitts , interplane struts?
  73. Different center on JR8411
  74. CG on a 35% Radiocraft Extra?
  75. Whip antenna
  76. mech.retracts
  77. Hitec Servos
  78. How Big A Ignition Batt. Pack ???
  79. Great Planes Pitts
  80. H-9 Cap 232 90"
  81. Hobbypeople Joss Stick 68" wingspan
  82. 3W-P51D Mustang
  83. You Guys Are Awesome!!!
  84. Suggestions Anyone?
  85. Giant Scale batteries
  86. Looking for 80" or bigger kit
  87. Moki 2.1 Prop
  88. Aeropro Cap
  89. Help needed re: shipping a large airplane
  90. Lainer 33% extra 300s
  91. CNC cut wood and foam set for Hurley Extra 300LX
  92. OS 320 PEGASUS 4STROKE-4CYLINDER
  93. 130" FMG Raven
  94. How big of a plane?
  95. Giant Scale Spinners
  96. Giant Scale Planes, Katana
  97. American Eagle Mustang 102 inch (help)
  98. Christen Eagle Plans
  99. Futaba 9450's in AW 33% Edge 540T
  100. H9 1/4 Clipped Wing Taylorcraft repairs (windshield)
  101. H9 Cap or Extra?
  102. DA100 degrees of offset
  103. Elec Issues-Dual RX, dual batts, isolators, 6v, voltage depression, redundancy, etc
  104. Super Stinker BiPlane Moki 2.10 motor
  105. 1.2 Laser with G-23
  106. Corsair type prop hub for G62??
  107. Edge 540T instrument panel photos
  108. Foam 1/4 Scale Staggerwing
  109. Dynaflite decathlon engine?
  110. Anyone have the Lanier 37% Sukhoi??
  111. Mounting foam wings
  112. H9 Cap 232 73" OS 1.60FX w/ slimline mount problems
  113. ARD Extra 300L - Anyone have one of these?
  114. PLANS for Britten-Norman Islander??
  115. PLANS or KIT for Aero Commander??
  116. Pushrods
  117. Market research (poll) on new ARF Extra
  118. Weight of Zenoah Spring starter??
  119. morrisey bravo
  120. Would like reviews on GP Giant Extra
  121. H9 33% CAP flyers: anyone flown a Wild Hare Giles yet?
  122. building a Glasair
  123. Building a Glasair
  124. Fiberclassics 33% Extra 330L
  125. Is Performance Products still in Business????
  126. Wing Jig
  127. Dave Patrick Ultimate..here yet?
  128. Ikon west Tri Pacer
  129. wood substitute
  130. Edge 540t 30%
  131. h9 1/4 cap & moki 1.8 ???
  132. Dynaflight Super Decathalon--Which Engine?
  133. Aeroworks 33% Extra 330L ARF
  134. AW 40% Edge Horizontal stab????
  135. laser 200 engine
  136. Scale WWI prop nut?
  137. Beware, Watch Out For Toy Planes!!!!!
  138. Gaint Aeromaster CG?????
  139. A-W Edge 540-29% CG??
  140. Great Pilot
  141. Yellow Edge 540
  142. plane for engine break-in
  143. What size motor for the H-9 46% Ultimate
  144. Skis for a third scale Extra?
  145. Remote battery location question
  146. Engine for 1/4 Scale Tiger Moth
  147. Direct Throttle Connection Gas Engine
  148. Tail wheel assembly
  149. spartan executive
  150. Wild Hare Giles G202
  151. bombardier dash 8
  152. What size prop after break in on BME100
  153. prop shaft adapters(inch shaft, metric bore)
  154. Taylorcraft, Ikon N'wst
  155. cap 21 72" need to find a gas engine to match
  156. spacewalker
  157. Building a trailer
  158. La Ferte' WOW!!!!!
  159. Strip Hinge installation
  160. Wated < Model Finisher
  161. Help Request: OS Gemini FT120 Timing
  162. Four Star 120 Engine Choice
  163. 1/3 or 1/2 Scale Fokker DR1 Plans???
  164. Four Star 120 Engine Choice
  165. Great Planes extra 330L and 3W100
  166. Electronics!
  167. PZL Wilga Plans
  168. building planes
  169. Bristol M1 Plans ????
  170. H9 46% Ultimate (ordered)
  171. Best 1/4 for ZDZ 50
  172. aeroworks 31% edge 540T
  173. Lots of Plane-Lots of Hours-Lots of Landings
  174. GP RYAN STA Landing Gear
  175. North West Hobby's Laird-Turner racer help!!
  176. 46% H9 bipe
  177. CA hinges on 33%
  178. 1/4 Cub Advice
  179. Ace Extra 30% 230 Plans or fuselage
  180. Bridi P-51D Giant Scale
  181. Pilot Wanted
  182. First gas engine aircraft.
  183. Crash video!
  184. Two tank fuel system?
  185. finally started my Stinson
  186. How many gallons through BME 100 for break in
  187. Good Digital scale for weighing plane???
  188. Aileron linkage GP Pitts
  189. Lights
  190. Looking for G-Shark
  191. Anybody try a different cowl for a 120 Stinger?
  192. 3W Open House
  193. NEEDED G62 CRANKWORK OR NEW ONE ***L@@k***
  194. "Typical" TOC Wing Loading anyone?
  195. G&L Models website??
  196. Zenoah G62 Crankshaft Fix Or Replace ?
  197. Zenoah G62 Crankshaft Repair Or Replacement Cheapest Way To Fix Or Replace Help!!!!!!
  198. B-17 plan article
  199. Tell me if this is about right for a MW Extra
  200. Raven 2,5 m
  201. Giantscaleplanes.com edge 540 103" wing span
  202. Carl Goldberg 73" Sukoi
  203. wendell hostettler cessna 182
  204. Os 5cyl Radial What Plane?
  205. BCM Quadra 65/75 inverted muffler weight?
  206. Hurley Extra 300LX-foam cores-1/2 price
  207. Looking for a website for aerobatics.
  208. Flair Kits Tiger Moth and PT 17
  209. midwest extra300s cg location
  210. The right plane for a Zenoah G38?
  211. Cap 232
  212. construction questions
  213. Amphibian Biplane 4 sale
  214. What charger are you using to charge giant scale
  215. Servo Arms
  216. Need help advice, clues, everything on STORCH PLANE
  217. Fusco has a limited-time offer we like -- READ THIS
  218. g-62 tank
  219. Bigger CG Sukhoi?
  220. Telemaster 150 Building tips
  221. CA ANDERSON 31% Owners
  222. Mr. Mulligan probs
  223. gp 1/3 pitts
  224. Quadra 50
  225. bates yak3
  226. Fuji gas engines
  227. Mallory Lazor with Quarda 35
  228. Rudder Control horn mounting
  229. Servo extension cables on scale
  230. Engine for Giant Aeromaster...
  231. TS-42 in a MW Extra XS?
  232. What's the best smoke syetem??
  233. Best tail wheel assy. for AW 40% edge?
  234. Prop for Saito 180(carbon fiber)
  235. aeroworks replacement wheel pants?
  236. aileron control horn location
  237. Ziroi Skyraider?
  238. 1/3 Turbo Ravin Kit. Power Plant Question
  239. Rudder Servos - Analog or Digital?
  240. scale sizeing.
  241. Carbon Fiber Props
  242. Need help tuning G-38
  243. Ziroli P38 Landing gear bay door hinges
  244. Robart hinges & Elmer's aliphatic resin
  245. Need help setting up 2 RX's w/9Z...
  246. IYO, are 2721's fine on 33% ail.?
  247. Pete Bowers
  248. Servos on a CG Ultimate?
  249. Bulk Servo Wire Found!
  250. A&A Cessna 310
