PDA
View Full Version : Giant Scale Aircraft - 3D & Aerobatic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Need Help for installing Servos GP Pitts
  2. Control Throws and CG for Aerotech Chipmunk?
  3. Please be wise.
  4. Plans idenity
  5. Sukhoi Ohio R/C engine mounting?
  6. CA hinges on a large aerobatic bipe??
  7. New FiberClassics
  8. Need a little help on a Giles 202 40%
  9. Questions about the MW Extra 300S
  10. 3w or da
  11. Katana ??????
  12. Lanier 1/4 Scale Laser Construction Questions
  13. anyone ever heard of Aviation Direct
  14. Byron Cap21 CG questions
  15. Texas Hurricane First Flights!!!
  16. battey backup
  17. Looking for a Sukhoi
  18. H9 33% Extra video
  19. Aluminum Servo Arms
  20. My flying partner and his H-9 Edge 540
  21. Desert Aircraft Phone Number Disconnected?
  22. Pull-Pull Elevator?
  23. Ohio 33% ultimate
  24. if I go with two receivers, what is the best way to wire them in
  25. Engine box reconstruction
  26. 1/4 Cub Test Flight
  27. 21st Century fabric--a real problem
  28. 103" bleriot undercarrage
  29. Has anyone actually flown a DP Edge with a 50 cc gasser?
  30. Kangke Laser 2000 or Great Planes Patty Extra 300
  31. What fuel line can I use for smoke system?
  32. IMAA -- discussion
  33. I just couldn't resist!!!
  34. Chief Aircraft vs BME Direct
  35. H9 Untimate
  36. Carden 35% edge weight
  37. LANIER 1/3 extra canopy tint ??
  38. wild Hare 300
  39. SIG 1/4 Cub...Long wing
  40. Lanier Edge 540 90" Arf ????
  41. Gaz engines for Extra 27%
  42. Aeroworks 33% Edge Kit Assembly Manual
  43. ZDZ 40 with APC 20X8
  44. ever use a 4 stroke in some thing bigger than 25% aerobat?
  45. mounting DA on H9 Extra 330L
  46. J&A mufflers?
  47. Hangar 9 Giant P-51 ARF
  48. Hanger 9 Ultra Stick 120 review
  49. prop balance
  50. Struts or No Struts on a Robinhood 99
  51. Anyone have directions for the World Models Robin Hood 99?
  52. Servo ? ......What are you using
  53. Johnson mufflers 3w 100/106
  54. JR Matchboxes
  55. B&B Giant Scale CA Hinges
  56. First large model, advice needed
  57. Edge 540 Wing Bolts
  58. Post Your Bud Nosen Trainer Pics Here!!!
  59. Fleet Biplane Rigging, Engine
  60. Hanger 9 80" Cap & DW 50
  61. Sukhoi-Ohio RC??
  62. DH 88 Comet 1/4 Scale
  63. CA 34% Extra in a Chevy Tahoe?
  64. CA 31% or CA 34% Extra 300L for ZDZ 80 RV single?
  65. Great Planes PattyW Extra or WM Extra 300
  66. Pitts 12 Motor
  67. anyone have a HANGER 9 EDGE edge with a gasser. ...............HANGER 9 EDGE 540.....
  68. hangar9 1/3 cap 232
  69. 25x12 3-blade
  70. Help with throttle curve mix??
  71. Unionville Models
  72. FUJI BT-64 Five Stars *****
  73. MOKI 210 fuel rate ?
  74. rudder/aileron mixing
  75. 3D with C-ARF 2.6M
  76. Giant Stinger
  77. Need a little infor on the H9 33% Extra 330
  78. 35% Carden Edge/mufflers?
  79. Got me a new plane today
  80. Edge comparison?
  81. Carbon Gear springiness
  82. h9 edge, Lanier edge, Lanier extra 300l 120sizes
  83. Ohio RC Sukhoi ! Help engine size?
  84. 1/4 Scale Taylorcraft Full Pilot
  85. Hostetlers 33% Decathlon
  86. Radiocraft 35% Extra Canopy Needed
  87. Bungee Chords needed for 1/3 Scale Cub
  88. Elevator servo's in 35% Extra
  89. Anyone know anything about G& L hobbies-namely their 1/5 Chipmunk??
  90. 24% or 27% extra
  91. 33 and 35% extra's
  92. Tail bracing
  93. Flair Stearman-Gas Engine Choice?
  94. A question about airfoils.......
  95. Giant Scale Prop Question
  96. Extreme Aircraft 25% and 30% Extra 300L's
  97. 3W 36% Extra 330
  98. Engine for Aerotech Chipumnk (Help)
  99. Hangar9 80" CAP 232 BME 50 engine mounting
  100. Model Design Kits????
  101. pilot 1/4 scale tiger moth
  102. Want to get in Giant planes have a question about my transmitter.
  103. Futaba 9206 on 6v
  104. wire looms
  105. which fly slower in general
  106. Help with DP Edge Firewall Marks
  107. Fiberglass fuselage 27% aerobatic
  108. Alternative wing covering
  109. Anyone make a composite ARF
  110. Lanier 30% Edge Question
  111. Nieuport17 or Sopwith Pup?
  112. GSP Staudacher S300, anyone fly/own one?
  113. Zenoah G26 backplate
  114. How much does Monokote weigh?
  115. AW 33% Edge Engine Thrust
  116. Colombo Anderson 31% Extra 300L discussion
  117. G-Shark Wheel size
  118. CAP 232 Lanier, Engine Incidence
  119. Need servo setup advice for 31% CA Extra
  120. Need a pilot!
  121. Replacement wing core's
  122. c/a hinges for 40%
  123. Paint
  124. Pitts vs Ultimate ??
  125. Need fiberglass cowl for Concept Fleet.
  126. Engine for PW Extra
  127. Help!!! Monokote Saphire Blue
  128. Nats and Joe Nall
  129. 70% Staudacher...anyone know if it flew yet?
  130. How much battery do I need?
  131. Prop for Stinger/G62
  132. Smoke system problems ?
  133. New Book for beginners giant scalers!
  134. what plane for 30cc gas engine?
  135. 3" Ultimate style aluminium spinners
  136. calling all showtime smoke pump owners!!!
  137. nwhobbytech, out of business?
  138. Fail-on switch harness.....
  139. Sig employee now makes his own.....
  140. I found out what happens when the engine dies on a Cap.
  141. hanger 9 edge how slow does this plane land
  142. cannisters for composite aircraft 2.6m
  143. Great Planes Giles 202 or DPM Extra 300L
  144. mustang advice
  145. Starter battery
  146. H9 Titanium 1.25" pro link?
  147. Motor box for G62
  148. How to convert dm squared to sq. inches?
  149. Funtana from Desert Aircraft
  150. Sig ARF's
  151. Arf for G45 or BME44
  152. 3.2 brisson too much?
  153. hanger 9 egde, how well do these fly
  154. *
  155. jtec 40% extra 300Lx
  156. retiring over seas to Philippines
  157. Putting topcoat on Latexpaint..
  158. Hanger 9 1/3 Scale Cap
  159. BUSA Fokker D-VIII status
  160. Best 50cc ARF!??
  161. Saito Engines
  162. Mini Digital Servo For Throttle
  163. TopFlight Stinson Partial Kit
  164. lanier 30% edge
  165. Menz 26x10 S Prop
  166. Prop for Pacific Aeromodel's Tiger Moth
  167. Need Byron Pipe Dream setting help
  168. Glow Drivers Needed??
  169. Genesis 1/3 Waco YMF-5
  170. Scale Gear For 1/3 Spacewalker
  171. Top Flt Stinson Reliant , landing gear
  172. Transporting large planes?
  173. Dynaflight PA-18
  174. Composite landing gear for Lanier Laser
  175. Bme50, Da-50, or zdz50......
  176. GiantScalePlanes The Company Anyone have one?
  177. 52% Extra XS
  178. Topflite T-34B Mentor Kit
  179. Largest Big Bird Fun Fly in Alabama
  180. Gere Sport CG.....HELP!
  181. Dynaflite Chipmunk with G-23 ?
  182. Installing a smoke system
  183. Great Planes Giles 202
  184. h-9 taylorcraft
  185. 3w-100 in a Super Flying King?
  186. 52% Extra XS by Aerotech (got one?)
  187. worlds BIGGEST rc airshow. La ferte alais 2003
  188. Need some help.
  189. Dave Brown spinner question
  190. Lanier 80" Cap Engine Install
  191. Enya Vt240
  192. throttle return spring
  193. 1/3 Lanier Laser 200 ARF
  194. Centering Engine In Cowling
  195. Where can I find a 1/4 scale Super Chipmunk
  196. Ace R/C 4-120 Bipe/Ultimate 10-300 Kit Bash
  197. Wendell Hostetler Cessna
  198. Any interest in a 80" YAK 54?
  199. Balsa USA Aeronca C-3 Question
  200. Nall vid 2003
  201. Creaking Phenolic - Aeroworks Edge 33% ARF Wing
  202. MSC Prop and DA-100
  203. Glenn's 35% Extra 330L
  204. Bud Nosen "Mr. Mulligan"
  205. crazy fuel tank idea for my 18% DH Beaver
  206. best c.g. for carden cap 35%?
  207. Crashed GP 1/3 Pitts
  208. Spacewalker II covering
  209. Ignition Kill Switch For Zdz 80
  210. How many Batt Packs for Gas Planes?
  211. 1st 1/4 scale questions????
  212. no range with motor running????
  213. Nosen Gere Sport Top Wing
  214. Black Cardboard Tubes For Wiring
  215. Proper "CG" for Ziroli Zero
  216. GP 1/3 Extra 330L replacement main gear?
  217. Carden Who?
  218. wiring question
  219. Bud Nosen Trainer Pictures??? Anyone got???
  220. Dinaflite Chipmunk
  221. Cable Exit Through Fabric
  222. Servo leads?
  223. G.P. 1/3 scale Pitts pic's
  224. Cap / Breitling Font
  225. New to Gasser's,please help
  226. Carden G-300?
  227. All Metal Plane by Ted Nelson from Reno NV
  228. Picked up my giant Chipmunk the other day.
  229. Nwht
  230. Senior Telemaster Wing, 1 or 2 piece?
  231. GP PW ARF & G45? or G62
  232. Mega smoke sytems
  233. (very sweet) Aero Commander.... twin BME 50's
  234. behrens sopwith triplane
  235. Laird - Turner Racer
  236. spinner nose weight
  237. 1/8 scale DHC 2 BEAVER
  238. Troy Built CF Spinner
  239. Source for AW wing cores
  240. CG on aeroworks Extra 33% ARF question
  241. baby kirby
  242. 540T 33% AW arf OR 540T 40% arf DAVE PATRICK
  243. 90" Chipmunk
  244. Bud Nosen F4U Corsair
  245. 42% Ultimate
  246. DA 150 Electronic Module
  247. Aeroworks Ultimate
  248. Fuel system plumbing question(gasser)
  249. Byron Christen Eagle help
  250. Byron or Pilot Pitts......
