PDA
View Full Version : S.P.A.D. Aircraft - Coroplast design
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18
  1. Another GeeBeeQHOR...
  2. spad wing mod
  3. modified spad wing
  4. Wing attachment on Profile Edge
  5. In search of SPAD Twin engine
  6. What the heck is CA?
  7. Need SPAD help!
  8. Is a Good CG Possible Here?
  9. FYI: found a coroplast source in Athens, Ga
  10. Tornado props-where and how to buy?
  11. GMS .47 problem
  12. Source for 2mm
  13. Sp3d wing construction
  14. Please identfy?
  15. More inflight pics
  16. Easy starter spad plans
  17. The next spad fest
  18. battery powered trainer?
  19. CA bonding problems-Helpl!!!!!
  20. Please Please Help Desperate
  21. Spad wing flex
  22. 60in Flying Wing
  23. SPAD Dogfighter Question
  24. Where to balance my plane when spar is moved.
  25. FLat Bat question
  26. Got My Spadfest Video And It Is Great! A Must Have!
  27. SPAD Boat !
  28. Low-wing attachment, and retract placement?
  29. Another SPA3D...
  30. Lets see ya do this with balsa
  31. INTRODUCING-the vertical SPA3D landing gear!!
  32. The Spa3d must be as fertile as rabbits
  33. not a SPAD, but I was sad to see it crash
  34. mass producting spa3ds
  35. Old SPADS never die.....they just morph into other SPADS....
  36. "A spad is an ugly, heavy plane that does not fly all that well."
  37. SPA3D Tough as Nails!
  38. does anyone have pizza box spad plans???
  39. QHOR Question
  40. Lightening methods
  41. 61 Corospitfire
  42. props on SPA3D
  43. Ducted fan Spad?
  44. airboat spad
  45. SPAD Column in RC Report!
  46. PBF with SPA3D airfoil?
  47. 3D Spads
  48. My new SPAD construction tool
  49. first spad
  50. DDust Questions
  51. Hello Bell-Air club members - looking for local b'ham coroplast source
  52. Spa3d inverted flight
  53. Poor Roll Rate on SPA3D
  54. Aileron hinge question
  55. 24" wing span and pqhor
  56. my qhor wont flat spin
  57. Coro-Floats
  58. Gluing Bottom panel to top wing panel question
  59. My SPA3D.
  60. Need some ideas on making a canopy??
  61. My new Demon
  62. Deb taildragger dihedral
  63. alternative to glueing wings????
  64. WOW! Frank Costa has his own monthly SPAD REPORT In R?C Report now!
  65. spazzler low wing
  66. Found a great supplier for Coro
  67. A little confused on spad building...
  68. Spad 3d
  69. SPAD Dogfighter
  70. Question about spar height
  71. What SPAD to build for a Trainer
  72. OK, tell me what this SPAD is all about?
  73. Created a Crooked Rudder!
  74. quick in the air...
  75. .25 sized spad?
  76. ALWAYS! Safety First
  77. It had to happen (Flat Bat sloper)
  78. Flight of the Cor-Star 60
  79. New Spadet
  80. Motor mount width on PBF for TT-GP42
  81. PVC square pipe?
  82. Can i hover with a .25FP
  83. OMG this SPA3D ROCKS
  84. Really stupid question about coro...
  85. Flatbat flutter problem, please help ASAP!
  86. Cartoonified for your decal making enjoyment
  87. SPAD with Saito .72
  88. Spadango
  89. Seeing double? Naa, that's just my new Cor-Star 60!
  90. July 27 Fun Fly in Rocky Mount, MO
  91. Dasplastic with canadian gutterpipe
  92. Anyone tried making a SPAD Spad?
  93. To test a SPA3D tomorrow
  94. Qhor question
  95. SPADanon - a twelve-step program?
  96. Canadian SPA3D
  97. VILGA in coro
  98. Interesting Debate in the Clubhouse
  99. Fusing coro pieces together
  100. Make a SPAD out of an Aerobird - Challenge
  101. Spads in the classroom
  102. None Spad flyer with a question or two.
  103. Any Cheap Lost Plane Finder?
  104. how do you make the wings?
  105. Flying my QHOR
  106. Spads and hot temperatures
  107. SPA3D with 2 aileron servos
  108. Show em we exist
  109. Is there an advantage?
  110. SPA3D photo
  111. Perfect Leading Edge......
  112. Graphics for a SPAD
  113. coroplast sources?
  114. my new spad
  115. live help
  116. US Source for Canadian Downspout???
  117. Coro cleaner/prep
  118. SPAD for 3D
  119. Cutting HDPE Is Not Fun....
  120. SPAD overhead projector
  121. 25 size CC Edge
  122. Spa3d=fun
  123. A flat bat with dihedral?
  124. Gave up on my PBF for now
  125. Other simple plastic planes
  126. First flights with round PBF!
  127. A TRUE newbie!!!
  128. Holy cow! Have you seen Kraut's new gasser?
  129. Flight report on my first SPAD...
  130. need help in finding tings for my 1st SPAD
  131. QHOR flys - Awesome!!! Couple questions
  132. Barn storming event.
  133. Any plans for an 80"ws spad?
  134. What's everyone use as pushrod attachments to the control horn?
  135. Are You Hungry?..................
  136. Simple Parachute Activation Device
  137. SPA3D vs. Beginner ???'s
  138. what .46?
  139. Tail wheel or skid on Spitfire?
  140. wing ship cg?
  141. 1st Plane?
  142. Applying water slide decal sheets?
  143. Seeking Knowledge
  144. PBF and SPA3D exhaust extension...!!
  145. Another question on scaling up plans.
  146. what can i build with this much correx
  147. Spad 3d - So Fun!
  148. OK, this is an unabashed humor type thing.
  149. What servos to use in my spad?
  150. Espad?
  151. HS 81 MG servo problem on PBF
  152. 4' PCV or fence post
  153. Carbon Fiber rods for PBF flutes?
  154. Rit dye and Coroplast.
  155. Alternative Wing Design?
  156. UK spadders ?
  157. Lightening a SPAD?
  158. 89% spa3d
  159. It's another one...
  160. Just finished a DPS
  161. QHOR Flight problem
  162. SPA3D compared to a Sledge or an OMP edge.
  163. My new Ultra PlaStik
  164. SPA3D madion tommorow!
  165. New Glue (( Maybe ??)))
  166. PVC Suggestions
  167. Servo Extensions
  168. .25 3D SPAD plans?
  169. changing rubberband wing mount to bolt down?
  170. Twin spad, P38ish.....
  171. Modified PBF
  172. Wing problem on corospit
  173. Help a new guy
  174. The Elevator on my BUHOR...
  175. Thin CA vs Medium CA
  176. Anyone done this yet?
  177. Here's my PBF in the tree, I have a question
  178. another large scale trainer question
  179. Corrugated Plastic in Ireland??
  180. Covered my PBF, take a look
  181. Missing QHOR found
  182. Please Help SPAD GODS
  183. Finishing touches to a spad?
  184. spa3d/ pqhor climbing ability
  185. First Spad Combat
  186. PQHOR and .25FX
  187. Cool hinge cutting tool !!
  188. Low wing SPAD
  189. How do you keep the edges of the vinyl from peeling up?
  190. Hot Spads
  191. Qhor
  192. Setting Control Throws and Making Control Horns...HELP!
  193. 1st QHOR is 2nd Coro project
  194. Debonair + PaintBalls=Fun
  195. strange pbf variation- what is it?
  196. Giant wing hold-down methods
  197. Thank You
  198. SHORTY ? ? ? ? My newest bird.
  199. SPAD Hor hand lauching problem
  200. Vinyl gutter downspout? Same as PVC?
  201. PBF with gear based on SPA3D
  202. duel aron servos?
  203. A spad question for everybody.
  204. Straighten bent coro?
  205. My SPA3D........ UPDATED 26 JUN 03 With pics of new SPA3D v.2 on pg. 2
  206. Dragonfly BUG
  207. Inflight Spad3d pics
  208. HOR powerplant question...
  209. Off Topic Aussies contact list
  210. thick flat pizza
  211. my first spad!!! need some help though...
  212. FlatBat construction question...
  213. Alternative to CA and hot glue?
  214. round PBF CG and rudder
  215. V-tails, just a couple questions....
  216. GOOP substitute.
  217. Building From Balsa Plans
  218. Debonair finally finished
  219. SPA3D Question.
  220. 8' Wing
  221. EZ wire gear setup
  222. NEW design
  223. Another reminder on safety
  224. Good low wing SPAD
  225. bad day with first PQHOR
  226. Uk Spad Arf
  227. Questions about Corospit?
  228. Dual Aileron Servos on SPA3D
  229. What should I use for a 72" combat wing spar????
  230. New SSC Dogfighter - First Flight!
  231. The Thing
  232. Dino Plans
  233. Really planted my DPS
  234. instead of glues or gooooo
  235. ghor or pbf
  236. Spad Plans for free
  237. Coroplast
  238. GeeBee PQHOR - First Spad
  239. where to get free, old correx?
  240. What Prop?
  241. More inflight pics
  242. My qhor is done! this one flies great!
  243. Spadet resizing question
  244. Help
  245. Man am I excited!
  246. Spad at the field
  247. CofG for a Delta SPAD - help
  248. Firewall on coroplast fuse
  249. Canadian Gutter Pipe
  250. How to cut PVC gutter
