- SPAD Swept Wing Pusher Canard
- Flutter
- Free plans
- SE5 video.
- WOW! The easiest way I have found to cut Coro!
- Finally built a combat Plane
- 2.4 GHZ & Spads
- D Dust
- .15 ,DAZI 36" wing
- Plane ID
- New SPAD to crash
- My SPAD Ugly Duck
- 1/4 scale SPAD Fokker D-VII
- New Spitfire PDF plane. Quick Fun build.
- Spad bearcat
- glue problems
- Spad Construction question
- 2mm flat bottom wings
- Spad Stick
- spad P 38
- .10 size spad?
- Spadet on floats
- SPAD wing Sharp leading edge.How bad is it?
- Just Maidened my Saturday Night Special
- electric spad?
- flock of spads
- SPAD Twist-VSF
- Canard with Pusher prop
- Spad Supplies in NZ?
- Own Design Electric SPAD
- New Combat Flyers
- Spad plans???
- Question
- where can i get 2.5x2.5 square pvc (in kansas city)
- Rebuild attempt using coro
- Spadet trainer
- Sturdy Birdy II
- spad Primo(profile)
- Coropusher???
- Flashing Coro.??????
- spad AT-6 Texan
- Building Wing??????
- 1st officail build attempt
- electronics kit?
- Fighter Jet Plans
- Dasplastick build - questions on wing
- Where to get Square PVC??????
- 48" Foam Delta
- .25 QHOR Maiden - finally!
- USS With TGY52 Stripped Servos
- Debonair Power Question
- FYI Spad Materials in Australia
- SPAD AT-6 Texan
- SPAD SKIS
- Cheapest spad
- .25 QHOR Spad build servo mount question
- Spad corsair
- Firewall thickness advice needed, please
- SPAD stik for a .28 Thunder Tiger motor?
- 96" coro delta
- Overweight 82" Ultra Spad
- Debonair - Taildragger???
- Debonair landing gear specs???
- PVC pipe
- Flying wires
- Trainer choice
- SPAD's Over the West Coast
- Gap filler
- Source for 2 mil coro in Houston, TX??
- Can epoxy be used to attach correx to EPP?
- Gasser Pattern Spad Plane
- Old Spad Builders
- Bending Coroplast?
- question about ultra spad stick
- Definition of a SPAD
- New Snow SPAD
- Need a foamie,to fly in a gym
- 2.4g radios & SPAD / Corroplast
- Foam Board?
- CALLING WEST COAST SPADDERS
- Free airplane building material..polling places
- BUHOR
- best engine for a SPA3DT
- Remote suggestions
- Electric Mini HOR
- Spad for a 25cc gas engine
- SPAD Biplane
- Spadflyer.com Slowflyer as Trainer ??
- making a foam hot wire
- What adhesives can I use to glue correx to blue foam?
- ST75 on a BUHOR?
- new S.P.A.D. website
- I Built a Mugi Evo Tonight
- ght. QHOR ?
- Aileron flutter
- Electric SPAD
- Cheap SPAD trainer
- Flat Bats...?
- Wasp-named SPAD with Wankel Rotary from Russia)))))))
- Painting SPADs
- SPAD gnat for G51
- Spad Insight (Pattern Plane)
- What to do...
- Coroplast/Corex Purchasing Locations
- SPAD first flight : Problems getting nose up
- new combat spad
- Spad (CC) Edge 540 Maiden Flight...
- Adui's Deb build, my first SPAD
- Biplane
- My New Gnat
- Hot rod deb
- Foam Core Wings
- New SPAD Racer
- Title change: Im gonnabe a spadder now THANKS!! :)
- New spad
- SPADET 72" span for ASP 600
- new mini spad stick design
- SPAD FLYER
- SPADFEST 2008 Location has changed
- Wing struts
- Spad Trainer
- two new spads
- New Spad
- need ideas of plane to build
- pylon racer
- Plastic Concept Planes Contact info...?
- qhor vibration airation in tank
- Upsized Bulldawg
- SPAD Swept Wing Canard
- plastic welding
- Has anyone made RealFlight G3 models for SPADs?
- Hello Spadders
- Link to plans?
- Delta motor
- SPad Delta
- tribute to the spad sticks
- SPAD Combat Bird
- Giant spad?
- Wild Thang?
- Mini-Deb Wing Build
- spad dogfighter question ?
- folding 4mm coro across the grain
- first time spad
- Last SPAD of the Winter
- qhor and 46LA
- My firtst build! I used the ribbed gutter pipe.
- where do I start ? prefer foam!
- New Favorite Airplane ESPAD3D
- New Derelict
- PBF
- Shock absorbent landing gear
- Wing question
- Debonair maiden
- 1 hour Coro Delta
- Delta
- Crop duster
- REALLY fast .40 size SPAD?
- Twin Tail SPAD
- Another SPAD Trainer - Maiden Video Added!!!
- SPADdict??
- light weight
- have a question about a gas tank...
- Which Paint scheme for SPA3DT?
- First Coro build
- maidend 2 planes today
- sorry couldnt figure out how to delete post
- im in a really good position!
- Simple SPAD Stik on Skis
- 2008 SPADFEST Website
- Simple SPAD Stik Maiden Video
- Hinge options
- I was looking into this kit, I think it belongs here....
- Styrofoam
- maidened 2 planes today
- modified debonair
- .65 sized Pizza Box
- If Only I Were Closer to Retirement....
- Simple SPAD Stik finished!
- Building a SPAD Trainer
- What Glue?
- first spad, need a little help
- Simple Stik
- A newbie to coroplast.
- SPA3DT
- Gnat on Skis - Now with Video!!!
- ducted fan??
- soloed my deb!!
- Fastest .40 sized spad
- Painted Finish Question
- Las Vegas Spad Fliers
- Fall 2007 SPADS Over Texas Videos
- Debonair flew today
- Folding prop
- Budget Rx's and Servos for SPADs?
- My first Spad w/ pics--Suggestions??
- 22x36 coro help
- Advice on First SPAD
- Finding Mats.
- 2mil corpalst
- So whats the biggest spad ever built and flown?
- Anyone Made a Foam Cutting Tool?
- Spad delta wing designs?
- spad help
- what to do with spare wings?
- See that 4mm in his suit?
- us or canadian downspout
- Huge, giant spad with large bomb drop.
- Big buhor wing on Debonair fuselage
- stupid sign shop
- Nose heavy AirCore 40 Trainer
- CoroFunFly 51
- Cleaning coroplast signs
- flying witch
- S.P.A.D. THE MOVIE
- Hello I am new here.
- easier wing LE fold technique
- CoroCub - a little bigger one.
- Dogfighter Squadron for the club
- Spads Over Texas Fall Event
- SPA3DT Build
- espa3d weight
- weird situation
- free sign Board, by the truck load!!!!!!!!!!!!!!!!!
- another SPAD turbine model...
- First SPAD: Racer design
- SPA3DT build
- Electric Demon, anybody done it?
- fuel tank help
- Where to buy-Spad
- New SPAD
- Attaching PVC control horns to coro
- Sickle - skid plate?
- Coroplast wing fixture
- 1st build 2nd spad
- Spad Spitfire.
- Spad
- talon good spad?
- SPAD on Floats!! (pics)
- STTB plans in Word documents
- What would be a good first 3D Spad?
- 36" span coro delta wing pics
- 60 size Coro High Wing
- new spad sport...sort of
- B-2 Stealth Spad
- Tubester
- Debonding coroplast???
- Skewed wing a problem?
- Growing a Pizza Box ???
- ULTRA SpadSitk building thread
- Ideas for wing construction?
