View Full Version : RC Airboats
Pages :
1
2
3
4
5]
6
7
8
9
10
11
- 775 Size 3s 16 Inch Airboat
- here is you a motor
- Airplane Parts Converted Into Air Boat
- Nitro to electric?
- New RCAA Class D Hot Hydro Water Record
- Vid of Gators in action
- bad porpoising please help..
- 3D product design project
- Hovercraft update
- torquey prop for .46????
- airboat push props
- Airboat for OS 55AX??
- Video of a some grass running
- my new boat please look!!!
- Airboat in Fiberglass -My third airboat
- anyone know...
- Balance point for starting point
- how big
- Tunnel Design Plans
- RC Airboat race Vid
- os 46 la
- Parts Source AquaCraft .46 Engine?
- AQUACRAFT AIRFORCE HEEELLLLPPPP !!!
- fail safe
- What is the best airboat kit for a .46?
- Dear, Mr. Cajun Gator
- air boat wieght
- has anyone used sintra
- Foam Foam Foam
- problem with pressure
- New RCAA Class E Stock Hydro Water Record 2-09-08
- Glasgow scotland
- .75 hull size and type
- new project need some advise
- motor size?
- glass shell??
- 540 propeller
- bluebird jet boat ducted fan power
- Which brushless motor for lil swamp buggy?
- anyone remeber the Puddle Jumper?
- CG or CB
- Round Nose Hydro
- os 40LA question?
- cuttin foam??
- engine mount help
- Anybody besides me running on snow/ice ?
- 24" Cajun Gator plans .40 build
- This Ain`t no, Boogie Board Boat Build..
- Project...."Chasing NITRO"
- BRUSHLESS Aquacraft Air Force VIDEO updated
- which radio???????
- NITRO Playing Around With His "SI" 3 Pt
- New RCAA Top Speed Record 1/26/08
- hey guys which one ???
- From the Netherlands
- HELP WILL THIS WORK????????
- a .61 glow laying around
- boat with cage and progress pics
- pusher prop
- pics of a newbee foamie
- oh the joy of air boats lol
- Inverted gas engine ok?
- im so confused!!!!!!!!!!!!!!!!!!!!!!!
- hull for gas engine?
- foam boat what do you use
- swamnp buggy brushed
- FIRST TIMER PLEASE HELP !!!!!!!!!
- my boat being built
- First scratch built Air boat, problem
- My 1`st Scratch Built Airboat,,EVER !!
- Jasper's SI3
- dumas airboat problems
- Doubledog's building a luftboot
- what to do
- Foam hull / boat
- Making a Blizzard, with a Vortex
- air boating in glasgow scotland
- Lehner 5300 motor -- uses?
- Building the Miss Take to be EP
- ice any tips
- modifiying servos
- Vintage airboat plans??
- Big swamp buggy,.... scratch build?
- Rockaway Beach , MO - RC airboat meet ????
- Lipo3(4!)pointer Depron airboat with video!
- hull pics
- rudder thingamajig
- confused question
- what r theses called
- Twin hull airboat,check it out..
- :) A little Help :)
- First attempt to build..questions
- Cage Roller.
- New RCAA Top Speed Record 12/8/07
- rudder mount
- Boogie Board airboat contest 4/15/08
- run on ice snow
- what size motor will do
- newbie
- air force by aquacraft ..any good for beginner?
- name this boat
- how to water proof servos and controll box? and what size prop for a 500 moter
- Winter project
- cage
- Airboat, bottom finish
- variable pitch prop
- .61
- good airboat motor
- New plastic gasser
- Prop choice, gas airboat.
- what material do you build with
- Big swamp buggy with SuperTigre G90 ?
- Weedeater powered
- how do you make the fastest boat
- rebuild help
- First part of the puzzle
- i'm buildin an rc airboat!
- motor problamo
- filling pin holes
- cardboard fiber galssing
- Dumas Swamp Buggy
- new hull plans needed
- popsicle @ buttons creek & rubbish @ the dam
- steering engine mount???
- Restyled flatbottom (added vid)
- Ideal Boat
- Should I buy An Airboat
- My EP airboat project
- Somebody running Airboats in Oklahoma?
- starting a scratch build
- Newest micro fleet addition...wood hull...
- Shovel Nose Airboat Find:Worth Restoring??
- scratch build question
- Dumas Big Swamp Buggy... LOTS of work ahead
- project RUBBISH
- pusher prop
- motor want stay on at full throttle
- rudder ideas??
- pusher/ rudder setup
- LARGE aluminum hull
- new foam air boat
- prop questin
- air boat kits for . 40 motor
- big air boat propeller size ???
- what do you build for..
- BH7
- Pacer
- water proofing/glassing hull windy airboat
- windy build questions - motor shims
- What radio to use
- radio
- Kyosho Wind Rush 2
- New project: Electric Air-prop canard.
- Pusher vs puller props. Let the debate begin !
- total newbie
- photo sharing
- think i have killed my boat now
- new project..
- airboat engine size
- Miss Take air driven hydroplane?
- rudder..
- Dumas Windy Build
- RCAA Okeechobee Fun Run Sep. 29th '07
- update
- Boogie Board Conversion
- simple plans??
- power
- ****Nitro .46****
- ideal hull...
- plans for a foam hull
- fiberglass/foam hull
- Micro depron airboat...NOW BRUSHLESS...
- Airboar Hydros for club racing
- hovercraft
- rudder size
- prop
- quick anser needed prop sizes
- servo and reciver setup
- motor mount
- Flitecraft Mi$$ Outlaw Prop?
- dumas windy-.15-what prop
- Help please got more problems lol
- Two 3 point airboat
- roll over problem, ideas anyone
- just bought a band new sc 61
- I'm lost on new tech.......
- newbe Question???
- NiMH weight..
- Air Filter?
- a bit of the carb fell off do i need it !!
- No rudders boat ?
- ESC for Airboat use
- Help with twin rudders setup
- Shortening prop?
- convert to outboard?
- OS 160???
- Motor amp draw ?
- 1st airboat!! DUN!!!
- rudder questions
- high torch motor
- Should I use a pusher prop configuration?
- building a Big Swamp Buggy
- prop size?
- hull
- rpm
- lrp speed control problems and spped issue
- My boat thinks its a sub
- my airboat "chispa 46"
- my new gasser 35cc
- Prop adaptor?
- engine very tight help please UPDATE ITS FIXED NOW
- Starter wont crank engine over?
- Got motor need hub
- brushless motor probs i think
- What boat is this?
- my brushless motor will not spin
- RCAA Fun Run 9/8/07 In Okeechobee, Fl
- esc and motor
- Post your airboat pictures here!!!
- Airboat basics??
- Foam coating
- help I crashed tore a hole in my hull
- Help, I've caught this fever?
- Custom Rudders and Engine Mounts
- Wanna buy a fast Airboay!
- .46 Vortex (Pro Boat)
- New micro build!!!
- kinda worried about my motor power
- balsa or styrofoam?
- asp61 enigine help please
- fuel life
- electric dumas swamp buggy
- Dumas 28 Swamp Buggy ... my first boat
- need some help hooking things up
- Gas Tank position Question
- 2nd project - Airboat/tunnel hull
- lights very cheep and easy
- Flightcraft Shockwave
- wats the diff??
- right contoller?
- Alright I give up, Can you help me
- wing in ground effect boat
- 50cc gas engine air boat?
- My First Build
- Fellow Airboater
- rc airboats in the news
- My Latest 3 Pt. Project
- ah the fun of air boats lol
