- savage hopups?
- I'm screwed...or am i?
- ""Power Loss""
- Baja b5 LED lights for savage
- HELP! DISASTER!
- metal spur gears
- SEAL leaking into rotostart
- Baffle with Savage X
- Engine problem
- Thick Clutch Springs = Lower Engine Temps?
- Pullstart/no compression problems!
- Help...Flameout when steering on corners
- new body from hpi raceing
- Nevermind
- wat things that u like teh most abt ur savage
- Savage won't shift?
- 20 mph New Bright F-150
- Savage 25 to Savage X
- done with my savage!
- savage 3.5 rtr wont run properly
- Anyone have an SH engines .28?
- click this need clutch help
- weak steerimg on my Sav x
- OFNA Throttle Mod
- picco .28
- Has Any One Seen This Before ?
- ENGINE WONT START- CUE NITRO EXPERTS
- for noobs what u need to do to make ur savage into the ultimate bashing machine
- My bash day!
- i need some advice on a problem.....
- Is the HPI SF-2 STEERING SERVO STRONG ENOUGH?
- More shopping for me.
- I need a good cheap charger :-)
- .28 PICCO TUNNING QUESTION
- (Newbie Tuning Question) Idle Hassles
- My New Savage X
- 28.picco is spring needed
- radio station added r/c to site
- My second Savage!
- setting on the 28.picco need help
- HPI tuned pipe melting bodies...help
- rechargable packs
- cabane play on the shaft!!!
- New addition to the family
- engine suggestions?
- A-ROD 300Mil??
- Siro 30
- stearing bearings
- No more half tank lean?
- Anyone bashin in Vancouver BC.
- axial motors question
- boost bottle
- Where to Bash?
- What's with people are they jealous?
- yes or no will the under head for 21bb fit in 2 25 engine?
- Savage 25 Tuning Question?
- Reverse Modules?
- Fail safe
- A couple easy questions
- Savage Exhaust
- {big help} i kill spur gears
- sts.30 engine
- another savage swimming post
- savage x 4.6 breakin tank 1
- No power to front wheels on Savage X
- Picco .27 or .28 ?
- HOW DOES THE HOT BODIES MUFFLER INSTAL ON A SAVAGE 4.6 RTR
- Wheely king Videos
- main chassis?????
- Savage 2-Speed and 3-Speed Gears
- should brakes be like this
- SC vs HC
- brakes
- Making own cleaning solution
- have to say the picco .28 is so fun
- New to hobby
- hpi savage .21 not working
- mammoth mt
- VERY HAPPY WITH THE PICCO .28
- needle settings for dirt demon
- brakes on my sav x?
- savage x 4.6 3 spd conversion done...
- HPI Wheely King Question
- Hi anyone own a maximizer diff locker for the savage
- how fun is racing?
- WORLDS FIRST DRIFTING SAVAGE
- one bad thing after another
- im in need of your idea's.....
- the reverse
- Pressure Reservoir?
- Fiberglass Brake questions SAV 25
- Motor tuning
- savage action & broken parts
- finished/losi shock conv.
- i think i will get this
- HPI savage x 3 spd trans?
- Built my Savage Work Stand tonight...
- Gearing Math.....
- Aftermarket head causes my engine not to start
- picco.28 rock
- savage clutch bell which one
- big Joe's?
- savage x
- aluminium / stickers!
- Brakes?
- Trying to remove carb
- Savage shocks
- best bashing truck
- help with FLM mods
- I'm a Noob!
- dogbones for extended TVP's
- Greetings! (Nitro Newbie)
- Integy???????
- WILL THIS ENGINE WORK IN THE SAVAGE 4.6
- modding my savage
- Savage 25 one way bearing upgrade?
- Should I?
- RE:REpairs Warehead Evo Nitro Monster truck
- LST Shock Kit
- Savage chop shop?
- truck cleaning with turps help
- Axial .28 front bearing air leek
- HOW ABOUT THIS FOR THE SAVAGE 4.6
- My e-savage + and my review
- Simple question, quick answer!!!!
- NEED HELP PICKING ENGINE
- Glow Plug ??'s
- Hump pack
- A Q about the lst shock mod?
- Ordered this from Tower, wondering about a part.
- Weakest part on a Savage X
- Axial .28 vs. Picco .28
- Fuel Lines....
- My latest video
- Balancing Beadlocks
- Engine tuning help
- Proline Blazer body problems
- Savage X 728
- 3-Speed assembled drop in to X 4.1?
- Need tips for starting a hot truck
- Savage diff probs
- Sirio 27
- removing mounted tire--need help
- Mugen Tank = No wheelies? :( HELP!!
- Any Truckzilla owners outhere
- Holes in windshield?
- What to do???
- getting my gears perfect
- 3spd trans internals into Savage X Gearbox Case
- Chronic LCG TVP's + Innovative RC LST conversion... pics
- My Mid Tank Mod
- my midtanks
- NEWBY NITRO TUNING-VITAL
- A (Driver) for my Savage!
- Pythonfan Wins!!!!!!!
- Crowd Pleaser Body... pics and info please
- RC Solutions Savage X Roll Cage
- please need help breakin picco.28
- --=Help with nitro trucks please=--
- waht is the stock # for the front bearing on the f4.1
- fail safes
- Engine bog???
- Engine safety review
- carb stuck closed!
- Exhaust header rubbing frame
- What happened to FLM?
- Murphy's Law Strikes the Savage...
- bad news hpi
- ENGINE SHAFT BEHIND FLYWHEEL
- need a roto plate set from my new LRP 28spec 3 engine
- Nubz, Offset beadlocks or Lcg Tvp's for savage x ss?
- going to upgrade and need help
- Odd Spur gear shredding..please suggest..
- exhaust pipes
- slipper clutch question
- Need help with Diff ASAP!!!
- Spektrum Ni-Mh upgrade
- Question for Married RC Guys...
- f 1 4.6 is wat size
- A Transmission question?
- New to HPI Savage
- Big Block
- Eliminate rear turnbuckles?
- xtm 457 exhaust
- innovative r/c/lst shocks
- hoiw can u check out if ur transmission
- DO YOU RACE YOUR SAVAGE????
- will it matter
- Savage GPM alloy Stering kit
- Savage handling
- Eatin em like candy
- Finely a success story!
- cooling?
- change motor ??????
- Hellfire Questions
- Which Glow Plug?
- Settings (diffs, spurs, cb's etc.)
- can you run 'artifically' too rich?
- K4.6 engine problem
- My Savage with a ( New Look )
- Possible fried clutch and bell
- Look at my mods that Im currently doing
- 3 speed question
- Home Made Mugen Tank Installation!
- who's making the best bead lock?
- Savage w/Hellfire body
- hytec 645
- offset rims and tires
- Motors
- 1 way bearing
- RD logics 200cc fuel tank?
- Hump receiver battery on fire
- Building my savage x ss
- Help! Reciever issues...
- my spur gear shredded
- spur gear ?
- Picco P-3 .28!
- help electrics
- JUST MODDIN'
- last question....how to take out a flywheel
- Faster 3 Speed
- Benifits of throttle mod and links
- Engine sealing?
- finally got to bash my savy
- hot bodies gt10
- Clutch shoe placement?
- Differential Shimming
- NEWBY NITRO TUNING HELP PLEASE!
- Stripped servo gear in savage (stock)
- half Tank Lean
- Hot Bodies Dodge Durango Hemi Body
- imex pipe 7301 and a 3spd
- battery question
- Which Shims
- Aluminum e-savage upgrades
- Has anyone ever done a brushless wheely king?
- one of the many vids of me sav x....
- TVP question
- Savage X SS help
- Nosram 28 evo
- mt2
- i think i'm hooked
- what upgrades have u done
- megatech charger
- im thinking about a new enigine for my savage
- Anyone try a Perry Pump?
- Cheapest place for a savage x ss?
- Good Deal or Bad Deal?
- Tire Glue
