PDA
View Full Version : E-Flite Helicopters
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Brand new blade cx2
  2. Blade CX2 loosing power
  3. quad blade rotorhead??
  4. cx2 battery quetion?
  5. Blade 400.. New to heli's..
  6. Blade CX2 High Altitude Lost Signal
  7. blade cp landing gear help
  8. blade cp main motor question
  9. B400 power cuts out
  10. blade 400 one way bearing ?
  11. setting up st-1 on b400.
  12. Help with batterie(s) Blade CX
  13. HBK2 first chrash bunny hopping.
  14. B400 reassembly question.
  15. more cx2 questions. skids?
  16. upgrade suggestions please
  17. first crash 400
  18. B400 pitch set up
  19. Anybody use Revo mixing with an HH gyro?
  20. Honey bee king 2
  21. CX2 blade vibration
  22. lower head
  23. Cypher 3D
  24. HELP!!!! me solve "hunting" CX2 heli issue please
  25. landing skid upgrade
  26. fms
  27. CP Pro orings
  28. Which charger should I buy for CX/CX2 and B400?
  29. B400 O rings
  30. (need help please)servo and speed control hook-up questions on the blade 400
  31. throttle adjustment issues sudden altitude drop
  32. B400 G90
  33. Blade Cx2 acts funny with higher rated lipos
  34. Blade 400 on GWS Floats!
  35. Testing the water
  36. Compare the CX2 to the Esky heli's (Honey Bee fixed and collective)
  37. Blade 400 Moter wires
  38. Realflight G4 and cp+ interface wire
  39. GY401 Blinking!!!
  40. honeybee king 2
  41. Holy smoke Batman! What’s that smell?
  42. Is this CX2 for me, or should I return it?
  43. sk 360
  44. Blade CX2 blade upgrades??? Worth it or not???
  45. Thunder Power Battery
  46. blade cp pro tail motor
  47. B400 ESC mounting and Thunder Power Bat
  48. CX2 fall down go boom
  49. BAD BLADES
  50. S75 Sub Micro Servo B400 tail
  51. Newbie with a CX2
  52. got my CX2 stuck in a tree
  53. My Blade 400 took off by itself, Danger!
  54. longer lasting battery pack for cp pro?
  55. Blade CP flight tracking?
  56. Blade CX Shake
  57. Noob and Blade 400
  58. JR 3400 and 401 on B400. Help sought.
  59. Auto rotation help please
  60. B400 motor and esc
  61. CX2 Creaps backwards
  62. Vibration problem with new B400
  63. New CP+ Glitches
  64. CX2/DX7 Glitching
  65. Blade 400 Flex/Vibrates
  66. help with cp
  67. part numbers for bearings B400
  68. Problems with gyro set up on B400
  69. blade 400 - slop in blade grips??
  70. pitch for cp pro?
  71. 4 in 1 unit for Blade CX
  72. New CX2 ... in a tree
  73. Blade cp pro hovering help?
  74. B400 tail wagging
  75. General rotor blade question?
  76. Eflite stock servo question CP Pro?
  77. help with channel setup?
  78. Eflite Balancing Charger
  79. Power Supply
  80. ESC Fire! B400
  81. Blade 400 Tracking In Forward Flight
  82. Memorial Day Wishes
  83. Hobby question for experienced people
  84. Esky Sim Control
  85. Feathering shafts available
  86. Trueblood swash tool Cp Pro Tip
  87. upgrading the gyro and tail servo.
  88. Who's running DS285's?
  89. I need help please
  90. Blade CX2 Transmitter?
  91. ar6100e Question Blade cp pro
  92. DX6i Radio Problem
  93. replacement blades for e-flight blade cp
  94. lipo batt problem
  95. BLADE 400 LIPO CHARGER
  96. servo alignment
  97. CP PRO Troubleshoot
  98. Show Off Your Dual Tail Motor CP/CP Pro
  99. Make two good batteries out of three?
  100. My 400 spins like a top on the floor
  101. Blade CP - Mode 2 to Mode 1 change ?
  102. looking for training moves link
  103. Bad Battery?
  104. B400 with DX7
  105. Home Field Advantage
  106. Blade 400 Monitoring Menu
  107. lama/CX2 carbon shafts
  108. Showoff! You know you want to.
  109. CX2 with DX6i
  110. Free!
  111. blade cx range problem
  112. Battery Charger Question
  113. Blade 400 & JR 3400 Servo
  114. Blade 400 Radio Setup DX6i
  115. bladecx2 spinning to right
  116. B400 REPAIR HELP NEEDED PLEASE
  117. When carbon blades meet vinyl siding
  118. Blade cp+ w/ gy401 HELP!
  119. Crashed CX2, I think the RX is dead!!
  120. B400 Feathering shaft...
  121. possible problem?
  122. Blade cx or cx2
  123. buying first blade, whats the best?
  124. Blade 400 Sudden Spin Down
  125. Crazy B400 Tail Spin -Help-
  126. Thro Hold
  127. Where to from the CX2?
  128. Flybar Weights??
  129. cx shake
  130. cx2?
  131. DX6i/CX2 Tail Wagging
  132. WHAT IF....?
  133. Congratulations Shane ! ! http://www.rotortech.ca/
  134. dx6i & blade cp
  135. Videos from collective
  136. Spare parts
  137. CX2 4-in-1 HELP!
  138. blade cp and dx6i and ar6200 set up
  139. How is suppose to hover blade CX2???
  140. Exactly how LOUD is a Blade 400 ???
  141. taming down your blade 400
  142. Setting blade pitch
  143. Loctite on feathering shaft screws?
  144. Finished airbrushing & fitting new canopy
  145. CNC Parts
  146. CP PRO tail moters
  147. LiPo charger question?
  148. blade cx flight time
  149. Stupidest crash ever!!
  150. How to setup a DX7i on a BLADE400.
  151. Blade 400 battery
  152. 2 quick questions
  153. IDLE 430
  154. Blade CP tail wags
  155. CX 2 toilet bowl swirl when hovering
  156. align blade grips for blade 400
  157. HS 65 servos
  158. Best servo for the stock gyro Blade 400
  159. Lots of Hop Ups for the B400 on HH's page
  160. What a fun heli
  161. Blade 400 on dx7i help please
  162. Blade CP Makeover Pics
  163. Blade 400 boom tube replacement
  164. Stock head speed in normal?
  165. Flying the CX2 without canopy
  166. Blade CP pro 2
  167. from Bell back to Blade
  168. B400 speed cntrl
  169. No Lift, and HALF Rudder
  170. blade cp+ dx6I
  171. What the 400 can REALLY do...
  172. Anyone seen the Blade CP Pro 2?
  173. E-Flite CP Pro 2
  174. Lama grips?
  175. Blade CP Rotor Pitch??
  176. heli canopys
  177. Blade 400 Cool Down
  178. Gyro's
  179. Blade 400 gear mesh adjust
  180. CX2 LOWER ROTOR HEAD REPLACEMENT
  181. Spektrum Dx6i changing from Heli to Airplane
  182. 400 batteries
  183. blade 400 canopy
  184. considering a CX2 makeover
  185. B400 owners report in. i dont trust the heli mags for some reason
  186. DX6I VS REAL FLIGHT 3.5
  187. HEAD SHIMS
  188. B400 flybar paddle cntrl frame rod
  189. Symptoms of an overtaxed stock B400 ESC/BEC?
  190. Blade 400 or CP Pro canopy clear? Availability?
  191. RESPECT
  192. fs: blade cx2
  193. BLADE 400 SERVOS
  194. Need help, blade 400 3d is too sensitive
  195. Blade 400 charger question
  196. Blade 400 Eflite Servo position sensor gear issue
  197. Newbie Down...I Repeat, Newbie Down and in need of serious help
  198. What Happened To My Blade 400!
  199. Blade 400 tail wagging HELP!
  200. B400 Bent main shaft.
  201. CX2 swash plate, level or not
  202. Im thinking of upgrading already and I need some help.
  203. B400 Under Water
  204. CP downgrade
  205. B400 Gyro Question.
  206. Blade CP+ Uncontrolled Spool Up
  207. Stock E-flite servos
  208. CX2 tail a bit twitchy
  209. Blade 400 with Futuba 7c 2.4 ghz transmitter/reciever
  210. lipo cutoff
  211. Bob Whites videos
  212. linkage lengths
  213. Blade 400
  214. B400 lack of head speed
  215. Blade 400 - Best Replacement Servos ?
  216. twister
  217. E-FLIGHT BATTERY FOR CX: PROPRIETARY CHARGERS ONLY??
  218. Blade 400 - AAAARRRRGGGGHHHH!!!!
  219. carbon boom for B400
  220. Tail belt and servos blade 400
  221. CX2 proportional adjustment Question
  222. CNC Parts and Plastiblades for 400
  223. My Jet ranger video!
  224. Opinion on metal gear servos?
  225. cx2 yaw
  226. CPP main shaft wallowed out after blade strike?
  227. straightening a CX2 flybar?
  228. Blade 400 RTF F mode 0 or F mode 1
  229. B400 tail adjustment
  230. blade 400 servo failure
  231. B400: Blade Pitch
  232. familiar issue w/ blade cp?
  233. CX2 problems
  234. CX2 snow mod
  235. Extremely impressed with new B400!!
  236. Blade 400 Broken Ball Link
  237. can i put a cp battery in a cx?????
  238. New Blade 400 battery questions?
  239. Best Blade CX2 upgrades?
  240. blade 400 issues
  241. Sad day for me
  242. Auto battery charger "clean" enough for blade 400 charger?
  243. idle up Questions B400
  244. eflight charger messing up
  245. Training gear Blade 400
  246. CX2 aluminum outer shaft bearing holder
  247. CX2 flybar options?
  248. Battery go boom?
  249. Things are looking good, so far! video
  250. Blade 400 Power Supply and Battery Questions
