View Full Version : E-Flite Helicopters
- CP Pro tail motor burnt up
- CX2 Rotates with Rudder Input Much Faster One Way than The Other
- Hu
- Sold my DX7, how 'bout Futaba 7C w/ BCP?
- E-Flite Negative Shift receiver
- CX2 Better Landing Skids?
- cp pro Simulator?
- Blade CX2 Xtreme boom skids canopy
- Maybe This Will Help Someone?
- CX Battery Mount Mods?
- CX2 Exstream boom and rotor
- Need info on - How to setup Blade Grips
- E-Flite CP Pro Upgraded
- cx2 neck strap
- Troubleshoot CP motor power burst or Any engineers in the house ?
- Blade CP Pro, Original pitch values
- cp drifts around (even in FS One)
- CX2 New Motors In:No Lift
- pimp my flight: blade cx edition
- 11.1v Lipo + 'device' on Blade CX2?
- When They're Gone, They're Gone! (Blade CP/CP Pro Tail Motor Mounts/Fins)
- Water Break in?
- Saving a lipo
- CP Pro Upgrade Vendors
- Are the stock gassner batterys supposed to suck?
- CX2: Dual or Single Flybar linkage
- Blade CP Pro
- Charging lipo Help
- CX2 will not fly after Microheli & Vortex Upgrades
- stripped servo?
- bladecx2.com
- BLADE CP+ with fuse pics
- CX2 Blade Crashes
- I Got Wobbles!!
- Carrying bag for CX2
- Trouble with pitch on CP
- Elevator Aileron seperation problem
- CP Pro tail motor problem??? Question!
- blade balance
- newbie wish to use bcp with 4ch sim tx
- is it possible??...
- CP+ Battery Question
- Blade CX2/DX7: Hyper-sensitive throttle
- CP pro Spindle and main shaft bend easily.
- Good ole CX2 - WEATHERPROOF!!!
- Lower blades on a CX2
- CP Pro flying with red light on 3 in 1
- CX or CX2??
- cx2 outer shaft spur gear
- I
- trying yet again to
- CX2: Motor siezed
- Which blades for cx2
- Heli fuselage wanted for CX2 or CP PRO suggestions?
- ick
- blade cp upgrades
- what is the next heli from a cx2?
- Best Lipo for Blade CP?
- CP Pro G90 Gyro with DX7 SETTINGS 100-110???????
- CP PRO DX7 QUESTION
- What kind of E-Flite Heli do you have?
- Blade CX2 Li-Po Balancer
- CX2: Left (lower rotor) Motor Bad???
- What is this toggle switch atop of the transmitter?
- CP Pro modified too far
- twister cp2 sixth channel
- Teaching a 6 year old to fly a Blade CP
- Blade CX Motors start
- ICS-50 Tail mod with DD tail
- Forum Firefox login blocked
- CX2 Europe
- CX2 Yaw problem after a crash
- Hey Wolfpackin-NAV lites!!
- blade 400
- CX2:Flybar Weights-Lock Collars Source?
- Good upgrades 4 cx2
- BCX2 Inner Shaft Retaining Collar
- Bad battery?
- Blade CP rotor options
- BCP flips too slow?
- Power Problems short run time
- DX7 and G90 Gyro setup?
- How do you know when the G90 Gyro is set correctly?
- CX2 Flys Again
- cp dual tail surges, but only when...
- HeliHobby CP upgrades?
- blade holders
- Problems upgrading CX2 with Vortex shafts
- ANYONE HAVE DX7 SETUP FOR CP PRO???
- Dual Linkage on CX-2?
- Painting a CF Boom
- Make lighter a blade cx
- Best battery for the blade cx2?
- What does TX mean
- Installing the dynam vortex motors on Blade CX2
- CX-2 ELECTRONICS. NEED HELP!
- BCX2 Lower Blades Slow After Crash
- A New DX7!!! with CP
- How to: Replace your Blade CX2's inner shaft and upper hub
- Brushless tail motor......
- New CX2 for a Newbie
- Blade Rotation
- blade cx2 tail wagging
- I have mastered my hb fp, now what?
- blade cp
- delete
- CX/CX2 Heat Sinks, Heat in general and you
- Blade CP tail motor fix
- short flight time
- NEWBIE WARNING! Blade CP Pro Tail TWITCH
- Think My Motors Are Going
- Blace CP pro power loss after dual tail motor instalation
- got a lama v3,now want a blade cx2
- green light turns red on 4 in 1... help please
- cp pro question
- 4 in 1 Question
- Remove ca/superglue?
- Blade CP Pro problem - a little help please
- Wires too short to attach new tail motor?
- Eflite Blade 400 3D RTF w/ DX6
- adjusting the pitch control
- Brushless and three in one.
- Trainer Port?
- Quick loss of altitude with the CX2
- Gyro Question??
- Blade CP pro dual tail motors
- CP Pro twitching
- A Newbie with a Blade CP Pro???
- Stock CX LiPos Not Holding Charge
- Blade CP Pro lipo charger?
- cx2 vibration
- CX2 Pitching Problem
- PROBLEM W/UPGRADING CP-PRO PER MANUAL
- Pics of a Modified CX 2 Pro
- BCPP - Bye!
- blade cp or venom night ranger xl? which 2 buy?
- General blade pitch help / Eflite pitch gage help
- first heli
- Im a Knee-you-bee-pilot in need of some tips.
- BCPP and BCP+ Whats the difference?
- CX2 Blade Strikes??
- My 4 in 1 won't arm
- blade cx upgrades
- Servo Adjustment-CX-2
- BCP major Vibration before takeoff
- CX2 and its relationship to E-sky / dynam
- cx 2 fly bars
- cx2 inner / outer shafts and gears
- NEW GUY TO NEW GUY "HELP"
- CX2 motor runs constantly
- Dual Tail Power
- CP Pro Interference! STATIC OR RADIO OR???
- My Blade CX just flops over
- Blade Grips
- Bit of a Problem!!
- Heading Hold Gyro.... How do I set it up?
- Paging those with microheli cnc hub for blade cp.. help
- cx2 gears
- CP Pro assembly, setup Info/Thread?
- 4 in one problems???
- Grass landing and take off with the Blade CPP
- blade cx not getting any lift
- whats wrong with this picture?
- Noobie CX2 help!
- GWS Tail Motor
- blades not spinning anymore
- blade cx2 run time
- E-Fllite BL setup question
- BCX violent wagging, then spinning
- Heli-max tail mod for Blade CP?
- Blade CP Pro not flying correctly
- CNC head
- Blade cx gyro problems
- Tail Authority
- CX2 blade replacement
- BCX2 Twitching in the Air
- need some part no.s dd tail,dual motor
- Blade CX2 Hover Issue???
- Eflite Aluminum Head vs Micro AL Head For BCX2
- Which Lipo for Blade CP?
- Futaba T9CHP Transmitter
- new super skids 3d =)
- HELPPP TRANS ACTING WEIRD
- Blade CP Pro servo noise
- Right servo glitching
- Hm, took the ESC out of the 4 in 1
- sport conversion kit cx2
- cp pro / gy401 problems..PLEASE HELP!!
- New parts! Microheli spindle shaft to long?
- cp pro problem someone please help im going crazy
- MicroHeli Ineer Shafts Too Short
- blade cx2
- It doesn't get ANY worse than this
- cp brushless recommendations please
- e-flite blade cx2 or a teamassociated rc18t
- Do you customize your blade canopy?
- 3-in-1 red light during flight?
- Blade CX Bodies
- Blade CX - Help Me Please!
- CX2: CF Boom & Front 3rd Stock Tail
- CP Pro servo radio sensitivity
- CX2 & Dynam Vortex Flybar
- CP Pro Twitching????? HELP! Suggestions!
- BCX2 Maneuverability Limits?
- Help with triming of a BCPP
- OFly Blade CX knock-off
- To use the trim or not?????????HELP!
- after-market canapies
- Which radio for my new BladeCP Pro?
- CP Pro boom
- 7.4V 800mah Battery Below 3V - Help how to charge?
- BCX2 Gear Set Bearing Question
- Blade CX - Help Needed.
- T-Rex or Blade Cp
- please help with Blade CPP problem
- CP Performance Help
- Blade CX2 Rotor Blade Replacement
- Help Cp Pro with Orion 300 Slow max motor
- Blade cx2
- BCX2-MicroHeli Upper Blade Grip/Head Question
- Battery for Blade CPP
- Blade CX Piro Figure 8 ?
- CX2 and CP Pro supplied tools
- Cannot fix my CX2
- Be Careful Using the CF Tail Rotor
- Need more power!
- Securing the lower head assembly (CX2)
- Move from CX to FP Heli...
- Eflight CPP
- BCX2--What Other Heli's Parts Compatable?
- CP Pro 3 in 1 or speed contol??????
- Direct Drive Tail--CP Pro
- good news =)
- Help Me Please CURSE YOU CP PRO
- CX flight too good to be true
- Ducted Fan Tails??
- Blade CP PRO Tail mod
- Power Shutdown, Blade CX2
- Blade CP Tail Rotor moved upwards MOD
- 4n1 Flashing, not working!!
- Flipping Blade Grips on CP Pro
- Tune up time
- My CX2's Flight Problems
- delete
- Logbook program
- cp tail. dual or brushless?
- cx hovering problem
- CP PRO 3 IN ONE RED LIGHT?
- Flybar detaching in mid air
- BLADE CP With JR RADIO XP662
