PDA
View Full Version : E-Flite Helicopters
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32
  1. G90 Sub-Micro Gyro On A Blade CP
  2. nomex socks
  3. A question about the Cp Pro ...
  4. Blade CX2 battery and balance charger questions
  5. My CX/2 Experience
  6. CP pro barely getting off the ground??? help!?!?
  7. CP PRO Radio question?
  8. Which tail upgrade for CPP?
  9. For a Beginner heli pilot
  10. New to CX2, woes, suggestions, etc! :)
  11. Can you get more forward thrust in a CX?
  12. Strange Occurance - Blade CP Pro
  13. blade cx/cx2 recommended upgrades thread for newbie's
  14. E-Flight CX Battery???
  15. Balancing main blades
  16. CX inner shaft Alterative for use with Alum upgrade..
  17. Should I purchase this
  18. Avionics Slo-Max 300 for Blade CP
  19. problems with electric heli -dragonfly
  20. Pitch Gauge
  21. carbon fiber props for CX2
  22. Blade Cx2 Range
  23. Fried ?
  24. hdx300 is it any good?
  25. Hirobo XRB Stabilizer bar on Blade CX2
  26. Helpppp!!!!
  27. damaged 4 in1 ?
  28. microheli.com?
  29. ***??
  30. cp pro 3 in 1
  31. Blade CP Pitch Problem
  32. Thunder Power batteries...
  33. blade cp help
  34. HOW CLOSE IS REAL FLIGHT G3.5'S RC HELICOPTERS TO THE REAL MODELS?
  35. Blade CP/CP Pro Mod's
  36. Heat sink for CX2
  37. Lower head component sold seperately?
  38. Belt Drive Conversion Kit
  39. Low Skids Cx2 Prototype
  40. Receiver Question EFLH-1024
  41. blade cpp tx cable with fms-free?
  42. My CX2 W/ Microheli Inner Shaft & Boomtown CF Boom!
  43. Cx Blades with no lift
  44. swash raises with throttle
  45. Getting into this sport
  46. reversing blade cpp blade grip?
  47. brushless current draw?
  48. Trex or Raptor??
  49. balancing charger
  50. Droopy blades.
  51. A couple of CP Pro questions
  52. blade CX2 trouble
  53. Blade CP for Aerofly ?
  54. Final word on BB motors for Blade CX/2?
  55. Repairing carbon fiber
  56. Arg! keep losing retaining pins!
  57. Flat or symmetrical
  58. tail motor on CP Pro
  59. Belt Conversion Kit
  60. Blade CP Freaks Out
  61. preiflight simulator for the blade cx cp and cp pro
  62. Blade CP Pro Tx Mode 2 to mode 1 conversion
  63. extra 4-1 for BCP...
  64. Tail wag?
  65. CX2 blade clack
  66. DX6 battery
  67. DX6 and CP servos
  68. Cool CX2 Mod for "hard" landers
  69. Transmitter for Simulator?
  70. blade cp and telebee hh gyro
  71. CX2 right stick works opposite
  72. G90
  73. another sticky collective fix
  74. having a forward flight prob with my CX2
  75. Vibration / Stabilisation Problem Blade Cx2
  76. FS One users, read this.
  77. bcx2 throtle mod oops
  78. BCP questions
  79. Losing power during brief hover ...
  80. Trug, got a Question for Ya.
  81. Questions+ CX2 fly bar and Microheli blade grips
  82. Zero Blade pitch for Blade CP
  83. CP Pro Flybar Paddle Question
  84. "Outdoor-Size" Coaxial Helicopter?
  85. Bind Plug
  86. g90 install and setup questions?????
  87. More shims with a Bell Hiller?
  88. Radio Glitching in CX
  89. Blade CP vs CPP
  90. whats needed for a DX6 and Blade CP?
  91. rotor blade balance
  92. CPP Microheli Autorotation Gear/Hub and Shaft
  93. blade cp pro rtf and hitec transmitter
  94. Blade CP & DX6 issue
  95. Cp Pro & DD brushless Tail
  96. full speed red light?
  97. Tail moving on CPP wrong way???
  98. E-flight li-po charger
  99. Blade CP Pro -Scale Commanche
  100. Swashplate separating
  101. How about this for a Scale Fuselage?
  102. Belt drive or tail motor
  103. Blade CX2 problem
  104. cx2 circles
  105. Blade CP Pro -- No lift
  106. blade grip removal ???
  107. BCPP troubleshooting
  108. CP compared to CP PRO
  109. cx-2 rotor help!
  110. A cool carrying case for the CX
  111. Tail Motor or something else? Help!
  112. too much pitch?
  113. Servos twitching (Revised post)
  114. CX2 blade weight waaaay off balance......
  115. Has anyone ever ordered the stersman CX tail boom from charlieshobbies?
  116. CX2 Tail Boom Question
  117. A cool idea. Works wonders.
  118. Blade CP Complete Conversion kit for an all aluminum Precision Heli (belt driven tail)
  119. brushless cx(2)?
  120. Craziest real heli 3d video
  121. Micro heli lower hub problem
  122. Brushless tail setup?
  123. 3 cell in blade cx , cx2 thread. ?????????
  124. FS One adapter
  125. Silicone lube good / bad?
  126. Update: Xtreme Production Ball Bearing Motor Upgrade for CX/2
  127. For people using tp batts (910’s). stock charger?
  128. increase your cyclic response by 50%, NO MODS NEEDED, BCPP
  129. charging error
  130. dx-7 and cpp
  131. Blade CP Brushless upgrade
  132. New Kit Ideas
  133. A helicopter poem
  134. Setup Info Needed...
  135. Transmitter Question
  136. Eflite CP Pro Manual
  137. New CX2 Marines body
  138. Troubleshooting my CX2 electrics....
  139. blade cx pro PROBLEMS???
  140. Blade cp tx mod ?
  141. HELP!!!! BCX2 LOSES ALL POWER MID-FLIGHT!!!!!!!!!
  142. From a Newbie to Helis
  143. DD tail motors
  144. How do I know when the tail motor is going?
  145. CP spinning out of control!!!
  146. Installing a computer radio in a CP Pro????
  147. Cx 2 as first heli?
  148. Constantly Breaking Blades - Alternatives?
  149. question about using different battery in Blade CPP
  150. Aerial Photography
  151. New Designs
  152. New CF tail boom by ESP for CX/ CX2
  153. tail motors last with lithium
  154. Esky Honeybee CP2 / Blade CP Same??
  155. My CX2 does a beautiful clockwise swirl (help!)
  156. searching for bdavidson's (blade tuning thread)
  157. Got my new boom installed on my CX!!!
  158. Blade CX2 Lower Blades Shortage?
  159. Blade CX 1½?
  160. CP Pro Simulation
  161. CP/P Warning
  162. My CX Mods (so far)
  163. CP Super-Skids....
  164. Blade CP Newbie
  165. Fixed the Glitch!! Dirty Pots CP Pro
  166. CX2 lower blade tracking
  167. DD Tail - Bad/fried motor?
  168. Frying 4-1 unit
  169. Blade CX Push Rod Adjustment
  170. Where are all the parts?
  171. Hitec HS55 vs. S75 Servos
  172. My Totally Fictional Heli Crash!!
  173. Ultimate CX2 Mod Guide
  174. Blade CP Pro Spectrum DX6
  175. Loc-tite + RPM
  176. Blade CP Help
  177. How weight blade cx can lift
  178. Allen wrench suggestions?
  179. Blade CX Tail Boom Kits
  180. Y-harness servo leads on a CX?
  181. CX2 please help me with right stick....
  182. CX not responding w/ new parts
  183. Newbie asking for thoughts!!!
  184. CX CX/2 video with prototype tail boom
  185. CX, CX2 and Vortex and ??????
  186. CX2 and police body
  187. Brushless - Battery Life and DD tail CPP
  188. fixed servo, now more problems
  189. Need some more help -trim CX2
  190. Help with setting up BCP with JR7202
  191. Bind Plug Puzzlement
  192. Pitch Guage
  193. Control link length
  194. tale of all tails
  195. Hovering easier sideways, or am I nuts?
  196. What tools do I need for CX2 ?
  197. E-Flight Blade CP Pro or Venom Night Ranger 3D Micro?
  198. Have your CX's new blade sets arrived out of track?
  199. Blade CP Pro jumps up and down.
  200. Blade CP Hovering Troubles
  201. Blade CP Bell Hiller?
  202. DX6 and CPpro
  203. CX2 - upper and lower gear - need some help
  204. blade cx2 controlls reversed.
  205. Upgrade motors?
  206. How to remove main blade grips from rotor head?
  207. CX with CX2 electronics
  208. Blade cp Pro DD Conversion
  209. Blade CX2 Back and Forth Motion
  210. BCPP Tail Boom replacement
  211. Just bought a Blade cx2 and having a prob
  212. remote tension adjustment
  213. e flite cp pro trainer
  214. burnt 3in1 repair
  215. Did your new Blade CX2 come with faulty Servos?
  216. Pivoting blades for CX2?
  217. CX2 motor heat sink(s) education please....
  218. Blade CX has no lift
  219. BCX Servo Travel - how many degrees?
  220. Blade cx2 and DX7
  221. Interesting "Toilet bowl" effect story
  222. Vortex parts on Blade CX2
  223. Possible servo problem ?
  224. Cx2 To BCPP
  225. New head which to get?
  226. CP-Pro question lookin 4 help??
  227. Hi guys. Newbe here
  228. Any one experience this on their CX2?
  229. Bad 4 in 1???
  230. Blade CX2 modified for aerial photography
  231. Ran down my Lipo too low, now what?
  232. CX2 control unit
  233. blade clack?
  234. Li-Po Question...technical
  235. Ordered CX-2 CF Boom, MicroHeli CNC Inner Shaft, Swashplate, & Lower...
  236. Finally got a hover
  237. microheli dual tail motor mount
  238. blade CX pro
  239. falcon 40 flight sim setup help
  240. gyro question
  241. CP Blade trouble shooting...
  242. E-flite Celectra charger for CX and CP
  243. CX PROBLEM NEED HELP DESPRATELY!
  244. Extra channels on CP 4-in-1?
  245. Tell me
  246. CP Blade main motor question
  247. cx2 charging problem?
  248. Switch Transmitters Blade CP Pro
  249. Best aftermarket main gear and shaft
  250. CP Pro TX Glitch-Make it Stop!!
