View Full Version : E-Flite Helicopters
- Trouble with BCXR3
- Any Help Getting MSR to turn Left Smoothly?
- Blade MSR - Some questions for my fellow fliers
- problems with mSR spinning out of control (not TBE)
- msr tail rotor
- msr board
- Big Lama 3 in 1
- questions using LP5 tx with mSR BNF
- first single rotor
- balls used for tail and training
- MCX Outer shaft main gear question
- nothing, re-post
- CX2 Swash Plate
- CX2 will not failsafe throttle - anyone else?
- CP tail rotor conversion.
- New SMC lipo for Cx3
- Removing MCX motors
- Just got a new Blade 400 (pic)
- New Servos for Blade 400
- Mcx question
- Resoldering loose/broken Blade mSR motor power socket
- Just got the Blade MSR!!!
- mCX inner shaft
- sticker
- Smoked my CX2
- e flite battery charger
- eflte tandem heli need help on how to replace the 5n1 board
- Breaking in motors
- Problems with the tandem heli
- Blade CX-3
- Your opinion counts.
- Can I bind an E-Flite heli to an Esky Tx?
- My mSR landing gear fix
- help with cx2
- Flybar Links for CX2????
- problem with eflite cx3 3n1 ctrl unit?
- CX2 Servo Noise
- MSR Yaw/Rudder Trim Issues
- Stuff new to me :) MCX adjustments
- Blade cp pro autorotation?
- Blade 400 3D - Tail Slider - Lubrication??
- MCX Controller remember last setting?
- Cool Hi-tech CX2 Project
- How to test blade MCX parts?
- trims are maxed out!
- bcpp2 bent main shaft
- How to securely mend a broken off mSR shell support prong
- hs-5045hb on a b400?
- Please, give me an answer!
- New MCX S300 question on maneuverability
- looking to step up
- just purxhased:Blade msr
- Mcx/Msr Controller
- Bad CX2 3 in 1 Mixer
- Request To Horizon
- CX2 lower blade tracking problems
- blade 400 3d
- cx2/3 hard core tail twitching
- found a new little trick
- MSR taught me how to fly ccpm
- MSR Upgrades?
- Blade MSR Main Rotor Grips - Washers and O-Rings
- FYI if you decide to upgrade from AR6100E-AR6110E
- Will a 150mah work in a E-flight MCX S300?
- CX2 Brushless Kit
- CX2 - Flying FAST
- cp pro controller
- Help! upgrading my cx2 from 4-1 to 3-1
- CX2 oscillation issue
- Help with flimsy/breakable Blade mSR struts
- blade msr throttle cut off problem
- Blade mSR main rotor shudder problem.
- Trouble with mCX S300 Binding
- MSR Trim Issue
- mCX S300 yaw
- CX2 help Outter shaft with main gear w/ PICS
- Futaba 7C 2.4 GHz battery questions
- eflh2219 mCX Flybar - Which is correct?
- Blades on MSR
- New Blade SR: collective pitch!
- MSR Question
- An easy way to balance MSR blades
- Blade CX3 spinning out of control
- Caliber 400xp vs. T-rex 450xl HDE(bare bone kits)
- HELP! Blade MSR Upgrades+Spares!
- MCX problems
- want to get a mini but what one
- No fly zone
- Blade MSR banks right in forward flight
- Came home with some new Helis...
- Better Blades for MCX?
- CX2 Heli: Important Blade Selection Tips
- New Blade 400 is not responding
- Death of MSR?
- Storing Lipo Batteries
- HS-55s are NO JOKE
- Noob in need of help with blade cx2!!
- Blade MCX Tandem
- Great little heli! Blade MCX
- Monitor Those LiPOs! Tip!
- Blade mSR main frame
- cx2 swashplate issues
- why msr more stable than cp?
- B400 tail grips wobbly
- Forward Flight; MCX S300
- CX2: Do you have to cut the flybar to remove the rubber tip?
- Fusalage?
- cx2 lower rotor head question?
- MSR - is the DX6i worth buying?
- case for blade msr
- 5th chanel on BCX2?
- CX2 4 in 1 problem
- Best batteries for an MSR?
- AR6200 in a Blade 400
- Blade msR Problem
- MSR Paintjob, Anyone Else?
- Blade msR Problem
- Blade mSR - not enough lift / power
- CX3 Drift
- Binding
- newb... i need blades cpp2
- Blade MSR blade grips aluminum or not?
- First Auto-rotation gone wrong why???
- Newbie and need help
- LP5DSM DIP SWITCH SETTINGS FOR MSR
- Few questions about the B MSR
- Glue for Msr?
- I got a slight problem with my Msr
- msr problem
- cheap China blades
- Blade MSR, The Hype.
- Binding the blade 400
- MSR leaning but hovers in place? WEIRD!!!! HELP?
- MCX...adjustments, upgrades, I like it!
- B400 setup issue's!!!! Help!!!
- Broken Tail Boom on Blade CP Pro
- Blade MSR... is it fun?
- MRS wont respod to inputs
- Would anyone want to see a Blade micro CP?
- Blade CP Pro 2 Motor Upgrade
- Anyone need a blade 400?
- servo problem?
- Hacker* Blade 400 Upgrade?
- Struggling with single rotor basics V2
- What is the Blade 400 like?
- CX2 Jet Ranger Tail "Tip"
- Blade 400 Hover Issue
- Loops went great.. then crash!!!
- tail drift on blade 400
- MSR/MCX battery life
- Chirping sounds from gears
- Eflite blade mcx s300
- $1.50 30 lots on EBAY OFFICE CLEAN UP
- CX2 or CX3
- Celectra charger from Blade MSR
- BCX2 troubles already...
- Wich micro heli will get me ready for a full size rc heli
- blade msr
- binding e flite mcx and msr
- binding e flite cxs and msr
- e-fight 30-amp pro brushless esc
- Got a couple of MSR questions here
- blade cx2 a good choice?
- New Blace mCX S300 Owner!!! New Pilot Too!!!!
- CX-2 replacement battery suggestions
- New CP Owner
- Li-Po Charger
- NEW! - Blade mSR - MIA Nano Nellie Body and Trike LG Kit
- Mcx issues with glow in the dark parts
- Official E-Flite Blade MCX Tandem Rescue
- cx3 problem help!!!!!!!!!!!
- BoomTownHobbies needs for test pilots again. MCX, S300
- Help with new mSR
- anyone know if there going to come out with symmetrical blades for the MSR
- Loaner Blade 400 Video
- CX2 Battery - Holy Cow!
- MCX issues after replacing inner shaft
- Blade CX2 newbe
- CX II Speed control
- when blade 400's attack
- cx2 extreme motors, who is running em? rcrivesud questions as well..
- TANDEM RESCUE
- Aluminum Swashplate - CX2
- CX2 Transmitter - Dual Rate
- CX2 Upgrades...?
- CX2 New Lower Blades - DEFECTIVE?
- Blade MCX S300
- Blade 400 w/ a streamer attached
- Sick BCX2
- MSR: Opinions on MicroHeli Aluminum Blade Grips
- Stuck Throttle on Blade CX
- Blade MCX vibration issues after crash....Help!!
- Happy Thanksgiving
- Need help choosing next bird
- eflite 400 throttle hold switch
- Need Help With My MCX
- CX2 and DX7
- Blade CX2 - Is it normal to have to readjust swashplate when ....
- TEACH ME HOW : m-SR
- Help blade 400 settings
- Micropter by Propel
- Blade 400 Problem
- So Who Whould You Call?
- Blade CX2 Charger - Will eFlight Radian Charger work?
- throttle and pitch vures for cp+
- new: please help
- blade 400 just flying
- NEW NEW UPGRADES MCX ,S300, TANDEM RESCUE
- MCX weak lift, slow CCW rotation
- EFLIGHT TANDEM RESCUE
- My Grandson LOVES my MSR!!!!!!!!
- Awesome !!! MSR UPGRADES
- change CX2 to Mode I
- new blade cp+
- MCX Spins left at full throtle
- MSR and Specktrum dx6I
- mSR servo questions that ANY OWNER can answer for me... PLEASE!
- MSR Mildly Erratic Flight
- MCX Outer Shaft Retaining Collar ?
- blades
- toilet bowling MSR
- Need Servo Help
- Helicopter Pitch and Roll
- Need Help With CX3 Gyro and TBE
- Should I use the timer, or is mSR LVC safe?
- mSR Canopy Trimming Anyone?
- MCX S300 problem- does not lift off
- need help!! will paid
- changing from 4 in 1 to 3 in 1
- Cp pro 2 main shaft problem
- Blade CX2 or CX3?
- need help blade MCX S300 problems
- binding
- Need Help Choosing A FP
- Blade CX3 problems Help!
- Tip for beginners - Blade mCX & mSR
- Blade CP 4 in 1 flashing, I need help!
- Aluminum mSR head parts
- CX2 Hopups
- Where to buy mSR cary bag or case.
- MSR swashplate slop?
- upgrades that will never been see again
- INHIBIT Setting for Blade 400
- HK450 Heli's...?
- CX-2 Blade Tracking? Swashplate levelling?
- LP5DSM with Simulators?!
- Zippy 2200mah for $13.99
- Money to spend....Need advice!!
- trouble with aluminum lower rotor head
