View Full Version : E-Flite Helicopters
- B-400: GYRO- re-re-revisited :P
- first flight with a blade 400
- dx6i can any one help with basic set up for cp pro
- need dx6i set up for cp pro
- futaba 401 gyro problem
- Destructive tail vibration problem, B400
- New to Blade CPP
- CX2 Major crash.........
- First Major Crash
- What gyro for my CP Pro???
- Help Blade 400 - THANK YOU
- CP PRO Tail issue
- blade 400 gyro problem
- CF vs wood blades
- Crashed Blade CX..Help
- ok,now what? blade 400
- got a problem
- Quick Brushless question.
- Help With Blade 400
- 6XAS?
- Blade 400 tail rotor or gyro problem.
- You know your addicted when (part 3)...............
- b400 carbon fiber flybar
- Plain is sexy.
- Cx Upgraded parts pics!
- Blade cx2 Enoying problem
- Blade 400 Belt To Lube or Not?
- Welp my CX is dead :(
- Mod/upgrades for CP+
- CX2 gone brushless?
- Blade CP+ turning off
- Top Main Gear Rubbing Frame...Why?
- Eflite blade cp pro
- New b400 pack
- blade cp pro retaining pin
- Blade CP+
- Upgrading from a CX to a CP or CP Pro...
- Blade 400
- help with breaking in motors for cx2?
- Blade CX2 with 3 cell?
- BLADE CP Help PLEASE
- Rudder Trimming
- Aerofly with Eflite TX
- motor are way to hott?
- ???What?
- Plastic flat bottom blade/Blade 400
- Help with Blade CP...
- Flyrcrivesud = Great parts - slow shipping
- CX2 owners ever do this for a kick?
- Blade 400 & G90 Gyro
- The mCX2 arrival date?
- Dead B400 pack
- TBE ( TOILET BOWL EFFECT ???
- Trex 450 AND Blade 400 owners
- I GIVE UP!!!!!!!!!!!!!!!!!!!!!
- Blade CP Pro build videos
- Any breakage problems with CX2 CF tail boom?
- Blade 400 3d idle up problem
- Shaft Replacement CX2 Instructions
- Confirmed date?
- B400 Replacement Motor
- Retractable landing gear for CX2
- Battery issues w/ 7.4v Li-Po.
- How to Improve Blade CX/2 perfomance etc.
- Running Hitec HS65's?
- Wierd problem (B400)
- Vibration mistery on Blade 400
- CPP questions
- Blade cx2 Rising Problem
- Who Makes OEM CX2 Battery For E-Flite?
- Heli and field frustrations..
- alloy blade grip trouble
- CPP with G110 TONS of questions.
- BLADE CP THROTTLE JUMP?!?
- curious to know????
- Futaba S9257 in Blade 400
- Time to move up to the Blade 400
- Blade 400 battery won't charge or faulty charger?
- E-Flight 3S balancing adapter for Equinox
- E-flite Blade CP Pro RTF
- CP Pro and Futaba 9C programming
- gy401 and Futaba 9650
- Blade CX2 Problems
- Blade CX control issues
- What did I mess up now
- wobbling shaft
- CP Pro 2
- "E-Flight" B400 UPGRAIDS yay
- Blade CX2 Aluminum
- Blade 400 won't initialize
- B400 Tail Drive Pulley
- When people ask you...
- HELP Gyro trouble ????
- G90 Gyro on CPP
- Question about Blade CX2 Control Unit
- Soldering Battery leads
- Blade CX2 VS ESky Dauphin CoAxial
- help my heli thinks it's a seesaw. cpp
- B400: grip flip, gyro issues revisited.
- CX2 YAW PROBLEM BOTH DIRECTIONS...LETS SEE HOW GOOD YOU ARE!
- New to forums and RC Helo's
- Lama blades on a CX2 ??????
- Blade CP Pro Tips Please?
- Looking for aluminum blade grips for CX2
- Upgrade Servos-Blade 400
- Reading PPM signal from Blade400 DX6i
- e-flight blade cp tail spin
- did i kill my battery???
- BLADE 400: if it feels wrong..it probably is.
- Air wolf body for CX2, where 2 get one????
- CPP out of control!!!
- Engine Stopped working CP PRo
- Awww the drama
- Eflite stock tail motors
- Heli-max blades on the CX-2?
- Started flying on the third hole!!
- Blade 400 Gyro
- First Flight With The Blade CP Pro
- Are Aluminum upgrades worth it for CX2?
- Will Mega Power 850mah lipo battery fit CX2 charger?
- BLADE 400- stock gyro setting in TX.
- CX2 trim issue
- NEW! E-Flite Blade Micro CX
- Blades Finally Hit...
- Blade CP pro
- CX2 Transmitter
- Blade 400 that sputters at 1/2 to 3/4 thrott
- Bell hiller grips larger than stock?
- Inexpensive wood Blades for the Blade 400 and Belt CP
- Need help guys ..
- CX2 Flight Duration Issue
- the blade 400 is sooo responsive.
- Eflight charger vs esky charger??
- Blade 400 Battery ???
- Whats the resistance of a stock motor?
- Cutting Rx Antenna wire on CX???
- Blade CP Pro controls messed up?
- questions
- Help Needed - Blade 400 Upgrades
- B-CX2 w/ Blackhawk scale body.
- making CPP easier to fly
- Embarassing battery question
- quick question? blade 400 110 gyro
- Help, bell hiller upgrade now struggles to lift!
- JUST bought a blade 400 today, WOW.
- tail spinning?
- Blade 400 3d DX6i setup please
- Bell hiller upgrade....WOW!
- Shorted a lipo for a split second, is it safe to use?
- Blade 400 Upgrades etc..........
- CP Pro Motor option?
- B400 & G90
- about Blade 400 upgrade
- I just Need to know how servo arms sit on servo's
- Direct drive tail on blade cp, any problems?
- is there a size 200 helicopter?
- I like my cp+
- How to setup CX transmitter for buddyboxing
- AccuCycle Elite power supply for Eflite Charger?
- 401 help?
- brushless w/ blade cp pro
- Do direct drive motors burn out as easy?
- Blade 400 third flight (I love this thing!!)
- b400 tail rotor & throttle lock questions
- NEWB Blade 400 ??
- b400 charger needs e-flite power supply?
- http://www.rcrivesud.com/ yes or no
- Father and Son getting into the hobby.
- blade400 esc?
- Battery disposal?
- BLADE 400 RUNNING PROBLEM HELP!
- Cheap Gyro alternative
- Problems with blade cp: HELP!!
- Whats a good asking price for my b400?
- swashplate lubercation
- Scale bodies
- dx6i to dx7?
- B400, head o-ring?
- CX2 servo linkage
- Blade 400 Glitching
- Esky Comanche fuselage fit the blade CX2
- blade cx went for a swim and now having 4 in 1 problems
- what would it be worth if i were to sell it
- Blade Cp Transmitter Help
- CX2 swashplate sliding down-help
- Blade 400 gyro setup???
- Tracking suggestions HELP!
- 11.1 v 800mah in my cx2
- Blades for cx2
- Blade CP Pro Tail motor going?
- Blade 400 AH-HAH's
- Blade CP PRO2
- Blade 400 factory settings?
- Blade CX2 battery in a CP????
- Blade 400 with hs65hb's
- blade 400??? plzz!!!!! help!!!!
- cx2 rotating clockwise
- Blade 400 Feathering Shafts HELP!
- Blade CX2 Defective blades........
- cx/2 and Dx7
- Iraq Soldier's Donation Fund
- SET-UP: linkage/servo/blade Q's
- CX2 rear fusalage
- Blade 400 going on ebay today
- Crashed my 400 Adjustments needed
- Blade CX2 Indestructable Skids
- Blade CX2 w/6100 swashplate mixing
- night flying a 400
- mast size
- S Needed!!
- CRASH: operator, or......
- Blade 400 - Vibration Isuues
- are these blades any good for cp pro?
- Blade CX2 Pulls A 100 Foot Wire Through An Atic
- Head cap screw for cp pro?
- Xtreme motors for cx2
- B400 Tail Help!
- Blade 400 Tune - Ups
- How do you use a pitch guage and set tracking on a Blade 400
- cp + problems grounded
- Mixer/ecs/gyro placement on CX2
- Is a blade cp really that bad?
- eflite 400
- Help!! Blade 400 Servo Upgrade
- battery charing problem
- Blade CX2 + 450SE V2 batt?
- SCALE -flying setting DX6i...?
- definition of "mistake" for heli bail out?
- next step after cx2?
- Blade 400 Battery Connector/ Alternate Batteries?
- Gyro Issues GY401 on B400
- CP Pro FM Receiver
- cp pro hop ups' and upgrades? for better 3d
- head speed cut out
- blade 400 motor care??
- **The NEW Blade CP Pro 2 RTF 2.4**
- fixed my cx2 no lift problem
- Changing out the gyro questions
- Blade CX2 Battery Holder!?!?!!??
- blade cx (swirly bird)
- My Raider Micro Heli
- Help! CP PRO tail rotor motor question.
- Large Scale High performance CX2?
- 400 main gear cracks at bearing, happen 2U?
- Blade 400 not Lifting
- Any pilots near Raleigh, NC
- help with useing carbon blades on a cp pro
- Let's just talk heli
- looking for a cheap blade 400
- better outdoor flying with cx2?
