PDA
View Full Version : E-Flite Helicopters
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32
  1. BLADE CX canopy removal? HELP!
  2. Thanks Everybody!
  3. CX2 Shortened Flybar w/Paddles
  4. Total newb needs setup help
  5. Do the flat bottom blades make a big differance?
  6. E-flite Blade CX2 Trim Problem
  7. CX2 heat and 4-in-1
  8. CP Pro Tail Boom
  9. NEW E-sky HH gryo for $38
  10. CX2 servo "noise"
  11. bcp and fuse problems
  12. E-Flite Blade CP2 w/Spektrum ???
  13. free cp pro
  14. CX2 Metal Whine
  15. The end of the road of my lipo?
  16. CPP gyro trouble.....
  17. Cloaking Device for Blade CP Pro / Just for fun
  18. BLADE CX2 vs. HIROBO Lama
  19. eflight vs esky - experiences owning both...
  20. need some help please
  21. 3 Volt Light
  22. tracking issue
  23. When & How to use idle up switch
  24. 9yo's first CP flight - fixed vid link
  25. disk for the CX
  26. DX6 & CX2
  27. Time for me to move on
  28. Blade CP tail rotor whipping/overspeed...
  29. CX2 Question
  30. $8.00 Blades for the cp pro
  31. Pros and cons of Blade CP Pro?
  32. Howdy boys! I'm back! And; just ordered a CX2!
  33. blade cp
  34. Spektrum DX6 & Gyro Setup for Dual HH Selection.
  35. Setup for Spektrum DX7 and Blade CP Pro?
  36. pitch and yaw response on CX2
  37. cx tail
  38. Problem with hovering a Blade CP
  39. CX2 w/ NAV LIGHTS!
  40. CX2 Flight / Crash Videos
  41. would new servos be best BCP upgrade?
  42. couple of newb questions for CX2
  43. BLADE CX2 TALK
  44. CX Aluminum Lower Head
  45. Charged battery question?
  46. more questions Blade CP
  47. 4-in-1 vs 3-in-1
  48. To the moon Alice!!!
  49. Strange problem with CP Pro
  50. Quick fix for CX tail drift. december 2006
  51. CX2 Warning - Read if you adjust your servo arms!
  52. Bored with the CX... What Heli should I get next?
  53. BLADE CX2
  54. did i make the right choice?
  55. help a noob
  56. My funny way of adjusting 0 pitch without a pitch guage
  57. Best, cheap batteries for the CX2!
  58. More pictures of my Blade CP
  59. pictures of GWS tail mod for my BladeCP
  60. Should I Take The Next Step?
  61. New projects
  62. Swashplate Position on CX
  63. BCPP flies OK, then not
  64. honey bee fp notar experiment
  65. CX-2 Carbon Fiber Tailboom?
  66. FSOne and Blade CP Pro question
  67. CP Pro--Gateway drug?
  68. CX2 Battery/Equinox Balancer
  69. Separate gyro and Rx
  70. JR Digitals for Blade
  71. no lift off on blade cp
  72. new Tx(Futaba 6exh)
  73. Weak power on my cp
  74. lipos
  75. CP Trim Settings...?
  76. 4 Questions
  77. BCP main shaft/gear?
  78. New Blade CP questions...
  79. What is Bind Plug used for?
  80. CX2 Motor fuses?
  81. CX2 Hovers in a circle after aluminum shaft swap
  82. CX2 5th Channel
  83. CX2 Lipo question?
  84. Blade cp pro set up q's
  85. CX2 Servo Settings
  86. Stainless Steel Main Shaft
  87. Electronic stabalization systems?
  88. CX2 - Can't hover
  89. More online sites-for upgrades
  90. Online Shopping
  91. Okay all you CX-2 owners!
  92. Blade CP
  93. Question about my Lipo.
  94. Color markings for easy orientation in the air?
  95. Everyone's tips on wood blade repairing please!!
  96. noobs and carbon fiber
  97. Shogun 400 & Hitec Eclipse 7
  98. Blade CX-2
  99. Tail motor refuses to respond
  100. CP Pro Tail Problem After Motor Burn
  101. anyway to adjust sub-trim in stock BCP TX?
  102. Blade cx problem
  103. Blade Pro direction
  104. Best sim for Blade CP Pro
  105. Brushless Setup on the CP Pro
  106. recommend buying gyro for new cppro pilot?????
  107. CP Pro carbon fiber tail rotor vibration
  108. getting off the ground
  109. BLADE CX ALUMINUM PARTS WEIGHT
  110. CX won't get out of ground effect?
  111. BLADE CP PRO
  112. Blade CP Pro rolls left on forward pitch?
  113. video ...honey bee fp w/ducted fan tail
  114. Esky Gyro
  115. need help with my video upload
  116. My New Tail
  117. weirdest reciever problem ever
  118. flying the blades right off my cx
  119. overcharging = dead battery?
  120. Weird servo problem
  121. Blade CP with E-Flite Park 370 4100 KV motor temperature
  122. aerobatics with the blade!
  123. how long should the servo control rods be?
  124. tail jerks around randomly on BCP
  125. CP HELP!!!!!!!! Tail locks out!!!!
  126. A timer for my TX?
  127. I fear Lipos...need tips
  128. What's the normal progression in Helis? CX- CP- Pro then what?
  129. pics ...ducted fan tail in flight
  130. BLADE CX2
  131. Li-po batteries for Blade cp
  132. Blade CPP won't take off
  133. BCX vs Coco Lama
  134. whats wrong?
  135. Spindle stretching????
  136. walkera dragonfly
  137. Blade CP (orig) external HH gryo mod
  138. CPPRO 1st forward flight - wow - question?
  139. Blade CX Flybar Mod - cont'd
  140. blade cp aileron glitch
  141. 9CHPS and Blade CP
  142. JR 8103
  143. Tail bounces up & down, Need advise / Choppersrule
  144. all cali blade cp or pro Pilots
  145. How do I change a motor pinion?
  146. Best reciever to replacet he stock on in CPP
  147. CNC HEAD for Blade CP Pro
  148. Blade CP Stability Problem
  149. Blade Cp Wont Lift
  150. Blade CX LED kit... with VIDEO!
  151. Blade CP and Eclipse 7 settings
  152. Getting a CP Pro to fly like a CP???
  153. Bent Head or...(part 2)
  154. pre-ordered a CX2 !:)
  155. Direct drive tail BCPP
  156. What Exactly Does the Heat Sink DO?!
  157. campbell 's hi-tech blade balance tool
  158. Blade CX Flybar... a rant!
  159. TCM adjust (advicee for learning 3d)
  160. New Tail Motor Coming!!!
  161. Rambling: A pushmi-pullyu double-ended Blade?
  162. Do flat blades need more power?
  163. Blade CX:
  164. CP or CX
  165. wanna go brushless... but the tail...
  166. possible plastic blade cf tail boom fix
  167. BCP drops head speed...why?
  168. Blade cx problem
  169. Tail Rotor ? Blade CP Pro
  170. anyone ever smelled there 3 in one?
  171. CX fast forward
  172. blade cx battery question
  173. Bent head or...
  174. HELP!!!!!!! CP PRO problems--update
  175. BLADE CP PRO fuses
  176. good li-po for cx?
  177. Blade CP Pro gyro selection
  178. Blade CP Pro How-To Question
  179. CP Pro Gyro Options
  180. Possible way to save skids
  181. blade cp 4-in-1
  182. problems taking off with training gear
  183. Blade CX CP CP Pro compare to Falcon 3D
  184. new e-flite servo S75 travels too much
  185. HELP !!!!!!! CP PRO problems
  186. Blade CX Flight Time
  187. CP jumping on lift off
  188. Stock settings detailed- for BLADE CP on Futaba 9C
  189. blade cp pro is glitching ... dont know why
  190. CX lower rotor head
  191. Servo Glitches
  192. Dark Knight 2 and 2SE parts
  193. Blade CP Pro Aluminum Hard(head)ware
  194. Trim Questions
  195. Separated Swashplate - snap or glue?
  196. Blade CX UPGRADE!!
  197. Micro Heli swash
  198. Upper blades don't spin after crash
  199. Blades for the CP Pro
  200. Hirobo XRB-S vs CX
  201. Microheli frame
  202. quick disconnect tail boom
  203. Blade CP PRO Training Gear?
  204. CX LiPO battery failing
  205. Blade CX Questions and problems
  206. Blade CP Pro/ G90 P.O.S.
  207. Gone In 30 Seconds...
  208. PicooZ Spinning
  209. JR XP 6102 with Blade CP
  210. My first Foward flight woo hoo
  211. iblade cp question
  212. Changing motor pinion on dual motor tail.
  213. helidirect 8 bux blades
  214. Battery install on Blade CX
  215. 4in1 remote gain?
  216. CP Pro Radio Change
  217. CP Pro Paint Job
  218. Carbon Fiber Blades
  219. 4 in 1 red led question
  220. Slow pirouette one way on CX
  221. brushless tail w/ G90
  222. Blade cp pro rotor blade question
  223. Reality check...
  224. Esky Honeybee CP2
  225. CX charger for CP LiPo?
  226. TP LiPos
  227. Flight Tech Head Unit
  228. I Got A T-Rex
  229. Direct Drive Tail CPP
  230. Regarding BCP 4-in-1
  231. Don't fly without Tx Antennae
  232. Stupid stock main shaft...
  233. Motor Break in.
  234. Any eflite user in PA/ South Jersey?
  235. CP Pro upgrades which first
  236. BCPP jumps at take off??
  237. Important message for all forum members
  238. Retaining pin is stuck, now what?
  239. 20 foot drop and minor damage
  240. Blade CP Pro Hover Speed and 3-in-1 LED
  241. Blade CP Pro - Upgrade Battery
  242. pitching up issue
  243. twister bell 47 vs lama 2 v3
  244. Dual Main Motors?
  245. Blade CX Question
  246. Blade CP Pro - Drifting to the left
  247. Bad slop in blade grips
  248. glitching issues on my BCPP
  249. E-Flite Vs Other Helis
  250. Carry case for Blade CX?
