View Full Version : E-Flite Helicopters
- New Blade 400 battery questions?
- Best Blade CX2 upgrades?
- blade 400 issues
- Sad day for me
- Auto battery charger "clean" enough for blade 400 charger?
- idle up Questions B400
- eflight charger messing up
- Training gear Blade 400
- CX2 aluminum outer shaft bearing holder
- CX2 flybar options?
- Battery go boom?
- Things are looking good, so far! video
- Blade 400 Power Supply and Battery Questions
- Blade 400 Setup
- Blade CX2 video
- Blade 400 works one day...and......
- Not happy with eflite in the uk
- CP PRO on a DX6i
- Blade CX2 3in1 red light?
- Blade grips moving?
- Blade 400 main shaft?
- Aircraft (B400) shot down in Iraq
- TIP on finding parts or even a Helicopter
- Question on the DX6i
- Blade Cp Pro 4in1 problem
- New K&S blade balancer problem?
- B400 servo
- Blade 400 New Servos
- CX2 only flyes at 10 feet??
- I have some questions...
- Frustration with simulator
- CP PRO Head speed
- main shaft on BLADE CP PRO
- compatability question
- forward flight slow, want more speed
- charging li-po's
- Another B400 Problem
- to HeBlade 400
- Blade 400 loosing power???
- B400 Battery
- Blade 400 Spindle/Feathering Shaft = Crash
- CX2 servo adjustment question?
- easiest question....
- Blade 400 and Wind...
- first big crash
- Reflex Sim & TX
- LED Lights on a CX2
- Blade 400 DX6i glitch?
- CX2 stability...
- Blade CX2 Lipo question
- B400 main frame
- CPP setup advice/DX6i (long)
- Help setting up blade 400 3d with futaba 7CAP
- HBK2 and Cheese Balls
- Rotor speed vs. stability question? (Newbie)
- binding?
- B400 tail problem
- CX 2 spins to the right under rotors
- Motor to 4-in-1 wiring question?
- swash mix
- Blade 400 mods, lights, camera, action.
- How do you loosen gear mesh on cx2
- Blade 4003D
- No throttel Cp Pro
- GWS DD tail
- help! cx2 uncontrollable after new fuselage
- B400 gyro opinion
- Align blades on B400
- Real Fight Sim 4 Blade 400
- Advice setting up G110 gyro in CPP?
- Almost lost my B400
- Breaking in my Extreme 180's
- CX2 Xtreme metal blade grips, who has them??
- Just some pics and stuff...
- New Xtreme SE180 Motors
- CP Pro new finding- Motor Power Loss
- cx2 is getting up there then going down
- upgrading servos now after servo fails nose dive!
- DX6i Settings for CP PRO
- belt cp blades?
- Considering G90 gyro for CP Pro?
- EFlite Blade LiPo Charging Problems
- Cellpro 4s Charger Questions
- Blade 400 Head Pictures
- the Collective's Iraq Soldier Project
- HELP! Blade CP w/new 3 in 1 - Tail Freaks Out After Several Minutes of Flight
- TRI FLO ON BELT HOW IS IT DONE?
- Blade 4 in 1 reciever
- upgrade battery for blade cp pro?
- eflite spektrum radio controller
- Next heli after my CX2?
- Solar powered Heli desk toy I built
- Other Forums
- 6 volts on blade 400?
- lama v3 help!
- dont tell me
- Eflight Blade CP
- micro heli upper rotor head/shaft and lower rotor head for sale or trade.
- Here's My Tidy Bench. . . again for the new people
- My first two CX2 videos
- servo sensitivity
- Tip for Getting More life out of Your XTREME motor brushes
- Blade 400 dicky servo
- How old are you? Just Curious
- First CX2 video
- RE : Honeybee King 2
- DX6i and AR6200
- dx6i
- TBE problem and fix
- 5th channel & LED question
- Moving up to Blade 400
- Clearview with Esky 6 channel TX
- LiPO Charger Lead Blues....ARRRRGh
- Can the videos be downloaded?
- How "controllable" is the Blade CX2...?
- CX/2 Looking for CPPro?
- blade 400 tail wagging
- Blade 400 / DX6i / Swash Type?
- Stripped servo?
- Brushless or BB brushed for the CX2
- Moving on up...
- BCP crystal
- CX2 still creeping forward a bit
- Mini Heli Performance Servo Set in B400
- adjusting pinion gear question?
- scale body for the cx/2
- CX2 inner shaft lube
- B400 PITCH GAUGE HELP
- Looking for a thread regarding CX2 LiPo?
- Help with DX6i in CP Pro ??!!
- Anyone tried the DS3500G yet?
- Blade CX2 nose won't stop going to the left
- scale blade 400
- B400 Rotor head, witch way do it go
- eflight battery charger
- cx2 cracked frame, go plastic or CNC?
- Blade 400 head speed
- HH and V1.6?
- New CP Pro wobbling, shaking??!!
- CX 2 right death spin
- Sulking CX2 flyer needs help!
- cx2 glitch problem
- Which SIM shall I get for practice Blade 400?
- THe Next Step CP+ or 400
- Blade CP Pro leans to the right
- Question ABout Blade CX and Blade CX2?
- WoW I like it...!
- 5th channel activation?
- dean connectors
- Blame Soloboss
- cx2 battery
- Blade 400 Default Linkage Length and Horn Position - HELP
- question about the esc
- CX2 not getting off ground
- Flying effectively with a "not level" swashplate
- Blade 400. What is 400?
- Longer Flight times on Blade 400
- Product Review: ESP Hobby Tail Boom Kit
- cx2 battery help
- Happy Easter Everyone
- Blade 400 stripped servo
- Building another CX-2 and need help
- Battery? Wich one....
- telebee hh gyro install in cp with 4 in 1
- Help CX2 problem
- CX2 trim problem
- Brand new CP Pro question...
- heat sink not ok?
- My first BIG Crash... Need a bit of Help please.
- Blade CX2 problems, norhing in search engine
- The "Esmart" is an Esky product,...Isn't it..??
- E-Flite Blade CP
- cx2 led spot/search light
- Do you charge AC or DC?
- cx2 3 in 1 yaw problem SOLVED!
- shorter flight time with a new body?
- HELP!! Blade CP Leds flash red/green
- Inside stock flybar
- I did ask the exceed forum with the host..?? But..!
- Looking for a good option on AC / DC Charger
- Blade CX with a Futaba 7CHP
- fly bar
- i need help deciding between a cx2 and a cp
- Stick Bling 2
- Project: RC Soldier in Iraq
- Cam
- B400: Replacing tail boom
- Binding issues with the 4-in-1
- EC3 connector removal?
- B400 GYRO SET UP? NEW SERVO
- Blade 400 Battery charge rate?
- upgrading cx2 gyro?
- so what does the Gyro actually do?
- Extreme Frustration
- I have a killer question......
- BCX2 Outer Shaft Assembly Question
- B400 or HIROBO SRB QUARK
- Blade 400 first outside flight!
- quick question
- Heli-Max Canopy Red Rotofly
- Blade CX hardware question
- CX2 Trainer Jack to Sim or Buddy Box Cable
- Help me decide
- Will it work?
- CX2 on MTV's Rob and Big
- Cx2 "scale" bodies
- cx2 spins
- CX2 canopy
- T-Rex 500 vs Blade 400
- B400 HS-65-MG Servo problem
- CX 2 Heat Sink for the Motors
- CX2 blade problem
- blade 400 main shaft length
- cx2 water crash
- Esky 2.4GHz compatible with DX7?
- Blade CP Replacement Tail Boom Longer Than Stock
- BCX2 transmitter range
- help.
- Battery trays suck!!!!!!
- To motor or not to motor, that is my question.
- Check it out guys
- alloy main frame.
- how to you remove bearing from main gear???
- Either a great idea....or a huge waste of money.
- CX2 Top Rotor Wobling
- Couple o' questions
- Pitch Adjustment
- Eating crow: I was wrong about the CX2
- Easy flybar fix for poor newbs like me.
- hardware question
- Unruly Blade CP
- newbie question, CX2 rotor problem
- B400 LOWER GEAR BEARING ON MAIN SHAFT
- Eflite Quality? or just a fluke?
- How mch free play in blade grips, BCP?
- Help with stock tx please
- Transmitter built wrong?
- CX2: Tape leading edges of blades to make more durable?
- b400 lipo no good anymore?!?!
- FUTABA 401 WITH FUTABA 9257 TAIL SLIDER NOT CENETERED ?
- www.advancehobbies.com
- FMS Sim
- Buy the Blade 400 or repair the Walkera..
- B4OO Hitec hs-65mg Servos
- blade cp tail driving me insane, please help
- B400: Replacement ESC?
- B400: Limiting Tail Servo Throw???
- Happy again with USHOBBY Supply
- Flying Foward
