View Full Version : E-Flite Helicopters
- When is a CP not a CP anymore?
- Whats a good Brushless 4 tail on CP?
- 4in1 Repair
- Learning to Side-in Hover
- Where do I buy dual tail motor mount?
- hummingbird elite cp with slow cyclic
- beginner helicopter wanted
- HH gyro a waste of cash? think so
- how much throttle trim?
- FP vs. Cyclic/Collective Pitch: What can one do that the other cannot? Confused!!!
- Possible boom fix idea
- OMG I am STILL dumb
- closed
- Blade CX Battery Help
- Lipo Battery & Charger choices
- Beginner with BCPP
- How to prevent tail from sliding?
- How Good are You with your BCP or BCPP?
- Aluminum swash is sweeeeeeet
- Blade CX Engine Problem.
- Need a good sim
- Blade wont take flight
- Went to LHS...Now im broke..lol
- HeliDirect recieves an A+
- need help quick wit blade grips
- Replacing Tail Boom
- I'm wondering..should I now consider a CP? I flew a CX for a few weeks...
- heres a semi cool ducted fan mount
- Been Practicing...
- Dynam Vortex Coaxial Helicopter
- Blade CX Yaw question
- 3in1 unit BCPpro
- Blade CX ?'s
- blade cp pro/school of RADD
- hey wheres my parts
- BCP boom and tail mount fix??
- Blade CP Allen wrench?
- anyone tried an Eco8?
- Need Floats on CP
- need help with setting pitch bcp
- New Blade CX Questions
- Bell mixer upgrade = $30 = Awesome!
- Hola :)
- CP Pro G90 Heading Lock Performance
- CP 2 CPP conversion
- Need aftermarket 370 for CP
- I have the worst luck!!!
- When hovering...Do you look at the tail or the nose?
- Shear Pin = Sheer Luck?
- BCP: proportion mix and gyro gain settings suddenly change during flight
- Fuselages
- Dual Tail Motor Mount Question
- When is the power too low on the TX?
- Landings = Too Rough
- CHOPPERSRULE WHATS IN THAT BOX????
- Who has a brushless CP?
- lol Have you ever noticed
- CP Crash: Parts okay?
- When servos go bad
- new motor for the 3dx-400 shogun
- Video: Crashing the Blade CP
- ducted fan tail pics
- Strange Problem BCP Pitch and Elevator Control Reversed
- I lost my Blade CX. Can I buy just the helicopter? Help!!
- Charging the transmiter.
- Blade-CX -- Does anyone do this?
- CP takes almost full throttle to lift off???
- New to all of this, first flight in 12 hours!
- newbie CP pilots and the RADD training system
- Setting gain and prop'l on CP
- CPPro -- Maybe expecting too much?
- blade cp pro
- Blade CP skills
- blade cp blades
- super landing gear any good?
- How do I replace the Blade CP Tailboom?
- PLasti-blade link here
- Level Hovering
- how long to charge batteries
- Simulator for Blade Cp
- What lipo
- Product Question4 HeliDirect
- HeliDirect shipping speed2 Canada??
- Hard Time Holding Altitude
- X-Rotor Picco Z Micro Helicopter
- Took CP head apart and now blades are facing WRONG!!!
- cp pro brushless
- E-FLite Blade CP Pro @ Readyheli.com
- HDX300 Build Videos
- hey guys-newbie here
- What does the CP draw?
- Air Hogs HELIX Micro Heli
- Futuba 6ex setup for Blade CP
- CF blades make the difference.
- Whats needed for brushless CP??
- Check centre hub 4 sticky collective
- Another CX to CP upgrader
- Just spins on ground
- NEXT E-HELI
- Blade CP Wow
- Yesterday...it clicked
- I TOO AM SO DUMB!!!
- The weekend's over - Is your heli still in 1 piece?
- Cx Problem.
- Stuff learned, moved from CX to CP Pro
- 2 Questions, Replace pitch linkage and blade pitch
- ball joints links
- 30 dollar Lipo
- Paddle pitch??
- Computer radio for Blade CP
- motor question
- Blade CP and New Head (Help Adjusting)
- Digital servo
- Pre-flight blade cx/cp edition
- sticky collective??but how??
- I'm sooo DUMB TOO!!
- how do u post a video on here
- Blade balancer already paid for itself!
- Posting your ability can only help
- CP glitch and CRASH!!!
- Blade CX heat sink
- lube question
- Cool lights for your heli
- CP is going sideways....
- Creating A Solid CP
- WOOOTi am very happy just got my CP
- cx acting weird
- CX 4 in 1 problems
- Throttle position on hover for CP Pro?
- CP pro gyro
- New radio for Blade CP Pro.
- HDX300 gear and shaft?
- INFO. on Battery + Chargers for a Blade CX
- What lube do you use on your CP/CX??
- Real Flight G3 / Blade CP
- HDX300 All-Metal Bell-Hiller Head System
- E-FLITE BLADE CP PRO
- Is BellHiller good for Newbies?
- Shogun V2 speed control settings?
- Main Motor & 4-in-1 toast / I didn't heed the warning signs
- Blade cp TRAINER SWITCH
- Tail motor fried????
- Hows this for a main motor!
- Rotor dampening - BCP
- Blade CP Symmetricals
- Blade CP Shaking
- GOD!!! I am so DUMB
- Blade CX Rudder HELP
- cp tail rotor problem
- brass collar on tail motor pops out
- Camo CP? Is it Possible????????
- hirobo x-rotating lama
- blade cp upgrades
- main motor failure
- LIPO Safety reminder
- CPs on the workbench tonite
- Dual tail or DD??
- need wiring diagram 4 dual motors!!!
- With the CP pro available, is there any reason to buy a CP?
- Blade CX launches a rocket
- LED Port on CP???
- funny video
- are the replacement blades for the CP already balanced?
- 4 in 1 unit light question
- blade cx
- Bell Hiller question
- When are the Blade CP Pro's getting shipped?
- E-flite Blade CP Pro is here
- Blade balancer with 2mm pins???
- Hows my flying?
- BCP sure can bounce
- Website URL for plastic main blades ?
- BCP/CP2 parts
- Take off/land on grass w/CP???
- That stoooopid Idle up switch!
- 4in1 warranty replacement
- Blade CX yaw speed
- CP boom support shock absorber
- eureka!
- Blade CP left hand drifter
- Blade CP gyro gain...
- Look Ma! No Hands!! (at least for a few seconds)
- Difference between 8t or 9t pinions
- charging li-po battery pack
- Blade CP belt drive
- Main rotor not spinning?
- Pitch Control Link Set (small and large side)
- Video: Flying the BCP
- Blade CP - 2 week parts total
- Aluminum Frame for BCP
- What others colors you will like to see for anodized upgrades for CP
- Adapter to charge stock CP battery?
- Burnt Motors: BCX?
- 4 in 1
- FUTABA T6XA S T6XAS Setup that works
- My 1st real Blade CX hover indoors, and outside this morning....
- Optic 6 good transmitter for the blades?
- Evil Wind!!!
- main shaft-drive gear
- What, exactly, are the six channels?
- Blade CX spins out of the box.
- HELP Just got a CP
- ROTOR HEAD DISASSEMBLE???
- Eliminating the whobble/vibration on the CX.
- Charger q's
- BCP battery question
- 4 in 1 or tail motor?
- How to replacei nner shaft? Blade CX
- blade cx battery charging?
- First Flight of the Blade CP!
- Blade CP Pro (when?)
- CX Cp or Pro which is for the newb?
- CX or CP Pro ? (im about to make the move into RC Heli from RC-Onroad racing)
- loops harder with cf blades
- That tiny, tiny screw at the top of the fly bar...
- No vertical thrust with poly
- no lift
- Guys (and Girls): I just bought a CX. Finally!!
- battery chargers (accucycle plus)
- Help with 4 in 1
- blade cx wobbles at half power
- REALLY nice "Sim" type game thingy
- Flying at the Park
- $5 light mod for any chopper!
- blade cp/plastic blades/pitch= not enough high flight power
- Buying a used CP ??? Basic checks and trouble shooting...
- Blade CP Main Blade set-up ?
- Blade CP barely flies with Plasti-Blades
- tail motor problem...
- Loose servos, fixable?
- CX won't lift off, need advice
- Problems using a Blade CP with a Futaba 7C tx
- Will CX Charger work on 3 11.1V LIPO ?
- E-flight Blade CP - Popular as ever or waning
- intermitant power
- Esky 4in1 works
- BELT DRIVEN TAIL ROTOR FOR CP
- boom install?
- 4 in 1 replacement help
- 7mm boom conversion? anyone got answers?
- Dual tail motor mod
- Arms fine but goes crazy
- quick and easy brushless conversion for BCP
- Yet another tail motor question...
- Battery life challenge for cx/cp
- CP rotor tracking question?
- blade cx first parts change
- Blade CP Radio - Is it any good?
- Aluminum Lower Rotor Head for CX
- Do I Nedd A New Battery
