View Full Version : RC Pattern Flying
- .45 Size PP under $250
- webra 1.45 modification ??
- YS120 - NC,FZ,AC, SC
- Plug in Tails
- Problems with my engine......(OS 61 FX)
- Oxai-Europe
- Futaba 9550 & 9350 Servos
- Pro Line Radios
- RE 2C engine for Beaton 50?
- ys 120 ac model
- Fixed landing gear for Tai-Ji 60
- Flair Lark/Swallow tuned pipe/muffler instalation ?
- Mistress by Phillips Aircraft
- finesse parts
- Nylon Gearset for JR8411
- Engine Question for Non-Competitive Pattern Flying
- engine for my plane
- New size Tru Turn spinner for PL Prod and other euro designs
- wieght and balance question
- Ordered a Widebody 60
- help with buying a pattern ship
- Webra external pump
- Spectrum OS 50 SX vertical performance problem
- Aileron differential
- F3A DVDs - Where can I find them ?
- fuel
- Panacea first flight impressions
- Double Vision ARF
- Focus by Piedmont Models
- Phoenix 8
- Kit Cutter For Patter Planes
- Tuned pipe & header advice for OS 160 Fx?
- 4 Stroke vs. 2 Stroke for pattern
- Covering or Glassing?
- Fixed Gear Advice
- ys 120 fz vs. ys 110
- Where to find F3A-schedule for 2004\2005?
- Fuel tank setup?
- wide fuselage good or not for P-05??
- Ecplise availibility
- Tuned Pipe For YS140
- Wing Reinforcement
- DZ140 GasGuzler ???
- Kirk Gray
- Best Pattern Plane
- ys 140 sport vs. os 160
- ZN Evolis and two-stroke
- suxess
- Flair Magpie with 40 engine ?
- 2M 4 Stroke vs 60 size two stroke
- Fiber Glass or Kevlar Carbon Fuselage ?
- MK Models Web Page Address ?
- Two fuel tanks in pattern plane
- Pattern flyers & Magnum I & II fuel?
- Webra 50 looking for a plane
- PPG Concept paint activator
- 1st 2M Plane-YS140L or YS-140 Sport?
- F3A (Past Results)
- 2 stroke engine mounts
- Pattern planes capable of being speed planes
- 3M-170
- Venus 40 empennage controls?
- Fascination & Mintor140
- Pipe for OS 140 rx
- Bully 1.20 HELP
- YS 63FZ or OS FS-70 Ultimate for Kyosho Majestic?
- Better than the Venus??
- I want to no about the MK Arrow
- Prefered rolling direction;any tips on perfecting the other direction
- Prop size for Magnum 52 ?
- Best servo combination?
- Troy Newmans elevator control system
- good pattern plane for .50sx
- 140 on a Quest??
- MK Hi-Isolation Mount for OS140
- CAD for pattern
- Fuel proof
- F3A World Championships Videos - Where are they??
- 140L pipe
- Dash 5
- P05 & F05 Manoeuvre Descriptions ?
- Colombo+Fantasy=Fantastic
- what built up pattern for first pattern plane
- Widebody40 + Saito.72
- Beginner Pattern Plane
- need sugestion for plane, and .72 Saito (new to pattern)
- TAI –JI 60 or Quest ? Which one is better for pattern?
- Mystic 90 ARF
- Servos for ZN Majestic
- Snap roll button good or not??
- PO5 loop?
- Expensive servo for flying in lower classes, is it pays to have?
- Piedmont Temptation construction questions
- Epoxy finish
- Pilot Models .25 Supra Fly Plans
- Aresti 40
- Making Rudder Control instinctive - how?
- GP Venus 40 - - good 1st pattern plane?
- CA Eclipse Pattern Plane
- Best Patternship
- What is it?
- Foam Core Wings
- YS 1.60 DZ DINGO??
- 91 FX. Will it work with a Hatori 650?
- APC prop loads?
- Seduction 90 C.G ??
- Zen II 140
- Patter Plane Design
- pattern arf
- Tai-Ji
- Webra Aero 1.60 XP
- servo jitters
- Como (ST) 75 for pattern
- Conquest Pattern Plane
- Mark Atwood Please Email me
- ZN Majestic Wing Section
- King Altair
- my first own design plan
- CG on Focus ARF/ARC
- Intermediate question
- In the ZNLine shop, quick tour.
- Cermark Javelin
- MOVED: Need Redefined SPA or New Class!!
- Pilot Seduction 90
- E-Factor F3A on electric power
- SL-1a
- header and pipe for Webra 1.60
- Building Materials for pattern plane
- Material for Pattern Model
- .61 engine choice?
- Rubin upgrade
- header& pipe combo for Typhoon 2000 OS 140 RX
- Eclipse & Fantasy CG locations?
- Typhoon 2000 Plan Questions
- converting a 1.40L to a DZ?
- YS .61 RE in older Pattern Plane
- CA Models Fantasy
- Video of Sportsman pattern Sequence
- NOISE PROBLEM IN OUR LOCAL FIELD
- Mecca Models
- 4.8 or 6V for pattern flying?
- CF wing tube installation???
- Who knows this plane?
- Dash 5 recommended throws?
- Are we building them too light?
- Double Vision
- WHAT HAPPENED TO HENRY PIORUN MODELS??
- Fiberglass Tigertail
- Daddy Rabbit questions..........
- MK Topstar: ARF, ARC or sticks?
- How to get over the loss of a loved one!
- OS 140 header
- ZNLine Supreme
- Como "ST" 75 for pattern
- knife edge question
- balance point for world models-tai ji 40
- Rev Pro
- Profile Pattern, anyone done one?
- CA Widebody 60
- Barrrel Rool - How to
- Fantasy and Mintor 170
- Lets have SPA pattern contests in the Mid Atlantic Region
- Mintor 140
- Q's about a plane called "Solution"
- YS DZ prop selection
- Searching for the "BEST" 60-90 A.A. Pattern
- pattern; gettin ready
- Looking for a plane
- New-b to PAttern... What exactly is pattern flying?
- PL Prod pattern babes
- Need info on a plane
- Where are the Mitor 1.70 ???
- Protech Onyx 140 ARF
- Direct Connection USA Star
- Zen 90 YS 110 header and pipe suggestions please!
- Made your Zen or Tai-Ji fixed gear?
- Mac's Quiet and Muffled pipes?
- Patternship wing Root LE vs Tip LE
- Aresti
- Need info. on a Dick Hanson Tiporare
- Do you know this plane?
- OS 61 RF-P pump settings
- Japan and/or China beautiful pane's
- Gear for Bridi Escape
- Would a cloud dancer make a good first pattern plane?
- YS .80ST Heli engine for pattern use??
- Tip of the day: check those eng mount bolts!
- Retract Strut Tool
- Pattern newbie help
- Best Fuel for YS DZ Dingo?
- rhom air struts
- MK Skystar 90 IN DA HOUSE!
- OS 61RF-P Pump settings
- Synergy 90/where are the constructions posts?
- new to pattern
- Oxia Impression 140
- Pumped 90 - Webra 80? Any experience?
- Airfoil
- Cam installation for YS 140L
- Need help to Identify this .60 Pattern Plane
- Hinge Tape - sealing hinges ?
- >>>TIPORARE<<< "Dick Hanson"
- Plane builder in San Diego, Phoenix or LA
- Pipe / Header Length
- Upline snaps
- Foam in Fuselage?
- Dirty DZ
- Nose Ring for OS 1.60
- Would you like to enter a pattern contest sponsored by the Senior Pat
- My own construction
- Zen 90, AAP Pipe to long, cut it?
- YS 160 DZ
- How does the Partner from PL Products fly?
- MK Aurora 60 CG Location
- doug cronkite
- YS140DZ vs YS140L
- My first contest
- Purple Power!!
- Good Hobby Shop in Hong Kong?
- Atlanta for lower classes? Thought? Opinions?
- Weird stall turn behavior?
- SPA Serior Pattern Association
- practice airplane.
- Futaba Zap snap condition
- YS DZ 140
- How do you select your F3A team for the WC?
- When do you start competing P05?
- OS 61RF-P
- Urgent! a 90 size two stroke with pump for pattern and 3D
- Shop in Tokyo
- 3M Mintor Header for Temptation
- Where is the swap shop
- Covering job
- Smargd and Partner
- RE-building a pattern plane.
- Cross Country Pattern Plane Shipping
- MRC-EZ Models
- Dave Smith Models Smart Move?
- Tiger Tail question
- OPS Pipe setup
- Which Flight Simulator
- P-05.17
- Airplane stand from Japan
- Pattern in Albuquerque??? Is there????
- JR Models SHARK - Any info?
- simplest power setup for F3A
- Spinner size for PL PROD Smaragd
- Smoke Systems
- Electric Lazulite for F3A
