- Hyde AR Mount Question
- LiPo maintenance
- need diagram of pattern maneuvers
- Ken Velez E mail
- Looking for a 160FX crankshaft
- How to make a perfect landing with a pattern ship?
- O. S. .91 FX prop suggestions
- YS Motor Question
- Best place to send YS motors for a tune up?
- PPG DBC Basecoat Paint
- engine for majestro
- which for first pattern, .40 or .90 size
- Orlando Pattern contests etc.
- When is Fresno contest?
- fantasy video
- Pattern Planes
- More on gas pattern-sm30
- Graupner MC24 and a Multiplex PPM Duel Rx
- YS DZ140 question
- Bridi Great Escape
- Horizontal Eight Question
- My New Custom built K-TRICK 90
- Anyone See this Plane
- CA Model Epsilon Gear Dimensions
- flexable antennas
- Pattern?
- Where to buy CA planes online?
- fantasy pics
- Can I determine engine tunning from Glow plug color?
- Widebody 60 Landing gear
- 2004 Precision Aerobatics Nationals.
- Rolls to the right when I use elevator
- Second plane advice needed
- CAmodel Widebody 60 vs Epsilon
- Wing incidence problem ??????
- What's better, Hitec HS-945MG or JR 4721???
- Making a Three piece wing from a One piece wing
- Professional looking fuel filling points
- Camodel Extra 300 L 27% vs Camodel Fantasy
- I took the Plunge!
- What plane is this? Old pattern plane?
- HELP FOR EPSILON CONSTRUCTION
- Need Tigertail IV Kit or plans
- "The BOX"
- Simulators
- Pattern Engine Choices
- Digital Servo's
- Flair swallow.hhmm
- IMAC and Pattern
- Gas Engines for Pattern
- Clearance between spinner and cowl (140DZ with Hyde ARIA mount)
- nemesis 90
- control throws
- MK Extra 300LS
- Engine for a Lark......
- Pete Illick passing
- Who's Coming to Baton Rouge this W.E.????
- set-up wing/stab incidence CA Eclipse
- Hacker C50 help needed.
- Who sells pull/pull?
- F3A or Artistic Aerobatic Videos?
- Tail heavy ZN Majestic
- coolpower 30 and paint...
- NMP's New DZ Header and Pipe
- WANTED your old TIGER TAIL IV KIT
- Pattern plane
- Dingo questions
- Desire 60 build, first jig built balsa.
- CA model eclipse videos?
- Retract advice...
- OLD SCHOOL PATTERN WITH NEW LIFE!!!
- Masters manuever help
- 2005 Masters schedule. Passed by AMA Contest board.
- Pattern Schedules
- KaZoom - Aerobatic Biplane
- Super Kaos 60
- What spinner adapter ??? help !!!
- Finishing question
- O.S. EFI?
- Building a JR models Diablo
- 91 FX on WM midget mustang--what prop size?
- Danny--JR 326-X receiver question
- dingo power
- 4 stroke vs 2 stroke
- Need advice on 2004 NATS
- ZN-Line Alliance trimming question
- After Run Oil for Pumped 2-stroke.
- What size wing tube?
- OLD Pattern-ships VS NEW Pattern-ships
- Spinner nut for YS 120
- Quest 90
- 3D flyer wants a pattern plane.
- Super Kaos 60 kits
- Great Planes Venus 40
- Top Hinge Question?
- Who's hoarding all the contest balsa?
- dick hanson elan 120
- it's almost impossible to keep the..
- Top Star 2
- Nemesis 90
- GP Venus 40
- Epsilon kit...where to get?
- Defiant #2 Finally Flys
- Electric Pattern
- Medium sized aileron servo
- split elevator 2 servo setup
- An original color scheme?
- What type of wing??
- O.S. 91 FX rear exiting header
- O. S. 91 FX curved header
- Which plane is more forgiving?
- CA Hinges
- Phoenix 8 latest
- Mintor 2 Plug Head?
- Graph Tech Contact Info
- .61 size Tsunami CG
- SIG King Cobra info wanted
- YS-140 DZ and 510 mm ASANO pipe
- MC carb setup
- Quest 3D...where to buy
- C-F Tuned Pipe
- A good Pattern ARF?
- Rear pipe mount for models with one piece wings
- Need advice for conducting a pattern primer event
- Carolina Models TigertailIV
- OS 1.60's
- Funtana-wing question
- How to program your JR 8103?
- Hangar 9 Aresti 40 - H Stab Failure?
- Majestro ???
- Composite ARF Impact
- Updated SL1A?
- CG&Throws
- Engine intake silencer
- WM midget mustang engine mounting
- SkyLark
- What is the Zen 30 like?
- hobby-lobby skylark?
- l'ESSENCE - wing location witn OS160FX?
- Black Dirt Squadron Pattern Challenge.
- Bridi UFO C/G question......Help!!
- Trying to decide?
- YS 1.10 questions
- home-made nose ring
- baffle-less 91 FX
- Really simple pattern question
- What Pipe for DZ with NEW "High Flow" header
- EPSILON CAN FLY LIKE A PATTERN????
- OS 91FX silencer breakout
- OS 140 Plumbing Question
- G-Trick 90 cg question
- Excelleron 90
- Pattern Airplane
- flair swallow
- How much wing dihedral?
- YS Dingo 160's marketing date?
- Bully 1.20 any good?
- Good pattern plane?
- JR 8611 in a pattern plane.
- PL Products Kits in the U.S.
- Karl Mueller Custom Headers
- what about MDS 78 PRO????????????
- thrusting issue
- Magnum DZ blend or 30% heli for 140DZ
- Pattern video for d/l ?
- Speed of modern 2 meter planes?
- Smarged Instructions?
- ZN Alliance engine query
- Engine for widebody 60?
- Looking for .......
- YS 140DZ vent line (1 or 2 vent lines?)--- opened or with check valve?
- need help to identify this plane
- MACSS
- Airfoil for Synergy
- Widebody 60 CG
- JR dual output servo
- Yaw problems / Fixed landing gear conversion/ Zen 120 / yaw problems
- Warning about Lanier RC
- kyosho G-Trick, what engine n servos?
- Magic 60 plans for scaling to 2m
- Can a $10 "pattern style" airframe really exist?
- OS 61 Hanno help
- New Oxai P05/F05 model called Diesel
- Modified Synergy
- Epicure or Epicure II not sure
- Recommended Pipe and Header for OS 1.40Rx
- knife edge pitching
- Air Filters re OS 140
- OS 70B mix carb
- 2 Stroke engine to power Synergy
- Ordering directly from Aerotrend.com
- Anyone flying an Entropy?
- Help finding a pattern plan that suites me
- quest 90
- F3A book ??
- GLASS FUSELAGE FOR TIGERTAIL IV
- 9411 NYLON GEAR CONVERSION
- What is Pattern Flying?
- Kondor Aresti III
- thrust. pitch, rpm....aarghh!
- PL prod smaragd
- Need Plans to Bob Smith Patricia
- Futaba servos
- major problem with my matrix.PLEASE HELP!!
- Near Catastrophe!!
- EZ CAVALIER 20
- Bridi Killer Chaos or GP Ultra Sport 60, which would you build?
- Thunder Tiger 120 Pro question.
- Boxer series Back Again!!
- "OUYA" Flight Report !
- My new Eclipse enjoy
- Radio South Pro-Driver MKIII
- OS 140 with APC 15.5*12 (4 blades) performance
- clear coat paint
- Quest CG?
- Hyde ari mount
- RÖDELMODELL EXTRA 300/300L
- Best & lightest way to attach wing skins?
- Hyde mount for a Saito
- Airframe for an OS Max 1.20 SP....
- Monokote help needed
- Link for PBG
- propeller choice
- Changing Crytals.. What to expect??
- Digital or Normal (is it analog?) servos in Pattern Plane
- whats a great pattern aircraft?
- Which engine (Widebody 60)
- Saito 150
- Sportsman sequence in RIBBON format??
- 140L problem, again
- Tuned pipe help on GP Venus?
- URGENT.. HOW FAR CAN I PUT THE FUEL TANK
- YS 1.20 NC
- plane down!!
- Phoenix Models Giles 202 .40?
- Hanno 61 fuel consumption
- Control horn on the hinge line
- pull - pull
- OS 91 FX pipe length help required
- Hatori 699 muffler and Header Mounting
- Pattern plane from SCRATCH
- O.J. Stillman
- New YS140 exhaust components
- Ron Chidgey
- 4.8 or 6 volts in pattern?
- ZNLine Supreme building questions
- cg or incidence? suggest.
- OS1.40RX Tuned Pipe - $240.00!!!!
