PDA
View Full Version : RC Pattern Flying
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34
  1. Side thrust and down thrust on a patternplane
  2. Looking for Mach 1 pattern kits, or plans
  3. What is the BOX ?
  4. Pattern And Gas
  5. Thunder Tiger Imagine 50 thoughts
  6. Fuel recommendation for YS63FZ-S
  7. AFPD Sim Pattern Plane
  8. GP Venus 40-TT .46 Pro or OS .61 FSR?
  9. New wing delima, opinions wanted
  10. New F3A plane from CA Model
  11. What power setup do you use for your primary pattern plane?
  12. CPLR flying a bipe next year
  13. Short version hatori muffler for YS
  14. MERRY CHRISTMAS
  15. Temptation Wings
  16. Positron Special Edition Released
  17. Finesse canopy attachment?
  18. Adjustable Stab
  19. Rudder Trim?
  20. What type starter to use?
  21. Dubro Long Control Takeoffs
  22. Zen 90 Vs Tai-Ji 60
  23. Gator RC
  24. Venus setup help
  25. Beginning Pattern/Sport Plane
  26. 140 rx fuel
  27. Which servos.....
  28. Has anybody flown the LA-2?
  29. Wing incidence adjustment w/o adjusters
  30. New plane from CA Model???
  31. esc settings for Hacker 90 acro
  32. O.S. FS-91 II Surpass
  33. Please choose what describes your pattern activity in 2004 in the US.
  34. Will this be enough engine...
  35. NSRCA Presidential Election
  36. YS 110 motor mount question
  37. What Transmitter mode is everyone flying??
  38. Pattern Guide?
  39. Temptation Stab mounting question
  40. Pattern Season?
  41. Mejzlik propellers
  42. Good pattern plane for saito 91
  43. CA Models 40 Size Epsilon
  44. Proper Prop installation?
  45. Dave Patrick Finesse
  46. What servo do you use for elevator @ rudder?
  47. Impact Warning/CARF Kudo's
  48. Pattern in Phoenix Az
  49. Best Visual Marking for top or btm of plane
  50. There's no cure for Patternitis is there?
  51. Software for aerobatics
  52. The lost Kaos link
  53. Pl Products
  54. Epsilon cowl
  55. NEW Impact Instruction Manual
  56. Velcro Hold Downs, Who makes them?
  57. YS 1.10 available now
  58. CPLR goes electric?
  59. Tuned exhaust for YS 110
  60. Hitec Servos for Pattern
  61. F3A possible with 40 ? Which one ?
  62. Coolpower Heli 30
  63. OS140RX
  64. The One from RCME
  65. D.E.P.S. question
  66. Rudder servo pull-pull installations
  67. Venus w/ RE MVVS .49
  68. Dr Jekel
  69. Webra 160
  70. Kids grown /want pattern plane recommendation
  71. Book: Building a Pattern Plane
  72. Futaba 14MZ
  73. Prop for YS 160 DZ
  74. Trim drift
  75. ST 90 Header
  76. Icepoint Anyone??
  77. jett.90 s
  78. Executive AirFrames
  79. CMPRO LEO 110
  80. Focus 1
  81. 3-Blade Prop
  82. Electric Angels Shadow
  83. Where's a good CG for the 2M Finesse?
  84. need cowl for widebody 60
  85. F3A NATS and team trials
  86. New .90-size ARF pattern plane
  87. What do you say when this happens????
  88. Anyone flying the Dream 110?
  89. Powertorque Starter from Central Hobbies
  90. Unicorn 110
  91. Champion 45L Aileron dimensions
  92. Need replacement for Spectrum.
  93. Anyone purchased from specializedbalsa.com ???
  94. Hey "Mister" your Cowl ate my engine
  95. 2 Stroke or 4 Stroke? Why?
  96. Temptation build question
  97. heli 20% for dingo?
  98. webra 160 with mc user need help
  99. O.S. Tuned Silencer 1.40 RX
  100. webra 160 with mc carb
  101. Motul Oil for 2 strokes glow engines
  102. Dual Elevator system
  103. Having problem reaching 8000 RPM on my Webra 160 Areo XP
  104. ZEN50 YS45 engine install help
  105. engine help
  106. Which Hyde mount fits the Mintor 170
  107. Pattern Flying - Beginner Questions
  108. CA hings for tai-ji 60
  109. Angels Shadow
  110. Gelcoat prep question
  111. So. Cal. Pattern contests?
  112. Look what I got ahold of-
  113. Engine recommendation for Javelin II
  114. Excite-90 for pattern?
  115. My own design
  116. 2X2 Extra
  117. CG of direct connection ultimate kaos
  118. Center Maneuvers, the Correct way ..???
  119. 2005 sequences
  120. Wing tube socket and foam core fit
  121. Mintor 1.70 Fuel Consumption
  122. New OS 140RX tuned pipe mounting
  123. CA Epsilon on a Saito 1.0
  124. Foam wing construction help
  125. T2 A
  126. Bellcrank Question
  127. Wing tip shape
  128. arresti III engine mount position
  129. Nose ring with Dave Brown Vibra-Damp Mount(Von Linsowe) Soft-Mount
  130. Pattern ARF/ARC wanted 72" long or less
  131. Swallow EX90 drops wing
  132. Arresti III w/ OS 1.08(enough engine?)
  133. prop for tai-ji 60
  134. Mama Mia by Joe Bridi !!
  135. Brio
  136. *Best prop for OS .61FX*
  137. Muffler for Mintor 170
  138. OS 160FX + Hyde ARIA mount
  139. Kaos
  140. H9 Aresti questions v437.5
  141. NSRCA Feedback needed
  142. Excelleron 90
  143. OS-160 FI
  144. flair swallow
  145. Two Meter Pattern Questions
  146. Zen-50 CG anyone?
  147. Taller Landing Gear
  148. Nosegear Steering Arm?
  149. What does the average sportsman competitor fly?
  150. New Club in GARNER, NC
  151. Question regarding building balsa wood plane
  152. Angels Shadow tailwheel?
  153. Pattern and speed?
  154. Argh! MK mount - 91FX?
  155. Does Flap Application Cause a Pitch Down?
  156. Fuselage jig/"vee" blocks
  157. Elevator set up question
  158. 90 sized engines
  159. YS140 dingo mounting
  160. Rookie Pattern Wannabe
  161. Impact elevator servo mount
  162. ESC for electric F3A: LVC setting(?)
  163. Another Retract Question - Nosegear
  164. Electric Pattern Pioneers - Please share your experiances...
  165. New ZN-Line Synergy 140 3D
  166. R/C in Mexico - R/C en México
  167. Pro pattern Fuel.
  168. Widebody 60 setup
  169. Hello all ONYX 140 experienced fellows
  170. pattern plane for a saito .91
  171. HOW TO START AEROBATICS
  172. New apc prop-18x10pn
  173. Hacker C50 Bearing Replacement
  174. NSRCA 2005
  175. Aileron servos in Widebody 60
  176. Your Battery choice for electric (F3A) pattern???
  177. HELP NEEDED for new plane!!!
  178. GP Venus 40 Engine Thrust
  179. ca model fantasy almos done
  180. Sunglasses, lenses for poor visibility days
  181. Hard mouting OS 140
  182. SWALLOW 90 OR EXCELLERON 90
  183. Kwik Fly & Tiger 60 ARF Impressions
  184. Arresti III - Nov 04 Version
  185. Midairs at the Nats?
  186. Excelleron 90 engine thrust angle
  187. Arresti vs. Focus 2
  188. arresti III engine mount for YS140dingo
  189. Trimming for Dummies or 099 trim class
  190. Pattern Plane/Sport Flying
  191. ST90 Vs OS91
  192. The best engine for Imagine
  193. Idle on OS140RX
  194. Anyone know which vintage plane design this is?
  195. Futaba Corelss explanation
  196. Widebody 60 video
  197. Engine for GP Venus 40
  198. Sorry for Quique
  199. Find me a 60-70 inch span low priced pattern plane
  200. MOVED: Webra .61LS-RE
  201. What the best magazine for modelling
  202. Pattern in PARADISE!!!!! (Aruba)
  203. Any info on the CA wide body 60
  204. ZDZ 40RE Powered Impact
  205. Angels Shadow
  206. Where can these be found?
  207. great planes illusion
  208. My new Pattern Plane
  209. 90 Pattern plane profiles and moments
  210. Pattern plane and servos?
  211. Power MG BB Servo. Metallgetriebe
  212. Any news from CA models?
  213. 2x2m patternplane setup, sevos, powerplant
  214. OS 140Rx or 3M Mintor 170.
  215. F3A Synergy 140-instructions
  216. arresti III instructions
  217. Abbra 2m pattern arf
  218. Latest and greatest equipment?
  219. Widebody 60- gluing hor. stab question
  220. Funtana 140 videos?
  221. Zen 30 with an os 46 fx?
  222. What Mintor Header for ZN Synergy
  223. Caller's Function
  224. CHEEK COWLS
  225. Help ! widebody 40 vs. os 46
  226. Adrenaline?
  227. F3A Videos?
  228. Oxai Models
  229. YS vs Saito
  230. Masters schedules for 2005
  231. Arresti Availability
  232. MOVED: Tiporare
  233. Jevan Fitzsimmons-R.I.P
  234. Elongate Fuselage?
  235. Prop for YS1.10
  236. ZigZaw Atlanta
  237. Control Horn Hard Points
  238. ni/cr vs inconel for foam cutting
  239. Pattern Gas?
  240. .40 size pattern ship - which one.
  241. Javelin II or Widebody 40 ?
  242. OS 160
  243. What servo to use ???
  244. ONYN with OS140RX
  245. JR Propo explorer v50
  246. POSITRON 90 Scheme
  247. BEST COLOR SCHEME
  248. Larks Contest Motel info
  249. YS 140 FZ Generation I Questions
  250. Composit ARF Revolution Pro "Help"
