View Full Version : RC Pattern Flying
- anyone no anything about the ak models fasination
- Gator rc
- Artistic Aerobatics/ F3A
- What is the optimum and guidelines to choose tuned pipes for OS91FX?
- Silvestri's "Angel S" - is a kit available?
- YS 110 consumption
- My new Mantis Ex
- My Extra300LS pattern
- OS91FX vs Saito FA120
- World Models Groovey 90 FA engine
- Identify this engine... please???
- Groovy 50 3A by The World Models
- New Orleans - Katrina Pattern meet
- OMP F3D Fusion for pattern
- OS 160 prop and fuel?
- A good pattern plane for my Saito 91?
- The same
- Help, what polisher do you use ?
- MOVED: Pipes and Retracts SPA Contest!!!
- Hello,I am Chinese. My new plane.
- Worlds Planes Power Plants
- YS 140 Muffler question
- Help Identify This Plane
- F3A WORLD CHAMPIONSHIP 2005 - LIVE!!!
- YS 110 muffler
- Excelleron 90 with Mark 135-- What motor mount??
- Ultra fast servos on ailerons?
- Typhoon 1000 parts
- What happened to Hanno Prettner and Giichi Naruke?
- What is pattern flying?
- Quique flying F3A??
- Testing and Correcting Trim
- Rx Battery - Li-Ion or Li-Po for Digital Servos?
- Pattern flyers like ringed engines??????
- incidence on WM Tai-Ji 40
- ARESTI P-O7 -HALF CLOVER
- GO BRUSHLESS USERS
- Why Electric?
- Nose heavy solution?
- Epsilon arc finishing questions.
- Eclipse 2
- elevator linkage for removable tailplane
- Servo noise what do you think?
- 3-blade on a YS 63?
- My new Zen 50
- 2005 F3A World Championships
- Need FAI schedule for 2006/2007
- Please help!! Remote Glow Plug
- Hirobo Stream Balance point
- Rx Battery consumption--how much per flight?
- Alliance Canopy wanted
- JR Propo F3A Pattern plane?
- What size batttery?
- please help me deside on 90sizers
- 4 Blades
- Impact Aileron Screech Fixed!
- EXCELLERON 90 HORN FAILURE!!
- Mintor 170 setup
- Pattern plane and YS Set-up fueling??????
- World Models Groovy 50 3A
- regs for 2006
- regs for 2006
- Hammer 40
- Recommended first pattern plane
- New model recommendation
- epsilon colour scheme
- Webra 1.45 Promix II carb
- Wheels
- CArbon fiber rod for elevator halves?
- Leo F3A
- Precision transmitter gimbals
- Brio F3a in Argentina
- Dons Snap Article in the K Factor.
- Just Got MY OTOP!!
- Weathervaning and Pattern Planes?
- CAmodel Epsilon 120 motorization?
- Nashville, TN Pattern Competition Aug 27-28
- looking for a chin cowl for ca eclipse
- help pick my Epsilon engine
- Aeroguidance Society Pattern Meet
- Angel's Shadow spinner size?
- St. Charles, IL Contest - Aug 6th and 7th
- Brio knife edge trimming?
- cockpit models unicorn 110
- Futaba Digital Low Profile Aileron Servos
- C A models Epsilon 120
- Powermaster DZ fuel question
- Oly Medal Repaired
- CG question on GP Cap 580
- ASAno leaks
- balancing APCs
- Got my Excelleron.. now what??
- Widebody 60 ARC
- World Models Groovy 3A
- subforum
- High Plains CHampionship, Aug 6-7
- Rudder inputs on belly-side knife edge.
- Pattern Meet in Hadley, MA
- ASANO Tuned Pipes
- How do you carry your planes? OR What RPM do you run?
- YS 91 needs a pattern plane!
- YS CAM Gear Bearing Removal
- Trimming Header or Trimming Pipe
- Fashion 50 F3A
- *Giant Scale Planes Tsubame*
- New flying glasses????
- Sword 2M pattern plane
- Ys 160 Dz first start in the morning
- New(?) Glow Driver
- Rolling circle
- the future is here
- OS160 Fi troubles
- 95 mm (3 3/4") FAI Spinners
- FL contests, Apopka & Jax
- CG for Widebody 40
- Non linear rudder to elevator mix
- Saito 180/Groovy 90 ?? Is it too much??
- Gator RC Clear Canopy replacement?
- Sneak Peek Pattern flyers - Our soft post-beta launch of WattFlyer.com
- Zen 90 question
- Model Setup Trimming & Mixing
- F3A leo 110
- MOVED: Pictures of a Taurus Replica Pattern Ship
- 2005 US Pattern Nationals
- Elevator carbon Push rod question
- Master Builder in Japan
- BEAT-ON 90 PATTERN PLANE
- AXI 5330/18 ia an eclipse II
- Fliton Infinity 90 question
- Great Planes Venus .40 Review
- What propeller??
- Is the MVVS 91 Good for a Pattern ?
- Engine for Great Planes CAP 580 ARF
- JAX, FL Contest, Sept 3 & 4
- Differential
- I need Wings!!!
- New Quest CG problem
- Whittier contest
- Trailing edges
- Sorry wrong post.
- Nats Who's Coming
- Trimming: knife edge setup
- Zen 90 or groovy 90? info needed pls!
- Widebody 60 Engine Suggestions Please
- MOVED: 60's/70's Pattern Ships
- Pump mount
- New look to the members profile area
- Plettenberg Motor Temperatures
- argentina´s f3a world championship
- "Smart" fuel pumps
- MOVED: NO NATS COVERAGE
- Now this was some bad flying!!!!
- UAV Bully engines - parts/service??
- OnBoard Glow Problem
- Chip Hyde's Genesis - PROP!!!!
- Arresti Four - Updates
- Last ounce before the NATS
- MOVED: OS 61 Hanno Special question
- MOVED: prop question
- hello everyone. i want your advice plz
- Otop's fuselage
- How to fix warped elevator half?
- Kudos to PatternProz
- Icepoint
- Prop for MVVS .77 for pattern
- Center of Gravity for Wingspro Synergy
- Groovy 90, What Engine??
- Head to head pattern planes
- NATS scores.....
- July AMA
- Laser throw meter
- Header tank?? Good?? Bad?? should I, and how to do it
- Spoilerons/Flaperons for 3D ?
- What is the best engine for a Tai Ji 60
- Heading to Klagenfurt
- Nederland Contest
- MOVED: super tigre 90 for aurora
- Arresti X
- 18x10 prop????????
- Aresti 40 What Engine r u Running?
- Desert Aircraft: Hello????
- Just got my Javelin II
- Focus II E-flight conversion
- 9 ZAP ATV and AFR
- Large horizontal stabs, elevators, rudders, and so on
- Epsilon gear
- Pattern Props
- Javelin II and O.S 50 SX
- MVVS 144 twin
- Widebody pieces?
- MOVED: Dirty Birdi Question
- INVERTED AND FALLING?
- Carbon build up
- CMPRO Swallow 90 EX power plant
- 15th annual Pocono Pattern contest
- MOVED: *Old School*
- Hitec HS 635HB servos in Excelleron 90
- Check this out!!!!!!!
- K&B 100 DF with prop
- plane for a super tiger .61
- Electric stuff
- Ex-Treme 330 Expo and throws
- New pattern flyer needs recommendation
- Pattern/f3a plane
- e-Infinity Maiden Voyage
- Score tracking spreadsheet???
- BN Models Impulse Have Arrived !!
- Gearbox maintenance
- Help
- parcs pattern primer
- D4-D5 shoutout
- Seduction FreeStyle-please Post your pic
- Thinking about getting a Groovy 3A .50
- Electric Pattern
- Pattern sequence
- Who can make a DVD or a Video of the F3A World Championships in France?????
- Enigma CoG
- xtra 25-13 temps
- Romilly 2005
- Pattern in South America
- DZ header question
- How to fuel cowled in engine?
- Pattern in sacramento
- Balancing Point for Sig Kougar
- MOVED: Plans from the very last part of the .60 2-stroke period
- 18" Prop on 160DZ
- Focus2 Header
- YS .63 or OS .70 Surpass for Javelin II
- Icepoint Wing Failure
- Smaragd Z canopy
- 3D QUEST
- MOVED: Dirty Birdi 60
- canopy question
- Andersonville carnage
- Javelin and GMS 47
- Need Help
- Quique Somenzini will fly at the RAMS Open House
- Moisture in glow fuel?
- Best 90 size pattern plane
- HELP PLEASE
- Balancing 4 Blade Props
- Quique not going to France this year?
- Need Help Identifying Old Pattern Plane!
- Cermark Javelin- Best Engine?
- .46 Sized Quiet Pipe for Small Pattern Airplanes
- Push rod support
- what would be a good gas pattern airplane?
- OS 160 burning plugs
- Ione, California contest
