- aeroslave problem
- JR DS3401's on Elevator Duty
- OS 140 RX Pump Problems
- Hobbynet order problem
- Reliability of YS 1.60 DZ
- JR X9303 or XP9303looking for best long-term investment
- P-09.01 Reverse Split S and Split S Combo
- 9ZAP Condition Trim problems...
- Inspec
- narca hsv al pattern contest 14-15 june 08
- Radio South PPG Concept Urethane Clear
- Regulators For Dummies
- Masters judges - FAI 1-1/4 down snap
- Judges reference sheet
- Integral wing and stab tube replacements?
- Pattern Bi-Plane???? 33% Fliton Roque Bipe anyone????
- Jaccio regulator weights?
- Best price for a YS110S?
- Right prop????
- The loss of a good friend
- Jetero Pattern Classic
- Pilots
- Pattern scoring
- CG - extreme composite otop
- 18th Annual Pocono Pattern Contest
- 09 AMA patterns
- Snap Rolls - P09
- Heart of Ohio Pattern Classic
- SebArt Wind S 110
- which f3a for a 75 2st on pipe
- honda eu1000i
- 2008 nats/Concours de Elegance
- European Championship 2008 - Brescia Italy
- 2008 Asia Cup in Taiwan
- YS-170CDI Flight Report
- Venus II questions
- Tulsa Pattern Shootout
- 1000mah NiMH 2.2 oz OK For Pattern ?
- F3A plane
- CA Model Epsilon 90 building thread!
- Peach Pattern Classic '08
- Nats early registration
- Field Stands
- Beryll GP Build
- Servo selection on a budget
- Lincoln Nebraska Sky Knights Contest
- Color Scheme
- RAMS Pattern Classic update
- Pattern Plane for Saito 100
- Pattern plane for Saito 100
- CMP Quest 50
- OMG!
- New YS DZ170 cdi
- Damaged Typhoon 2+2 Repair
- Corrections and updates to the image-base
- Elevator Bell Crank MK
- CA Widebody 60 Tank Support
- RAMS 08 Preregisteration
- Precision linkage Setup????
- What plane is this?
- Knife edge trimming question
- Engine Offset In Pattern Plane
- 140 RX Pump Question
- Pattern in Greece
- Looking for a specific video
- prop questionMVVS 1.50
- JR Servos
- First pattern plane size 40?
- CPLR & Oxai
- Don Ramsey DVD
- O Rings
- Futaba 2.4 Ghz reciever installation
- Good Pattren plane? Zlin Z-50
- OS61FX vs OS91FS
- A123 Batteries, anybody?
- Retract question
- Houston, TX pattern contest May 3rd & 4th
- Rhom-Air Retracts...... Parts ??
- Fuel tank size - YS 120
- Temple,TX Contest Pics
- YS 110FZ very lean at Mid throttle, help!
- Advante 2/Evolution 100
- WHERE TO GET TEFLON HEADER TUBING
- 3 blade prop for YS-160 DZ
- ZN Line Twister
- Hobby shops in Munich, Germany
- Glassing and Painting wings
- Pattern By The Bay Contest Moved - April 26th and 27th
- Setting-up a F3A plane - Beginner need advise
- Wind/weather forecasting !!
- pattern sites in Orlando
- Hobby-estore Power 3D pattern plane?
- Birmingham AL Pattern Contest
- The Quest shall live again
- Looking for a **VERY GOOD** pattern plane for 91 4-stroke?
- "Bootlegger" any pix of it
- Dingo Help Please!
- OMP 80" Fusion
- Sudamericano F3A
- MK/OK kits ?
- GMA Pattern Contest April 12th & 13th
- YS110S - Typical Prop Sizes
- 08 RAMS R/C Pattern Classic
- F3A scoring enquiry
- How Much Do You Practice?
- OS 140 question?
- Groovy 90 3D Experience??????
- CA Models Glow Pass-Port Build
- Setting the pipe length ?
- Four Stroke Kaos?
- Stupid Newbie (to pattern) Question
- CLPR's choice of airfoil on the osmose.
- Fort Worth Vintage Pattern contest
- ZNLine Alliance incidence
- F-09 video
- 40-50 size pattern arf
- Gears for Futaba 9150 Aileron Servos
- X-tech Infinity Belly pan
- Focus I help
- 3M Mintor 170 Bearing
- Looking for an expert "Glasser".
- Great Escape and FZ91
- Epsilon 120 ARC US Source?
- Hacker C50 13 XL Acro Competition
- MVVS 1.5-walbro carb question
- Header to Muffler connection O.K.??
- Four bladed props
- Black-Magic - Sport (1.10 Sized)?
- OXAI - ARIES 7
- Epsilon 90 Cowl paint: how to?
- ca models osmose (bulk head issues)
- Nebula New personnal Pattern Plane
- ZEN pattern plane
- spot on 50
- Oxai Altair 09
- Naruke Aries setup
- cordless starters
- aerial - inside or outside fus?
- DZ160 Issue - Injector Coming Out of Head
- Flexible"cooling" Header Repair possible??
- Requesting information on this Chris Lakin designed Fascination Pattern Plane (pics attached)
- Negative snap for P09 manuever
- Replace YS 1.20NC with YS 1.10FZ?
- tracer for speed
- Typhoon sport
- Need a new pattern plane?
- Contact wanted for Krill
- Pattern Plane trimming
- Traveling to Venezuela
- Saito Glow-Plugs in a YS140DZ??
- Does anyone know what plane this is?
- FUEL TANK MOUNTED ON THE CG
- How to fix the servo cable on a light way
- spektrum "throttle kill swithc"
- How do you snap?
- YS Engines NO WHERE TO BUY!!!
- P-09 woes
- Pattern Clinic and Judging Seminar March 16th
- Pattern Plane Recommendation
- Glassing a fuse
- JR DS168 servo,46oz torque,,enough power for ailerons on 2x2 F3A model?
- CA Models Pass-Port Build
- now fly "euphoria"
- Hyde Mounts
- ZN Synergy with T-Canalizer
- what is the difference between cored and coreless servos
- Leo 110 assistance
- Onda's Narlar
- CG of a Bridi Great Escape
- best propeller for YS 170DZ
- Phoenix Pattern Contest
- X-Tech Infinity
- CG Obsession - Pattern Control Throws
- YS 1.40FZ Question
- wingtips
- P-09 takeoff advice
- what does F3A and FAI stand for?
- NSRCA is moving!
- OXAI Pinnacle Downthrust
- New Kyosho Osmose 70 ARF
- Mylar Hinge "treatment"
- OS .56 or .81 for this model?
- Webra 145 R manual
- YS 120 Hyde Mount and Throttle linkage
- 11.1V Lipo for JR 10X transmitter??
- YS160DZ with Powermaster 30/23LV heli
- BLUE MAX Challenge for Pattern Contests
- Class Progression in Pattern
- Hatori pipe repair
- Angel's Shadow Anyone?
- S2G Bolero
- How to secure and lock shocks in YS super mount
- Question about the Webra 145R
- Should F-XX be flown at local (ie: Non-Nationals/Team Selection) events?
- Axi 5330/FAI witch adapter for spinner
- Good plane for a YS 60 2-stroker?
- A123 Batteries for Pattern Rx ?
- F09 a killer or not
- Anyone know a pattern flyer "Frannie" from NJ?
- Showtime 50 as a "fun pattern" plane... anyone?
- Homeless Saito 100
- ROLLING ROLLING ROLLING
- Finding and aliging fuse centerline
- Question Aileron Servos
- Contest Balsa Source?
- OTOP VS. EPSILSON 120
- Futaba 14MZ sound
- Euphoria wings
- HELP! K&S 600cc F3A fuel tank needed
- DZ Foam Clunk
- funtana.... patern ship???
- Flyers In Los Angeles Area
- Flyers In SFO and Bay Area.
- *SWORD-90*
- os 140rx Pipe
- Where to get Bolly props
- I need a starter pattern plane
- FAI F3A Sporting code 2008 edition
- Snap / Spin exit
- 20/30 vs. 30% Cool Power Heli for YS 160 or 170
- YS DZ technology??
- Fashion 50 Quality
- Beryll GP,...Anyone?
- Zeque+Oxai+Axi+Roi Import Team
- Adjustable Wing / Stab Trimming Question
- YS DZ170-M
- Why need low wing trainer?
- Question - Sportsman Schedule
- Genesis replacement parts
- Futaba 4.8v Servos with Jaccio 5.2v Regulator
- Composites Supplies?
- Angel S EVO Build Thread
- Amazing build log (japanese Addiction build)
- Ocala Pattern Event March 2008
- Glow driver delay
- Electronic caller
- Focus 2 CG Range
- What does the nose ring do?
- Flying Models OPTION 120 Plan
- Retracts ??????????'s
- Oxaï New Biplane - Amethyst
- Challenger VI ???????
- Pl prod Tornado???
- Prop choice
- tunepipe sharing for F3A
- Practice stick planes
- YS Front Bearing Oil Seal
