- 3D Buddy power system problem.
- Cheapie brushless...
- Himaxx
- Can i Fix this motor?
- Timing advance used with AXi 4120 series?
- Help ! how to put out the propoller washer from the shaft
- axi 2208/26 and phx 25 noise
- Queation on ep42
- motor and fan recomindations
- GWS Set
- AXI 5320 series... experiences please.
- Is Shaft replaceable on Hacker B20?
- Need a brushless recommendation
- eflite outrunner and hobbylobby airblaster...
- AXI 2826/12 Watts help please
- Alpha Corsair & MP Jet Red outrunner
- Hacker x series speed control
- Electrospad esc advice needed!!!
- Motors ESC question
- Speed control voltage?
- Need ESC advise.
- JETI ADVANCED 70 OPTO CONTROLLER
- RT Model CL- 415
- Loss of Control after a bit of runtime
- Hacker A20-22L and 23oz electric plane
- hacker mounting
- Noise from Servo
- AXI Recommendation/Superstar EP
- STRANGE SMELL
- Problem with Phoenix 25
- Help to understand electric motor
- Help! - Throttle problem with Phoenix 60
- AXI Lovers Sale!!
- AXI Lovers Sale!!
- AXI Lovers Sale!!
- I think I wrecked my E-Flite 400 Brushless?
- 801V INFO>>>>>>>>>>>>
- Great Planes RimFire ...Need Help
- ESC help
- brushless comparison
- E-flite Ultimate Bipe
- GP1100s cutting out
- Which ESC for Axi 4130/16
- Speed Control or Battery problem?
- AXI 2208 bearing removal
- Himax 2025/4200 w/ 35A ESC
- brushless help
- Matching motors for a twin
- High efficiency motor
- motor loosing power
- Help with seting up my esc
- Info in motor!
- brushless break in?
- Which AXI = HAcker A20-20?
- Break In Cobalt Motor??
- Cool S 4200
- Measuring current on brushless ESC
- 40mm, 18slot statorlaminations, group order
- ElectriCalc
- mystery motor ??? hirobo top gun 9017
- 4 servos w/3cell lipoly phnx 25
- Pinion gear for Electrifly Ammo brushless 2mm shaft
- Cool Running ESC
- Electrifly BL8 esc recall?
- Hot Motor/Battery
- 43oz of thrust around 15amps,who am I?
- ESC Malfunction?
- scematic for brushless controller
- Prop efficiency vs system efficiency
- two motors?
- sig cadet ep 42
- U-Can-Do 3D EP Frustration
- Eflite 400 outrunner after doinking problem
- Stryker Help
- Jeti Jes030 Jumper set up???
- Motor Size. How it works?
- One ESC for two brushless motors ?
- I need help choosing a brushless motor.
- Which motor?????????
- Jetti Voltage Cutoff To Low???
- BP21 BP18amp. how many servos
- Gear Box for Wattage Cobalt 400 motor
- axi 2212/26 shaft reverse
- COOL STUFF HERE!
- Speed controller information please
- Help with setup
- broken axi shaft
- Alternative power setups for GP Siren?
- AXI 2212/26 Question
- Replacing Shaft on Hacker A20??
- prop size for Direct drive 280 motor
- Jetti 30
- New problem with old Pixie 20P ESC
- SuperFly meets UltraFly
- Help on prop selection
- Got an idea for my brushless jet set up!?
- How much can you push AXI 4130-20?
- U-Can-Do 3D EP
- HiMax 2808-0980 controller settings
- EFLM1000 Problems
- Need some help with someone who has motocalc
- Aveox F12 for continuous flying???
- Axi motor and Phoenix 10 throttle backwards need help!
- My motor cuts out and I don't know why
- Two Jeti controlers
- I'm falling apart!
- Help I'm confused AXI Brushless
- dual motor gearbox
- Full throttle and you fall out of the sky HELP
- New Great Planes ESC Question
- NEED HELP BAD
- Is this a good power system selection
- Axi 5330 GEARED.... Has it been done?
- Baby Bee replacement motor???
- Unusual Problem
- Help! Cannot keep the prop on my Himax
- Hollow Shaft Bent
- micro 5-3D
- will my 20 amp great planes ESC be enuff
- I need some help
- Eflite 20Amps Brushless Speed Control?
- Electrifying a B-25
- increasing modor rpm
- Cirrus & FMA RX's, Good, bad?
- Hi Max 4100 mounting screws
- Very urgent Question!!
- Need to service my Astroflight Cobalt?
- Typhoon Micro 5/3D
- Hacker shaft coming out all the time
- Brushless motors
- Midflight brake GP 20A ESC + GWS 350BB motox/box
- what does WOT stand for
- brushless help
- what are the 4 wires on thunder power batteries?
- using a rc car esc
- How to solder motor connectors ("G3.5")?
- will this have enough power to fly
- Speed 180 Amp Draw
- ESC gets HOT
- GWS dual motors 4.8v any good?
- AC 28/7-35D outrunner w/throttleability "issues"?
- What Prop?
- [delete]
- Down thrust neccessary?
- A Align brushless in the Rascal from SIG?
- question for lipos and motor to be used
- possible EDF-75 b/l motor upgrades...
- twin brushless motors and esc
- brushed 400 to = brushless
- AXI 2208/34....HOT or NOT?? Be honest...
- 30 turns in Brushless?
- Align 400lf owners look here
- pinons
- AXI 2826-10 on 6s
- park 370 outrunner
- Need propeller advice...
- Brushless interference - help ?
- Speed Control Cooling
- 5.1 geared 400 question?
- 4130/16 Radial Mount Shaft
- Little Screamer Performance!
- Dymond Model Sports Li-Po Batteries
- MEGA - ACn 16/25/4 with LiPo
- Rotation and Props?????
- Question on Astro Flight Mighty Micro 010
- Align 25amp brushless esc
- bp 21
- Help me sort out motor size.
- Himax 2025/4200 Bent Prop Shaft?
- Brushless Motor, ESC, and Li-Po choice
- motor cuts in and out during flight
- Ele EBM-950 or EBM-850 - Experiences?
- Smoked Speed Controller
- Mega Broke, Can It Be Fixed?
- brushless for parkflyer?
- Esc bec question
- NEED GWS LITE STIK GEARBOX
- AXI vs. GS Outrunner
- Any difference?
- MOVED: What receiver should I use if i want to install a brushless
- Ball bearing bird
- Himax outrunner motor for GWS Corsair?
- Brushed Motor Info.
- Help please!
- What APC prop for HiMaxx 2816-0850
- Eflite park 400 shaft / rotor replacement
- Where to find capacitors for my E-flight 20 amp brushless sensorless speed controller.
- Motor choice for 40" 3D Foamy ???
- PJS 1000 back plate
- Hacker A20-34S
- AXI 282610
- Hyperion 80 brushless esc..number of lipos?
- Newb to Electrics what setup for this plane?
- Shaft Replacement on Hi Max 2015
- OMG!!!!
- do i need diodes on the motor ?????
- two brushless motors
- Changed Batteries and now have a problem
- Pheonix 25 questions
- Newbie Motor Question??
- Which ESC to buy?!?!?
- newb to electric question
- Jeti Advance Plus program card
- BP 21 getting hot?
- PHX-Link won't work
- Eflite 20 amp esc making my motor twitch and cog
- newbie question -Outrunner vs other brushless motors
- Not enough amps
- Testing Jeti Advance ESC
- Motor Won't Start.
- Align brusheless 35A or 25A?
- Help with motor choice for 36" Wing
- 15A ESC with speed 400 motor?
- APC prop on a GWS gearbox
- How do I connect a Feigao to a Jeti ESC?
- Thrust question
- Frying Servo's
- I need something to control the current to a motor from the reciever
- LittleScreamers brushless...Verdict?
- Sensorless ESC with an Aveox 1114/4Y?
- Motor vs Speed Control placement
- Zagi Tazz Brushless System
- Are they ok?
- Electric motor questions
- Align Motors
- 2204/54 equivalents/competitors?
- aerobird xtreme motor weight?
- 15 lbs thrust
- Hacker brushless ECS
- VTOL
- Counter rotating drives
- Axi 2808/24 need help please
- LensRc now offering DIY kits!
- AXI 2826/12 - Phoenix 45
- question about outrunner brushless motor!!!
- GWS Motor dilemma
- Question (pics) about brushless operation
- MPJet 28/7-35D Outrunner + RV-4
- Home Built BEC Advice
- neumotor
- question for matt about endoplasma motor
- 85,000 rpm outrunner motor
- Watts to thrust.???
- Is this too much prop?
- To BEC or not to BEC?
- astro 15 how many cells????
- Opinions wanted regarding new ESC damage during install
- CoolRunningUSA brushless control $29.95
- Mega 16/7/7 motor
- Outrunner vs Geared brushless
