PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26
  1. Razor service sucks
  2. Gary Wright gear drive problem. HELP!!
  3. gobrushless.com?????
  4. Kyosho cessna 180
  5. Where to purchasse a 76T spur gear for GWS
  6. What prop and bat to use on this motor?
  7. Combo for scratch built t-28??????
  8. RAZOR VS.HIMAXX
  9. Are other geared drives as bendy as GWS?
  10. Battery Size for Configuration? HELP
  11. 370&380,speed 400?????
  12. Can't get my 400 motor to run . . .
  13. PJS motor bearing replacement.
  14. Speed 480 power expectations
  15. GWS ZERO gearbox setup with himax 2025
  16. Fried GWS 370 motor with 3 cell LiPo.
  17. gws edf brushless conversion
  18. Triton Question with a Lipo battery
  19. how to install pinion gears
  20. Fried Motor and Connector Terminology
  21. shockflyer
  22. Don Smith P-61 build for E Power
  23. Motor doesn't stop
  24. Installing 2 Speed Controllers
  25. where to buy coreless motor
  26. Astro Flight Cobalt motor ID
  27. Connectors for Lipos
  28. Speed 400, what Himax replacement
  29. GWS Gearboxes
  30. Astro 020 Brushless Question
  31. AXI 2208/34 and Phoenix 10 problem
  32. Motor question
  33. Speed 380,3.75:1 geared, 9x4.5 prop,etc
  34. Slow Stick and 1147 props: Don't even try.
  35. Has anyone tried the Himaxx 3600 motors?
  36. Le Mans Speed 480. How much current?
  37. Need LiPo + ESC connector advice
  38. Kyosho Gear Unit
  39. Hacker C50 14XL mounts
  40. E-flite Motor Specs?
  41. Choosing a hotliner prop (baudis banana)
  42. S400 bad magnets and venting
  43. Himax silly complaint
  44. prop question 2,3&4 blade.
  45. FMA Lipo Propulsion Pack
  46. suggestions for brushless motors, please
  47. Heatsink for a Himax 4100 or E-Flight 370????
  48. How many ESC per motors?
  49. brushless/lipo estarter
  50. Lifespan of a brushless???
  51. Breaking in Electric Motors?
  52. heli esc's?
  53. speed controller,battery,reciever combo
  54. Speed Control Problems
  55. Mounting APC prop
  56. PJS Website ??
  57. magnetic mayhem
  58. Which Motor, Speed Control & Gearbox?
  59. Did they wire my motor backwards?
  60. Graupner Speed 300 problems???HELP!!
  61. Hummingbird tail rotor motor
  62. esc for Slow Stick with 300 motor and LiPo 2100
  63. ESC damage due to hard landing?
  64. Park 400 Brushless NOT on foam wings!!
  65. Over power for grass take off.. or diminishing return?
  66. Possible to get a flat spot on a GWS bearing (300 motor)?
  67. 30A ESC and 400 7.2 Motor
  68. Not Enough Power With My Slow Stick
  69. Motor glitches
  70. Where do you shop online?
  71. ESC and Motor WIRES
  72. backwards zagi pusher
  73. Help! Great Planes Electrifly 5ch RX/ESC
  74. mega 16/15/4, did i make a mistake?
  75. Info source on GWS motor comparison
  76. Which Brushless For A MiniFlash?
  77. lighting transmitter
  78. 2brushless motors in parallel 1 controller
  79. Motor Cuts off after 1 min??? Help Please???
  80. cdrom motor
  81. ESC help
  82. Mounting a Promaxx gear box
  83. Tsunami 10 + Micro 6 problem
  84. prop velocity calulation
  85. himark brushless motor
  86. Gearing for what?
  87. Himaxx motor
  88. Himaxx motor heat???
  89. Astro 205 ESC specs
  90. E-wirering set up question
  91. Firebird II Battery Packs 8.4v 700mah?
  92. Hardened GWS gear shaft
  93. Aerobird motor in Graupner Stinson?
  94. microtex 20/5/18
  95. Trainer cords
  96. Simplified Battery Tables??
  97. How hot does a brushless get
  98. Astro Flight Colbalt 05 Help
  99. distance between motors
  100. E-flite esc and radio help
  101. Wet break in
  102. help needed from the pros
  103. Setup Question
  104. multiplex 480/8d
  105. Twin jet speed controller size
  106. bent gearbox axile
  107. Slow Stick with EPS-400C?
  108. GWS Corsair prop selection
  109. Motors, Controllers & Batteries, OMIGAUD!!
  110. What Motor Do I have
  111. brushless for espad3d?
  112. IC to E conversion ; help needed...
  113. Links for Electric virgin
  114. What brushless motor for my Slow Stick
  115. Super Cobalt 400's
  116. Mega 16/15/4 vs Mini AC 1215/9
  117. My pheonix 10 is all messed up!
  118. Question on receivers
  119. Mega 16/15/2
  120. Oil brushless????
  121. Jeti Vs Castle Creations?
  122. Twin Electric Question
  123. help!!
  124. Electric motors and capacitors
  125. ms-001 brushless
  126. ESC with BEC = more cells o.k. with RX batt ?
  127. Triton discharge question
  128. Hacker B20-22S and Li-Poly setup question
  129. ESC Selection Help
  130. Razor vs. Himax????
  131. Himax 2025-5300 running hot(why)
  132. Benchtop brushless motor testing controller
  133. Bent Prop Shaft
  134. Confused, please help!
  135. Output shaft wobble?
  136. Zagi XS on Lipoly. Nothing fits the battery tray or balance??
  137. Chili Pepper CP20 brushless, anyone tried ?
  138. Triton E charger
  139. APC E-Prop or Slowfly Prop
  140. motor & battery suggestions
  141. New to E, need motor suggestions for Filip 400 Sport
  142. Himax 2025-4200 amp draw
  143. Mega 16/15 and Phoenix 25 problems
  144. extremeflightrc mini 3d brushless setup
  145. Motor shaft length
  146. 3 Cell LiPoly and GWS motor
  147. 2 motors, 1 esc
  148. brushless upgrade question
  149. Please advise on AXI
  150. Himax 2015-5400 Questions
  151. finding an ESC for this Motor (W/PICS)
  152. dynamo electrics
  153. Wons Custom Himax Gear Box
  154. Brushless Motors & Jeti Controller w/training cord over amp?
  155. Jeti Gold label brushless ESC
  156. Help with GP C-50 ESC
  157. What are specs on Electrostreak ESC?
  158. HiMax 2025 4200 / CC25 / Confused
  159. Power hookup question on a cobalt 400
  160. alternative to Mega?
  161. Motor/Gearbox Questions - GWS Beaver
  162. EDF 55
  163. Brushless CDROM ESC
  164. Not the electronic expert, help plz!
  165. building plane
  166. how to retime my baja motor?
  167. How to determine if a brushed motor is bad?
  168. How many turns for 3D?
  169. Manual Programing CC controlers..HELP!
  170. ESC and Battery Distaster!
  171. Setup question
  172. question about brushless speed control and brushed speed control
  173. Question about Moto calc
  174. Castle Pixie 20P ESC BEC problem cut off w/fully charged batteries
  175. 010 trouble different
  176. What combination for best speed/efficency/weight
  177. Motocalc static readings
  178. Amp check question for brush-less
  179. Help with gearbox and prop!
  180. New guy w interference!
  181. first plane almost done, but might have the wrong esc
  182. Brushless
  183. Single Motor Belt Drive 2 Duct Fans
  184. Speed 700 BB Turbo 9.6V - what battery/speed control?
  185. ubec for 10s lipo
  186. Where to buy Hacker motors?
  187. Great Planes 600R
  188. Alternative ESC Source
  189. What SpeedController ???...
  190. Where to get Ikarus props?
  191. how many amps does a speed 400 motor draw
  192. Soldering capacitors on Ikarus shockflyer
  193. Mini 3D on AXI 2820-12 with install photo
  194. Motor mount info needed
  195. Brushless set-up on Jumping Jack?
  196. 33% GP Extra Electric Power?
  197. axi wont turn, am I missing something??
  198. I need help with a power upgrade please
  199. Beaver Down! Beaver Down! ....UH OH
  200. Which Plane?
  201. Brushless Combo for...
  202. Why aren't brushless motors standardized?
  203. Newbie-Lipo do's and don'ts
  204. Gws gearbox gear change
  205. IME CONFUSED with speed controllers
  206. Noise level: Electric vs. Glow
  207. What cutoff voltage for 3s1p Kokam 1500?
  208. Gear on MEGA 22/30/3?
  209. Pinion keeps slipping off motor shaft, Help!
  210. Shape of propellor
  211. Pixie 7p cuts out
  212. Is my motor ok ?
  213. How hot can a motor get
  214. Graupner speed 300 question
  215. Speed 400, what is max current?
  216. gws 350
  217. brushless motors for a Slow Stick/ GWS Zero?
  218. Prop pitch selection
  219. Questions about a Himax motor setup for FS P40?
  220. ESC & Servos for the SLOW STICK
  221. Motor selecction - need help
  222. MP Jet Prop choice
  223. Twister motors
  224. Propeller for Accipter Badius
  225. mega motor cutting out
  226. cheap small motors?
  227. Which Himaxx motor for 13.8 oz plane?
  228. HiMaxx prop?
  229. multiplex motors
  230. Help - Bent Motor Shaft
  231. prop for 3 turn
  232. Seem to Have a problem with a speed 400
  233. What are the diff between these speed 400 motors?
  234. What Can I Do, Need Some Prop HELP!!
  235. Razor2500a TOO HOT?
  236. Mega mini 7 motor?
  237. Watt Meter
  238. Motor gear box help
  239. New to electric, want a versatile motor
  240. Thrust for Axi's
  241. Brushless Gurus- Need more power
  242. Brushless Info???
  243. Brushless for Graupner Terry
  244. PJS 1000 3D PROBLEM
  245. Can someone with a motocalc plug this in for me please?
  246. best prop
  247. power loss issues
  248. Question regarding Atomic Force Vs. Endoplasma
  249. Float Plane electric questions
  250. Any problem using larger controller?
