- Squall 4s speed control
- brushed 550 and jeti esc
- motor cuts off
- Twin out runner motor's and speed controllers
- turnigy 100amp esc driving me up the wall!
- Wiring question for electric twin
- Brushless motors and pusher props
- Ever make your own prop adaptor? I might...
- Do i have a bad motor or ESC?
- Ducted fan
- Scorpion Commander ESC question
- Replacing ESC?
- need info about motors
- WHAT PROP SHOULD THIS MOTOR TAKE
- trouble shoot motor, esc?
- Need Help Converting YS-140 T-Craft to Electric
- hyperion yak 55 "10" motor set up
- How many poles does my motor have?
- wiring question
- Capacitors on Speed 400 - this one from Slinger kit.
- 4mm prop adapter
- Outrunner and ESC need a new plane!
- J-3 cub
- Brush spark suppression on 2.4 ghz?
- Prop Question
- brushless inrunner
- brushless motor
- park 480 screaching sound
- 450 upgrade ???
- Exceed ESC problem
- aveox 1406/2y brushless motor
- What size speed control?
- 370 Brushless
- 100 amp esc
- Need some help...Will this work?
- losing power after 2 minutes
- Programming ESC's for Newbies??
- Considering electric flight, help needed
- turnigy 3536-1100 bearings
- Idle Current?? Long duration glider flight.
- Bigest Brushless, Which one ?
- Can a brushless motor turn in reverse
- turnigy 3536-1100 prop
- What Astro Flight is this?????????
- Rimfire 42 - 40 (.25) screeching noise!
- 11.1v lipo on a 9.6v speed control
- Jeti 18 amp Advance ESC User manual
- How did I fry my Electrifly?
- Help picking a motor for pulse 25
- In search of hobbyking reversible esc's
- Help with Throttle....
- Motor for glider conversion
- Parkzone J3 Cub
- motor and esc connections
- 12 V motor recomendations
- Electric Motors
- Need a cheap(er) alt to the Hacker A30 : 10XL
- motor Kv- min or max value
- ESC Question oor Problem?
- Want to replace my brushless...
- Plane should be setup with 6s want to use 5S
- Twin BEC`s
- Help with Deuces Wild and Kontronic FUN400-23s
- Problem with ESC ????
- Electric Rotowing
- Swapping motors... Questions?
- Scorpion S-4035-250
- ESC control problem?
- ezrun esc prob
- Electric brakes
- how do you hook up twin sped 4000 motors in series
- Brushless motor Grinding noise
- BEC or RX battey?
- Esc-Motor wiring help?
- stopping the prop
- High Revs
- 35 amp -vs - 45 amp ESC
- Brushless Beech Staggerwing?
- Motor taking out esc's?
- help for a prop adapter and mount?
- power differance?
- great planes electrostreak brushless conversion
- Disastrous maiden flight. Help, please.
- opening up park 480.
- Odd question/situation
- Brand new to electric and need help!!!
- How do I do the battery hook up?
- Sweet Motor/Prop Setup!!!
- GForce G46 Brushless Outrunner Motor (50-55-580KV)
- Please help. I am lost with this brushless engine.
- Cheap motor recomendations for DW 55" yak
- NANO Tech??
- Please Delete
- TURNIGY LIPO BATTERIES
- Esc?
- Which motor for Mini Funtana X, easy flying?
- Geared brushless motor source?
- indoor micro brushless motor options
- Factory pre-set Cuttoff voltage ?
- P-51D Mustang BL RTF by ParkZone
- Esc Ques Hack30x Runa A Scropion 480
- Cyclone battery size?
- Surge 400 motor
- ESC & BLDC problem [Solved]
- brushed to brushless
- Neu/Castle motors which will work fine in a Mamba Monster on 6s?
- what prop size
- Discontinued Electrifly SU-31 profile plane
- T28 Trojan Replacement Motor
- Medusa Questions
- ESC
- what motor for 600g picojet
- best motor
- Sync 2 electric motors?
- 2- vs. 3-blade prop
- ferrite motors
- Setting Brake on ElectriFly 25A ESC Help Needed
- different shaft for a brush-less motor
- Capacitors?
- motor size for epp f22
- ESC shrink wrap
- What is the proper size engine for my electric glider?
- ESC heating
- stupid noob question
- Kontronik Fun 480-33 help
- Twin motors and Motocalc
- What is "kv" rating?
- how to replace shaft exceed 480 outrunner
- How do you epoxy magnets back in??
- gearbox explosion?????
- Large Chinese motors experiance
- How to test brushless ohms resistance
- Alpha 370 Brushless problem
- Low RPM motor for very high altitude
- ESC question
- Higher power consumption after crash?
- 2 outrunners on same shaft
- Special ESC
- Hoffman Magnetics HMI 10-8, How good are they?
- twin eng. with 2 ESC with 1.5 amp BEC.
- Cox Airplane 5030/18 Brushless Motor & 90A OPTO ESC
- Sensored Brushless ESC's
- Ultra Micro P-51 motor/gearbox problem
- MonsterPower 110 (295kv) Brushless Motor
- Thinking about starting a motor line
- Czech Brushless outrunner is similar to what??
- low speed (0.1 rpm)
- Wiring multi brushless motors
- Mystery motor
- Motor Timing??????
- turnigy shaft 35-30-1400kv sk
- Electric motor upgrade for T 28
- Strange motor reaction
- Is my speed control big enough?
- heat sink
- Need help for prop size on electric motor
- pentium esc program card????
- What capacitor for long battery leads?
- esc with start button with 2 channel radio
- Aeolian esc
- Any good techniques for adding downthrust/right thrust to outrunner?
- E-Flite Motors
- Recommend 120 amp ESC please
- amp draw
- parkflyer jump jet
- ESC
- Question
- Emax 960 KV. BL2832/05 motor...
- Help with replacement
- Change eflite esc mode for Ni-MH bat?
- prop bake feature on eflite esc
- Hot Motor
- is my math correct?
- BEC voltage output?
- hacker a20-50s and x-7 what batt
- Super Tigre ESC voltage cut-off
- Motor cuts out after 1/3 throttle
- 2 bl motors, 2 bl esc's, 1 y connector, different start points?
- Texas Rc Planes Pantha
- Upgrade electric motor?
- Problem with Electric Motor Cutting Out
- Supertigre st.10
- What motor for a ducted fan unit?
- EMax GT Series Outrunners
- Emax Bl2220-07
- Let's blow something up!....ESC, Motor, Prop combo question
- Can someone help a beginner with some voltage/wattage/motor math?
- 3 blade prop
- ESC HELP
- Power 90/110 prop size
- Rimfire 28-30-950 & Kyosho T-33
- Looking for inexpensive (~$30-$100) 4-+ pole 540 sized or similar BRUSHLESS motors
- What the hell is an outrunner motor?
- Jeti 77 opto
- Big Problem-need help!
- Motor, fan and ESC from hobbyking
- programing cards
- Are capacitors needed on brushless motors?
- Brushless inrunner over heating
- Help: brushless motor speed control
- Contra-rotating motor set up help
- Brushed ESC without "safe-start" feature
- Connecting a motor to a speed controller
- Dynam Skybus Motor replacement
- Speed 400 brushless
- TURNIGY K-Force 100A Brushless ESC any good for 10c
- Rimfire 65cc Need Help
- Oiling the bearing in a Turnigy brushless outrunner motor
- What does OPTO mean?
- ESC question!!!
- guanli a10 problem
- E-Flite 60ESC pro 7 servos plus retracts ????
- Turnigy motors from hobbyking
- stryker motor conversion
- Converting a Hobby King Turnigy C3530-1700 motor
- Wattage Cobalt 400 motor mount?
- Programming a E flite ESC
- Hobby King SS 90-100amp ESC
- Nitroplanes Yak 54 .25 size motor suggestions
- brushless help
- One Dime RC ESC Help !
- current drop vs. battery rating
- Sky-Wing ESC
- PHOENIX 25(CASTLE CREATIONS) WHAT VOLTAGE GOES TO RECEIVER????
- Turnigy 50-65 and 63-64 anyone have experience with these?
- Do I need capacitors?
- Possible motor timing problem
- Sentilon 100A HV ESC
- HELP DECIPHERING THIS MOTOR/PROP
- Need some help and suggestions from smarter people
- ok, so I just smoked 2 speed controls...
- motor and prop for p38
- gws ics-480
- Hi cell count lipo arcing
- $200+ bucks brushless WHAT!! @#%^%
- timing issues or bad ESC?
- timing?
- Volcano 60 amp esc
- amp calculations
- Mini Sport motor???
- what exactly is a ESC
- Turnigy esc an brushless inrunner question
- Help! Too many servos.
- Change the KV of a motor
- Mystery 200a programming
- HELP...I need a few dimensions from an E-flite Power 46 Outrunner.
- ESC TIMING QUESTION
- ESC ratings, what do they mean?
- had a water "incident" with my seaplane
