PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26
  1. Hacker B40 11S?
  2. 9 Hours
  3. Motor Theory 101
  4. Stuff for a foamie...This OK?
  5. Setup Recommendation needed
  6. Kokam 1500 Problem???
  7. Ultrafly Typhoon brushless esc, need info
  8. global super colbat 400 motor
  9. Need help with ESC
  10. Is the Electrifly Ammo motor made by Brushless Motors Inc.?
  11. ESP on/off switch
  12. Voltage cutoff on Electrifly C30 esc ?
  13. Freezing motors before break-in????
  14. Question about the new Himax Outrunners
  15. Zagi 400 X motor
  16. How battery with Axi 2208/34 and Phoenix 10
  17. Pheonix 10 and Hi-Max 4100
  18. cell allowance with an axi 2212/26?
  19. skatty MTM Motor max motor 400
  20. Mini-AC motors
  21. Astroflight Cobalt 05 FAI racing motor
  22. Which prop?
  23. Jeti18 & AXI 2212/26 soft & hard timings
  24. GWS EPS-100C(DS) with Slow Stick
  25. GWS motor performance question
  26. GWS motor performance question
  27. New Hi_max Outrunner
  28. disconnect BEC
  29. Really need a "Reverse" motor for a Gearbox?
  30. direct replacement
  31. need help calculating thrust
  32. BIG MPJet outrunner/MEC superbox 2:1,16x12!
  33. jetti lost instuctions
  34. questions about 2 motors, how to do
  35. 540 motor question
  36. Jomar ESC
  37. Substitute Motors for B-17
  38. What do KV ratings mean in a BL motor - and should I care?
  39. Brushed ~20A ESC with brake and Lipo?
  40. Yokomo aircraft motor
  41. New PJS 400j high speed outrunner
  42. Fliton Jumping Jack setup
  43. Great Planes Electrifly Ammo Brushless Motor
  44. brushless esc choices
  45. Set screw size for Himax blue gearbox?
  46. 370 motor
  47. Need a pro for electric motor question
  48. motor and speed control
  49. Cant get my jeti 18 p to beep
  50. Littlescreamers.com New 21gram brushless motor
  51. Inexpensive starter kit with: Brushed motor / battery / ECS ??
  52. Axi 2212/34 Phonix 25 and prop sizes
  53. questions on new types of motors?
  54. Drilling Props for Electric Flight
  55. motor
  56. Phoenix 25 cuts out at full throttle
  57. Great customer service
  58. C-123 with 2 Axi 2826/10?
  59. Direct drive vs geared???
  60. what motor controller for a Hacker B 20 15L ???
  61. GWS Connector
  62. MP Jet Gearbox
  63. TEKIN'S PUBLIC CART IS OPEN
  64. Looking for Info on Brushless & ESC for Shogun
  65. Which Speed Control to use?????
  66. Phoenix 25 jiggles outrunner but it wont start
  67. B-25 mitchell twin motor
  68. gearbox problem
  69. GP Electric J3 Cub
  70. Battery connector for AXI JETI08 and Thunder Power
  71. Newbie needs help with motor numbers - what do they all mean?
  72. Stalled propellor
  73. Praise Where Praise Is Due!!!
  74. Speed control on steroids!
  75. what brushless motor?
  76. what battery for a MP jet 25/25/26?
  77. Weight to motor size ratio
  78. "Unloading"
  79. nosram international please help
  80. Brushless NiMH setup
  81. Brushless / ESC ??
  82. Jeti JES30
  83. MTM400F outrunner w/GWS 400C gearbox
  84. Gear Box question/problem?
  85. GP Electricub with Magnetic Mayhem
  86. Astro 010 quits 5 secs after full throttle?
  87. Newbie Questions
  88. PRESSING GWS PINION GEAR ON HIMAX B.LESS
  89. Brushless motors
  90. what esc is on superstar ep?
  91. Speed 300
  92. Battery Pack Mah
  93. Phoenix-25 & NiMH
  94. Brushless for .40 size Smith Mini Plane.
  95. Brushless motors
  96. Best props for cobalt 05?
  97. WHATTMETER by AstroFlight (?)
  98. Castle Creations Phoenix 10 ESC on Backorder
  99. surging-3s1p,jeti18,eflit400 brushless
  100. Prop choice????
  101. Can you alter small dc brushed motors?
  102. GWS EDP-50
  103. Astro 625G uses how many cells?
  104. Question about cheapy BL ESC
  105. Jeti 18 timing, soft or hard??
  106. Will this work?
  107. Helicopter or Airplane Brushless performance
  108. motor twitching
  109. Is it safe to use these props on this setup?
  110. How do you know which way the prop goes?
  111. E-Flight 400 Problems
  112. Pusher Props for GWS drives
  113. Question about number of servos
  114. Proper brushed motor breakin?
  115. What is brake on an ESC?
  116. AXI MOUNTING IN SU 26 MX
  117. When motor shaft bends!!!then!!
  118. Multimeter with > 10 Amps
  119. Help with Speed Controller
  120. GSP mosquito
  121. Shafted...
  122. Old RC on off switch operational problem
  123. 2 Motors 1 Battery Pack
  124. jumpy brushless motor
  125. E-Flight 370 Question
  126. Where can I get AXI bearings?
  127. Please help? Speed control issues!
  128. PROP LARGENESS
  129. AVX27 OR AXI2826
  130. Jeti 20 + LiPo + forgot to unplug = NFG LiPo
  131. New Himax "Outrunner"
  132. 350c is dead... now what?
  133. propeller Tiger Moth slow flyer
  134. Slo-V engine cutting
  135. Brushless prop sizes and EPA
  136. speed 400 duration
  137. slow stick with eflite park 370 5400kv?
  138. think I killed my brushless motor
  139. Exp. with DIY brushless motor from Aircraft-world?
  140. Jeti 18?
  141. Jeti Advance 30 brushless
  142. Brushless ESC for brushed motor
  143. Speed control for Tigermoth 400
  144. ? for Smart Person - Quick Speed/Prop/Gear Advice
  145. Jeti controller
  146. Three Bladed Prop
  147. Wiring Diagram
  148. Please help before I blow myself up !!
  149. Does size matter?
  150. AXI_2212/34 & 2212/26
  151. need help hith e-setup
  152. R/C Motor 30 lbf Airplane
  153. Going brushless for the first time, need suggestions
  154. Astro 020 Changed Direction ?Suddenly?
  155. ESC WOES
  156. Is c-10 electifly speed control good for 400 motor?
  157. E-Flight brushless motors?
  158. What size motor would I need?
  159. Newbie needs help with motor break-in
  160. Aerobird Challenger Alternate Motors & Props?
  161. Propeller Choice for FS P40
  162. How to time an Astro .020 Cobalt?
  163. what is no load amps?
  164. Himax motor/gearbox problem
  165. Static Thrust of Propellors and Ducted Fans
  166. New BIG AXI 5320 and 5330 series motors - anyone any news?
  167. Gearbox repair
  168. Speed 300 heating, burn outs... Help
  169. ESC question
  170. Brushless Turbo Bee
  171. my luck continues feigao woes
  172. Is this a good brushless?
  173. axi 2212/20 thrust
  174. pinion gear attachment to motor
  175. Stevens AeroModel Cutter/Strippers
  176. Which speed controller
  177. HELP! Which brushless to use ALFA P-47???
  178. no load amps for axi?
  179. PJS 1000 Timing and Frequency
  180. ESC Amps
  181. Checking ESC Cut off Voltage
  182. locktite on prop adapter???
  183. Great Planes ESC mini 30 voltage question
  184. Speed control for Speed480 with 3,45:1 Gear
  185. Fuses
  186. E-Flite Parts
  187. multiplex 480/6
  188. cermark 600bl2 stripped threads How to take apart
  189. Brushless....WOW!!
  190. VOLTAGE REGULATOR
  191. astro flight 020 diamiter
  192. My motor just shakes violently????
  193. Wattage cobalt 400, any good?
  194. Max amp load
  195. what brushless motor will fit in a gws eps 300?
  196. Tiger 400 gearbox
  197. Green brushless motor.
  198. How would I debug this?
  199. ****Help Again 4-blade propeller*******
  200. Help with basic electrics...newbie
  201. Two brushless motors on one ESC?
  202. Bearing size for Razor RZ 2500 motor?
  203. Flight times are insane
  204. AXI motor mount?
  205. Prop kept getting loose. Any suggestions?
  206. speed 400 motor mounts
  207. Distance of ESC to receiver?
  208. Running in a new motor
  209. ? on # of turns in a brushless motor
  210. burnt out razor 300?
  211. Cheap brushless and ESC?
  212. APC/ GWS Equivilant?
  213. Castle Creations PHX-Link programmer
  214. Phoenix 35 and 2212/20 Whines!!
  215. Motor gone whacky - Question: motor or esc
  216. Motor/esc
  217. GWS Prop Question?
  218. Will I damage my batteries?
  219. What Speed Control and Battery
  220. watts per pound
  221. Zagi motor break-in
  222. ***counter rotating propellers on a C-130?
  223. Make Your own Brushless ESC?
  224. E-Flite 370 Brushless Li-Po Question
  225. Understanding Gears
  226. deleted
  227. 44" Chipmunk Power Setup
  228. Himax 2025-5400 or PJS 1000?
  229. Dual speed controls = more servos
  230. Power Plant Forumula
  231. Hi perfo motors and GWS props?
  232. WHATS YOUR FAVORITE BREAK IN METHOD?
  233. Balanced Kavan prop won't be used
  234. LiPos for GWS T moth
  235. which brushless
  236. Phoenix-25 Speed wacky at low throttle
  237. frying 400 motor on 1st flight
  238. Just received a new brushless motor
  239. learning electrics. How to choose motors?
  240. Hacker gearbox repair question
  241. Re-winding an AXI
  242. LiPos and Speed Controllers
  243. Identifying Motor
  244. brake function on Castle Creations Pegasus
  245. Large Electric
  246. Homebuilt props?
  247. Any harm running a higher amp ECS?
  248. Help on an C-130 Propeller
  249. APC 9/9E @ 8000-10,000 rpm, direct or geared?
  250. Replacement for 400 Cobalt Motor
