- Gear for E-Starter in another plane.
- troy bilt website
- Great Planes PT Electric
- Stock Tribute on 3 cell lipo
- E-Flite Brushless
- Goldberg Tiger 400 Motor Selection
- Amp rating for the Parkzone J-3 Cub 370 motor.
- New to Motor and Controller
- Motor and Battery Questions
- Super 400 Gearbox installation
- Motor,speed control and battery specs?
- what lipo
- Nippy Black" External Rotor Brushless Motor
- Hacker B 20/18 vs Mini AC 1215/16
- Multiplex Brushless Motors any good?
- [Deleted]
- Smallest power source possable!
- Brushless replacement for 6V Speed 400
- ***Help on an Electric C-130 *****
- connectors: brushless motor
- LiPo setup help - need more power
- Charging my LiPolys
- Feigao motor in Tiger Moth IPS..... WOW !
- LiPo/ESC advice on GWS Corsair w/ EFlite 370
- Lehner motor help needed
- RPMs and thrust
- Servos working the opposite of what they should.
- MEC Brushless motors
- controler problem
- Motor rotation question?
- get pinion on shaft?
- Need Advise on Converting Global RCM Trainer to Electric
- 9.6 AAA vs KAN Question
- What batteries do I need???
- How do I attach/remove pinion gears?
- brushless motor help needed
- gearbox efficiency
- Numbers on brushless motors?
- Is brushless really that good?
- New ACTRO motors from Hobby Lobby?
- Substitute Axi2208/34 for HiMax2015-4100?
- HELP! Motor keeps not responding, glitching
- Motor going bad
- Brushless Motor Configuration for "Home Built"
- Help needed with Compro Controller and 22.2v
- MFA Rocket 400...
- DSP4 - HiMax connection question?
- brushless without brushless controller
- Electric Motor Primer
- Pixie 7-P ESC problems...
- Thrust vs AUW
- How Long will it fly on a charge
- GD600 Gear Box
- prop size for 400 motor
- GWS 350 brushed motor question
- Which AXI is equal to PJS1000?
- is this ok esc/motor/Gbox/lipo bat combo?
- Is this a good setup?
- BEST MOTOR
- I AM STUCK
- Charger Advice
- How to safely attach a folding prop to Speed 400 shaft?
- Motor help wanted
- Powering a Wattage Super 400 motor
- ESC and servo question
- setup for crazy 8
- What is the red button for?
- Hacker B20-15L
- direct drive questions
- More Park 370 info!
- mp jet 25/25/26
- AXI AMP HOG!!
- 2 Himaxx questions
- Boinked Himax
- Help?? My Clancy Lazy Bee Lacks Power!
- too much prop ?
- Mabuchi motors (GWS, SIR, wattage and everyone else)
- Brushless motors, esc's, batteries?
- Predict what will happen
- Which power package?
- motor and ESC suggestions?
- Brushless CD Rom IPS Replacment
- Castle Creations Pegasus 35 ESC
- MPJET Gearbox Broke... Now what????
- Has anyone tried HiMax Brushless on Dynamax?
- Motor Quits
- ESC advice
- What Prop?
- Looking for GWS "IPS" motor RPM per volt?
- 3 blade prop = more current/amp draw?
- $1,000,000 receiver question
- Battery problem....
- A basic lipo/esc question
- SPEED 400 prop selection?
- Need help with my Himaxx/Lipo Set up
- homemade logging dynamometer
- Please help with a few calculations
- ESC Programming Question
- Do you think my Lipos are fried
- 2 channel radio
- New PJS motors!
- Hacker B40? question
- gws upgrades
- kyosho caliber m24 motor
- GWS ESC Question
- BRUSHLESS ?'S
- ESC for B50 13S
- Help, fried speed control
- Multiple engine setup
- Hacker Master Speed Controller
- Axi 2212 mount screw size?
- Anyone have Gen 2 TP1320 3s1p in stock?
- How do you stuck a pinnion ?
- Servos touching each other and pusher motor question!
- 30A Electrifly..disabling BEC
- Re: Help: Prop set up for hacker B20 12L
- Motor selection for a light twin
- Got a plane and 2 motors. need help
- GARY WRIGHT - ENDOPLASMA/GREAT PLANES
- FEIGAO BRUSHLESS MOTOR WIRING
- wiring question.. new to electrics
- $25 CD Rom Motors
- upgrades.
- Motor Cutting Out
- Quick & simple (I hope) question
- GWS 400 gear - shaft won't slip past bearings
- JETI MASTER 77 OPTO Instructions in English
- himax motor for Great Planes Slinger
- Park 370, 1st impressions!
- Changing gears
- himax 2015-4100&6x3folder
- Axi engines types
- Burnt out GWS motor: why did the ESC get so hot?
- power loss, himax??????????????
- Zagi ESC LVC
- Anyone know PJS motor's web site?
- Is there a rough guide for electric motor equivalencies to gas engines?
- brushless advice for mini laser 3d
- Which Great Planes Control?
- gws gearbox noise
- PJS1000 Motor help needed
- How to remove bend shaft from GWS 350 gear box?
- pressing pinions on?
- Himax Help
- HELP estarter speed control - what connector?
- what kind of motors?
- Wattage IC-15A premature BEC cutoff
- Motor timing problem
- li-poly fire extingruisher
- Best Brushless ESC for 34 cells?
- Tekin 410s esc
- Hacker M 48 O heli questions
- Prop Shaft adaptor for new Himax GBX??
- Geared brushless
- Parts for PJS motors
- Same setup - variance in performance
- Brushless speed controller HELP?
- will a hacker system fit in a losi xxx s G+?
- How are motors measured - i.e., what is a "Speed 400"
- Beeping from motor, and no throttle control
- speed control , 350motor, and nimh 9.6v battery
- Is their a problem *Himaxx 2015-5400 / 3S 2100 Thunder Power
- NOOBIE needs INFO... Britney Spears, Paris Hilton
- naive question about brushless motors (+)
- amp meter
- Nippy Black 0808-98/ Where to solder?
- What is the best battery for Mega 16/5/5 Brushless?
- motor spec
- B-29 Speed 600 x 4
- Master Air Screw 3.5 :1 Gear setup
- Very Large electric brushed setups - Where to get?
- How to get my pinion gear off?
- Where to get brushless feigao 1308434s Cheap$$$
- motor shaft won't turn
- Megamotor 16/15/6 what gearbox and prop for 3D?
- No. cells
- 9Z, P10, Hacker B20-26, Bergen combo
- Himax pinion
- novak brushless in a plane
- help me figure this out
- ESC for AXI 2208 34
- Need Planetary Gearbox for a Himax
- What RX?
- AXI 2208/26
- I just don't understand where to start
- MEC Monsterbox Upgraded
- HIMAX 28/15/2000 CHEAPEST PURCHASE
- Running in My Johnson 250 motor
- Twin Engines and ESC - DO you need 2 BEC inputs
- ESC for Park 400?
- lipo Battery problem
- Fried ESC W/ Photos
- Prop Help with 300 Slow Stick
- CC Phoenix Timing -- Power vs. Efficiency
- modify aerobird circuit board
- Motor rating basics
- AXI and props?
- What gws for a 3dx?
- Please help, Power cut out problem?
- Axi 2212/34 only developing 17.5 ounces of thrust
- ESC Problem - Motor too slow
- Speed 400, battery & prop advice needed for "Scooter-E"
- Compair glow size to electric?
- what size motor
- GWS Pinion on a HiMax
- e flight 400 brushless broken shaft
- multiplex 480/4 geared
- How much thrust?
- Phoenix 25 settings for AXI 2208/34??
- PJR 550R Speed Controller Mount
- Hitec 555 receiver questions
- A/I Robotics FX35 Digital speed controller
- himax 4100 -25 castle creations 25 controller What prop to use?
- AXI 2208/34?
- brushless help PLEASE
- Props
- GWS MOTORS/GEARS
- Multiplex Permax 280 BB
- Parkzone Cub LiPo setup
- Crashed in water, now what?
- Motor Cutting Out During Flight!
- Hacker Motor Extremely Hot
- Jeti Advance 30-3P Problems
- Time for Fire extinguisher if you fly Hacker
- brushless 4 hobbico select ep
- where can I get j250's from?
- Battery Recommendation please....
- Attack 4 electric radio
- Before I start,, is this a good setup?
- can i turn my brushed esc into a brushless one?
- GWS Twin 300 engines and ISC-300
- Prop for 3D flying on GWS 400 "D" drive?
- Does anyone know if these can be swapped ?
- Replacement motor for Slow Stick
- making a shunt for a DMM?
- Speed control plug and recever question
- will a pheonix 10 run a axi 2212-34 w/3cell lipo?
- Good brushless combo for a wattage crazy 8?
- Parkzone j-3 cub battery
- Electris Newbie seeks HELP!
- Motor and ESC for TM upgrade
- Three point prop
- Phoenix 25 with Himax 2015
- what clearance for pinion gear?
- GWS EPS 350C motor and gearbox squeaks
- Packing Maxon Gearbox with grease?
- Plain bushed Speed400 lubrication
- Wemotec fan?
