- Motor / Propeller / Throttle Trim
- Disabled BEC Phoenix-80 castlelink won't work
- in need of batteries
- Which motor should I use?
- Monitoring output... ??? heh??
- Sig Wonder on electric
- Speed 550 Motor for a glider
- MOTOR AMPS AND WATTS????
- BM 2409-12 Turn United Hobby Combo? (Novice)
- setting up 6s cutoff using programming software
- which one should i get please help?
- Help...Kontronik gear match ?
- brushless ESC with no BEC - how to over come this?
- Pulso 450H starting problem?
- Major overheating on Li-Po set-up
- Planetary Gear Box Removal? HELP
- New motors from China
- BP-12 Delta
- New moter is bad? HELP!!!
- NEED MORE POWER...12mm Muedusa to???? for Micro Stick?
- Where to get magnets?
- Thrust Q?
- need help
- Hacker 20-20L HELP!
- Heard from Jeti in the Czech Republic again
- Medusa 12mm Motor w/Micro ESC won't run...CHIRPS
- Hacker A20-20L vs Scorpian 2215-18
- Repairing ESC
- Bad batch of Jeti Advance PLUS 45 Opto's??
- Ø90mm Fan Power Advice
- big problem please help soon
- programming/jeti card/dynam 45 esc
- Whats this good for?
- ESC NEEDED GPMP2020 20 AMP BRUSHED
- Brushed motor 2 leads brushless 3?
- electric motor running backwards
- comparison of Jeti ESC's
- size of esc, bigger is better?
- hacker esc fried twice!
- AXI Motor question
- Welgard ESC
- Scorpion Motors
- 4 ESC`s off 1 rec.????
- Kontronik SWING 1000
- No throttle control in flight- CC Phoenix 10
- Eflite 370 BL/CC Phx 25 ESC compatibility
- Brushless ESC and BEC ?????
- Counter Rotating 3 blade props for P-38
- 2 b/l motors off one esc?
- wild thing motor info
- Are ESC's necessary. Can we do away with them?
- question about Jeti Advance 70 plus
- HELP Please- LARGE scale commercial project needs power advise
- Help with cut-off voltage
- whats the most powerful motor for a 1/10 r/c tamiya
- AON Electric Customer Service
- GP electrifly Piper Cub upgrade.
- What 35 amp draw Brushless motor?
- EDF Combo Questions
- GWS or Waypoint 35A ESC?
- Rotofly CDROM motor
- brushless cdrom, steppermotor, starwinding and ESC question. :)
- Do I need a UBEC with a TowerPro 65a G2 esc?
- Why would a brushless moter get "sticky?"
- Heli ESC vs Plane ESC ?
- speed control wire length. please help!
- Good thrust values for power etc? Astro readings off? TwinstarII...
- Phoenix 110HV What connectors for motor?
- BRUSHLESS OUTRUNNER TO GEAR BOX ?
- ESC Choice: CC25 vs Eflite 20
- Phoenix 45HV will not arm?
- Slow stick graph
- LIPOs, ESC and Motors Books or Articles?
- Specs for 180 motor?
- Minimag Brushless
- where i can get cheaper or used Lehner 2250??
- Help!- Jeti 012 ESC problems
- Can a Jeti Advance 70-3P be used with 6 cells???
- question about brushless
- what do the numbers mean on BL motors?
- cutoff voltage
- gear drive to direct drive help !
- whats your experience with the supersportster
- Brushed-Brushless conversion
- brushless esc theory of operation
- Speed 400 Brushless alternative
- E-flite 25-Amp esc Problem!
- Ultrafly apollo-25 esc
- prop adapter
- TwinstarII with Hacker A20-26M and 15 amp ESCs a good combo?
- Stupid/naive Axi 2826/12 Question
- Replacing a Motor Shaft
- Noises a brushless motor might make
- Strange problem with airplane!!!
- advance 40 opto plus
- parkzone fw-190 HELP!
- Books on electric propulsion
- GWS ICS-600li
- Direction of rotation for a pusher
- Programming Jeti Advance 77-3P Opto
- What makes castle creations so good??
- contoller temperature seems too high.
- Jeti/Axi Running Rough
- BL Outrunner to replace brushed 400 inrunner
- Mystery Motor
- WHATS A BRUSHLESS?
- Phoenix 10 and 25 differences?
- appollo-25 esc and 11.1 2070 mah lipo
- how to program esc
- Brushed Electric Motor Break-in Guide
- Himaxx 2025
- E-Flite power 32 BL
- How to tweak thrust angle
- Geared Brushed upgrade?
- Mini Rx Using High Volts!
- Arcing ESC
- Multi Motor setup question.
- How much is shipping from Unitrd Hobbies?
- Brushless setup for Zagi XS
- Use watts to measure motor power?
- Brusless inrunner question
- 3s1p lipo too much power for a brushed 480 with gb?
- Easy Glider brushless upgrade
- Urgent help on ESC
- Three hole stick mount for rimfire available?
- can i use 3 servos with a castle creations 10?
- Question on Silver Series ESC
- AirBoss 35 programming
- Help!! Glow 4stroke to electric in Cap 232
- Help!! Glow power to electric in Cap 232
- Brushless inrunner and ESC advice?
- ESC for Mini Pulse XT...
- How to repair my E-Flite 20 Amp V2 ESC??
- Programming Instructions for the Mystery 40A - 120A ESC
- GWS 400 pulsing at 1/2 throttle
- 400XT with 7 cell 2/3AA NiMH pack-- how much power?
- AXI 2820/10 (expensive) vs Rimfire 35-48-1000 (less expensive)
- Motor/Prop/Voltage/RPMs/Thrust/HUH?
- HobbyZone Brushed 480 Prop Tests
- Outlet for Batt Balancer Plugs?
- ESC with no low voltage cutoff
- New ELE EX28 inrunner motors
- timing vs amps?
- Li-po and esc ?
- MICRO Telemaster motor recommendations
- multi motor setup (the best why??)
- Speed control or motor?
- DSM Remote - Lose signal and throttle goes to full
- apache air 20A brushless speed control
- ESC not arming
- AXI setup
- Which rating do you use to calculate watts?
- Home Brew Motor/Prop Tester
- my expierence with props today...
- 5 wire servos/ESC
- HiModel ESC?
- ESC Program Card - Do I want one?
- E FLITE ESC
- Comparing motors
- Welgard Motors & ESC's - input???
- Help on motor selection
- Need some recomendations
- Timing for zpower 450 (3800kv)
- ESC Low Voltage Cutoff
- Prop recomendation
- Gearbox Help
- good enough?
- Replacement bearings for outrunners ???
- custom spinners
- Cheap motor any good?
- High Advance Timing motor timing? Hi-Maxx 2812-0650
- 6 bladed prop
- Twin Brushless motor
- Soldering Bullet Connectors
- Help with Motor and ESC selection
- Trouble arming an E-Flite ESC with a DX6 radio
- E - Flite 480 910KV OR 1020KV ?
- How to smooth start a motor?
- ESC for a Hacker A20 20L
- Great Planes B/L Motor Mount with an AXI 4130?
- mount outrunner mount
- Firewall Motor Mounting
- Need motor for 6S LiPo
- HELP....motor/speed control cuts out.....
- Two motors at once?
- Removing Prop Adapter
- Mounting an AXI 2208/20
- HOOKING UP A PROGRAM CARD???
- low voltage and high current brushless
- WHAT IS A PROGRAM CARD? . . .
- thrust setup-axi 2820/10
- Speed 280BB vs Speed 300 - Need education
- Eflite 40A ESC on FIRE!
- 22 oz P51 Mustang
- ESC Frequency Options
- Bad ESC or bad motor...please help?
- esc problem ' question
- esky brushless motor help
- Motor, ESC, etc Choices for EFlite Mini-Funtana
- Benefits of buying next size ESC
- Avoid RC Hobbies unless you know all the answers
- Do I add a Switch to my Pheonix 45
- Two Brushless, Two Esc, One battery
- Is a KV950 brushless more powerful than 480 brush
- Watt Age Cobalt?
- EM-300/34 motor
- Typhoon brushless motors
- Ammo brushless direct drive
- Brushless timing problem
- Motor Recomendation
- will a castlecreations pheonix 35 esc work with 4s lipo w bec?
- NEW PIXIE 20P PROBLEMS! HELP!
- Why no universal standard?
- electrifly c-30 brakes
- Which brushless set up for Minimag?
- Quick Brushed motor question
- 2 blade to 3 blade (rough estimates)
- DUCTED FAN ESC SETTINGS?? FOR CC35
- CC Phoenix 45HV Problem
- gear box for Go-Brushless type cdrom motors
- Speed control prblem?????
- Question on 400 brushless outrunner
- Ultra Low KV Help
- Is it a 35 or 45 CC ESC ?
- old 20 amp e-flite controller
- Does this motor/speed control/batt combination sound right?
- Is this a good ESC?
- which propeller?
- Looking for info on a Cermark speed controller
- Jeti Spin Bec V/S Opto
- Bullet Connectors
- Mega 22/20/2 question
- Electric motor for 60 size F4U Corsair
- EP is driving me to the EDGE Of SANITY!!!!
- How to attach propeller to GW/EDP-50XC
- CDROM Motor & ESC
- Feigao motors anyone?
- 4cell lipo on a eflite 480
- skyartec motors
- motor wiring
- Suggestions on a brushless for rookie?
- brushless motor choice
- Wood Prop for Axi 2826/10
- Tower Pro Mag 8 20A esc
- Can you ID this Controller?
- Prop connection to GWS motor shaft
- Motor Diameter VS KV size
- GP Rimfire and GP Esc wires don't connect
- castle creations or venom ?
