- Han9 eindecker and brushless motor
- How many magnets do i need to use?
- how much power or cells
- Need more prop?????
- High voltage or Low voltage cut off?
- PJS motor help
- Problem with motor run
- Castler Creations PHX-Link
- What determines max motor voltage?
- Motor Upgrade for my Mini Super Sportster
- Novice mistake?
- Twin set up counter rotating prop
- Need help with GWS ICS-300E Speed control
- motor choice for a 22 lbs twin
- Mini Funtana prop balance
- Cermark Islander Power
- Is there interest in custom motor mounts for NIPPY,PJS,AXI, ETC?
- Brushless upgrade to Wing Dragon
- Prop Pitch?
- Motor info needed...
- Hacker A20-34S measurements
- Best retaining compound for brushless motor assembly?
- Gypsy
- AXI motor for 32 oz. plane
- AP29 & amps
- Align RCE-BL10A
- axi 2808 wheigt of model
- axi 2820/10
- axi 2814/10 weight model?
- Newbie needs help with programing ESC
- Hobby Lobby P-38
- Phoenix40A/AXI2826 causing fatal radio problem in 29 MHz
- ESC cutoff for LiPo and NiMh packs
- brushless motor animations and simulations
- copper, neodymium and diy brushless
- checks&tests before connecting newly wound motor, ESC and batteries
- Speed control and Li-Po
- Power setup need replies
- Speed 400 motor
- The need for speed!
- BRUSHLESS FOR RAMBBLER EP
- AXI Help
- Brushed 480 prop
- brushless would not run,why?
- Help with what to buy?
- Brushless motors/ESCs
- Need Hi-Maxx gear box
- Matching my motors to my planes....
- Cermark CEM-600BL-2
- new to electric, want shock flyer, HELP
- Electric Newbie...Looking for guidelines
- Brake "on" or "off"
- Phasor 30/3 what size plane goes with it?
- Hi all, need help with micro gearboxes...
- EDF 75 4 blade or 6 blade ??
- TP 1320 battery setup problem/Question for foamy
- Himaxx brushless parts
- park 370 brushless
- reversing and timing an electric motor ?
- Zagi Brushless
- ELECTRIC CONFUSION!
- great planes electrifly????
- Which Prop
- Hacker b13s with 4s3p lipo in me262
- AXI 2808/24 equivalent
- JETI ESC - Possible problem?
- Will this work?
- Who got the best deal on foamies/motors/esc/lipo's?
- Need help with JETI JES 012
- Recomendations for gypsy
- CD-ROM motor question
- bp 12 outrunner
- updated list of outrunner (kits too) manufacturers, over 50
- Hacker B20-15L fit 6.6.1 gearbox????
- Johnson 600 aircompressor motor?
- Align motors
- problem with Himax
- SU-DU-KHOI motor?
- Programming voltage cut-off for Phoenix-35
- Sportster ESC problem.
- PJS 3D 1000 shaft slip problem
- Hi all !! Ducted fan question
- New Komodo Hobby DIY Motor Kit
- Alfa Corsair motor question and did I forget anything
- Need help w/ Phoenix-25
- Axi 2208 motor shaft
- Castle Pixie 20 not working
- Is my Pheonix 25 'tarded?
- Brushless--how does it work
- Multi engine, brushless application
- 2808-1160 Himax Outrunner + 3S lipo. What prop to max out?
- Jeti ADV 70 OPTO LV settings
- Help with MP Jet Hook up
- ESC Theory
- AXi Radial Mount Question...
- outrunner direction swap
- Homebrew Brushless Motor efficiency
- Which is better geared or outrunner for 3D
- Receiver on/off switch on Esc.??
- gear it or direct need opinion
- AXI 2808/24 or Hacker B20 15L?
- to gear drive or direct
- BRUSHLESS EMERGENCY
- motor for my indoor foamie
- how do you drill your props
- feigao bl motor 3808412s
- Power setup for 4m scale glider
- himax & gws proo
- Oh Crap.....
- GWS IPS 12mm*30mm mtors
- MGM TMM 18 amp ESC programming
- pinion trouble?
- Is hard timing ok on a 2 pole motor?
- Feigao 130 Short w/3.2:1 Planetary Gear
- Short Videos of my planes with NEW motors
- gears wearing out on himax gearbox
- Jeti Jes 350,speed 400 problems
- prop size
- axi 2208/34 on a 3S 340 li-po
- ESC and receiver setup, help!!!!!!
- Brushless Vs Brushed
- propellers
- my clamp on amp shows 7.4 in one wire, is that the total amps?
- Raiden Tech Outrunner 400T
- Opening up a Himax
- Reverse a Reverse Rotation Motor?
- MEC Super Box-How did you mount yours?
- MEC Super Box- How Did You Mount It?
- Post your AXI 4130-16 setups and performance HERE!
- Looking for a lost thread
- ESC for surface vehicle operation
- lipos and speed 400 motors
- 56mm, 24 pole brushless motor
- Will this combination work?
- proping??
- Definition of motor "sizes" Please?
- New ACW DIY motor
- ikarus brushless set!
- Prop Question
- Futaba FP-R127DF Question
- Removing gearbox from Hacker B50-11s??
- E-flite 20A brushed ESC problems...
- ???? Speed controller
- Relationship Between Voltage Wattage Amperage and Prop Diameter etc.?
- DC Motor for Electric Starters
- Capacitor and Diode installation Help.
- Pushing the boundaries of Castle Creation
- E-flight brushless 370
- prop angle at motor shut down?
- Power setup advice needed.
- urgent working on plane right now
- speed 600 what sise prop
- Capacitor Question
- Calculation for sizing a motor
- Battery Connection ?
- Need more from my 2212/34
- Motocalc n00b questions
- Electric power newby question HELP
- GWS eps350 gearbox- engine location (AMMO)
- Try to get Kyosho Le Mans 2405 powered - on a Valencia
- HELP!!! NEED MORE POWER!!!!!!!!!!!!!!!!!!!
- Aluminum stick mount for AXI 28XX series?
- How to mount an APC hub on my plane ?
- AXI 2208/34 with pheonix 10
- Motor for banana baudis. ??help me.
- Torque of Motor
- 10 Cells on astro 020 question
- Motocalc, please
- GWS ICS-480 J Speed Controller plug???
- Question on Phoenix 25 setup
- Hobby lobby Megatech P-47 power options
- How to swap my wimpy 380 without breaking the bank?
- cheap 370 motor
- HEELLLPPPPP MY 05 Cobalt stinks!!!!
- ESC Setup..
- electrifly c-20 wiring
- Better gear drive for mini Futana?
- Brushless Stagger Bee???
- Astro 020 in the Stryker f-27
- Brushless motor RPM under load
- Prop Adapter...
- Best Slow Stick prop
- GWS Motors
- Loss of power has me stumped!
- UBEC - Who Makes 'em, and where can you order them from?
- Balsa BP21 Outrunner/ TM 400
- I Have a Strange ? For You Guys
- 370 Outrunner Question
- Johnson 250 gear drive options
- Himax 2812-0850 for mini funtana
- Aveox problems (manual)
- Affordable replacement
- Slow stick brushless questions
- Looking for a ducted fan
- balsa products esc, thunder power lipo question
- GWS/EDF-75 Brushless Conversion?
- Eflite 20A brushless ESC question
- New Ballsa Pructs BP-series Ourunners
- Can I get himax parts?
- E Flight 370 Outrunner and Attaching Props
- Brushless in the rain?
- Help Shocky motor SCREECHING!
- not enough revs
- Correct switching of bec/ lipos
- E-Flight 370 Outrunner Shaft?
- Using Novak SPY speed control in a parkflyer
- apache batteries
- DO ESC's care about AM or FM ?
- Help and Avise
- what ESC for tensor??
- Apogee 830 vs 1050 for AXI 2212/34 CC10
- Motor cuts out at half throttle. (Phoenix 25 controller)
- Outrunner Brushless vs. Regular Brushless
- newbee on batterries
- 2212/34 output vs Motocalc
- MORE POWER! I need 2000 Watts
- rewiring motors
- INTERFERANCE? How close is CLOSE?
- Best Brushless for Slow Stick
- PHOENIX 25 TIMING ADVANCE QUESTION..
- Brushless motor problem, need help.
- Brushless KV Question
- kyosho on 3 lipos
- Shocky with PJS 300SFR what battery?
- Help with SU-27
- guillow cessna 170 24" conv.
- How to connect three brushed motors?
- Motor wires too close to Rx??
- Some Questions concerning watts/size/etc.
- E-flite Brushless 400 Temperatures?
- Speed 400's enough?
- PHOENIX 25 ESC QUESTION...
- home made electric motor
- Slow Stick 400 prop doesn't fit!!!
- Phoenix 10 And E-Flight 370 outrunner
- Himaxx gearbox problems!
- Kontronix Fun 400/23 vs. Mega 16-15-4 ?
- Question
- Out of control servos!
- LIPO battery pack reduction question
- Pico Stick with EPS-100C
- Spur Gear Problem w/GWS Gear Box...
- Eagle /prop/thrust/hover
- automatic cell sensing ESCs?
- Help with a brushless 400 and phoenix speed control question
- How many amps can the astro 020 handle safely
- wattage 400/6 with different motor thrust?
- endoplasm and magnetic mayhem questions
- Twin Speed COntroller
- what gear box for mega 22-10-5
