PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26
  1. AXI Motors PROS AND CONS?
  2. Jeti 45/3
  3. Down-right thrust mod on Slow Stick
  4. Gear box for an AXI
  5. Low voltage cutoff on Jeti/Hacker Master 18 - 3P
  6. 16/25/3 SETUP
  7. Difference between "6V" and "7.2V" speed 400 motors
  8. Difinitive Word
  9. Crazy 8. Will an Astro010 G work?
  10. GWS EDP propeller problem
  11. prop for Himax 2025-5100
  12. Motor Contact Confusion
  13. GWS 350 D gearing??
  14. GWS A Drive
  15. help please
  16. Herr Piper Cherokee
  17. eHawk 1400 upgrade
  18. Planes for Futaba S3004 Servos
  19. GWS ISC300E SPEED CONTROL QUESTION
  20. Vario Prop Problem
  21. Gearbox for Speed 300
  22. Any speed 400 motor optimized for 11 volts?
  23. GWS 350 Motor Cut Out
  24. Himax motor selection question
  25. Drivetrain for 7-cell glider
  26. Brushless motors need lubrication or matinence?
  27. fans
  28. Simple questions
  29. Minimum Advertised Pricing, fixes prices...
  30. Prop Shaft/ Gearbox Question
  31. Problem with set up
  32. Direct drive or Geared
  33. Brushless for Accord II and Mini3D???
  34. Beginner's Questions
  35. Astro .010 geared 3.3 geared system comps
  36. Brushless ESC/Brush ESC
  37. AstroFlight 020+Castle ESC combo is not programmable?
  38. GWS ESC Question
  39. GWS 350 problem
  40. Power! from 480
  41. No BEC? Now what?
  42. ESC Burning Up
  43. ESC Burning up
  44. Who has Brushless in stock??
  45. Spad to convert to electric?
  46. quality& perfofmance of AXI brushless
  47. LiPo's with Brushed Motor?
  48. Cermark 600 Size Brushless 79.99
  49. Pls. Advice, What ESC to use for Lipos
  50. brushless replacement for the 280?
  51. Max voltage on a brushed motor.
  52. what motor??
  53. Engine Hot with LiPoly
  54. GWS 350 Substitute or GWS availability!!
  55. GWS power system weight?
  56. Programming a Hacker controller?
  57. Best micro servo
  58. diy cd rom motor
  59. Himaxx 2025 Question
  60. Speed 400 for paper plane
  61. Post your 40" Ultimate specs
  62. Slow Stick Saga continues
  63. Kyosho Endoplasma breakin problem
  64. Retime Motor?
  65. Lots of brushless motors-No way to test
  66. Advise on a good inexpensive ESC for Li-Po
  67. How long do most Brushless motors last?
  68. Motor cuts out. EPS 400C on Slow Stick
  69. quad motor aircraft
  70. Himax 5300 or 4100 ?
  71. Reversing ESC
  72. 15A ESC cutting-off at only 3 amp.
  73. Motor winds.....? Help!!
  74. GWS 300C/350C replacement hop up?
  75. astro 010 how do I install their gearbox and pinion
  76. Johnson motor equivalent help
  77. Broken motor mount
  78. QUESTIONS: Astro Flight - Firefly motor
  79. Difference: NARO and PICO?
  80. Dead motor?
  81. Pinion Removal!
  82. ESC
  83. Number of Turns
  84. What are the turns numbers on brushless motors
  85. Matching Battery to Motor Question
  86. brushless controller on brushed motors
  87. Motor Beep Help
  88. Thrust from motor wrong way
  89. Axi 2820-10
  90. brushless set up
  91. I took the Electric Plunge
  92. Himax powered UB
  93. Silly Question - ESC that allows reverse
  94. ? on 300, 350 and 370 motors
  95. Prop adaptor or ?
  96. What is the third wire in a sensor less motor?
  97. Hacker 18L w/11x5.5 versus 15L w/10x4.7
  98. First electric - motor question
  99. Difference between Mega 22/20 and/30 series?
  100. GWS-A Replacement Gearbox
  101. Shockflyer and nippy black
  102. help with the ms d55 plus speed control.
  103. ESC on CL plane
  104. Hummingbird 370 motor
  105. pjs550r?
  106. Slowfly propeller vs 'standard' propeller
  107. Speed 400 Size Brushless Motor Question
  108. Sailplane Motor Question
  109. Are you suppose to hook battery pack to esc??
  110. GWS 300C or 350C?
  111. Help I'm new??
  112. Battery selection problems.
  113. Inoperative ESC
  114. Himax pinion change help
  115. Supplier of Razor RZ2500 brushless motor
  116. GWS Speed motor Questions
  117. Brochert Brushless motor?
  118. Brushless GWS IPS replacement is available
  119. MOVED: ROyal Cessna 310 conv. to electric
  120. Brushless,Lipo experts?
  121. Finding supplier for Black Magic motors
  122. Which socket??
  123. GWS EPS300c & Razor 350 pinion
  124. Alternative to Motor Spray?
  125. Anyone use the Plantraco mini receiver/10A esc??
  126. Please Help new to Electrics...
  127. Parkflyer Props
  128. got some by mistake
  129. Brushless motor choices???
  130. Motor cut off
  131. Castle Creations & Dynamo Electric Brushless ESC
  132. How do you calculate motor/battery requirements
  133. Motor cuts out
  134. PJS Brushless Motor Manufacturer
  135. Mini AC 1215/16
  136. watts/lb to design for...
  137. Motor increase 380 to 400. What to expect?
  138. what batt i need?
  139. Electric Motors in Multi Engine Planes
  140. How to Id a motor brand
  141. Razor 350 and 400 the difference?
  142. what??? How???
  143. 2 motors one controller
  144. Turn on transmitter first?
  145. speed control ??
  146. SS motor problems
  147. Motor Windings
  148. electric twin vs single engine... power, endurance ect:
  149. Slope conversion power questions....
  150. Measuring Amps
  151. Desperately seeking more power
  152. nut that goes on prop shaft of GWS IPS motor?
  153. Motocalc Accuracy
  154. MotoCalc question
  155. GWS Formosa
  156. Burning out GWS 350 motors
  157. dymond AT-6 conversion
  158. speed controller...
  159. Motor heat question!
  160. Prop Removal problems
  161. Stuck on Full Throttle
  162. Lipo's and Speed 300 motor?
  163. Reverse Pushers - Why?
  164. Motor/Prop Question
  165. Brushless Knowledgeless!
  166. mp jet 26/45/20-d 2.8/1 geared
  167. Motor Question
  168. GWS ICS 400 esc
  169. Thrust to watts
  170. What motor should I get?
  171. Kyosho Endoplasma, how many cells max?
  172. Jeti 5 REX receiver - specs
  173. Charge rate for KAN 650s?
  174. gs-100 jr esc question
  175. Motor Break in
  176. Standardizing Electric Motor Specs
  177. What type of Brushless
  178. pinion gear removal, Astro 25
  179. GWS EPS 350C longevity and alternatives
  180. Brushless slow stick???
  181. Wattage Super Cobalt 400 + gearbox woes
  182. Static Thrust on AXI 2212/26
  183. Castle Creation Phoneix 25 Speed Controller Advise
  184. Mega 16/15/7 with 7.5x4" folding prop
  185. Car ESC with GWS A10
  186. Over propped?
  187. props
  188. Astro Motors
  189. What motor / gearbox?
  190. Which motor for Southern X2 (Razor, Himaxx, Astro)
  191. Not getting expected thrust from GWS EPS 350 powerplant
  192. Brushelss Motors for Dummies
  193. GWS gearbox/Razor 400
  194. AC 25/35-20 MP JET Brushless Timing Help
  195. EPC 300 vs EPC 400 Slow Stick
  196. Homemade speed controller circuit useing uk parts
  197. ICS wired backwards?
  198. Electric Recommendations for a Scratch Build
  199. switch the bushungs out????/
  200. HIMAX is it really HIquality?
  201. Brushed or Brushless
  202. 3-bladed prop for Speed 400 motor
  203. Electric Lancaster Bomber
  204. Razor 2500a engage/disengage problems
  205. Floppy drive motor convertion
  206. HiMaxx 2015 4100kv pinion gear question
  207. IPS motor direction
  208. Mega 16/25/3 ?
  209. Major Power System Problems
  210. Help:What motor for mini F3A?
  211. GWS Motor Mount Alternative
  212. Calculating Amps.
  213. What are the Significants of a capaitor?
  214. Will Cobalt 400 handle Electrostreak?
  215. WattAge IC 15 ESC
  216. Interferance, Please Help!
  217. What does the Speed # mean?
  218. Hacker B40 18s
  219. new motor for my superstar ep
  220. GWS Formosa and Brushless education
  221. MPI Promax 400 motor - 6V or 7.2V?
  222. Cooling of Electric Motors?
  223. brushless motor help
  224. How to measure RPM?
  225. Where can I buy spare motor parts?
  226. Zagi ESC on Sky Scooter
  227. foamie p-38 power
  228. Current draw on stock Pigi?
  229. Nippy/PJS How Good
  230. motor break-in
  231. Speed 300 GWS EPS
  232. Prop size
  233. kyosho Foam Arf Zero
  234. Up Grade Motor for Crazy Max
  235. Help! No response
  236. MOTOR MOUNT FOR PJS OR NIPPY TYPE BRUSHLESS EXTERNAL ROTOR MOTOR TO GWS SLOW STICK
  237. Graupner Speed 480 - Need to Re-Time?
  238. 3V motors operating at 7.2V?
  239. servos with 5 wires instead of 3
  240. Battery charging
  241. Graupner CAM Folding Props
  242. need some advice...
  243. Himax/ Hacker interchange setup
  244. ESC - Brushed motor with Li-Po's
  245. advice for aveox motor
  246. Brushless replacement for GWS 350C
  247. Soldering speed control
  248. calculate
  249. E-Starter Power Upgrade?
  250. What to expect
