- Electric Advice
- lipo applications
- Need Help with Eflite ESC
- Running two ESC's and 2 motors?
- Dead E-Flite Super Cub
- help needed identifying/programming a unknown esc.
- How do I rewind an electric motor? small oz foamy motor
- prop holes (electric)
- Hacker A20-20L - No Prop Adapter?? How too or Parts order where?
- motor for heavy sailplane
- where can get the skywalker ESC manual?
- truck motor for airplane?
- Brushless motor shutters
- Replace Motor Shaft
- replaced Apprentice 15e motor and ESC
- Help, need a large, low kV motor.
- Hi-Model FLY-12A ESC Timing Setup
- Motor or ESC problem?
- Is it a HET 2W-20 or a HET 2W-23?
- Hacker Question
- ElectriFly 80A HV ESC w/o BEC
- Under proping
- Non - airplane application for motor
- EFLA308H 2-in-1 Brushless ESC/Mixer Blade SR CP Pro 2 Esk
- park zone engine swap typhoon 3d
- Safe thrust testing, BP Hobbies thrust stand.
- AXI Awesome Customer Support!
- PROP ADAPTOR
- scale speed
- I can't get my eFlite 370 to work with my eRC 25 amp ESC
- Over-tec BM 400 4600Kv
- motor size?
- Hitec Servo
- help please, I am new to electric
- AXI 5360 and Castle Phoenix Ice HV 120 Brushless ESC
- Exceed RC rocket motors
- Motor Efficiency
- Parallel MAH?
- motor kv
- Eflite 110 info
- Can you all help the newb!
- AXI 5360 12mm Prop Adapter
- Re-using Zagi motor
- Motor turning wrong way
- Mysterious beeping
- E-Flight ESC
- BEC ADAPTER
- RC servo ultra-mod
- Timing change Turnigy Plush 60 ESC-?How?
- Turnigy Plush 60 ESC programming
- P-51 power help!
- inflight load verses on the ground
- Pheonix Ice 120 HV Version 1?
- Servo motor choice
- ESC help
- Brushless Upgrade Recommendation?
- R/C brushless motors
- Pitts Power requirements
- how to wire receiver battery with motor batter
- 160 motors squels
- E-Flite Power .52
- extended speed cont. wires
- What mounts for AXI 5345?
- How to reverse throtel direction on Futaba 9CAP radio for H-King 50 A ESC
- Hacker 40 10S
- Need new motor
- Moter help plz?
- turnigy motor help
- Looking for input for motors
- Motor stuttering/cogging
- PA Thrust40 motor
- Gunther BG and Dymond Futur(E) esc
- Speed Control Multiple Motors
- ESC on-board Sw Mode BEC
- Turnigy SBEC JITTER at start up?
- Am I safe pushing a bit harder?
- XOAR WWI prop on e-power?
- Help needed for conversion: brushed to brushless
- turnigy brushed speed controller
- 45A Brushless ESC for XB-70
- Gens Ace motor question
- Motor drawing too much?
- brushless help in easystar
- Voltage regulator for LiFe RX battery?
- electrifly .46 specs??
- help me compare 2 props please
- Folding Prop Weather veins
- Hacker A60 7S V2
- Please advise me on ESC brand
- Are there ESC that are 14s Lipo and 80A???
- Brushless gets hot
- Lipo and ESC for Tacon Motor
- Arc 36-75-1
- Hobby Lobby eRC 45 amp speed control?
- Turnigy Good or Bad?
- Dynam Sonic 185 30a ESC Brake On/Off
- i suck at e-flight
- world models p-51 brushless conversion
- Sundowner 36 ESC, Eflite 32 and switch question
- Motor Problems
- Motor, ESC most reliable choices?
- OSMG motor any report? - OS engines' -
- Eflite 450 brushless motor question
- Need help finding a long 8mm prop adapter!
- Generic eBay ESCs?
- Great Planes YAK 55-M
- ADHESIVE FOR MAGNETS
- PZ T-28 ESC Problem, Warranty?
- Etronix ESC programming help needed
- Can you run a 15Kva motor with 30amo speed control
- Gearvbox/Prop Size help
- motor power to weight ratio?sizes etc?
- Break In for Electric motor???
- Need held with motor selections
- axi motor parts?
- Need help with Turngy Trust esc
- PLATINUM PRO 120A HV problem
- New motor pulling to many amps?
- Help - need manual for ESC
- .40 equiv. motor?
- prop size for Hacker 20L
- XT60 Terminals
- Motor battery and esc for a combat wing
- Hobby Wing ESCs?
- Tacon Big Foot 46 Brushless
- slash problem with direction
- hacker C40 9L + multiplex funjet
- E-Flite Power 32 for a 6.5-7 lb Rascal 40 conversion
- Need correct ESC. What do I get?
- Mount Hacker A40-12L V2 Brushless on my 57" 3D plane
- Help with an electra and ESC for same
- 2 outrunners from one esc and battery?
- Exceed J3 cub 4 channel esc help
- Brushless motor selection/replacement - correct?
- Two Brushless motors one esc and battery
- Towerpro motor
- Lander 68mm EDF motor
- Hyperion hv 130 ESC any good?
- Bearings size in Himax HC3510
- Castle Creation Pheonix ice HV 120 burnout
- I need help on determining the right size brushless motor.
- How to open up HET 28 mm Motor ?
- Airfield 1100mm Hellcat prop
- brass prop nut on Rimfire .80 50-55-500
- Help with Motor ID!!!
- bigger EP setups and battery heat
- MotRolfly esc
- will a more powerful motor, esc & battery make for better handling at slow speeds?
- Mabuchi RK-370-SD
- Number of Cells and Prop Range
- Himax HC2208/0870 replace with what??
- Speed 400 upgrade
- can any brushless be used in direct drive
- ESC instructions for Hobby Lobby original F-15 Desert Camo 45amp controller
- Grayson Hobby - ESC Programming
- ratcheting motor
- HELP! 4130-18 outrunner, need specs!
- Motor Choice
- How to figure what prop to use for electric motor
- Wattage S 3 Viking issues
- Which side for velcro
- motor question
- LiPo storage question
- Electric R/C Aircraft Motor Problem
- receiver for electric rc plane
- Park 480 replacement
- HobbyKing SS 40-50A no beeps
- Turnigy Plush 18A equivalent?
- please need help on electric plane
- RV-9 esc programming question
- Atlas 45a ESC
- Need help with my Hacker Interface programmer
- Motor Performance Data
- Question about ESC
- help with plane
- ESC on a Budget? What works & Doesn't? Experience Proven ESC/Motor?
- Scorpion motors
- Higher KV Alternative to EMax CF-2822
- can someone please confirm which is the MULTIPLEX FUNJET ULTRA TUNING POWERSET????
- what is a pulse frequency on ESC?
- MULTIcont BL-70 sbec ESC help please?????
- ESC question using digital servos.
- Need help on ESC problem
- HELP W/ MOTOR- PROP COMBINATION
- Need help with amp meter
- Two Brushless Motors on One ESC
- Small outrunner shaft reversal
- Looking for 1,5kW brushless
- Ive got a problem with a little brushless outrunner
- which is a better brushless motor
- Got burned on a TGY motor on ebay.
- Scorpion ESC set up question
- Great Planes ElectriCub (Piper Cub)
- Hacker A20-20L motors
- Larger motor and esc on a smaller plane question
- Consequences of massive under-propping?
- Help identify a high power ESC
- HOBBYKING P38
- Brushed motors Avaible??
- prop shaft
- Motor comparable to Neu 1110/1.5Y/3.2
- selecting an in-runner
- speed gearing..???
- APC props
- Advice on Brushless Sensorless speed control for B4.1
- Difference between long and short brushless motors
- 5mm prop reamer
- Help with Turnigy Motor , Sbec, and Program Card
- gforce 400
- Hobbywing-Platinum-80A-PR
- Need prop for new motor?
- How to wire an esc
- Motor Size to use on Cap 232
- Is this motor a good choice for my wing?
- Great Planes Motor/ESC combo question
- ROCKET DIY BRUSHLESS MODEL 2506
- cheap prices
- A quick yes/no question about ESC/Motor
- Airplane ESC with reverse
- Choosing
- Exceed RC Optima Brushless Ducted Fan 70mm EDF Motor 2700KV
- wiring set up for a twin
- Lipo for 380 brushed motor
- SS-80 ESC Problems
- beware grayson hobby
- shopping list at hobby parts
- rimfire 35-30-950 question
- Props
- How many poles
- emax bl2826/06
- 1 esc powering 4 motor question
- Want to change GD-600 Gear Drive for Belt
- sticky info
- How do I choose best "c" rating for motor
- Wire length from controllers
- how do i calculate how many watts motor is pulling?
- power 25 brushless can i use a 11x7 prop?
- Need Electric help desperately (Constellation)
- F-27C Stock Stryker Motor Bent Shaft Fix?
- lipo C rate help
- 3 blade prop help
- expensive brushless motors
- Bracket/Beam Mount for Outrunner Motor
- Bent Prop Shaft
- Castle Thunderbird 18 esc Q?
- need prop help
- electric set up help
- need manual for hacker x-20
- Parkzone brushed motor
- Quanli PBY MOtor problems
