PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26
  1. what about the eflite 450 out runner
  2. Help! - Typhoon outrunners any good?
  3. 400XT Outrunner in a Slow Stick...mouting?
  4. Brushless motor Question
  5. hi max outrunner locking up
  6. noob project. maybe you can help me.
  7. Speed Controler cutout
  8. axi 2204 fix
  9. IPS-A Drive pylon race info NOW!!
  10. My Himax 2025-4200 W Gearbox is locked up
  11. Phoenix - 10 and 25 ESC but when I programme them
  12. Brushless 180 Motor???
  13. run a brushed motor with a brushless esc
  14. Electric Gumby needs help
  15. Himax 2015-4100 Prop?
  16. 3 capacitors
  17. pinion gear
  18. special project help! with electric motor!
  19. Phoenix 25 speed control problems
  20. assembling the west port cd rom kit.
  21. eddy current effect videos
  22. axi 2212-26
  23. Multiplex 480
  24. Help!
  25. BP21 On A 15oz Plane With 3 Cell Lipo. What Size Prop?
  26. Speed 400 equivalent
  27. CD ROM motor wiring?
  28. MOVED: Newbie EDF Question
  29. Burning motors
  30. is this ok for this motor?
  31. I need help in wiring my tiger moth
  32. Brushless Motors-WHATS WITH ALL THE NUMBERS??
  33. how many winds shall I do?
  34. Hacker A30-10
  35. E-flight park 400 need help
  36. ESC not for Lithium?
  37. Hp-200-6 motor
  38. Breaking in a Brushless
  39. How do I do it ?
  40. Dehavilland dash 8 power options
  41. Ceramic Capacitor
  42. Motor speeds up and slows down
  43. RPM per Volt??
  44. Feigao 540 Brushless Motor
  45. Need more power
  46. Brushless Gear box ?
  47. Peak Jaguar motor problem, pls help
  48. MEGA 16/15/7 what application ???
  49. Direct Drive for 600 Size Urgent!
  50. ECS For a 540 brushed motor??
  51. .46 Glow power to electric ??
  52. E-flite 400 and 18A ESC?
  53. How do I remove my motor shaft?
  54. Need some help with Elec stuff
  55. Multiplex ESC
  56. Motor and Torque
  57. Can two brushless motors be run from the same ESC?
  58. Hot Brushless Motor
  59. How remove speed control from motor - Graupner SPEED 300 PLUS, 7.2V with controller
  60. GWS ESC for a 480 motor low cut off volts
  61. Axi 2204/2208 flight times on a shocky?
  62. world models p 51 ep moter help wich one?
  63. Need Help to change electric motor shaft location
  64. Hacker 20-22L mounting?
  65. BP 40 controller, what is PWM?
  66. BP Motor Mount Question
  67. LiPo Newbie Help!
  68. Brushed 370 or Brushless RAZR 300??
  69. Brushless Problems
  70. HiMax outrunners
  71. jeti Jes 30 red controller, need help
  72. e-flite motor, prop size
  73. Quick Motor Mount Question
  74. Great Planes C-12 ESC Trouble!!!
  75. Nimh want to peak and fly[need advice]
  76. New brushless motor....help
  77. BP 60A brushls ESC / Feigo ESC Fried???
  78. ParkZone Typhoon Lipo/ESC
  79. A/F 010 QUESTION
  80. Two Electrifly T-600 motors on pt electric!!
  81. Phoenix 25amp Brushless ESP faulty?
  82. Aveox F12LMR
  83. 8 CDR's on one 126" Wingspan model
  84. How to break-in brand new motors?
  85. HiMax 2025 4100 KV pulling hi amps
  86. Harnessing a Hacker A30-12L's power>?
  87. a
  88. DIY Motor Turns & Winds
  89. Lipo battery damage
  90. Howling noise on startup of Eflite outrunner
  91. Hacker A 20 34
  92. bl22a brushless motor
  93. How do I remove a pinion?
  94. what did i fry? motor or esc?
  95. Wich brushless for super sportster EP
  96. Actro "big boy" motors
  97. do brushless motors wear out?
  98. Astro 05 radial mount?
  99. Stock Stryker question
  100. Elect motor question from lost nitro guy
  101. what battery for hacker 20-22L?
  102. Are brushless motors suppose to "windmill"?
  103. velkom motors
  104. Question about Ulttrafly A/30/24 brushless motor
  105. ESC basic question
  106. Does anybody know about this Walkera?
  107. Engine efficiency
  108. what brushless = 280 size brushed
  109. Battery Advice
  110. Zagi XS Brushless HELP!!!!!
  111. Phoenix vs. Jeti controller recommendation?
  112. cc 25 wire question?
  113. Electric Motor Conversions Question
  114. axi power loss problem?
  115. ALIGN products
  116. Axi outrunner or geared Hacker?
  117. Lower power output from a Mega 16/15/5
  118. ESC Problem ??????
  119. Mounting AXI 2212 with Radial Mount Set
  120. controller use, without throttle
  121. less pitch more thrust? calc
  122. motor cut out
  123. Himax 2812 ESC
  124. speed 400 Olympus 2.33:1 gear system
  125. Potensky 80 Watt Outrunner ???
  126. zagi 35 xt
  127. Align 25A ESC question
  128. PLEASE!!! BRUSHLESS GODS REPLY!!!!!!!!
  129. Mega 16/15/4 Users can you help me out!!!!!!
  130. Voltage Questions
  131. smaller props on HIMAX 2812-0850?
  132. hyperion motor and speed controler help
  133. Whats a good brushless / lipo combination for a twinstar2?
  134. Cobalt/plane help??
  135. CC HV 85 problem
  136. electric parts
  137. Which electric motor for a 7" prop?
  138. Two Brushless Motors On 1 ESC?
  139. C C Pheonix 10 ESC with the B/06/10 Brushless Motor
  140. mounting options
  141. 11 Cells for Brushless Motor and ESC?
  142. brushles with heat sink for walkera 39?
  143. HL Python 200
  144. Throttle setting for ESC with a Heli
  145. KMS Brushless motors
  146. Lithium or brushless?
  147. Can't find the power to hover
  148. Reverse a Jeti ESC W/O changing wires
  149. running brushless backwards
  150. Hacker B 20-22s
  151. Question for Himax 2015-4100 owners
  152. Himax 2025/4200 Watt Amps
  153. Jeti Jes 350 (35Amp) going berzerk?
  154. What is the right ESC for EFlite 370 - 1080KV
  155. BL-8 ESC not working Troubleshooting help needed
  156. motor application advice???
  157. cesssna 182 motor
  158. Phoenix-10 ESC HELP
  159. Need help with the speed control
  160. MOVED: Top flight p-51 conversion
  161. Scratch build Guillows to electric
  162. programming a hacker ESC?
  163. Electric Cosmic Wind / Little Toni
  164. EBAY 600W Outrunner Brushless?!?!
  165. EBAY Tower Pro 60A Controller question?
  166. Noise filtering - electric motor - HOW?
  167. jeti esc ,male or female connector?
  168. Himax wrench
  169. HiModel motors
  170. Does this look like a Good deal to you?
  171. Homemade brushless from glow-engine starter motor stators?
  172. E-Flite 40A Programing HELP!!!
  173. hooking a new ESC to a stock stryker?
  174. Multiple ESCs - one receiver?
  175. Need more thrust, more KV or bigger prop?
  176. Brushless motor burning wire
  177. Hacker A30-28S on Cessna182
  178. Hacker A30-28S on Cessna182
  179. Building a Skeeter, 12 - 14 oz balsa profile, need set up advise
  180. AXI 2208/34 bearing change?
  181. Another AXi with loose magnets
  182. calculating gear ratio
  183. E-flite mini Ultra Stick - which brushless motor??
  184. Suitable prop for Ultrafly A/30/29
  185. esc help please!!!!
  186. Brushless motor/25A Electrifly ESC Silver Series
  187. RC Smart 1280 Outrunner Brushless Motor & 30A ESC 05AUP
  188. Prop Questions
  189. I have the phoenix10 with 2 lipo....
  190. Nippy motor help needed
  191. E-flight 46 And 60 motor?
  192. Choosing single stator CD-ROM motor
  193. What Planes Are You Using A BP21 Brushless In?
  194. flint mini 330 extra
  195. Will the AXI 2204-54 fly this? Edit: YUP!
  196. Choosing a brushless motor
  197. Outfitting HL Yak-55
  198. what prop for kontronik brushed speedy 480
  199. Problem speed controller
  200. Walkera Dragonfly #4 brushless mod
  201. Park 400, Phoenix 25 question
  202. Anyone know about a 5 gram Brushless?
  203. Help! What gearbox is it?
  204. AXI 22/34 Prop Adapter Needed
  205. hyperion 3007/30 25a esc??
  206. Cessna 182 outrunner motor????
  207. changing brushes on a endoplasma motor
  208. What to do with Hackers B20 and C40?
  209. Permax 400 BB & 3 Cell 1500 MaH Lipos??
  210. Hacker vs Pheonix controler
  211. Walkera ESC low Voltage cutoff???
  212. Gearbox for Extreme Flight YAK 55
  213. What prop of a PJS 3D 800 with 2 cell pack?
  214. Need Help, Bad Motor?
  215. kontronic speedy 480
  216. Brushless plane size, power and propeler
  217. KMS Brushless
  218. Jetti (jes 050) brushed speed control specs?
  219. discontinued motors
  220. Himax Outrunner Problem....HELP!
  221. Hacker A20-S Shaft Position?
  222. Performance difference between 2s vs 3s li-op
  223. brushless motor switch
  224. Help on Castle Creations/3 cell/4 servos
  225. Help with power options for GWS
  226. Spinner screws
  227. replacment for speed 600 motor ????
  228. need info on power/esc
  229. Graupner speed 400 conversion to Brushless
  230. Esskay 400 XT, what is the next step up?
  231. Walkera 3200 m/Himax gear box on a Great planes suhkoi 3D
  232. multiplex Permax 480 BL 4.4/1 planitary
  233. 2nd request need help selecting Brushless
  234. Large 3D Foamie Motor???
  235. help with Master 77-0 Flight brushless regulator
  236. Himax 2025-3200 question?
  237. Need help with Mega 16/15/3 wiring
  238. Castle Link with a Macintosh?
  239. Gearing My Stampede
  240. hobby shop in Madrid(URGENT!!)
  241. Brushless for Super Impress
  242. Which Brushless Motor for ElectrOstreaK
  243. which brushless to replace a 600 Brushed
  244. needs a motor suggestion
  245. I have a problem with my Zagi
  246. My new Electrostreak help
  247. Connecting ESC to Motor
  248. himax 2812
  249. BEWARE OF ULTIMATE HOBBIES!
  250. Little Screamers Purple Peril vs. Hacker A20-34S
