PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26
  1. Geared motor question
  2. Brushless and Li-poly cells
  3. Motor specs, what do they mean?
  4. Hacker Web Site
  5. Motor Failure Question
  6. Astro 035 FAI Geared motor questons
  7. EPS-350 D Question
  8. timing the GWS 350
  9. New to electric and need info
  10. Were can I get a GWS replacement pinion gear?
  11. Sig Wonder conversion
  12. Electic newbie question. Will a Phoenix 10 be enough for a Himax HA2015-4100?
  13. Motor shutting down above 5/8 throttle....??
  14. Safety Switch
  15. MP JET PINION FOR GWS GEAR BOX?
  16. Wow, that is a lot of AMPS
  17. Materials Needed for a Beginner
  18. Which size brushless motor?
  19. how to measure
  20. Mega motors/APC props
  21. prop lengths , faster or slower
  22. Super 400 Cobalt in Lieu of Speed 400
  23. Help on castle creations pegasus 35p
  24. The 5 amp ESC Problem
  25. no servo/trans. control
  26. Power for Husky Sport
  27. 13-8 prop
  28. IT COSTS HOW MUCH TO REPLACE A HACKER SHAFT????
  29. GWS IPS twin motor
  30. Arming switch on the Freedom Flyer Plane
  31. Finding motor amp draw
  32. Power Reccomendations? Help!!
  33. Motocalc Recommendation
  34. equivalent motor
  35. Max rpm on Mega
  36. Prop Suggestion
  37. ESC? Where's that GO?
  38. gearbox suggestion
  39. SIg Rascal motor question.
  40. Lengthen / Extend Cables
  41. using Hitec SP-1010 ESC with 7.2v s400 motor
  42. esc
  43. vtol
  44. Razor Motors In Stock
  45. Want very small wind turbine. Know where to buy? Or how to make?
  46. What equipment for .40 size plane?
  47. GWS IPS A motor on 3 Lipoly?
  48. What size motor??
  49. Astroflight Speed control and Razor Motor?
  50. Black Diamond 301 & 3 Cell LiPo
  51. Super cobalt 400 motors (WattAge) + & -
  52. 400 motor and ICS-300 combo
  53. Life of a Brushless Motor??
  54. ESC? Gearing? Motor sizes? A noob needs guidance.
  55. Motor Beep, Beep ,Beep Error...?
  56. Brushless ESC question.
  57. **Help Help** Pinion Gear coming loose
  58. Battery Voltages
  59. Buying one brushless, what is most versatile
  60. Choosing ESC
  61. Himaxx Motor gear box
  62. Wattage Super Impress w/Cobalt 400 motor
  63. Suggestions for 3D plane
  64. ESC for EPS 350
  65. less thrust now?
  66. Too much voltage?
  67. motor for 2.6m glider
  68. controler circut
  69. Choosing most efficient Prop and Gearbox?
  70. Why some 400 motors toast.
  71. Choosing the right ESC
  72. gear box question ???
  73. Astro Cobalt 05 Brushless equiv.
  74. This might be a balance question or problem
  75. What is a BEL14 ESC?
  76. Jeti Model Speed Controller Master 40-3P Opto
  77. GP 30A esc cutting out
  78. 8.4v speed 400?
  79. Electric Motor,battery,Prop for Mini Bell
  80. speed controls
  81. Help me choose Prop please..
  82. need propulsion sytem
  83. What's up with my throttle control?
  84. ESC overheating?
  85. speed 400 speed control plans
  86. wattage motor smoking HELP!
  87. matched pair????????
  88. Need help with MP Jet 25/35-20
  89. Electric power question
  90. Rotating case motors (Large)
  91. MOVED: Li Poly Recommendation
  92. Really could use some help.
  93. Tekin Esc
  94. Hacker specs question
  95. Aerobird replacement 380 motor
  96. Forward and Reverse thrust in one!
  97. AXI 2820-10
  98. pusher
  99. Drill Motor Conversion
  100. When Off is not OFF
  101. ROBBE-KELLER 25/8 MOTOR Questions
  102. What is the proper mAh for a 7.2v motor?
  103. Black Diamond 301 Gear Drive?
  104. Gws
  105. jeti 15-3 or 4 gearbox
  106. GP Ryan STA EP - Motor Suggestions
  107. Mega FAI-10SP motor info?
  108. Electrify a Goldberg Eagle II
  109. onboard tach for brushless: cheat from motor wires?
  110. PT Electric with T-600
  111. 25/35/20? what do these #'s mean?? I would like to know more about brushless!
  112. Electric motor capacitor
  113. Do you have to have a resistor for a 7.2v motor?
  114. Gas to Electric
  115. ECS Question
  116. Kitbuilders...please check this thread
  117. gws p-51 4 blade prop, retracts......
  118. prop question
  119. Full throttle much vibration...half throttle OK!
  120. 380 AND 370 GEARED UPGRADE
  121. Lubricating motor bearings
  122. Speed controller advice
  123. Wattage Cobalt 400, Super or Not???
  124. Small motor timing
  125. Help with speed controlers
  126. Hacker B20 32L Q's
  127. Why is my motor shutting down with a full charge?
  128. wattage 2.25:1 gear box help
  129. Hacker B20 15L thrust?
  130. Nebula 2000e. 7.2 8.4 ?
  131. home made gear box???
  132. Amp draw , battery direct to motor vs thru ESC
  133. Brushless Twin - ESC configuration question
  134. Power problem
  135. Where to find replacement pinion gears?
  136. MotoCalc and Mega 22/45/3
  137. wattage ultimate bipe
  138. How to measure amp draw of motor
  139. Help.. What Motor???
  140. A simple S400 prop question
  141. Mabuchi 370 (Watt-Age)
  142. she needs more power!!!
  143. Want Super Cobalt 400 BRUSHLESS Repalcement
  144. somebody has to know
  145. 23 gr Micro BL Motor Group Purchase
  146. ElectriFly T-400GD ESC System
  147. Megatech P-51 Question
  148. Batteries Customize your own Too cool !
  149. Looking for Geared to direct drive equivilant
  150. MPI Cobalt motors power requirements
  151. Brushless motors in Foam Wings?
  152. Razor 2500, pinion gear
  153. what's a good plane for brushless mp jet 25/35/20?
  154. What's the Electric equivalent of OS 1.20
  155. Does anybody know.....
  156. Is this normal Brushless behavior?
  157. ELECTRIFLY System looking for a plane
  158. Robbe RSC730 Programming help?
  159. Gonna go with the new age...Lipoly help?
  160. which prop for my 400?
  161. Kontronik Tango 45-05
  162. Brushless Setup for Aero-Model UB, Newbie
  163. razor 400 bolt pattern?
  164. speed control question
  165. Esc Fundamentals
  166. Should Jeti 350 controller emit continuous beeeep?
  167. Electric SkyBird RES
  168. Gearbox installation problems
  169. lighter than a 480
  170. Need help with wire codes on brushless motor?
  171. Introduction to Razor Motors
  172. Using LiPoly with Master 11 3P
  173. how to figure what motor I need
  174. Help Sachs timing
  175. gws spares
  176. New ESC Co.
  177. cheaper alternative for a hacker
  178. Kontronic ???
  179. GlowX Electric
  180. Substitut for Jeti JES 30-3p
  181. SS1 Motor
  182. Aspire EP Motor Information Wanted
  183. Astro cobalt 05/geared- use 8 cells?
  184. Park Flyers in East Bay, CA?
  185. GWS P-51 gear ratio
  186. Robbe concorde & Multiplex sonic liner Query ??!!
  187. esc or 3 bad battery packs?
  188. Razor 400 motocalc results vs tested results
  189. MP Jet fit GWS Gearbox?
  190. MiniAC
  191. engine break in question
  192. wattage 370 gearbox change????
  193. Using watt meter with brushless
  194. motor for GP electricub
  195. 2mm pinion for razor motor
  196. Batteries and brushless motor
  197. Need More Thrust! How?
  198. What BATTERY?????
  199. Question - Brushless motor Winding
  200. 9.6 Volt batteries for speed 400 okay?
  201. 05 electric = glow equivalent?
  202. Can't figure this out.....
  203. Smoking motor.Ideas on causes?????
  204. Need Brushless can't decide please help!!!!!
  205. Motor selection?
  206. 480 replacement with brushless
  207. astro flight 350
  208. Electric Dilemma !
  209. How does this set up sound?
  210. Esc, Help
  211. Motor suggestions for 3D
  212. GWS Pico - Range issues???
  213. motor information
  214. Those looking for Razor motors
  215. E-Starter brushless motors
  216. Slotless & brushless PMDC motors for R/C
  217. e-starter prop
  218. endoplasm motor help anyone good with motors
  219. help - esc caught on fire when bench testing
  220. New ESC
  221. motor question
  222. Speed 400 - Equivalent Glow?
  223. cheap motor from wally world?
  224. Bad Speed Controller?
  225. better prop
  226. Please help...servo action is cutting power to my motor!
  227. Confused on throttle control
  228. Axi repair
  229. GWS geared motors
  230. Phaser 45-3 with bent shaft, Help!!!
  231. New Motor from GWS
  232. anyone know about sensorless brushless motorS?
  233. GWS P-51 Way underpowered or is it my setup>?
  234. Engine Cuts Out: engine or speed controller problem?
  235. Gws P-51 rolling on hand launch
  236. Planetary gear boxes?
  237. Info on Purchase of a motor Dyno
  238. What Hacker instead of GWS A drive motor ?
  239. Equivalent motor for Mega S-7??
  240. Rascal ARF- How do you set the gear drive mesh?
  241. Fighterbird
  242. Adequate motor?
  243. Outrunner motors?
  244. Brushless Choices And Comparisons
  245. Gear boxes and Ratios
  246. Sky Scooter Pro II problem?
  247. Converting to electric
  248. Astro 010 a good replacement for 400?
  249. Prop size...
  250. Suggestions for a brushless motor
