- Atlas brush less motor looses power
- Tm pro esc programming
- Castle Talon 90 spool up settings
- super tiger .10 with super tiger 30A speed controller 2200 Mah battery?
- Propeller, number of blades, another aspect
- Sensei motor shaft repair and motor shaft replacement. NEED HELP AND INFO!
- Hacker X-70-SB -Pro and Futaba SB rx
- I need bullet connectors . . . please help
- Electric Warbird: Help with ESC Selection
- brushed to brushless conversion
- dumb question - 100A ESC with HK Vampire
- Help-ESC Problem
- quick question about lipo + brushed motor
- airplane motor vs rc car motor
- ESC Soft Start?
- motor shaft
- What is the power equivalent?
- eflite bl50 magnets came loose
- 2 blade Pusher prop for SkySurfer2000?
- Which 3536 Motor to Run ?
- Cobri gearboxs....where to buy online?
- Eflite Power 15 Mystery
- Turnigy T285A ESC Trouble
- Soldering Electrifly ESC and Rimfire bullet connectors, need help
- Timing Questions
- Electrifly Rimfire .32 and 13"/14" props
- Esc help!!!!!!!
- turnigy park250 brushless outrunner
- 540 tamiya, what ESC?
- Hobby People ESC problems
- Smoked ESC
- robarts retract binding
- What is Optical Coupling?
- ID help needed
- Bent shaft on Dr Mad thrust 90mm EDF
- Hurc 40 and Hurc 18 problems getting full throttle from motor
- First ARF build questions
- .46 convertion
- hacker
- Changing out motors
- Mystery cloud 20A ESC programming???
- Wanted: WattAge 370 Power Set
- Old Phoenix 25 esc problems
- Wattage ultimate biplane brushless conversion
- Slipping Prop Adapter
- Size of Motor for a Gillows Balsa model
- Question in regards motor and battery
- first ARF build, could use some advice
- Are These motors basically the same?
- Using two different AMP brushless speed controls
- Identify my motors?
- Electric motor recommendation for hob warbirds
- Yet another Prop Size Question
- Need help with choosing a brushless speed controller
- FMS 60amp ESC programming?
- what voltage to use??
- motor to esc extension
- Extending prop drive, some thoughts and maybe your ideas
- How do i get more clearance
- help identify motor
- What to look for to replace .15 Glow
- Electric Motor Performance Data
- ESC problem with new plane
- AXi 2820/18 DroidWorx motors in Fixed Wing Aircraft...
- Aeroworks EXTRA 260EP-3D/Park400 (A little help, please!)
- Throttle delay Flyzone DH Beaver
- inrunner motor for .25 size airplane
- Any info on 4 blade prop for limited ground clearence issues?
- Need help picking power setup for HobbyKing Condor (a.k.a. Sky Runner EP)
- Science project: Two teens to build a static thrust test stand for electric motor
- HK SK3 F3a Motor
- Turnagy D2826/10 1400kv - can the shaft be reversed
- E-flite 60 amp speed control
- E-flite 60 amp esc won't arm.
- Reverse current flow through ESC data lead?
- Eflite 60 amp ESC ...not PRO.....Programming help
- World Models P-51 Mustang - EP - What is a good electric motor
- How do I know if bad ESC or Motor?
- Tekin
- Motor quitting
- Micro receivers
- Hacker X-Pro-Interface Programmer
- Eflite running backwards, stuttering, not working correctly
- Need prop advice
- Do I need more capacitors on Brushed motor?
- Turnigy T600?
- Motor and Prop Calculation Results
- Can brush motor change to brushless ?
- hacker A50-12s V3 motor
- On/Off Switch for ESC
- Krontronic Motor
- newcomer pleeaassee help t-copter build
- Is Hobbyking Politically Incorrect?
- Need advise on ESC
- ESC Program Cards
- Looking for a high ratio gearbox
- 1/2A Power Set Up
- 9G set up
- O.S OMA-5025-375+OCA-1100HV+OCP-1 Help to set!
- Computer power supply
- ESC damage
- Turnigy DLUX Programming Box Q
- Good Brushless combo?
- Can I use the KV ratings as a guide for motor replacement
- Prop size for Parkzone 950Kv .15 outrunner motor, 30amp ESC
- MVVS GLIDER Outrunner strip down
- Trying to salvage a nice ESC
- motor cutout
- No beeps or engine function after battery connected
- What is PWM for?
- Help Hacker B20-15L Gear Box
- Hacker A30-12L vs Turnigy SK3 3542-1000Kv -Head to Head PERFORMANCE TEST
- HK 190A 6s ESC buddy code $27.68
- motor Amps any one can clarify this for me
- I NEED HELP GOING FROM BRUSHED TO BRUSHLESS
- Performance Test: Turnigy SK3 2118-2250Kv, 17g, motor
- manual for a turnigy c6364
- Slow stick motor upgrade
- Prop Adapter Removal
- Burning ESC video
- Help with Hacker A30 motor-stuttering on start up
- What ESC to use
- BL motor and battery option for GP Edge 540 flat out
- How do you remove the Stators on a C05 Micro
- Don't understand
- Hobby King 50A Fixed Wing ESC
- Help ID'ing Motor
- Which chinese factories make various brushless motor brands?
- Electric motor stutters
- KV and performance
- Setup
- kontronik minijazz 20
- Testing a Motor
- Belt Drives....?
- Mount
- Homemade brushed ESC with BEC
- use my esc from 2 motora to one motor
- Wire Length
- E-flite Power 25 mounting pattern
- ULTRA HIGH VOLTAGE DUCTED FAN SETUP.... 75 to 100 volts....
- Taking Turnigy G46 apart.. HOW?
- Old Gasser Trying Electric
- Please answer a couple of questions????
- Balancing brushless outrunner motors
- Wiring an ESC
- Quick throttle squeal!!
- help me pick a motor, please
- Scorpion S55 bearing help
- 850KV or 1200KV
- what is 280 size motor
- What timing do I use?
- Prop Adapter Issue
- E wooden props will theybend motor shafts
- Teenie-tiny outrunners
- Motor Suggestions MoJo 60
- Turbojet Brushless, ebay, cheap motors, anyone experienced?
- Art Tech Speed Controls
- Will a 30 amp ESC be adequate?
- Which ESC?
- 2 batterys hook up,,,(plug)
- Hacker C50 12XL motor
- which motor
- dualasky motor
- Need to get a speed control for a friend Wing Maker DF-032 Panther
- E-Flite Power 46, 5S with 13
- Ammo 36-30-4000 problems
- cell count on brushless motors
- detrum esc
- Help - wiring 4 outrunners
- How to compare brushless motors
- Integy inta 3906 sppeed controler
- what is the difference between a switching ESC and a Linear ESC
- flight duraton very low with Lipo 2200 need help
- Chirping motor
- MAH battery question
- Axi 4120/18
- Speed 600 and ESC to use
- Uses for old speed 400 motor?
- Deens conetores and sizes or exstensions ?
- Brushed to brushless conversion...Unsure.
- NEO 25 890kv set up for 3D flying
- Which (chinese) facctories make various brands of ESC ..?
- is a 75 amp speed control too big for 450 heli?
- Brushed motor equivalent size
- durafly se5a power drain
- TOP Racing outrunner
- What are these?
- Help! What motor to use for 18a ESC
- Northstar Motor
- I am powering a twin with a seperate esc and 5 cell lipo for each motor.
- E-Flight 25 in a Hobbico 40 balsa ?
- NTM Outrunner Motor Mounts
- HiMax motor mount screw size?
- Newbi with motor ,esc, batt questions ?Falcon foamie.
- Newto this sparkey action, Happy I found this fourum.
- wooden electric props?
- Program card or no progam card that is the question.
- Prop nuts Help!
- puffed lipo battery to use or not
- Flight time with Rimfire 65cc correct?
- Dhc-2Beaver
- ESC progrmable type for battery types
- replacement for a Aveox F10LMR brushless in runner
- Signal vs No Signal
- Propping for efficiency
- Prop sizing for efficiency
- brushless book
- Brushless motor question
- proper hook up of system
- Brushed Motors With 2.4Gig Radios
- Birdie esc programming
- THOSE 3bladed nylon props
- concered about a APC prop ,is it for electric?
- Those heavy APC electric props or not
- esc
- new pt19 went down
- How test used FlightTech 80A Brushless ESC
- O.S. 30 Brushless
- Motor sizing help
- REAPER SBEC
- Electric motor help
- Phoenix Ice Lite 75 help
- Long leaded ESC's
- Power 25 replacement for T-34
- Turnigy 4250-700 ???
- Testing Servoless Retract Landing Gears safely
- Replacement motor for Pz T-28
- Strange launching?
- Loose Magnets
- himax 2816-0890 tight after a flight
- Not pulling power
- Low RPM problem
- Can't make it work
- squealing BL motor when snapping throttle
- DIY ESC
- How to compare electric motors and what do their specs mean.
- Lipo Charger Recommendations
- Help picking motor, speed control and servos for Extreme Flight Extra
- Logo 20 needs motor esc trying to find replacment
- Looking for a silent slow running motor/gearbox solution 2kW+ 240rpm
- Strenght of an electric airplane motor
- Suppo Brushless & ESC: battery calc?
- Need Help Quick - Going out to fly with my nephew
- reversing motor then back
- Engine Help
- Battery capacity and the Motor
- Need TURNIGY C3536-1100kv part
- Max voltage for a Hitec servo
- wiring help please!!
- motor, adapter, prop, thingie,,,,,,
