PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. power system for my micro whizz
  2. Need help with Dymond D-50 ESC
  3. Is it possible???????
  4. Grinding Outrunner!
  5. Motor Stalling????
  6. Prop spinning off shaft problem
  7. Operating instructions
  8. Power wires near servo wires: Interference?
  9. How to Dissamble Multiplex Permax BL-480/6D
  10. Just let the magic white smoke out
  11. changeing gears -do I need a tool ?
  12. Which brands of ESC's do not have over current protection ?
  13. Effeciency of GWS slow flyer props compared to APC.
  14. ESC problem with stock typhoon??
  15. Two motors, One speed controller?
  16. hi max gears
  17. motr want stay going
  18. Help with my Astro 020
  19. GIT Speed 18/25A Brushless ESC
  20. AXI-2814/12 BEARINGS
  21. Prop matching
  22. ESC amp question
  23. ESC timing-mode setting....
  24. What does a constant beep mean?
  25. Stagger Bee with Magnetic Mayhem motor.
  26. What happens with too much prop on a big motor...
  27. PLEASE HELP my seed control broke
  28. can the SS45d ESC run on 5 cell lipo?
  29. recomendation for motor & prop
  30. Maxford USA Spirit 3D Electric: Motor Question
  31. stryker question
  32. Fancy Foam Himax 2015 Prop
  33. how to connect esc to motor?
  34. Brushless motor replacement for Axe CP
  35. Himaxx brushless (stay away)
  36. Prop size?
  37. How do I use a watt meter?
  38. New foamie ESC and battery troubleshooting help!
  39. Electronic Speed Controller Timing
  40. Can I use Hacker A20-22L instead?
  41. Brushed motor will not stop
  42. Motor Pulses..
  43. Prop Adapter for E flite 60
  44. Great Planes Brushless esc or Jeti?
  45. thunderbird 18 cutoff voltage
  46. Great Planes Rimfire 42-40-800 brushless motor
  47. JETI vs Castle ESCs
  48. which gives more thrust?
  49. Help me pick a prop
  50. Info on Hacker Ion-X motor?
  51. axi 2217/9D gearbox failure
  52. Rimfire question
  53. ESC Beeps
  54. Need explanation to motor types
  55. Why some Esc Best for fuel aircraft
  56. SUPPO motors @ lightflightRC
  57. removing switch from esc
  58. Folding prop flies off
  59. ESC w/BEC and onboard RX pack
  60. mounting gws 8040 on bp-12???
  61. Dynam Brushless motor and ESC setup
  62. ESC w 3 or 4 servos ?
  63. 35 45 amp esc 380 motor then 600 motor later?
  64. esc
  65. Making an ESC
  66. motor for Multiplex MiniMag
  67. Which would be faster.. 14.4v or 7.2v 17t motor.
  68. Scorpion prop shaft
  69. scorpion 3020-12 from rimfire?
  70. phoenix 25 help
  71. axi motor question
  72. speed controller Hextronik pro 36 A
  73. ESC - Full throttle cut
  74. Testing the motors Amp Draw Question
  75. Old Fogey going lectric (finally)
  76. On The Subject Of Engines
  77. Sky Born 35 ESC
  78. esc timings generalised?
  79. Noob Question Again
  80. RIMFIRE VS HIMAX Brushless Motors?
  81. motor current
  82. winding brushless motor
  83. Himax2850-850 max RPM??
  84. need brushed motor selection help
  85. Flatouts Reflection came today, have some questions/issues
  86. anyone know of an alternative to expensive electric motor bushing oil
  87. Brushless motor poles
  88. New motor/ESC-nothing happens?
  89. BP Brushless Motor Questions
  90. Number of winds
  91. Rank Beginner ESC Question
  92. Help Hacker 20L Just hums and wobbles
  93. Help Hacker 20L Just hums and wobbles
  94. Programming problem with a Hacker Master 70-O-Flight ESC
  95. Brushed motor leads reversed?
  96. 85A+ Brushless ESC with built in high voltage BEC
  97. Capacitor use is noise reduction
  98. Anybody else having trouble w/ Rimfire motors
  99. Axi running backwards!
  100. Hacker FAI Master 105-3P Opto ESC
  101. Custom kit Specs??????
  102. comparisons
  103. hacker A50 motors
  104. EZ Glider Elec.
  105. Brushed to Brushless conversion
  106. .46 glow sized system
  107. Ok, lets make some comparisons and create some FAQ's
  108. Spinner for Extreme Flight Torque Series Motor
  109. Fried my Eflite 40A ESC V2
  110. GP Electrifly ESC question...
  111. Watt meter Help
  112. Medusa Research Shaft Removal
  113. Hobby Lobby cessna 172 arf all wood
  114. no power output to receiver problem
  115. wiring motor esc and battery for park fliers
  116. prop for Park 400 inrunner
  117. Counter rotating props
  118. What do you guys think about the Scorpion Brushless Motors
  119. Speed 400 Upgrades
  120. Help choosing a brushless motor for a Slinger
  121. TRASHED ESC'S ??
  122. Brushless motors in Parrallel
  123. A weird set up of esc and brushless motor, HELP PLS!
  124. spectra select setup
  125. Question about ElectriFly ESCs
  126. Tornado 400f bearing problem
  127. REVERSING MOTOR SHAFTS
  128. Which UBEC?
  129. Disable BEC?
  130. electric motor break-in questions
  131. Problem with Rimfire 28-30-950
  132. what is Rimfire equivalent to eflite BL450?
  133. Phoenix 80 ESC-BEC OK?
  134. rimfire 22-1000 abilties???
  135. Eflight 25 esc - no throttle
  136. Motor & Batt gets hot fast!!
  137. GWS PT-17 setup help needed
  138. Great Planes ElectriFly C-35 Mini Brushed ESC w/BEc
  139. Small EDF Motors - Jeti ESC Setup ?
  140. Older Jeti JES 30 ESC?
  141. Phoenix 35 cutting out
  142. Race Rat Power
  143. ElectriFly C-12 ESC jumper lost
  144. Brushless Help!
  145. xtra 2826/09 motor
  146. Newbie-How to chose a brushless setup?
  147. Kv,Io cell count and other mysteries
  148. electrifly 45 smp ESC with e-flite 15 motor
  149. Extending motor wires
  150. Software application?
  151. There are 3 watt meters available, right...
  152. Small brushed ESC
  153. Electronics New-B
  154. RimFire Motor
  155. Outfitting Spitfire
  156. what does a gearbox do
  157. Spinner for a Kontronic gear reducer GP Siren ?
  158. Help me select the right motor & prop for my plane
  159. How do I attach a 5" spinner to an axi 5330 or 5345 motor
  160. Powering foamies
  161. Thunderbird 18 programing issues
  162. KDA 20-34S motor burning out
  163. Inverse time feed mode ???
  164. e-flite park 400
  165. Largest prop on geared 400
  166. Brushed replacement?
  167. Electric Setup
  168. FlyWare 320-1000??
  169. WHAT ARE THESE THINGS FOR
  170. TurboProp RC News FLASH
  171. new to elec. having major issues
  172. TurboProp RC NOW Stocking Brushless ESC
  173. TWIN setup
  174. Need some giant scale advice....
  175. ESC Caught on Fire
  176. glow engine-electric motor equivalents
  177. Wire extensions for motor /ESC/Battery
  178. Blown motor... Help!!!
  179. esc/hobbyzone sc question
  180. fast gearbox
  181. Timing Question(s)!!
  182. New to brushless outrunners a few Questions
  183. ESC troubles - engine stop -
  184. Kokam 3cell LiPo makes it through the laundry
  185. Can getting water on an ESC start a fire?
  186. Setting EPA for ESC above 100%
  187. Calling all motor/ducted fan experts.
  188. how many poles does my motor have?
  189. problem programming hexatronic 80amp esc
  190. Question about ESC
  191. Conversion from 380 can motor to brushless
  192. cermark esc programing
  193. GWS ME-262 Brushed or Brushless?
  194. brushless set-up
  195. A hard brushless motor choice!
  196. Calling all experts to come help equip my plane!
  197. help with motor/prop set up Please
  198. Brushless motor help for stryker
  199. Electric Funtana issue
  200. question about 400T motor
  201. Hey quick question
  202. esc's and speed controllers
  203. Amps while using an esc
  204. Putting Magnets in my AXI
  205. Reducing 11.1v down to 9.6v
  206. Stryker BL to HOT
  207. Fizzzzzzzzz
  208. Hacker motor info
  209. HELP : SUPERCUB Brushless / LIPO
  210. MPI Speed 180 Specs for Motocalc
  211. Can't program ESC
  212. Probably an idiotic question....finding the right esc for a motor(mainly amps)
  213. Vibration
  214. Motocalc
  215. ESC + Motor incompatible?
  216. Broken E-Flite Motor Prop Shaft
  217. TurboProp RC TP-220050 test video
  218. jazz 40-6-18 programing progcard ?
  219. phasor 30/3
  220. Aveox motor with Maxon gearbox
  221. Transmitter not sending full throttle
  222. tower pro 2408-21T what ESC
  223. UUUHHGG!! So many brushless motor companies!!
  224. cut-off programing of the Hacker Master 70 bec
  225. Jeti ESC question
  226. One EDF motor quits after half throttle.Why.
  227. Connecting Brushless Motor to ESC
  228. novak gtb esc and velociti 4.5 brushles
  229. Explaining Electronics
  230. Brushless motor will not start
  231. Mega 16/25/4 needs a plane.
  232. ESC programing problems
  233. 2408-21T Motor and ESC problems
  234. Mamba Brushless motor Reversing problem
  235. Throttle cut-off at 90% power?? HELP
  236. First fire with Lipo!!
  237. WIRED THROTTLE for Brushless ESC instead of radio/receiver
  238. trex 450 xl electronics
  239. Tsunami 10 speed control
  240. motor recommendation for speed
  241. TurboProp RC TP-220100 beats Hacker A20-20L
  242. hextronic speed control problem
  243. Setup question
  244. Model Motors Mini Extreme
  245. What brussless motor is equil to a speed 600 and where 2 get a V cheap Brussless out runner and Esc!
  246. GWS 2208/18 brushless coffee grinder
  247. EPS-400 motor with an 1180 prop?
  248. ESC problem?
  249. Switching output shaft
  250. Li-po problems
