PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. eflite maxx 25 esc.....won't turn prop!
  2. new MM_Calc and Drive Calculator version
  3. ESC "OPTO"???
  4. ESC is Bigger Better?
  5. Help! Troubleshooting Receiver/ESC problem
  6. mini alternator? for electric flight
  7. To BEC or Not To BEC?
  8. Program E-Flite 20 amp ESC
  9. need a brushless motor for my stryker f-27
  10. Best LiPo for 13x13 4Blade AXI 4130/20
  11. Some more basic E-Flite Questions
  12. Thunderbird 54 Brushless Esc
  13. E-Flite extra, E-flite motor or hacker?
  14. kV Rating
  15. 35a brushless esc for a 3550kv motor
  16. Diodes for brushless generator
  17. Brushless motor& ESC for GWS C-47
  18. Under-proping a brushless outrunner
  19. rimfire burned up after 20 sec maiden flight
  20. Windings, heat sink compound, copper loss
  21. tower pro 18 amp controler
  22. Phoenix 80 FIRE
  23. nippy black 1812
  24. Astro 020 Alternative ?
  25. Looking for this-->GWS/LPS-B2C-CS
  26. Watts per pound question
  27. Motor Winding Question
  28. can brushless esc run a brushed motor?
  29. Old Castle Creations 25amp esc
  30. My 1200 kv motor is making a thumping noise after crash
  31. RC HOT DEALS
  32. Speed Control LiPo LVC
  33. Pusher
  34. engine thrust question
  35. Reverising the shaft in park 300??
  36. AXI and Jeti Problem....
  37. Help: I'm not getting the RPM I expected
  38. How many poles does the e-flite power 160 have?
  39. Great Planes VS E-Flite Outrunners
  40. Motocalc or similar test please.
  41. RCmegashop esc
  42. Hacker A30-14l
  43. Installing CC BEC's
  44. Ryan STA Power Plant Help?
  45. wrong programer on thunderbird esc
  46. Problems caused by extending motor leads?
  47. Long ESC wires or long motor wires?
  48. Need a short run small electric
  49. E-flite 20amp ESC Problems, I think
  50. Motor stuttering at low speed
  51. Brushless Jenny
  52. Big electric motor needed
  53. Advice on motor / drive
  54. Help with R114F Reciever
  55. what is the best/good external BEC??
  56. One ESC or two
  57. Align 430X motor
  58. Motor/Prop/ESC I've got a problem!
  59. Science Lab Free Flight Project, need advice
  60. EMAX HL2215/450 Outrunner - correct timing mode?
  61. Ripmax Air 25 ESC help.........
  62. Hacker 30-28S/ESC combo ?
  63. brushless motor for esky lama 4
  64. Throttle Sticking Open on PZ Typhoon 2--ESC Problem
  65. Great planes ESC mystery solved
  66. 30 amp wattage age esc
  67. formosa batter selection help
  68. airplane speed control w/ surface transmitter
  69. Motor problems
  70. New Budget Brushless option
  71. good deals on brushless motors and esc
  72. 950 to 1750 KV outrunner
  73. Looking for 90 sized electric
  74. Dumb electric questions, part three
  75. Blue Arrow 25A Brushed ESC
  76. Battery Near ESC?
  77. Brush2less device
  78. Brushless motor voltage?
  79. Using BEC with Jeti Advance 40 Plus Motor Controller (Non-Opto)
  80. Eflite Power 32 vs Rimfire & Dualsky 4250 vs Motocalc
  81. To All ThunderBird ESC are Bad?
  82. t-28 emits high-pitched squeal/tone?!
  83. Eflight 370 1200 ???
  84. Dynam esc Programming Problem
  85. Parkzone P-51 brushless set up
  86. Different motor for parkzone j3-cub BL
  87. Need cheap brushless/prop combo for funny park
  88. Tower Pro Mag 8 ESC 70 A won't program!
  89. Delete this post
  90. KONTRONIK JIVE brandnew ESC, JAZZ was yesterday
  91. Another "pecking order" question.
  92. Great panes ESC still no go
  93. "Mystery" ESC
  94. Motor Oscilating...
  95. Radio glitching
  96. park 400 inrunner brushless
  97. waypoint servos??
  98. Motor direction
  99. Hirobo Top Gun 9017 Motor/Gearbox
  100. Earth Magnet vs Brushless motor
  101. Brushed 600 size
  102. Brushless 400 SMOKIN !!!
  103. Motor and prop help
  104. Direct Drive or Gear Drive?
  105. Esc problem
  106. Jeti ESC question ADV vs SPIN series
  107. Tower Pro 30Amp ESC
  108. Nitromodels.com Brushless motors
  109. trouble with great planes ESC
  110. Can't get my blades to spin up
  111. Alfa EDF, Inrunner and ESC problem
  112. question about E-flite 25 pro ESC
  113. brushless replacement for a 280 direct drive?
  114. Any cheap 550 size brushless replacements?
  115. CC Phoenix 35 gets way too hot
  116. 60amp ESC for two 30AMP motors
  117. Advice for Brushless Motor for U-CAN-DO EP
  118. how to ID a esc
  119. Need advice on choosing motor and esc
  120. Need Help - Moving from geared brushed to geared brushless
  121. Spektrum AR 6200/Hyperion Brushless reg.
  122. BRUSHLESS MOTOR TONES
  123. Mini Review: Motrolfly 2210: 1400Kv, 1700Kv
  124. eflight park 400 outrunner bearing
  125. AXI4130 Rear mounting plate dimensions Question
  126. Jeti Spin 75 Cutting Out
  127. What happens to a motor when it "Burns Out"?
  128. Tower pro 70 A esc instructions !
  129. Failed ESC
  130. Need help mounting ESC to engine
  131. ducted fan
  132. Eflight Power 32 capabilities and recommended planes
  133. GP Lancair EP Brushless??
  134. Limiting current factor?
  135. Cessna 182 upgrade
  136. motor failure
  137. How much interference from brushless motor/ESC?
  138. axi 2820/10 motor noise
  139. E-Flite 25 Motor Mount
  140. AXI 221716 pushing the shaft through ?
  141. E-flite Park 370 BL outrunner problem...
  142. motor suggestions?
  143. Motor suggestions?
  144. About Cd-rom Brushless Motor and Battery
  145. Hacker Motor Problem
  146. Heat Sinks on ESCs
  147. Brushed motor underwater?
  148. 15% off CustomCDR Products Holiday Sale
  149. Need some MotoCalc help
  150. speed controller term meanings?
  151. No BEC with High voltage ESCs ?
  152. Wiring my ESC?
  153. Need help for identifying this motor
  154. Opinions needed on Motocalc report
  155. Motrolfly MIG 29 Video
  156. E-Flite 450,890 kv motor help needed
  157. Power for GP Ultimate 3D?
  158. Electric Wood Props
  159. HELP PLEASE!
  160. JGF 450 + Dynam 40 amp Esc = startup stutter?
  161. Help with gear that slips
  162. Amp , motors , batterys !!!!!
  163. batt. que.
  164. those stator Rings on motors
  165. Help Dymaxion motor Oxai
  166. Problems with Dualsky speed controller?
  167. what is the extra wire for
  168. Looking for an unusual motor...
  169. Speed Control
  170. Ever hear of or use a Tower Pro ESC70A?
  171. Park 480 Question
  172. New Electric owner ?
  173. what size outrunner for spitfire arf
  174. KMS motors
  175. Mini Super Sportster - E-Flite 450, 20Amp ESC - Won't pull plane
  176. Rimfire 35-30-950
  177. How to selecting a brushless motor
  178. Wattmeter numbers on my plane
  179. Ultra R/C Yak 55 Motor Suggestions
  180. Timing: programming an ESC?
  181. ESC question?
  182. 2 or 3
  183. slow stick helpppp
  184. Himax 2025-3200 problem?
  185. E-Flite Park 480 - a curiosity?
  186. Help with Zagi twin brushless setup please....!
  187. motor with 2 wires or 3 wires
  188. How do I build a dynamo? URGENT PLZ...
  189. Two motors, one ESC
  190. TowerPro 70a ESC
  191. TowerPro 70a question
  192. Hacker 20-20L
  193. lipo size
  194. Auto Alternator
  195. Mini Slinger Upgrade
  196. Good power regulator?
  197. Throttle resolution on "brushed" speed controls
  198. AXI 2814/10 motor
  199. Too much ESC?
  200. Brushless 400 help---what is a good motor?
  201. Comparing brushless motors
  202. Dynam Esc's
  203. Hyperion Emeter
  204. High Kv + big prop = low Kv + little prop
  205. compare these motors
  206. axi 2208/34 vs hacker A20-26M
  207. Larger motor?
  208. ESC Throttle Issues
  209. How do wire 2 brushless motors on 1 plane
  210. Nitroplanes/Raidentech brushless motors: Any recommendation?
  211. Temperature of Lipos and ESC?
  212. esb
  213. Mystery Outrunner D2632-1000 & ESC
  214. what reciever do i need for this motor, and what size servos, and battery.....etc. ?
  215. 1 or 2 esc's needed? A123's Please help
  216. Brushless for a .40 size plane ?
  217. Help with Jeti ESC advance 30
  218. D and Y Windings
  219. stryker motor upgrade
  220. What will happen if I..........
  221. AXI 2208/26 motor questions...........
  222. Mega combo question-
  223. what size motor to replace 540 brushed
  224. NITROPLANE servos
  225. Novak GTB 3.5
  226. Power system for Unicorn wing
  227. Jeti Brushless Advance 30-3p
  228. EDF for a 10+ lb. jet?
  229. how 2 tell
  230. CD-rom Brushless Outrunner Motors
  231. Stryker "C" motor upgrade
  232. What happens if ESC is too small?
  233. I found my problem!
  234. motor and prop questions
  235. Outrunners come apart!
  236. Motor Cutoff Problem
  237. Prop For DualSky XM3530CA-14
  238. Troubleshooting an Align ESC
  239. Motor size help
  240. e-flite 40amp ESC
  241. Pinion Question
  242. 72 amp shut off problem
  243. Brushless Motor Theorem
  244. Muscle motors!
  245. E-Flite Thunderbolt and 480 outrunner wackiness
  246. More Volts, Lower Current? Fly Faster.
  247. lipo battery
  248. E-Flight esc Questions
  249. problems with esc
  250. power system for my micro whizz
