PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26
  1. Hey
  2. How to fuse a brushless esc ? ??
  3. offset gearbox?
  4. drop in upgrade
  5. Disable the brake in the G.P. C-50A speed controller
  6. speed control switch for brushless ??
  7. Has anyone ever seen something about this cheap brushless motor?
  8. Motor for 12# plane ???
  9. hot speed control
  10. GWS EDF-55 problems, please help
  11. Mega 16/15/4 question
  12. Lazy Bee Motor Selection
  13. newb question about cdrom motors
  14. Finding Hacker A20-22L motor shaft replacements
  15. Drop in replacement for S400 direct drive...
  16. Building an OSPREY / VTOL
  17. twin flying, boat i need set up help
  18. Mamba in Plane?
  19. Hi to all, help with findng brushed motor COM ARMATURES TURNS?
  20. What speed controller would you use on a Speed 600 motor...?
  21. Some motor / battery Questions
  22. Wires becoming very hot.
  23. Eflite park 400 shaft breaking
  24. [b]MultiPlex 480G3 with 4.4 box sounds funny ??[/b]
  25. Brake Function?
  26. Tower S-600GD Reverse rotation.
  27. Motor Max Motors -anyone experience?
  28. Great Planes Outrunner
  29. mega 16/15/3 dual setup?
  30. does anyone use the mega16-7-3 ?
  31. Cold Fusion magnet motor?
  32. Tigermoth 400, Himax reccomendation
  33. radial mount options for AXI??
  34. How do you rewind an out runner
  35. Adding magnets to a motor?
  36. stryker w/5turn 3s x 2 in series
  37. HELP WITH PROPS
  38. E-flite=HiMaxx?
  39. What is the most important?
  40. Series or paralell
  41. ESC ,Motor..etc.HELP!
  42. dragonfly+himax2015 4100+?
  43. E-flight s400 help!!!!!
  44. 20A ESC+2 Cell Lipo Issue
  45. GWS questions
  46. DC-3
  47. Y-harness for brushless ESC´s on a twin
  48. Please help - How does one clean ball bearings?
  49. Is this right?
  50. Anybody running 4 cells?
  51. E-flite park 370 motor question
  52. brushless stopping after seconds
  53. ESC Problem???
  54. Graupner 280 6V Motor Question
  55. Brushless Speed Control set up ??
  56. stryker w3 turn mega cutting out
  57. Brushed 380 Motor
  58. Brushless S300 replacement?
  59. Phoenix 45 thermal shut down?
  60. Phoenix 45 thermal shut down?
  61. Pinion Gears - Help putting on/taking off
  62. PJS 3D 8000 outrunner-any good???
  63. E-flight resources
  64. CDROM Motor "Bell/Flux Ring Question"
  65. What would be the appropriate brushless motor size?
  66. Electric Newbie, measuring current?
  67. Electric Newbie, measuring current?
  68. BL with or w/o Gearbox
  69. Experience with Speed max 40 ESC from Firmtronics
  70. AXI 2212/26 and Eflite esc
  71. Problems with Astro 010
  72. Extreme Flight Brushless BL-20 Motor
  73. Axi 2212/26 and Jeti 18-3P…What could be happening?
  74. Prop adapter spun off
  75. MEGA 3:1 gear box binding.
  76. Will this work or is it to much????????
  77. Cool Running ESC
  78. Is my Phoenix 25 helping me??
  79. Gearbox for E-Funtana
  80. EVP, PPS, VPP Hollow Shaft Brushless Motors
  81. IKARUS VPP
  82. What size 3-blade prop to use?
  83. Self Destructed 2812-0850
  84. Wattage Corsair NO RESPONSE from servos
  85. Phx-link USB download
  86. Phx-Links 25 USB driver
  87. Another esc question
  88. Cermark BL-600-2L
  89. Typhoon brushless motor
  90. what does 5400KV mean
  91. Props, ESC's, & Motors.. Need Help.
  92. MPJet 28/20-7
  93. ESC Question
  94. CC25 reprograming
  95. Wire length for ESC and brushless motor
  96. motor comparison?
  97. Help me with My Endoplasm
  98. Will it blow up?
  99. Need Pics of Outrunner setup...Please
  100. Cut-off voltage on Li-Ion vs LiPo`s vs NiMh??
  101. Can I do this?
  102. Programming the Phoenix 25
  103. Low voltage motor for 1x LiPo?
  104. E-flite maxx 25 esc? anyone use one?
  105. In-runner vs outrunner, what`s the difference??
  106. A few simple beginner questions
  107. axi 2808/?? question
  108. CD-Rom??
  109. Electrifly S 600GD Set Up
  110. Motor voltage question
  111. Himax throttle cut-off, servo glitching
  112. MOVED: Lipo voltage drop under load
  113. Kontronic/Funtana
  114. overtightened prop nut
  115. Need Help In Converting Sky Raider I To Electric
  116. Mega 1615/7 Lipo cell ?
  117. AXI 28/26/10 0UESTION
  118. AXI 28/26/10 0UESTION
  119. Q&A My First Micro Flight
  120. Is a fuse needed in this setup?
  121. axi 2826/12
  122. Two ESC, one LIPO...
  123. a20l or b20-15l?
  124. Lost instructions for programming Align 10 amp esc
  125. outruner crash survivability?
  126. Axi motor for Mini Supersportster?
  127. what esc?
  128. Kontronic prices
  129. SS cutoff help
  130. Apex Mini300 outrunner kit
  131. Actro 12-5 setups?
  132. Brushless for mini hornet
  133. Standard size 400 brushless
  134. World Models Cessna Skylane EP Setup
  135. E-Flight 40 amp ESC
  136. Astro Cobalt 15 brushed with what lithiums?
  137. Battery Question
  138. How tight should pinion gear be?
  139. Fixing e-flite park 400 brushless motor
  140. Brushed and Lipo
  141. High RPM motor
  142. 2 or 3 servos?
  143. Keep stripping my pinion...
  144. Balsa Products - Tower Pro Outrunner.
  145. BEST PRICED/PERFORMANCE OUTRUNNER...
  146. ESC for brushed or brushless?????
  147. Prop Saver question
  148. Hobby-Lobby
  149. BEC & redundant RX Battery
  150. brushless speed control usage with lipo's
  151. Newbee question
  152. Visit to Little Screamer
  153. Which Brushless for Magpie
  154. Astro Flight 035 question
  155. extending bsc reciver wires?
  156. Kontronic controller question
  157. Need help identifying a GWS motor
  158. Which Watt meter is better
  159. Use Himaxx 2025-4266 without gear?
  160. Himax 2812-850 current draw?
  161. speed 300
  162. servos and esc
  163. E-FLITE PARK 370 MOTOR (outrunner)
  164. What Prop For Astro Flight 010 geared??
  165. Upgrade to Hi Max 5400
  166. Pros and cons of Brushless outrunner vs. Geared.
  167. what happens if the ESC is overloaded?
  168. Can we use a 370 ourunner with a standard 20 amp mini esc w/brake
  169. Brushless set-up for Wattage Stearman PT-17?
  170. Pinion gear position?
  171. Fliton ?
  172. No power out of Himax 2812????
  173. himaxx 2025/4200 vs. 2025/5300
  174. Prop size for TM400 brushless
  175. motor calc question
  176. gws corsair question
  177. Himax 2808
  178. prop advise for geared endoplasma motor
  179. what plane can i use this brushless with?
  180. Speed 400 props
  181. Tiger Moth 400 Power set-up question
  182. 30oz slow stick
  183. Medusa 12mm Afterburner In-flight impressions
  184. help with brushless instalation
  185. AXI by Model Motors BIG Problems please help
  186. Check my math ---Motocalc
  187. Any prop adapters fit most motors?
  188. brushless wire,repairable?
  189. AXI Motors/Prop Combinations
  190. planes for mpjet 25/25-26MK2
  191. How to pick BL Motor in series?
  192. Confusion with Himax Outrunner KV rating
  193. how do i get...........
  194. 18 gram Brushless CDR with 10 oz+ thrust
  195. Jeti Advanced 30-3P, which FETs?
  196. About speed 400
  197. TWIN AXI 4130/20 Battery options?
  198. adding a safety switch to an ESC
  199. Mega or Cermark600 for Banchee 3D
  200. Soup up elec Piper Cub...Recommendations?
  201. How is the Astro Flight Mighty Micro 010 Geared ?
  202. Brushless ESC & Motor Issue
  203. saltwater corrosion
  204. 40+ Amp ESC
  205. Electrifly S-370
  206. Glowheads and p-51 motor recommendation
  207. JETI 40-3P, safe to use with Lipo?
  208. those little orange propellers
  209. Help please Phoenix 25 motor cuts out at full throttle
  210. Ive blown 2 motors HELP
  211. "Outrunner" VS. standard brushless motors?
  212. Himax 2812-850 Shaft Breakage
  213. E2C-Hawkeye Electric Questions
  214. desperately looking for a prop-help plzz
  215. Axi 2208/34?
  216. AVC1AIR LOW VOLT CUT OFF
  217. axi 2814/10 batery?
  218. 2 motors and 1 esc??
  219. does anybody know which factory set profile is the 75% forward and 25% brake for cyclone esc
  220. CD ROM advise
  221. electrifly 30A esc arms backwards.
  222. himax outrunners vs. himax 2025-4200 geared
  223. Kokam super 30 ESC with 2 motors in parallel?
  224. Speed control - throttle on wrong channel
  225. CD-Rom Brushless - I removed it! What next?
  226. speed controller, how does it work
  227. wierd electrical problem anyone had same..
  228. 6x3prop vrs 5x4 direct brushed
  229. how to check jetti speed controller
  230. Outrunner equivalent chart?
  231. Kyosho Cessna 177, Le Mans, 7.2v 6 cells. Ever flown one like this?
  232. Hacker outrunner motor for Shockie
  233. E-flite brushless
  234. Himax 5300 Kv Motor
  235. eflite-outrunner prob
  236. JETI 08 with TP 1320mah 3 cell will work?
  237. 2 cell Lipos with an AP29 motor, will they work?
  238. PARK FLYER MOTORS
  239. Himax 2025-4200 Geared With Slow Stick
  240. how many volts can a 280 motor handle?
  241. Hacker model A20
  242. Axi and Li-Po ???
  243. Himax 2808-0860 or 2812-0850 for GP Yak?
  244. KV Rating on Motors
  245. eflite outrunner Thrust vs the others.....
  246. park370 damage
  247. What AXI for 25oz plane?
  248. Hacker B20 15L too hot to touch
  249. Hacker Outrunner
  250. brushless/controller q's
