PDA
View Full Version : Brushed/Brushless motors, speed controls, gear drives
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26
  1. What is your favorite 25A (275W) motor?
  2. brushless GWS beaver
  3. Need help with funtana setup.
  4. wili this set-up burn up my motor?
  5. Reverse throttle
  6. Do i need to grease brushless Motor
  7. A Spur Gear Pinion question
  8. gearbox removal
  9. I really need some help here on a hacker A30-16M..
  10. Motor Amps vs Watts
  11. Ultrafly B/12/10 Bruhless Outrunner in Ultrafly P-51 EP Mustang ARF
  12. Taking Care of Your Battery Series
  13. Outrunner for Todds Models Attitide ?
  14. E-flite Park 480 Shaft Replacement
  15. prop adapter puller
  16. Thrustmast 550 Motor A Specs??
  17. choosing the correct brushless
  18. eflite 20amp v2 brushless esc connectors
  19. Problem with Jeti Advance 30-3P
  20. require a motor calc
  21. Help programming my Towerpro ESC
  22. Cermark 5020-350 Brushless?
  23. Kontronik Fun 480-33 & Gear Box 4.2:1 for Great Planes SIREN EP HOT LINER
  24. AXI motor comparison ?
  25. Dual Motor Gearbox
  26. History of the brushless motor?
  27. ESC w/BEC connect to NonBEC receiver?
  28. unexplained crashes
  29. what is brushless motor?please help...
  30. fx35 esc will not arm
  31. brushless motor sputtering
  32. Park 400 voltage ??
  33. axi4120/14 bearing replacement
  34. Twin Engine Airplane
  35. AXI Prop Mounting Question
  36. HIMAX motor repair
  37. micro pits
  38. PJS1000/battery????????????????/
  39. Which Combination?
  40. e-flite park 370 shaft replacement
  41. Problem with electrics
  42. Does it matter Big/Small Deans
  43. battery for the KYOSHO SPREE ES
  44. Inrunner replacement for Speed 400?
  45. How to cancel a soft start of Hacker 40-B Heli controller?
  46. gws e-starter motor prob?
  47. AXI 5330/18 on 82" P-47D from Hangar9 - What Prop?
  48. AXI 2212/26 questions
  49. 380 and NiMh to Brushless and LiPo Conversion... what do I need?
  50. Opinions on buying sensored brushless motor....
  51. AXI 4130/16 RPM Reading Question
  52. Two issues: Current limit and BEC
  53. Dummy Question; if I change the ESC with different ratings
  54. LiPo question
  55. Brushless motors.. i dont get it
  56. Motor Spins the wrong way
  57. Motor Help!
  58. LiPos gone bad? Help analyze Emeter output
  59. small ESC, motors and servos
  60. Avionics
  61. First CD ROM motor sortof works.
  62. Static amps vs inflight
  63. Is it the motor, esc, or batts?
  64. Electrifly help!
  65. system failure???
  66. Inrunner ????
  67. hacker b50 gearbox
  68. Electric prop or gas prop
  69. Brushless equal to mega 16-15-6?
  70. Axi Website
  71. Bench Testing Esskay 400... is this BS?
  72. CC Pixie-20 and 730 mah Lipo question
  73. is there a site for?????
  74. Is my ESC toasted?
  75. Mounting Esskay 400XT
  76. Reversing the Hacker X30 Speed Control??
  77. Where to get a Tango 45-07?
  78. Hacker A20-20L
  79. HOT ESC
  80. Feigao combination
  81. 370 Brushed geared 1.8:1 PLEASE HELP ME
  82. Ultrafly Frio Motors
  83. Brushless Controller
  84. Low rpm brushless
  85. Brushless pusher problem
  86. brushless motors repeated use and heat
  87. what's the problem of zagi tazz?
  88. Kinda Cofused!
  89. E-flite/horizon product support
  90. Time for a new brushless..suggestions?
  91. Replacement spur gears for Himax GB?
  92. Custom CDR Double Kit on E-flite Ultimate FX
  93. Assan 36A ESC and Multiplex BL480-4G
  94. battery and controller question/interference?
  95. Help with older speed control
  96. motor question
  97. Serious Help! I Keep Burning UP, NOT as easy as you think, mr. amp guy
  98. Jet Program card
  99. Brushless Maintenance????
  100. 25LBS THRUST
  101. Rimfire output shaft - need to replace it
  102. Warm running Faigio motors?
  103. ever considered cryogenically treating your esc's?
  104. 10 cell Li-poly brushless reversible ESC??
  105. AXI bearing dimensions please
  106. 350 brushed motor for Slow Stick
  107. Jeti Advance plus 70 OPTO
  108. will this work?
  109. kyosho atomic force... with what ?
  110. Brushed EDF 300 & lipo ?
  111. Towerpro outrunners
  112. ultrafly B/06/12 outrunner motor
  113. Where and what to buy....
  114. Which is the + Terminal on Graupner 400?
  115. Choosing A Brushless Part 2 EDF
  116. Choosing a brushless
  117. Brushless Motor for Radical RC Mini-Stick
  118. convert outrunner to pusher?
  119. Phasor 45/3
  120. What size prop saver?
  121. High RPM?LowRPM?
  122. Aveox SL-18 help
  123. WATT-AGE - IC30A ESC ISSUE
  124. what brushless & battery for sig ep42
  125. esc question
  126. stick mount for outrunner
  127. Which brushless outrunner in mini edge 540?
  128. Brushless motors and Ni MH Batteries for Slow Stick
  129. Gearbox for Mega1615/2???
  130. Are these motors similar
  131. Astro Flight Cobalt 90 motor mount....
  132. 4 motors, 2 controllers?
  133. Need help power system SU 35 Twin EDF
  134. How to mount prop????
  135. Propeller Help Needed Please...Oriole elec twin
  136. CANT GET THE AMPS
  137. Looking for motor upgrade for wattage wildcat
  138. need some SERIOUS advice on a stryker project
  139. help
  140. what will this give me
  141. What planes can you put a BP21 in?
  142. MDrive controllers with RPM, temperature, voltage, data log
  143. Help! servo chatter.
  144. Jeti brushless controler not working. HELP
  145. BP21 info needed for Motocalc, & RPM/prop data
  146. 20 to 25 oz plane motors
  147. Eflite esc
  148. Goldberg Eagle 400 motor/battery?
  149. which is better
  150. thrust guess please?
  151. Disable GWS LVC 480Li
  152. Prop saver not safe?
  153. Hacker
  154. What do you think of this Brushless Motor?
  155. Help Eflite Brush speed control
  156. help,new to electric
  157. help,new to electric
  158. E-Flite Ultra Stick -- What Motor/ESC
  159. 480 park outrunner brushless
  160. Multiplex BL-480G - how many poles?
  161. Kontronik/Castle 45
  162. Rimfire...soldering question
  163. Checking amps the easy way
  164. info on lemans ap36L motor
  165. Brushless .049 equivalant?
  166. 4 Brushless motors on one channel?
  167. Wattage Cobalt 400 motor not turning!
  168. temperamental ESC in Typhoon 3d
  169. Rimfire 22M-1000 versus Esskay 400XT. Which one is more powerful.
  170. Wattage Giles 202 EP Brushless?
  171. kontronik motor with hacker esc?
  172. How many winds??? gbv 20mm
  173. heli tail burn out
  174. ESC automaticly "resets"
  175. Balancing propellers
  176. Brushless ESC Timing
  177. Zagi Aveox Brushless motor help!
  178. CC25 and Ultrafly A/30/24 Problems ??
  179. Hacker motor with
  180. MULTI MOTOR SETUP?
  181. HELP! Who repairs Aveox?
  182. ESC for Hacker
  183. How do i compare motor sizes/
  184. hyperion esc interface cable diagram Needed!
  185. Mini Funtana-Which Brushless Motor?
  186. ESC advance
  187. learning Electric
  188. Hacker A20-34s 8x3.8 prop???
  189. Art-tech brushless...any good??
  190. ESC placement
  191. Best Watt/amp Meter for the money?
  192. Gear box lube?
  193. Brushless Power Ratings???
  194. Brushless DC-3
  195. Which Brushless Manufacturer?
  196. 450 480 e flite motor question
  197. ESC help with Futaba MC114
  198. Propeller for Typhoon 15/10 on F15
  199. Adrian Page Cub Power?
  200. ESC OR RECEIVER
  201. Ultrafly PC-9
  202. Rimfire HELP
  203. Hacker dimensions
  204. Multiplex 480 gear boxes
  205. Himax 2816-0890: How to get 200W on 3s Lipo?
  206. Parkflyer's Cessna 182 need new mod
  207. New High Volt controller...
  208. park 400 inrunner broken shaft
  209. what brushless motor and esc for my axon?
  210. No luck with electric
  211. E-Flite 450 on a GP slinger
  212. C-rating on lipos?
  213. Slinger with Brushless Outrunner
  214. Which prop Mega 16/15/3 w/CC35
  215. eflight esc
  216. Brushless motors in parallel
  217. Motortron Brushless ESC's
  218. How much plane will a RIMFIRE and BL-8ESP fly
  219. Brushless outrunner won't run??
  220. Mini Funtana Takeoff
  221. IPS-A Drive 3 Blade Prop?
  222. Brushless conversion 60 size too electric
  223. Katana Mini moter problems
  224. E-flite P-47 and Park 450 motor
  225. Problem with Jeti program card
  226. ESC troubles
  227. dualsky
  228. hypirion 20 amp or castel criation 25 amp
  229. BP 9Y or Bp21 in Eflight p-47
  230. Amp question on twin
  231. Electric for a sailplane??
  232. thunder tiger =AXI elec.motors
  233. tower pro bm 2408-21 help esc
  234. Brushless Electric Engine Question
  235. walkera surface application?
  236. balsa product motor
  237. Wattage Cap 232
  238. LiPo/ESC/Votage Cutoff question
  239. thunder tiger brushless motors any good?
  240. Broken shaft on Himaxx - Is it done for?
  241. IPS power system, could it handle 3 lipos?
  242. BP 40 Amp ESC NEED HELP!
  243. BP 40 Amp ESC NEED HELP!
  244. NES WOW Brushless Combo.
  245. Brushed motor sizes
  246. Type of motor supplied with Shogun helo?
  247. Sub 15g cd motors????
  248. brushless motor question?
  249. BATTERY, ESC, & BRUSHLESS MOTOR ?
  250. Delete
